9x10 chess with centaurs
Number of moves before automatic draw
The game will always end in a draw automatically after 250 moves without capture or pawn move. There is no need to have any other automatic draw rule if there is the following rule for forced capture.
Legal capture with the king is forced (if legal) if both players had more than a king left and no checkmate position exist for either player with it's pieces against a lone king.
That is the case if both players has a single knight xor bishop(s) all confined to the same color.
Note that you can still claim draw from insufficient material if you do not have any pieces left and your opponent only had a single knight or only bishops of the same color. It's the player with the (at best) useless piece that cannot claim draw right away since he could potentially still lose by stalemating his opponent.
The game should end in a draw right away if both players only has a king left.
1. Legal capture with the king is forced (if legal) if both players had more than a king left and neither player could checkmate a lone king the previous move
2. Legal capture with the king is forced if there has been 1 moves or more since the last capture, both players has more than a king left and neither player can checkmate a lone king. Automatic draw after 250 moves with no capture or pawn move.
3. The number of moves before automatic draw should be reduced to 25 if one player only has bishop(s) left confined to the same color and the other player only has bishop(s) left confined to another color. The number of moves before automatic draw should be reduced to 25 if one player has a single knight left against a single bishop. You can claim draw after 25 moves of no capture if you have a single knight left against a two bishops confined to the same color. Otherwise 250 moves before automatic draw.
4. Automatic draw after 25 moves if one player only has bishop(s) confined to one color and the other player has a single knight or only bishop(s) confined to another color. Otherwise 250 moves before automatic draw.
5. Number of moves before automatic draw = 250 unless only 2 kings remain.
6. The number of moves before automatic draw should be reduced to 25 if one player only has bishop(s) left confined to the same color and the other player only has a knight left or only has bishop(s) left confined to another color.
7.You can claim draw if your opponents only has bishop(s) left limited to one color and you have not had a piece/pawn on said colored squares for 25 consecutive moves (not counting the king).
8. number of moves before automatic draw set to 50 if neither player has more than one non-king piece (not counting pawns) in addition to neither player having a piece you can promote to, 250 otherwise.
9. Number of moves before automatic draw = 50 * (number of pieces left besides the king), up to a maximum of 250, at least 30 if there is at least one pawn left.
10. Number of moves before automatic draw is 25 if neither player has anything more than a single pawn, a single knight, xor a single bishop, 250 otherwise. Instant draw if only kings remain.
11. Number of moves before automatic draw = 25 * (number of pieces/pawns of types you cannot promote to besides the kings) + 100 * (number of pieces of types you can promote to), up to a maximum of 250.
12. number of moves before automatic draw set to 500 but doesn't reset with capture or pawn move. Instant draw if only kings remain.
13. Number of moves before automatic draw reduced to 50 if neither player has at least 6 points of material, 250 otherwise. Instant draw if only kings remain. This assumes pawns being worth 1 point each, bishops and knights 3 points each, rook 5 points, pieces you can promote to 6 points or more.
14. Number of moves before automatic draw set to 10 times the material count sum for both players up to a maximum of 250 where pieces you promote to are all given the count value 9 for the purpose of this count.
Results from table-base evaluation
King + Rook vs king: checkmate within 19 moves
King + Bishop + Knight vs King: checkmate within 49 moves
http://hgm.nubati.net/applets/mating10.html?files=9&ranks=10
http://hgm.nubati.net/applets/mate31.html?files=9&ranks=10
The game should not automatically end in a draw because checkmate is no longer possible
It will be possible for at least one of the players to win by getting stalemated if one of the players has at least one piece/pawn left besides the king.
Sure you cannot force your opponent to stalemate you if you only have your king left but there are many games where you cannot win with perfect play, doesn't mean it should automatically end in a draw.
And if you run out of time and your opponent has no pieces left you should still lose since worst possible play for you should be assumed.
Note that https://fairyground.vercel.app/advanced.html will not retroactively award draw if you change the nmoverule if you have later made a capture. You can simply copy over the move list and change the settings when a capture is made (not fully ideal but should work fine).
#38
Rules
You win by checkmating your opponents king or by being stalemated.
The knight, bishop, rook, pawn and queen are move like pieces in standard chess.
The king cannot castle but otherwise moves like the king in standard chess.
A pawn has to be promoted to centaur, archbishop, queen or chancellor when it reaches a rank numbered 2 or 9.
The centaur
combines the power of the king and knight but cannot get checked.
The chancellor
combines the power of knight and rook. Cannot jump over pieces when moving like a rook obviously.
The archbishop
Combines the power of the knight with the power of the bishop. Cannot jump over pieces when moving like a bishop obviously.
Full piece set including pieces not used: https://mega.nz/folder/hiNyUAgI#Cke5jQrdAa5qHHRxfVNB5Q
Online version (work in progress)
It's supposed to have the exact rules i wanted including forced king-capture if neither side has sufficient material for mate against lone king even with opponent assistance and both sides has more than a lone king left).
https://9x10centaur.vintologi.eu/
I intentionally made it so players cannot make agreement for draw.
If you run out of time you will get the worst possible game outcome (if the game had continued) that however means that you can run out of time and still win the game (if you cannot avoid checkmating your opponent). The included engine will in some position pass the position to human play due to inability to properly evaluate the position (such as when you run out of time with king and bishop against a lone king).
The "resign" button should produce the same result as running out of time.
hvrex
New member
Fairy stockfish tests
1 000 000 000 nodes/move
f3f5 d8d6 i3i5 i8i6 d3d5 c8c6 c3c4 g8g6 f5g6 c6d5 c4d5 b10c8 h2g4 h10g8 b2c4 d9c7 e3e5 e8e6 d5e6 d6d5 c4e3 d5d4 e3d5 c7d5 g2d5 d10d5 d2c4 d5d10 g4h6 b9c7 f2g4 g8h6 i5h6 c7e6 g1d4 f8f7 g6f7 h9f8 b1c3 h8h7 i2f2 f9h8 c1e3 g10h9 c2e4 c10f7 i1i5 c9d8 a2d2 a9d9 c3d5 e6d4 c4d4 f10g10 a1c1 f7e6 i5f5 b8b7 b3b4 a10c10 d5f4 e6f5 d4f5 i9i8 f5g7 c8e7 c1c10 d10c10 e2b5 g10b5 f1b5 e7c6 g4f5 i10f10 f5d6 d9c9 e4c6 h8g7 h6g7 c9c6 g7f8 f10f8 d2c2 h9g10 b5d3 d8c7 b4b5 c7a5 e1f1 c6c2 f2c2 c10b9 d6d5 f8d8 h1f2 i8h8 d1f3 d8d5 f3d5 g9f10 f2e4 g10h9 d5d7 b9d7 d3d7 e9d10 d7g4 h9g10 a3a4 g10d7 e5e6 d7c8 f1g2 d10i5 e4f2 i5f8 g2h2 a5e9 g4g5 h8g8 g5h4 f8g7 h4b10 e10f9 f2g4 f9g10 b10c10 g7h8 c10f7 h8g7 f7c10 g7h8 a4a5 h7h6 c10a8 c8d9 a8b9 d9e8 f4d5 e8b5 b9b7 g8b8 b7a7 b8a8 a7f7 h8g8 f7c10 g8e8 e3b6 e8c10 c2c10 g10f9 g4h6 b5e8 c10c9 f9e10 h6g8 e9b6 a5b6 a8a2 h2h1 e8g6 g8f6 a2a1 h1i2 a1a2 i2i3 f10i7 b6b7 a2b2 c9c7 i7d2 d5e7 d2g5 h3h4 g5f6 e7g6 f6d4 c7e7 e10f9 i3i4 d4c5 e7d7 f9e8 g3g5 c5a7 i4i5 b2i2 i5h6 a7b8 d7h7 b8d10 h6i7 e8e9 h7e7 e9d9 e7d7 d9e10 e6e7 e10e9 g6f8 i2e2 d7d9 e9e8 d9d8 e8f9 f8g6 f9e9 b7b8 d10b8 d8b8 e2e6 i7h7 e6c6 b8i8 c6c7 h7g7 c7a7 g7f7 e9d9 g6f8 d9c8 f8e6 c8b7 e6d8 b7b6 i8i6 b6b5 g5g6 a7a9 h4h5 b5c4 h5h6 a9a5 e7e8 a5a9 g6g7 c4d3 h6h7 d3e3 i6e6 e3d3 e8e9h a9a7 f7g8 a7a4 e6e2 a4a6 e9e5 d3d4 e2e4 d4c3 e5f3 c3b2 e4e2 b2a1 f3e1
 f3f5 d8d6 i3i5 h8h7 c3c4 g9h8 a3a5 c8c7 b1c3 g8g6 g3g4 h9g7 h1g3 g6f5 g4f5 h10g8 d3d4 e8e6 f5e6 g7e6 b2d3 i8i6 d4d5 e6g7 d3f4 f9g9 c1b2 h8i7 h2g4 b10c8 g2e4 i9h9 d2f3 g10d7 d1b1 i10h10 i2h2 d9b10 e1d2 b8b7 f2g2 a8a6 e4f5 g7f5 c2f5 d7f5 g3f5 c8e7 e3e4 e7g6 g1e3 c9g5 f4d3 g5e3 f5e3 b10c8 d2c2 b9d8 g2g3 c10e8 h3h5 i6h5 h2h5 d8f7 e3f5 f7e5 g4e5 g6e5 d3e5 e8h5 g3h5 d6e5 c3a4 i7f4 i1i2 b7b6 b2c3 h7h6 i5i6 d10c10 f1h1 g9f7 a4b2 g8i7 h5h4 i7g6 h4h5 g6i7 h5h4 i7g6 h4h5 g6i7
f3f5 d8d6 i3i5 h8h7 g3g4 i8i6 b3b4 g8g6 d3d5 f8f7 d2b3 e8e6 c3c5 e6d5 g2d5 f9h8 b1c3 c8c6 d5c4 b10c8 a3a5 g6f5 c2f5 h9g7 f2f3 h10g8 h1g3 d6d5 c4d3 b9c7 e3e4 g9f8 d1c2 b8b7 e4d5 g7f5 g4f5 c6d5 h2g4 f8g7 b4b5 a8a6 b5b6 g7c3 b3c3 c7b5 c3d5 g10c6 d5c6 b7c6 f5f6 d9f8 g1e3 e9d8 e3h6 i9e9 h6f8 d8f8 c1e3 c9f6 g4f6 g8f6 a2a4 f8g8 i1g1 f6d5 e3h6 f7f6 e1f2 e9e2 g3e2 c10g6 h6d10 e10d10 e2f4 c8e7 a1e1 a9d9 g1g3 d10c9 f2g1 a10e10 g1h1 f10f8 i2g2 d5f4 a4f4 h8f7 c2f2 g8h8 f3h2 i10f10 b2c4 f8i5 c4d6 b5d6 c5d6 g6d3 f1d3 i5a5 d3c2 f7d6 f4a4 a5i5 a4a6 e10a10 a6a10 f10a10 h2g4 i5f8 g3d3 e7d5 g4f5 a10a5 e1e6 d6b7 e6c6 c9b9 c6c10 a5a1 h1i2 f8b8 f5g3 b7c8 b6b7 b9c10 b7c8 h8c8 d3b3 b8c7 c2c7 c8c7 f2f5 d5e7 f5h7 a1d1 h7e10 c10c9 e10b10 c9c8 b3b2 d1c1 b10e10 e7d5 g3h2 d5b6 e10c10 d9c9 c10e10 c8b9 e10e6 c9c8 b2b6 c7b6 g2g9 b9a8 e6b6 c1c6 b6b9 a8a7 g9g10 c8c10 g10g8 c10c8 g8c8 c6c8 b9c8 i6i5 h2f3 i5i4 f3d4 i4h3 i2h3 f6f5 d4b5
f3f5 d8d6 i3i5 h8h7 c3c4 g9h8 a3a5 i8i6 d3d5 f8f7 h3h4 g8g6 e3e4 e8e6 f2h3 g6f5 e4f5 h10g8 g3g5 e6f5 c2f5 d9f8 h1g3 h9g7 f5g4 f7f6 g1d4 g7h5 d2c2 c10g6 g2e4 c8c6 h2i4 c6d5 c4d5 b9c7 b1c3 f9g9 i2f2 g10d7 b3b5 b10c8 b2c4 d7g4 h3g4 e10f9 b5b6 c7e8 e4g6 h7g6 c3e4 i9i7 c1b2 i7f7 a2a3 d10d7 a3e3 f9g10 i4h6 g8h6 i5h6 a8a7 b6a7 h5g3 g4g3 b8a7 g5f6 a9b9 g3f4 g10h9 e4g5 e9f9 i1g1 b9b2 d4b2 c9f6 g5f7 g9f7 f4e6 f7e6 d5e6 d7d8 e3f3 f8h7 c4e3 c8e7 e3g4 a10c10 c2d3 i10g10 a1a4 c10b10 g4f6 e8f6 d1c2 e7f5 f3f5 g6f5 f2f5 g10g1 f1g1 d8e7 a4f4 b10c10 c2b3 c10b10 b3a2 f9c9 e1d1 h9h10 g1e3 f10g10 e2f3 b10b8 b2d4 b8b10 a2c2 c9c2 d3c2 g10g6 a5a6 b10c10 c2d3 h10h9 f5b5 e7e8 b5b9 h9h10 b9b7 h7g8 h6h7 g8h7 b7h7 f6h7 f3e4 g6h5 e3f3 h8d4 e4d4 h10h9 f3h5 e8h5 d1d2 c10c5 f4f9 h9i8 f9d9 c5c8 d9d6 i6i5 d6d8 c8d8 d4d8 i8h9 d8e9 h7g9 e9i5 h5d9 i5h6 h9g10 e6e7 d9d7 h6f6 g9e8 f6f7 g10g9 d2c3 d7c6 d3c4 c6c8 h4h5 g9h8 h5h6 c8d7 f7h5 h8g9 h5g6 g9h10 g6h7 h10g9 h7i7 g9h9 i7f7 h9i9 h6h7 d7h3 c3b4 h3b9 b4a5 b9e9 a5a4 e9d9 f7g8 d9d1 a4b4 d1b1 b4c5 b1f5 c5b4 f5b1 b4c3 b1c1 c3b3 c1d1 b3b2 d1e2 b2c3 e2e1 c3c2 e1e2 c4d2 e2h5 d2d3 h5h2 c2b3 h2h3 b3c3 h3c8 d3c4 i9h10 h7h8 c8h3 c3b4 h3b9 c4b5 e8f6 g8f8 h10h9 f8f6 b9i2 f6e5 i2g4 b5c4 g4b9 e5b5 b9e9 c4d6 e9g7 b5f9 h9h8 d6f7 h8i7 f7g8 g7g8 f9g8 i7h6 e7e8 h6i7 g8h9 i7i6 e8e9q i6i7 e9i5
f3f5 d8d6 i3i5 i8i6 d3d5 c8c6 c3c4 c6d5 c4d5 f8f7 h3h4 e8e6 b1c3 f9e7 e3e4 g10d7 g3g4 g8g6 h1g3 h10g8 f2h3 b9c7 d2b1 a8a7 c1g5 e7c8 h2i4 c9g5 i4g5 g9e7 a3a5 b10a8 b3b5 d9d8 g1d4 e6e5 d4e3 b8b6 a5a6 c10e8 c2a4 a10c10 g5h7 i9i7 e3i7 i10i7 h7g5 a9c9 e2e3 e9f9 d1b3 g6f5 g3f5 f10g10 b1a3 c8e9 b2d1 e10d9 g5i4 d9c8 i4h6 c8b9 g2f3 f7f6 a3b4 c7d9 a2g2 h9f8 f3e2 f8g6 g2f2 e7f8 h6g8 e9g8 a1c1 d9e7 e3d2 i7h7 i2h2 e7f5 g4f5 h7h4 h3h4 g6h4 h2h4 f8i5 h4g4 i5h6 d1e3 h6g5 i1i6 h8h6 g4g1 h6h5 f2h2 g10h9 e1d1 g8h7 i6i2 d10h6 f1f2 e8f7 d1c2 d7e8 c2b1 c9c5 b3b2 h6f8 g1h1 h7h6 a4b3 g5f4 h2h4 f8e7 h1g1 f4g5 h4h3 c5c9 d2d3 b9b10 g1i1 h9h8 c3a4 a8c7 c1c6 f9e10 a4c3 d8d7 e3g2 e7d8 g2h4 d7f8 h3i3 f8h7 d3h3 c9g9 b4c4 g5f4 i1g1 g9g1 f2g1 h8f8 h3h1 f4g5 c4b4 e8d7 g1h2 e10f9 c3d1 f8h10 h2f2 h10e10 b3a4 d7c6 b5c6 f9a9 b4a5 a9g9 d1c3 f7d9 c3b5 b10a9 b5c7 c10c7 a5b5 d9e8 a4d1 g9h9 h1i1 e10e9 i3i6 h6i4 i2i4 h5i4 i1e1 e9c9 e2g4 h9g10 f2h2 d8d10 h2c2 g5h4 e1h4 c7g7 b2a3 h7g5 h4e1 g5g4 d1g4 g7g4 c2c1 c9e7 i6i7 g4g7 e1i5 a9a10 a3e3 a10b10 b1b2 e8c10 c1c2 g10g9 i7i10 d10d9 e3d2 e7e9 b2a2 d9f7 c6c7 e9c9 b5c6 f7c7 i5i4 c7c8 d2c3 g7g3 c3c4 g3g7 a2b2 c8b9 c6b5 c9c5 b5c5 d6c5 d5d6 b10c9 i4i6 c9b10 i6f6 b10a9 c4e2 b9c9 f6c9 g9c9 c2c3 g7d7 c3e5 c9c6 e2c4 c6c9 c4e6 c9g5 i10i9 a9b8 e5c3 g5d8 e6h9 b8c8 i9i8 d8i8 h9i8 d7d8 d6d7 c8c7 c3e5 c7c6 i8i6 c10g6 e5d5 c6b5 i6e2 b5a4 e2c4 a4a5 d5d2
f3f5 d8d6 i3i5 i8i6 d3d5 g8g6 f5g6 e8e6 e3e5 d6e5 d5e6 d9e7 h2g4 e7e6 b2c4 h8h7 c4e5 h7g6 e5g6 e6g7 g6f4 b10d9 c3c4 h10g8 b1c3 b9c7 h3h4 d9e7 f2h3 f8f6 c1b2 h9f8 b3b5 g9i7 d2b3 a8a6 b5b6 c7e6 d1d10 f9d10 f4e6 f8e6 a1d1 g10d7 a3a5 c10g6 d1d7 c8d7 c2g6 e7g6 g4e3 d10c8 e1d1 g8e7 d1c2 d7d6 c2b1 a10d10 e3d5 e7c6 h1i3 f6f5 h4h5 e6g5 h3h2 i6h5 i3h5 g7i6 h5i7 i9i7 d5f4 g6e5 f4h3 e10d9 b2c1 i7g7 g1e3 g5e6 h3f4 e6g5 g2d5 g7h7 h2g1 i10i8 f4d3 c6e7 d5g2 e5f7 g3g4 e7g6 g2d5 g6e7 d5f7 g5f7 e3h6 e9f9 h6d10 c9d10 g4f5 d9c10 e2d1 c10b10 a2h2 h7h2 i2h2 f9d7 f5f6 e7c6 g1e2 i8i10 d3b4 c6e5 e2d4 d10f8 c3e4 d7e8 c1f4 f10g10 h2e2 g10i8 b1a2 i10d10 b4d5 e8e10 e4g3 a9g9 g3f5 c8d7 f5g7 f8g7 f6g7 e10g10 f4h6 d10f10 e2f2 g9f9 d5f6 f7h6 i5h6 f9f6 f2f6 f10f6 f1f6 d7f6 i1i6 i8h9 d1i1 g10f9 i6i8 b10a9 i8f8 f9c9 i1i3 e5d7 f8f6 d7f6 d4f5 f6e8 f5e7 h9h6 e7d8 c9d8 i3d8 e8g7 d8d9 a9b10 d9c8 h6h2 a2a3 h2e5 c8b8 b10c10 b8c8 c10b10 c8b7 b10c9 b7a6 e5e7 b3d4 d6d5 c4c5 e7g5 a6a9 c9c10 a9a8 c10c9 a8d5 g5f4 a5a6 f4c1 a3b4 c1e1 d4c3 e1h4 b4b3 h4e7 d5c6 c9d10 a6a7 g7e6 c3c4 e6d8 c6d6 e7i3 b3b4 d10e9 d6g9 e9e10 c4d6 i3h4 b4b5 h4f6 g9g10 f6f10 g10f10 e10f10 d6e8 f10g10 e8d8 g10g9 d8f7 g9h9 a7a8 h9g10 a8a9h g10h10 a9f9 h10i10 f7h8
f3f5 d8d6 i3i5 h8h7 c3c4 g9h8 b1c3 i8i6 b3b4 g8g6 f5g6 h7g6 d3d4 f9g7 c4c5 c8c7 e3e5 h10g8 h3h4 f8f6 e5f6 g7f6 f2h3 e8e6 h1f2 b10c8 a3a5 b9d8 f2g4 f6e7 f1f10 d9f10 d2b3 h9g7 g4h6 a8a6 c2e4 i9f9 h2g4 g10h9 c5d6 c8d6 e4f3 f10g9 g4e5 c10e8 g1e3 e10f10 i1f1 b8b7 b2d3 e7c8 e3g5 g8e7 f1f2 c9a7 g5e7 c8e7 d3c5 g9h7 e1f1 f10g9 f1g1 i10f10 g1h2 g7h5 h3g5 h7g5 c1g5 h8f6 g5f6 e7f6 e2e1 f6e7 f3b7 c7c6 f2f9 f10f9 b7a6 d6f5 g3g4 f5h6 i5h6 h5f4 a6c4 e9h6 h2g1 d8f7 e5d3 f7d6 d3f4 d6c4 b3c4 f9f4 c3e4 a9f9 a2f2 f4f2 e4f2 a7b8 a1a3 g6g5 h4g5 h6g5 i2i6 g5g8 a3i3 d10g7 i3i2 g8h8 e1e3 b8f4 e3h3 e6e5 h3h8 g9h8 c4d3 e5d4 d3f4 f9f4 i6i7 g7f8 f2h3 f4f7 d1d4 f7g7 i7g7 f8g7 d4g7 h8g7 h3f4 g7h8 i2i5 a10g10 g2f3 e7d6 g1f2 d6c4 i5f5 c4b4 a5a6 b4b5 f3e2 b5d6 e2f3 g10i10 c5e4 d6c7 e4f6 e8d9 f5e5 i10i2 f2g3 c7d6 e5e9 h9f7 f4g2 d9a6 g2h4 i2i5 g4g5 i5g5 g3h2 g5g10 f3e4 a6e10 h4f5 d6c7 e9e5 f7d9 e4g2 g10g5 f6e4 g5h5 h2g1 h5i5 e5c5 c7d7 g1h2 i5h5 g2h3 d7e6 f5g3 e6c5 e4c5 h5c5 h2g2 e10h7 h3d7 h8g7 g2f3 d9g6 g3f1 g7f6 f1d2 c5c3 f3f4 c6c5 d7b5 c3i3 b5a6 g6d3 a6c8 h7f5 c8b7 i3i2 d2f3 c5c4 f4e3 c4c3 f3e1 f6e5 e1f3 e5d6 f3e1 d6c5 b7f3 i2i1 e1d3 c5b5 d3e5 c3c2h e3f4 c2d4 f4e3 b5c5 e3f2 i1i2 f2e3 i2c2 e5d7 f5d7 f3d1 c2g2 d1f3 d4c4 e3d3 g2d2
In total there are
white wins: 6
draws: 5
black wins: 1
I used the following system to determine the nmoverule number:
Only kings left: 0 (instant automatic draw)
No piece but at least one pawn: 30
One piece: 50
Two pieces: 100
Three pieces: 150
Four pieces: 200
At least five pieces: 250
10 million nodes/move test with fairy stockfish
Using https://fairyground.vercel.app/advanced.html
Results from 50 games are
White wins: 46%
Draws: 24%
Black wins: 30%
d3d5 d8d6 i3i5 i8i6 f3f5 c8c6 d5c6 e8e6 g3g4 h8h7 c3c4 b10c8 h1g3 b8b7 c6b7 a8b7 g2b7 g9h8 h2f3 d9b8 b7c8 b8c8 b3b4 b9c7 a3a5 d6d5 b1c3 c9e7 c4c5 a10b10 b2d3 h9g7 e3e5 d5e4 c3e4 e6f5 g4f5 g7h5 c1b2 h8b2 a2b2 f9g7 f2g4 h5f6 g4f4 g10b5 c2a4 b5a4 d1a4 c10e8 c5c6 f6e4 d2e4 c8d6 e4d6 e7d6 f4e4 c7b5 a1c1 e9c7 i2g2 i9e9 d3e5 f8f6 a4d1 d6e5 d1d10 b10d10 g1b6 c7b6 a5b6 b5c3 e4c3 e5c3 c1c3 a9a1 e1f2 a1f1 i1f1 e10f9 f1e1 g7f7 e2c2 e8d9 e1d1 d9e8 d1e1 e8d9 e1e9 f10e9 b6b7 f9g9 f2g1 h10f9 g1h2 f9e7 g2d2 d10c10 b2a2 c10c9 b7b8 c9b9 c6c7 g9h8 a2a9 d9c8 a9b9 e9b9 c3d3 i10b10 c2c5 b10a10 d3d8 b9e9 d2e2 a10c10 g3i4 f7d8 c7d8 e9d8 c5e7 d8e7 e2e7 c8f5 e7e9 c10c7 b8b9c f5b9 e9b9 g8g7 h2g3 h8g8 b4b5 c7c5 h3h4 g8f8 b5b6 h7h6 i5h6 g7h6 i4h6 i6i5 h4i5 c5i5 f3d4 f8e8 b6b7 e8d8 h6f7 d8c7 b9b10 i5i3 g3f4 i3i4 f4e3 i4i8 d4b5 c7d7 f7d6 f6f5 b7b8 i8b8 b10b8 d7c6 e3f4 c6d5 f4f5 d5c5 f5e5 c5b4 b5d4 b4c3 d6e4 c3c4 b8b5 c4d3 b5b4 d3e3 b4b3
d3d5 i8i6 i3i4 d8d6 f3f5 c8c7 e3e4 b10c8 i4i5 g8g6 h3h4 h10g8 c3c4 c7c6 b1c3 c6d5 c4d5 h8h7 f2h3 g9h8 g3g5 f8f6 b2c4 b9d8 h2g4 d8f7 g1e3 h9i7 a3a5 a8a7 h1g3 i7h5 e2f2 h5g3 f2g3 f9g7 g3h2 f7e5 c3e2 g6f5 e4f5 e8e7 e2f4 g10d7 g4h6 d9c7 c1b2 c10h5 f4h5 i6h5 c2e4 d10d9 a1c1 c7d8 g2f3 e9e8 h3g3 e10f9 h6g8 e8g8 f3h5 d7e8 h5e8 g7e8 g3f4 f6g5 h4g5 e5c4 c1c4 h8e5 b2e5 d6e5 f4e5 c8d6 f5f6 i9h9 f6e7 d8f7 e5f6 e8f6 g5f6 f9e10 i1g1 g8f9 e4f3 f7f6 f3h5 d9d7 c4f4 c9e7 f4f6 f9f6 f1f6 f10f6 h5g4 f6h4 e3f2 h4h2 i2h2 d7d10 g4a10 d10a10 d1h5 a9d9 f2h4 a10f5 h4e7 h9e9 h5h4 e9e7 e1d1 d9d7 g1g5 f5f7 h2e2 e7e2 d2e2 d6e8 e2d4 f7f1 h4e1 f1e1 d1e1 i10i6 a2e2 e10d9 g5g8 e8g7 g8b8 i6d6 b8b9 d9c8 e2e9 g7e8 d4c5 d7e7 e1d2 e7d7 d2e3 d7e7 e3d4 e7d7 e9e8 c8b9 d4e5 d6d5 c5d5 d7d5 e5d5 b9c9 a5a6 c9b9 e8e7 b9b8 e7b7 b8c8 b7a7 c8b9 a7b7 b9c8 d5c6 c8d8 a6a7 h7h6 a7a8 h6i5 a8a9h i5i4 b7b8 d8e7 a9f9 e7e6 b8e8
f3f5 i8i6 i3i5 d8d6 c3c4 h8h7 g3g4 e8e6 f5e6 e9e6 d3d5 e6e9 h2f3 b8b7 g1h2 c8c7 b1c3 b10c8 h1g3 g9h8 a3a5 h9i7 b2d3 i7g6 c1b2 d9b8 g3f5 h10i8 h3h5 i6h5 g4h5 g6e7 d3f4 i8g9 g2h3 g8g6 f5e7 f9e7 i5i6 g10d7 h2i3 f8f6 i6h7 g6g5 f4g6 c10g6 c2g6 g9f7 d1c2 f7h6 h3d7 e7d7 f2g3 c8e7 f3d4 e7g6 h5g6 f6f5 d4f5 h8e5 c3e4 h6f5 f1f5 f10f5 g3f5 e5i1 b2i9 i10i9 i2i1 g5g4 e4g5 c9g5 f5g5 e9i5 e2f2 g4g3 f2g2 i5g5 i3g5 i9i1 e1e2 d10i5 a1i1 i5i1 d2f3 b9d10 g6g7 d10e8 c2g6 a9g9 h7h8 g9g7 h8h9q g7g6 h9h7 e10d9 h7g6 a10f10 g5f4 d7c5 f4g3 i1i10 f3d2 f10g10 g6h7 c5d7 a2a1 g10g7 h7f9 d7e9 f9f5 i10g8 f5h3 b8d7 g2f3 g7f7 g3f4 d9c9 a5a6 b7b6 a1i1 c9b8 e2d1 d7c5 b3b5 e9c8 f3g4 g8g4 h3g4 c5d7 i1i10 d7e7 g4i4 e8g9 i10i9 f7g7 d1c2 g9f7 d2c3 a8a7 i9i10 g7g8 c3d4 g8f8 c2b2 e7d7 i4i5 f7d8 i10i7 d7e8 f4h6 f8g8 e3e4 g8g2 b2b3 g2g8 i5i3 b8a8 h6i5 a8b8 i5h6 b8a8 i3h3 a8b8 e4e5 d6e5 d4e5 b8c9 i7i6 c9b9 h6f4 g8f8 d5d6 c7d6 e5d5 f8f4 i6i8 e8d7 d5f4 b9b8 h3h4 d7e7 f4d5 e7d7 b3a3 b8a9 i8i7 d7b8 i7i9 d8b9 i9i8 c8d7 i8b8 a9b8 h4h7 b8c8 h7f7 d7d8 d5d6 c8c9 f7f8 c9c10 a3a4 c10c9 d6b7 c9d9 b7b8 d9e10 a4b3 b9d10 f8d8 e10f9 d8h8 d10e8 b8d9 e8g9 d9f8 f9f10 h8g9
d3d5 d8d6 f3f5 i8i6 i3i5 c8c6 e3e4 c6d5 e4d5 h8h7 h3h4 h9i7 f2e4 b10c8 b2c4 e8e7 g1d4 g9h8 h2f3 g8g6 f3g5 h8d4 e4d4 f9g8 c4e3 h10f9 c3c4 f9g7 g3g4 f8f7 h1g3 e7e6 f5e6 f7e6 f1f10 d9f10 b1c3 c9f6 d4e4 b9c7 i1f1 i9f9 a3a5 e9d8 c1b2 a9e9 e4d3 f6g5 h4g5 d8g5 f1f9 e9f9 b3b5 a8a7 c3e4 g5h4 d3b4 f10g9 d1c1 c10e8 e1d1 a10c10 c2d3 g10h9 d1c2 h4d8 c2b3 i10f10 c1g1 b8b6 a5b6 c8b6 a2a7 g8e7 e4c3 e7c8 a7a2 i7g8 b3c2 g8e7 c2b1 b6d7 d2d1 d7e5 d3e4 g7f5 g4f5 g6f5 g3f5 e6f5 e4f3 e7g6 e3c2 g6h4 i2i3 d8g5 c2d4 e8g6 b2c1 f5f4 f3e4 g6h5 d4f3 h4f3 e4f3 c7e8 c3e4 e5f3 i3f3 g5g6 d1f2 e8f6 e2e1 f6e4 f2e4 d10d9 g1f1 f9e9 f3f4 f10f4 c1f4 g6e8 f4h6 h5g6 h6e9 c8e9 a2a9 d9d8 b4d3 h9f7 e1g3 g9g8 a9e9 d8e9 a1a7 e8b8 f1f2 f7d9 a7d7 d9f7 d7d6 b8e8 f2b6 c10c4 b6e9 g8e9 d3c4 g6e4 b1b2 e4g2 g3g2 e8c8 c4c3 c8b8 g2h2 e10f10 b5b6 e9g8 d6h6 b8h2 h6h2 g8e7 h2h7 e7d6 h7h6 d6e7 d5d6 e7c6 h6f6 c6e5 f6f7 e5f7 c3b5 f7d8 b5c7 f10e9 b6b7 d8c7 d6c7 e9d9 b2c3 d9c10 c3c4 c10b9 c4d5 b9c10 c7c8 c10c9 d5c5 c9d8 c5d6 d8e8 b7b8 e8f7 b8b9h f7g6 c8c9q g6h5 c9i3 h5g4 b9f9 g4h5 f9f4
d3d5 i8i6 f3f5 d8d6 i3i5 c8c6 d5c6 e8e6 g3g4 h8h7 h1g3 g9h8 c3c4 b8b7 c6b7 a8b7 g2b7 b10c8 b1c3 d9b8 b7c8 b8c8 h2f3 c9f6 g3e4 f6g7 f5e6 b9c7 a3a5 c10a8 f2d3 h9i7 b3b4 i7g6 f3d4 c7e6 b2a4 g6e5 d3b2 e5d7 d2b3 g7e5 g1h2 f9d8 c3d5 e6c7 h2e5 h8e5 a4b6 d7b6 d5b6 e5i1 b6a8 i1e5 a8b6 c8e7 d4f5 e7e6 b2a3 e5a1 a2a1 d8b7 c1b2 a9d9 b6d5 i9h9 i2f2 f10g9 h3h4 d10b10 f5d4 e6d8 f1i1 c7d5 c4d5 d8e8 g4g5 g8g7 a3c4 h10g8 b4b5 h7h6 d4f5 b10b8 a5a6 b7c8 g5h6 g7h6 f2g2 h6i5 e4f6 g8f6 g2g9 h9g9 h4i5 g10f9 e1d2 i10g10 d1h1 a10a7 b2d4 a7c7 c4a5 g9g4 c2d3 e8f7 a1f1 b8b10 f1f4 g4f4 e3f4 e9e2 d3e2 f7g6 e2d3 f6h5 b5b6 g6f4 b6c7 g10g2 d2d1 f4d3 h1g2 d9b9 g2c2 d3c2 b3c2 b9b1 c2c1 c8c7 i1e1 e10d9 e1e4 b1c1 d1c1 b10g5 d4e3 g5c9 e4c4 f9b5 c4c3 b5a6 a5c6 c7c6 d5c6 c9c7 c3i9 d9e8 i9i10 c7c6 c1d2 c6g2 d2c3 g2g6 i10c10 a6d9 c10c6 e8e9 e3b6 e9d10 f5d6 h5f4 c3b3 g6b1 b3a3 b1a1 a3b3 a1b1 b3a3 b1d3 a3b2 d3g6 b2b3 g6d3 b3b2 d3d2 b2a3 d2g2 c6c7 g2f3 a3b2 f3e2 b2b3 e2e7 c7c6 e7e6 b3b2 e6e5 b2a3 e5a1 a3b3 a1d1 b3a3 d1a1
d3d5 i8i6 i3i5 d8d6 h2g4 c8c6 d5c6 e8e6 c3c4 h9g7 b1c3 b10c8 e3e4 f9e7 b3b5 b8b7 c6b7 a8b7 d2b3 c9d8 f3f5 f8f6 h3h4 h8h7 f2h3 d9b8 c1d2 g9i7 g1e3 i7e3 g4e3 e7d7 b2d3 d8a5 h1f2 h10f9 g3g5 g7h5 f5e6 d7e6 g5f6 h5f6 c3d5 f6d7 d2a5 a9a5 f2g4 f10h8 d1d2 f9e7 f1f3 i9f9 f3g3 g10h9 i1f1 i10f10 f1f9 f10f9 i2i1 b7b6 i1f1 e7g6 f1f9 e10f9 e1f1 f9g9 f1g1 b9d8 a1f1 g9h10 g1h1 d7c5 d3c5 e6c5 a3a4 g8g7 d5b4 b8d7 e3d5 h9e6 b4d3 c5b3 c2b3 d8b7 h3g5 b7c5 d3c5 b6c5 e2e3 c10e8 g2h3 d10b8 f1f2 e9h9 a2a1 c8e9 h4h5 i6h5 g5h5 b8d8 a1f1 a5a9 f2h2 a10g10 e3g5 d8g5 h5g5 g6f8 a4a5 e9f7 g5f4 h7h6 b5b6 d7d8 d5c7 e8c6 h3i4 h8i8 h1g1 c6e4 a5a6 a9e9 g3i3 e6f5 b3a4 g10e10 f4h5 h9g9 d2c3 f8e6 i5h6 g7h6 h2h4 e4d3 g1h1 d3f1 g4h6 i8h9 i4f1 e6d4 c3g3 f5e4 h4e4 g9g3 i3g3 d4f5 h6f5 e9e4 g3g6 e4e5 h1g1 d8e7 f5e7 h9h5 g6h5 e5h5 c7d5 h5e5 g1f2 f7d8 f1g2 h10g9 a6a7 e10e7 d5e7 e5e7 a7a8 d8c10 b6b7 e7e9 g2h3 e9a9 h3b9 c10b8 f2e3 g9f8 e3e4 f8e7 e4d5 b8d9 a4d7 d9b8 d7b5 b8d9 d5c6 e7d8 c6d6 d9b8 b5f9 b8d9 f9e10 d9b8 e10c8 b8a6 d6c6 d8c9 c6b6 a6b4 b6c5 b4d3 c5b6 c9b8 c4c5 d3f4 c8e6 f4e6 b9e6 a9e9 e6d5 e9i9 c5c6 i9i6 b6c5 i6i9 d5e6 b8c7 e6b9 i9i5 c5b4 c7c6 a8a9q i5i4 b4a5 i4i9 b9d7 c6b7 a9i9 b7c7 i9d4 c7d8 d4g7 d8d9 g7e7 d9d10 e7g9 d10c10 d7c8 c10d10 g9d9
d3d5 i8i6 f3f5 c8c6 c3c4 c6d5 c4d5 d8d7 i3i5 e8e6 e3e4 h8h7 b1c3 b10c8 h3h4 g9h8 b2c4 e6d5 e4d5 b8b6 a3a5 h8c3 d2c3 c9f6 c3a4 f6a1 a2a1 a8a7 a1a3 d7d6 b3b5 e9e2 f2e2 f9e9 a3e3 g10e8 a5a6 b9c7 c1b2 e8b5 e3e9 d9e9 a4b4 i9i8 g3g5 c10e8 e2c3 b5a6 h2g4 h10f9 h1g3 h9i7 g1d4 a6b7 e1f2 g8g7 i2h2 f10h8 f5f6 i7g6 g3e2 h8h9 f2g3 c7a6 b4a2 a6c7 c2e4 e10d9 e2f4 g6i7 h2h3 e8d7 g3h2 d9c9 h3e3 i10e10 f4e6 d7e6 d5e6 b7e4 g2e4 a10c10 e4d5 c9b10 f1f2 f9d8 i1e1 e9f9 a2b4 e10e6 d5e6 d8e6 b4c6 f9e8 d1f3 e8d7 c3b4 d6d5 f6g7 d7c6 b4c6 c8e7 d4f6 b10a10 f6e7 f8e7 c4e5 i8c8 c6e7 i7g8 e7c6 d5d4 e3d3 c7e8 c6d7 e6c5 d7c8 c10c8 d3d4 d10b8 h2h3 h9g10 e5d7 c5d7 d4d7 e8d6 g4e5 g8e9 d7e7 c8c10 f3g4 e9c8 e1c1 b8a8 e5f7 a9f9 f2g2 a8g2 h3g2 a10a9 b2e5 a9b10 e5d6 c8d6 e7a7 f9a9 a7a9 b10a9 f7d8 c10b10 g4f4 g10d7 g7g8 d7i2 g2f3 i2h3 f3f2 h3i2 f2e3 b10e10 d8e10 i2e6 e3d4 a9a8 f4f8 d6e8 g8g9h e6d7 d4e5 d7b5 e5e6 b5b3 e6e7 b3e3 e7d7 e3h3 d7e8 h3e6 e8d8 e6e5 d8d7 a8a7 c1a1 e5a1 g9a9
d3d5 d8d6 f3f5 c8c6 d5c6 e8e6 g3g4 i8i6 c3c4 h8h7 i3i5 b8b7 c6b7 a8b7 g2b7 b10c8 h1g3 g9h8 b3b4 d9b8 b7c8 b8c8 a3a5 h9g7 b1c3 e6f5 g3f5 c9f6 c3d5 g7f5 c2f5 c8b8 f2g2 f6e5 e3e4 a10b10 g1b6 b9d8 g4g5 c10h5 f5g4 f9e8 d2b3 h10f9 c1f4 f9e7 g4h5 i6h5 h2f3 e7d5 c4d5 e5c3 f4d2 b10c10 e2e3 c3d2 d1d2 f8f6 h3h4 e8e7 g2g3 f6g5 f3g5 f10f1 i1f1 g10d7 g5h3 h8i7 h3f4 d7i2 d2i2 g8g6 b2c4 g6g5 h4g5 i7g5 i2h2 e9i5 a2f2 a9f9 e1d2 d10d9 b6d4 i9i8 g3h3 i5h6 f2g2 d8f7 a5a6 h5h4 a6a7 b8a8 g2g5 f7g5 h3h4 i8i4 h4i4 g5i4 h2i3 h6h2 d2d3 d9c9 f4e6 e7e6 i3c9 e6d4 b3d4 c10c9 f1f9 c9f9 d4e6 h2h4 c4d6 i10i6 e6d7 i6d6 d7d6 i4g5 d6e5 h4h5 a1i1 f9f3 e5f3 h5f3 i1i10 e10d9 i10i9 d9c8 i9i8 c8b7 e3f3 g5f3 i8h8 h7h6 h8h7 b7a6 h7h6 a6b5 h6h3 f3e5 d3d4 e5c4 h3c3 a8b6 c3c1 b6a4 e4e5 a4b3 d4e4 c4b6 c1c10 b3d2 e4f4 d2d3 f4g3 b5a6 e5e6 d3e4 g3h2 a6a7 e6e7 e4d6 c10e10 b6c8 e7e8 d6d7 h2g2 d7d8 e8e9c c8e9 e10d10 d8c8 d10i10 c8d6 i10d10 e9d7 d10e10 d6d5 g2f2 a7b6 f2g3 b6b5 g3g4 d7e5 g4f5 e5c6 f5g4 b5b4 g4g5 b4c4 e10c10 d5e6 g5h5 e6f4 h5h4 c4d5 c10f10 f4g2 h4g5 c6e5 f10d10 d5e4 d10g10 g2f4 g5h6 e5g4 h6h7 g4f6 h7h8 f4h5 g10g1 h5h6 h8g9 h6f7 g9h9 f7f8 h9h8 f8h7 h8h9 f6e8 h9h10 e8g7 g1e1 e4d5 e1d1 d5e6 d1e1 e6f7 e1h1 h7g8 h10i10 f7f8 h1h10 g7i8 h10h9 f8g7 h9h7 g8h7 i10h9 h7h8
d3d5 i8i6 i3i5 d8d6 f3f5 c8c6 c3c4 h8h7 h3h4 c6d5 c4d5 g9h8 e3e4 g8g6 g3g5 f8f6 f2h3 f10g9 d2c4 h9f8 h2g4 g6f5 e4f5 b10c8 h1g3 b9d8 b1c3 d8f7 c3e4 h10g8 a3a5 f8d7 g1d4 f7e5 c4c3 d9c7 b2d3 a8a6 b3b4 e5g4 h3g4 d7e5 g4h3 b8b6 d3f4 b6a5 b4a5 c9a7 d4a7 c8a7 f4e6 c7b7 c3b4 a7b5 c1e3 c10b9 c2a4 b9e6 f5e6 f6g5 e3b6 b7b6 a5b6 b5d4 e2d2 g5g4 h3g4 e5g4 d1g4 f9e7 f1d3 a10b10 i1f1 b10b6 b4c4 d4e6 c4b6 e9b6 a1b1 b6a7 d5e6 d6d5 a4b5 a6a5 e4g5 g9d9 g4a4 h7h6 i5h6 g8h6 d3h7 e7g8 h7a7 a9a7 b5c6 d9a9 a2a3 h8e5 g3e2 e5d6 d2d5 i9f9 a3d3 f9f1 g2f1 g10i8 i2i6 i10f10 i6i8 h6i8 g5e4 d6b4 a4b4 d10d5 b4b10 a9b10 b1b10 e10e9 b10b9 e9f8 c6d5 f10f9 d3f3 f8g9 f3f9 g8f9 e2d4 g9g10 b9f9 g10f9 e1d2 a5a4 f1c4 i8h6 d2c3 a4a3 e4f6 a7i7 f6h5 i7i2 e6e7 f9e9 h5g7 h6g4 c4a2 g4e3 d5g8 i2b2 d4f5 e3d1 c3d3 d1f2 d3d4 f2d1 g8b3 b2g2 h4h5 g2g4 d4d3 d1f2 d3e3 f2e4 h5h6 e4f6 e3d3 g4i4 d3c3 f6g4 b3d1 g4f6 c3b3 i4i1 d1i6 i1i3 b3b4 i3h3 a2b3 f6e4 i6g4 h3h1 g4f3 h1b1 b4a3 e4f6 a3b4 b1b2 b4c3 b2b1 b3a4 b1b10 c3d4 f6g8 h6h7 g8e7 f5e7 e9f8 g7f9 b10b2 a4e8 f8e8 f3h5 e8d7 h7h8 b2b4 d4c5 b4b2 h8h9q b2c2 c5b4 d7c7 h9i8 c2b2 b4c5 b2b5 c5b5 c7d6 e7c6 d6d7 h5g4 d7c7 i8b8
d3d5 i8i6 i3i5 d8d6 h2g4 c8c6 d5c6 e8e6 c3c4 h9g7 b1c3 b10c8 b3b5 f8f6 g4h6 a8a6 f3f5 g7f5 h6f5 e6f5 c2f5 h8h7 d2b3 g8g6 f5d7 f9f8 d7g10 f10g10 a3a5 g9h8 e3e4 h10g8 f2d3 b9c7 g1d4 d9d8 b3b4 c7e6 d4e3 f6f5 d3c2 d8f7 e4f5 g6f5 c3d5 c9d8 c1d2 c8e7 b2d3 a6b5 c4b5 e7d5 g2d5 f7e7 d3f4 e6f4 e3f4 h8a1 c6c7 b8c7 d1a1 c10h5 d5f3 c7c6 b4c6 e7c6 b5c6 a9a7 e1d1 d8f6 d2c3 f6e5 f3h5 i6h5 e2f3 f8e6 c2d3 a7e7 i2e2 e9e8 d1e1 i9e9 a2d2 d10b8 d2c2 g8f6 h3h4 f6d5 f4g5 d5c3 c2c3 e7a7 a1d1 a7a5 e1f2 a5d5 c3b3 d5d3 d1d3 b8a7 g5e3 a7a4 f2g2 a4h4 e3h6 e6d4 d3d4 h4d4 h6e9 e10e9 f3f5 d4d5 f1f3 g10g8 f5b9 e8d9 b9b6 e9d10 b3d3 d5f3 d3f3 h5h4 i5i6 g8d5 h1f2 e5g3 b6b8 d10c10 b8c7 d9c9 c7d7 a10a3 e2e4 a3a7 i1d1 d5h5 d7e8 h5e8 e4e8 c9c6 e8f8 g3f2 d1d2 f2b6 g2h2 d6d5 f8f6 b6c7 h2h3 c6d7 f6f5 a7a3 h3h4 a3a4 h4h3 i10i6 d2g2 i6h6 h3i3 a4i4 i3i4 d7d9 g2g6 d9i9 f5i5 i9d4 f3f4 d4f4 g6g4 f4i1
7 white wins
1 draw
2 black wins
d3d5 i8i6 i3i5 d8d6 f3f5 c8c6 c3c4 h8h7 h3h4 b10c8 e3e4 g8g6 b1c3 g9h8 g3g5 f8f6 h2f3 f10g9 f2h3 c6d5 c4d5 h9f8 a3a5 b9d8 b3b4 d8f7 d2b3 h10g8 h1g3 b8b7 b2c4 a8a6 f3d4 f7e5 d4e6 c9e7 g1d4 d10b8 f1f2 f8e6 d5e6 e7d8 c1e3 c8e7 a1c1 e7c6 d4b6 e5c4 b3c4 a9c9 c2a4 f6g5 h4g5 c10b9 c4b3 d8b6 e3b6 e9f8 c3d5 g8e7 i1f1 a10c10 b4b5 a6b5 a4b5 g10h9 a5a6 b7a6 b5a6 b9c8 a6b5 c8b7 f2e3 h8e5 f5f6 e7c8 b5c6 c8b6 c6b7 b8b7 c1c9 c10c9 b3a5 b7b9 a5b6 h9e6 h3h4 c9c5 b6a8 c5d5 d1d5 b9b4 d5d2 d6d5 e1f2 f8c5 d2b4 c5e3 e2e3 g9b4 f1d1 d5d4 e3a3 b4c3 g3e2 c3a3 a2a3 e6i2 h4i2 f9f8 e2d4 d9c7 d4f3 c7a8 a3a8 e5c7 d1c1 c7e9 g2f1 e10f9 f1c4 i10d10 i2h3 i9g9 h3g4 d10d8 a8a6 g9g10 e4e5 g10d10 e5e6 d8c8 f3e5 f9f10 f2g2 c8c5 e6e7 f8f9 g2h3 e9c7 e5f3 d10c10 a6a4 c7e9 f3e5 f9h8 c1f1 e9c7 e5d3 c5a5 a4a5 c7a5 d3e5 h8f9 g4h6 c10c5 f6f7 f10e10 c4a6 e10d10 h6g8 c5c9 f1d1 d10c10 a6d9 c9d9 d1d9 f9g8 f7g8 c10d9 g8g9h a5e9 g9h7 d9c8 e5g6 e9b6 h7f6 c8b7 f6d6 b7a7 d6e8 b6a5 e8c8 a7b7 c8d6 b7c7 d6c4 c7b7 c4a5 b7b6 a5e5 b6b7 e7e8 b7c7 e8e9q c7c8 e5b5 c8d7 b5b6
d3d5 i8i6 i3i5 d8d6 c3c4 h8h7 f3f5 c8c6 h3h4 c6d5 c4d5 g9h8 e3e4 g8g6 f2h3 b10c8 g3g5 f8f6 b1c3 f10g9 g1e3 b9d8 b2c4 d8f7 h2f3 h9g7 b3b5 b8b6 a3a5 b6a5 a2a5 h10g8 h1g3 g7h5 c1b2 c9d8 a5a6 d10c9 f1f2 h5g3 f2g3 f9g7 g3f2 a10b10 i1f1 g7h5 f5g6 h7g6 d2d3 e8e6 d5e6 e9e6 h3h2 e6e9 g2i4 h5g7 i4h3 b10b5 c2a4 b5b7 c3d5 d9b8 a4g10 g9g10 e3d4 g7h7 g5f6 g8f6 f3g5 f7g5 h4g5 f6d5 d4h8 d5b4 h3c8 b8c8 h8i9 i10i9 c4d6 b4d3 d1d3 b7b2 e2b2 c8b8 h2g4 d8c7 i2h2 h7g7 h2h8 i9f9 f2d4 f9f1 d3f1 a9b9 b2h2 g7f9 h2h7 c9e7 h7e7 e9e7 g4f6 e7e9 f6h7 b9d9 a1b1 b8d7 b1b10 d9d10 d6c8 d7c8 h8c8 d10d4 c8c10 e10d9 f1f7 f9e8 c10g10 d4e4 e1f1 e4e1 f1g2 e1e2 f7f2 e2f2 g2f2 c7d8 b10b9 d8c9 a6a8 e9c7 b9c9 c7c9 a8e8 c9a7 f2g3 a7c7 g3g2 c7b7 g2g3 b7h7 e8g8 h7c7 g3f3 c7f7 f3g3 f7b3 g3f2 b3c2 f2g3 c2d3 g3f2 d3f5 f2e3 f5g5 e3e4 g5i5 g10g9 d9d10 g9g10 d10c9 g10g9 c9d10 g8g6 i5e1 e4f5 i6i5 g9a9 e1f2 f5g5 f2h4 g5f5 h4h5 f5f6 h5h8 f6f5 h8h7 f5f6 h7h4 f6f5 h4h5 f5f6 h5f3 f6g5 f3e3 g5h5 e3e5 h5h6 e5h2 h6i5 h2i3 i5h5 i3h2 h5g5 h2g3 g5f6 g3d6 f6g5 d6d5 g5f6 d5d8 f6f7 d8d7 f7f8 d7f5 f8g7 d10e10 a9g9 f5d7 g7f6 d7d6 f6f7 d6d7 f7f8 d7d8 f8g7 d8e7 g7h6 e7h4 h6i7 h4e1 i7h8 e1e8 h8g7 e8e7 g7h8 e7e1 g6g8 e1e2 h8g7 e2e7 g7h8 e7f6 h8h7 f6f7 g8g7 f7h5 h7i7 e10d10 g7g8 h5i4 i7h6 d10e10 h6g7 i4i5 g7f6 i5i4 g9g10 e10e9 f6g7 i4i7 g7g6 i7i4 g6f6 i4i3 f6g7 i3e7 g7g6 e7e4 g6g7 e4e5 g7h7 e5h5 h7i8 h5i6 i8h9 i6h7 h9i9 h7f7 i9h10 f7h5 h10i9 h5i6 i9h8 i6h6 h8i9 h6i5 i9h9 i5e1 h9h8 e1h4 h8g7 h4e7 g7g6 e7d6 g6f7 d6d5 f7g7 d5d7 g7g6 d7e6 g6g5 e6e5 g5g6 e5e6 g6g5 e6f7 g8g9 e9e8 g9g8 e8f9 g8g6 f7d5 g5f6 f9f8 g6g8 d5g8 g10g8 f8g8
d3d5 d8d6 c3c4 i8i6 i3i5 h8h7 f3f5 c8c6 h3h4 g9h8 f2h3 b10c8 g3g5 f8f6 e3e4 g8g6 b1c3 f10g9 h2f3 b9d8 b3b4 d8f7 d2b3 h9g7 a3a5 b8b7 f3d4 h10g8 d4e6 a8a7 h1g3 f7e5 b2d3 d9b8 d3f4 g8i7 e6g7 h8g7 f4e6 g10h9 e6g7 e9g7 g1d4 g7h8 e2f2 i10g10 c1e3 e8e7 e1d2 h9f7 d2c1 g6f5 e4f5 c10e8 c1b2 f9d8 i1g1 e10d9 a2a3 g9f9 d1d2 b8c7 c2e4 a9b9 g2f3 b9b10 g5f6 e7f6 i2g2 d10f10 g3e2 g10g2 f1g2 i7h5 f3h5 i6h5 e2f4 e5g4 f2f3 f10i10 f4e6 f7e6 f5e6 c6d5 c4d5 g4e5 f3e2 b10g10 g2h1 g10g1 a1g1 b7b6 g1c1 b6b5 e4d3 i9g9 c3d1 c7a6 d1f2 d9c10 b3a2 c8e7 a3c3 c10b9 d4e5 f6e5 e3g5 a10c10 a2a3 d8b7 b2a2 h8g7 e2f1 i10g10 d3e2 c9b10 c3c10 e8c10 f2e4 f9f1 h1f1 c10e8 h3g3 g9f9 f1h3 e7g6 g3h5 g7e9 g5h6 e9d9 h3h1 g6f4 h5i7 b10e7 h4h5 b7d8 e2f3 d9b7 a2b2 f4d5 i7h8 f9f3 h1f3 g10h10 h8g7 e8c6 g7f7 d8d9 h6g5 a6c7 f3i3 e7g5 d2g5 b9a8 g5g8 b7b8 g8b8 d9b8 e6e7 c7d7 e4d6 d5e7 d6b5 e7d5 i3b3 e5e4 b5d4 h10i9 a3c4 d5f4 b2a3 f4d3 c1c3 i9i5 f7e6 d7e6 d4e6 i5e1 c3c2 b8d7 e6d4 c6b7 b3c3 e1c3 c4c3 a7a6 c2i2 d3e5 d4f5 d7e6 f5e3 a8b9 i2i4 b9c9 a3b2 e6g5 i4i9 c9d10 i9i10 d10e9 i10i9 e9d10 c3d4 g5f3 b2c3 e5c6 d4f3 e4f3 i9f9 c6e7 f9f4 h7h6 c3c4 b7d9 f4f3 d9h5 f3f6 e7g8 f6d6 h5d9 e3d5 d10c9 c4c5 h6h5 d6d7 g8e9 d7h7 c9d8 c5c6 d9e8 c6b6 e8d9 h7h8 d8d7 b6c5 d9e10 h8h5 d7e6 c5c6 e6f7 d5c7 e10c8 h5h9 f7f8 c6b6 e9d7 b6a7 f8e7 c7a6 d7e5 a6b8 e5c4 a5a6 c4d6 a7b6 c8a6 b8a6 e7d8 h9h8 d8e7 h8h5 e7f7 h5d5 f7e6 d5d6 e6d6 b4b5 d6d7 b6c5 d7e6 b5b6 e6f7 b6b7 f7e6 b7b8 e6f6 c5c6 f6g6 b8b9q g6g5 b9h3 g5f4 h3g2 f4e5 g2f3 e5e6 a6c5 e6e7 f3f9 e7d8 c5d7 d8e7 f9f8 e7e6 f8f6
d3d5 i8i6 i3i5 d8d6 f3f5 c8c6 c3c4 h8h7 h3h4 g9h8 e3e4 b10c8 f2h3 g8g6 g3g5 f8f6 h2g4 h9f8 b1c3 b9d8 b3b4 c6d5 c4d5 d8f7 d2b3 i9g9 g1e3 b8b6 c3b5 c9d8 h1g3 d10c9 g3i4 a8a6 b5d4 h10g8 b2c4 b6b5 c4a5 c10a8 c1b2 f7e5 a1c1 f9e7 f1h1 f8d7 c2b1 d7c5 a5c6 c5b3 c6e7 g8e7 d1b3 g6f5 e4f5 d8b6 d4e6 b6e3 g4e3 c9b8 a3a5 b5a4 a2a4 a6a5 g2e4 a10b10 b2c3 a9c9 c3d2 a5b4 a4b4 b8a9 b4b10 d9b10 i4h6 g10h9 i2f2 c9b9 b3d1 g9f9 h6g4 b9b2 b1d3 f6g5 h4g5 h9e6 f5e6 e7g6 i1i2 g6f4 h3f4 f9f4 h1h7 e10d9 f2f4 f10f4 h7h8 i10f10 e2f2 f4f2 i2f2 f10f2 e1f2 a9c9 g4e5 d6e5 h8h4 c9a7 f2e1 b2a2 d1i6 b10c10 i6h6 a8b7 i5i6 a7d4 c1b1 b7a6 h6e9 c10e9 b1b4 a6d3 b4d4 e5d4 e4d3 d4e3 d2e3 a2i2 g5g6 i2i6 h4g3 i6i8 g6g7 i8g8 d5d6 d9c9 d3a6 c9b9 g3h2 e9c10 h2b2 b9c9 d6d7 e8d7 e6d7 c8e7 e3a7 c9d8 b2b6 d8d7 a6b5 d7c8 b6e6 c8b7 e6e7 b7a8 b5c6 a8a9 e7f7 g8i8 f7h9 c10b9 h9i8 b9a7 i8e8 a7b9 g7g8 a9b10 e8e10 b10c9 g8g9h c9b8 e10b7 b8a9 b7b9
d3d5 d8d6 f3f5 c8c6 d5c6 e8e6 g3g4 i8i6 c3c4 h8h7 i3i5 b10c8 h1g3 g9h8 h2f3 b8b7 f3d4 b9d8 c6b7 a8b7 b1c3 d9b8 h3h4 g8g6 f5e6 d8e6 d4e6 e9e6 g2d5 e6e9 f2h3 h10g8 b2d3 h8c3 d2c3 c9f6 c3b4 h9g7 c1b2 f6b2 d3b2 f8f6 e3e4 f9e7 g1e3 g10d7 i2f2 f10h8 a3a5 i10f10 e1d2 e7e8 g3i4 g8e7 i4h6 f10f8 b2d3 e7c6 b4c3 a9a5 a2a5 a10a5 a1a5 e9a5 d1a1 i9a9 a1a5 a9a5 b3b5 c6e5 f1b1 c8e7 b1b2 d10e9 i1f1 b8c8 d2c1 b7b6 h3g2 e9c7 d3b4 e10d10 c3d4 a5a10 b2c3 c10b9 g4g5 f6f5 e3f4 c7a7 d4b3 d10c9 f4h2 c8c7 f1e1 f5e4 f2f8 h8f8 d5e4 c7e6 b3b2 c9b10 e2d2 g7f5 h6f5 g6f5 e4f3 e8f7 b4d3 e5f3 g2f3 e6c7 f3g3 a10a8 g3i4 d7b5 i4h6 b5f9 d3f4 c7c6 h6f7 f8f7 h2g1 e7g6 f4d5 f7f8 d5b4 c6a5 b4d5 g6e5 g1d4 f9g8 d4e5 d6e5 c3e5 a8d8 d2c3 a5c6 e5f6 g8d5 f6f8 d8f8 c4d5 c6d5 c3i9 b9c10 e1e5 d5d6 e5e10 a7c7 i9h10 f8c8 b2d3 d6c4 d3c4 c7c4 h10e7 c8c9 e10c10 b10c10 e7e10 c10b9 e10b7 b9c10 b7e10 c10b9 e10b7 b9a9 b7a7 a9b10 a7b6 b10c10 b6f10 c10b9 f10f5 b9b8 c1d1 c9d9 d1c1 c4c7 f5f8 b8a9 f8a3 a9b9 c1b2 d9d6 b2c1 d6g6 a3a4 g6g7 a4f9 b9b8 f9d9 c7f4 d9d2 f4f1 d2d1 f1f4 d1d2 f4f1 d2d1 f1f10 d1d4 g7f7 c1d2 f7f2 d2c1 f2f1 c1d2 f10a5 d2d3 a5a3 d3c4 a3a2 c4d3 a2a3 d3c4 a3a6 c4b4 a6b7 b4c3 b7c7 c3b2 f1f9 c2d3 c7b7 b2c3 b7c7 c3d2 b8c9 g5g6 c7a5 d4c3 a5c3 d2c3 h7g6 d3g6 f9h9 g6d3 h9h4 d3e2 h4i4 e2i6 i4i5 i6e2 i5i4 e2f1 i4f4 f1e2 c9d8 c3d3 d8d7 d3e3 f4h4 e3f3 d7d6 e2d3 d6e5 d3b1 h4f4 f3g3 f4i4 b1c2 i4i1 c2h7 i1a1 g3g4 a1h1 h7c2 h1g1 g4f3 g1i1 f3g4 i1i2 c2h7 i2i10 h7c2 e5d4 c2g6 i10g10 g4f5 g10f10 f5e6 f10e10 e6f5 e10e2 g6f7 e2f2 f5e6 d4e4 f7i4 e4f4 i4g6 f2e2 e6d5 e2b2 g6h7 b2b5 d5e6 b5b6 e6d5 b6b7 h7i8 b7b9 i8c2 b9b8 c2h7 b8b5 d5d6 b5h5 h7c2 f4e3 d6e6 h5g5 e6f6 g5c5 c2h7 e3f4 f6e6 c5e5 e6d6 e5h5 h7i8 h5h1 d6e6 h1h6 e6d5 f4e3 d5e5 h6h5 e5e6 h5g5 i8h7 e3d4 h7f9 g5a5 f9d7 a5a2 d7g10 a2a6 e6f5 a6a5 f5e6 a5a6 e6f5 a6a10 g10h9 a10f10 f5e6 f10e10 e6f5 e10e5 f5f6 e5b5 f6e6 b5b6 e6f5 b6b5 f5e6 b5e5 e6f6 e5e9 h9f7 d4e4 f7i4 e4d5 i4g2 d5d6 f6f5 e9e5 f5f4 d6e6 g2b7 e6f6 b7g2 e5h5 f4e4 f6e6 e4d4 h5h4 d4d3 e6d6 g2a8 d6c5 d3e3 c5d6 e3d3 d6c5 d3e3 h4b4 a8g2 c5d6 e3d3 d6e5 d3c3 b4b1 c3d3 b1b3 d3c4 b3a3 g2h1 a3a1 h1b7 a1a4 c4d3 a4d4 d3c3 d4f4 c3d3 f4d4 d3c3 d4g4 b7h1 g4g3 c3c4 g3g4 c4c3 e5d6 c3d3 g4g1 h1f3 d6e5 f3a8 g1g3 d3c4 g3g4 c4d3 g4g3 d3c4 g3h3 a8c6 h3h4 c4d3 h4h3 d3c4 e5d6 c6b7 h3h4 c4d3 d6c5 b7f3 h4b4 d3e3 c5d6 e3d3 d6c5 f3h1 b4d4 d3e3 d4a4 h1g2 c5d6 e3d3 d6c5 d3e3 a4b4 g2f3 b4i4 f3g2 i4d4 g2h1 c5c4 h1g2 d4d7 e3e4 d7e7 e4f5 c4c5 g2f3 c5d6 f5f4 e7e6 f3g2 d6c5 f4f5 e6e7 g2f3 c5d6 f5f4 e7e1 f3g2 d6c5 f4f5 c5d4 g2c6 e1f1 f5e6 f1e1 e6f5 d4c5 c6f3 c5d6 f3g2 e1e5 f5f4 e5e8 f4f5 d6c5 g2h1 c5d4 h1c6 e8e5 f5f6 e5e2 f6f5 e2f2 f5e6 f2e2 e6f5 d4c5 c6f3 e2e7 f3h1 c5d6 h1g2 e7e9 g2f3 d6c5 f3a8 c5d6 f5f4 d6c5 f4f5 c5d6 a8f3 e9e5 f5f4 e5e7 f3g2 e7e2 g2f3 e2e7 f4f5 d6c5 f5f6 e7e8 f6f5 c5d4 f5g4 d4e5 f3g2 e8f8 g2h3 f8f4 g4g5 f4c4 h3g2 c4f4 g2h3 f4f2 g5g4 e5e4 g4g5 e4e5 g5g4 f2f10 h3g2 f10f4 g4g5 f4f2 g2h3 e5e4 g5g4 e4e5 g4g5 f2f8 g5g4 f8f10 h3g2 f10f4 g4g5 f4a4 g2h3 a4e4 h3g2 e4c4 g2h3 c4a4 h3g2 a4a2 g2h3 a2a4 h3g2 a4a2 g2h3 a2a8 g5g4 a8a4 g4g5 a4b4 h3g2 b4b2 g2h3 b2b4 h3g2 b4b2 g2h3 b2b8 g5g4 e5f6 g4f4 b8b4 f4f3 f6e5 h3g2 b4f4 f3e3 f4h4 e3f3 h4f4 f3e3 f4f8 g2h3 f8h8 h3g2 h8f8 g2h3 f8f10 h3g2 f10f5 g2h3 f5h5 h3g2 h5f5 g2h3 f5f10 h3g2 f10f4 g2h3 f4h4 h3g2 h4f4 g2h3 f4f6 h3g2 f6f10 g2h3 f10f7 h3g2 f7f10 g2h3 f10f8 h3g2 f8f6 g2h3 f6f8 h3g2 f8f9 g2h3 f9h9 h3g2 h9f9 g2h3 f9h9 h3g2 h9h5 e3f3 h5h4 f3e3 e5f5 e3f3 f5g5 f3e3 g5f5 e3f3 h4f4 f3e3 f4c4 g2h3 f5e5 e3f3 c4e4 h3g2 e4c4 g2h3 c4h4 h3g2 e5f5 f3e3 h4b4 g2h3 f5g5 h3g2 g5g4 g2e4 b4b2 e4c6 g4f5 e3d4 b2d2 d4e3 d2h2 e3d4 h2d2 d4e3 d2b2 e3d4 f5e6 c6d5 e6d6 d5h1 b2b4 d4e3 d6e5 e3f3 b4b3 f3g4 b3b2 g4f3 e5f5 f3e3 b2h2 h1b7 f5e5 e3f3 h2h4 f3g3 h4c4 b7a6 c4b4 a6c8 b4b8 c8d7 b8b1 g3f3 b1f1 f3g3 f1a1 d7e8 a1h1 e8c6 h1f1 g3g4 f1g1 g4f3 g1a1 c6d7 a1b1 f3e2 b1b3 d7a4 b3b1 a4e8 b1a1
d3d5 i8i6 i3i5 d8d6 f3f5 c8c6 c3c4 h8h7 h3h4 g9h8 e3e4 b10c8 f2h3 g8g6 g3g5 f8f6 b1c3 b9d8 b3b4 h10g8 d2b3 d8f7 a3a5 h9g7 h2f3 b8b7 f3d4 f7e5 h1g3 f9e7 b2d3 c6d5 c4d5 i9f9 d3f4 a8a6 d4e6 f10g9 c1e3 d9b10 e3d4 i10i9 a1c1 c9b8 g1e3 g8i7 e1d2 a9c9 f1f2 a10a9 e6g7 e9g7 b4b5 g7g8 h3i4 g8h9 b5a6 a9a6 f4e6 i7h5 c2d3 f6g5 d3a6 g5h4 i4h4 b7a6 e3h6 d10d9 e2a6 c9b9 b3c2 b8d10 e6c7 d10h6 i5h6 d9d10 c7b9 b10b9 g2h3 h5g3 f2g3 d10h6 d4e3 h6d10 i1g1 g9f10 f5g6 e5g6 h4g5 b9b8 a6b5 h8e5 g3g2 g6f4 g2h1 h7h6 g5i6 c10b9 a2b2 b8c7 h3c8 b9c8 b5b10 c8i2 b10d10 e10d10 h1i2 e7c8 c1b1 d10c10 e3b6 f9c9 i2f2 i9i6 d1i6 g10f9 i6i3 c10d9 b1f1 f10d8 f2h4 d8h4 i3h4 c7d7 f1f4 e5f4 h4f4 d7e5 f4f1 h9f7 b6d4 f7f1 g1f1 e5c4 d2e1 f9g8 a5a6 c9b9 b2b9 c8b9 a6a7 g8f7 e1f2 e8e7 f1b1 d9c10 b1a1 f7e8 a7a8 b9a9 a1a7 c10d9 c2e3 c4e3 d4e3 d9c9 e3h6 e8c10 c3b5 a9a8 a7e7 a8b6 b5d6 c9d8 h6e9 d8e7 d6f5 e7e8 e9b6 c10b9 f2g3 e8f8 g3f4 b9a8 f5e3 f8e8 e4e5 e8d7 e5e6 d7d6 f4f5 a8b7 b6d4 d6c7 f5e5 c7d8 d5d6 b7c6 e3d5 d8e9 d6d7 e9f8 e6e7 f8f9 e7e8 f9f8 d5f6 c6d7 d4c5 f8e9 c5b6 e9f8 e8e9q f8f7 e9h9 f7f8 b6e9 f8e7 h9h7
d3d5 i8i6 i3i5 d8d6 c3c4 e8e6 d5e6 e9e6 i2i4 e6e9 f3f5 d9c7 i4d4 c9f6 g3g5 f6d4 e3d4 b9d8 b1c3 g8g7 a3a5 h8h7 b3b5 c7d7 h3h4 e9e2 d2e2 h10g8 a5a6 f9h8 c2e4 c8c7 h1g3 f8f6 h2g4 b10c8 b2d3 b8b7 g5f6 g8f6 g4f6 g7f6 c1f4 h9g7 d1b3 c7c6 e1d2 g9e7 g3i4 d6d5 c3d5 c6d5 e4d5 b7b6 f4a9 a10a9 d5i10 i9i10 i4g3 g10h9 f2h3 c8d6 a2c2 a9c9 a1a4 c10f7 d4d5 g7h5 g1h2 h5g3 h2g3 h7h6 d2c1 h9i8 e2d4 i10g10 f1f4 c9g9 g3h2 h6h5 i1e1 g9g4 f4d6 d7d6 h2d6 g4d4 d6e7 f7e8 b3c3 d4g4 c2e2 h8f7 d5d6 i8f5 g2d5 f7e9 d3f2 f10i7 c1b2 g4g6 h3h2 d10b8 a6a7 b8c8 a4a6 d8b7 a6b6 i7g7 f2e4 f5e4 d5e4 g6g3 e2e3 g3e3 e1e3 f6f5 e7f6 g7f8 e4b7 a8b7 e3e7 g10g4 f6d4 f8g8 e7c7 c8a8 b6b7 g4g2 h2g2 g8g2 c3c2 g2b7 c7b7 a8b7 c2f5 e9d7 b2c3 e10d9 d4c5 b7g2 c5e3 g2g7 e3d4 g7g3 f5d3 g3e1 d3d2 e1e4 d2d3 e4h1 c3b4 d9c8 d4f2 c8b9 d3f5 h1d1 b4c3 b9a9 f5d5 d1a1 c3b3 d7e5 d5c5 a1d1 b3a3 d1f3 a3a2 e5d7 c5e3 f3f5 e3g3 f5c2 a2a3 c2c4 g3g9 a9a8 g9f10 c4c3 a3a2 a8b9 f10f5 b9a9 a7a8 a9a8 f2b6 c3c4 a2b2 c4b4 b2c1 b4a3 c1c2 a3d6 f5d7 e8d7 b6a5 d6d4 c2b3 d7e6 b3c2 d4a4 c2d2 a4a5 d2e3 e6f5 b5b6 a5e5 e3f3 e5e4 f3g3 e4e3 g3g2 a8b7 g2h2 e3f2 h2h1 b7b6 h1i1 f2g1
d3d5 i8i6 i3i5 d8d6 f3f5 c8c6 c3c4 h8h7 h3h4 c6d5 c4d5 g8g6 e3e4 g9h8 f2h3 b10c8 g3g5 f8f6 a3a5 b9d8 h2f3 d8f7 b1c3 h9i7 b3b5 b8b6 b2c4 b6a5 d2b3 h10g8 a2a5 i7h5 a5a6 a8a7 f3d4 a10b10 d4e6 f9g9 c4a5 h5g7 a5c6 f7e5 c6e5 d6e5 g1c5 g9f7 h1f2 e8e7 f2g4 a9b9 b3b4 g10d7 g4h6 g8h6 i5h6 g7h5 c1e3 d9e8 e2f2 h5f4 e3f4 e5f4 f5g6 f7g6 e4e5 f6f5 h3f4 h8e5 f4f3 f10h8 f2e3 c8d6 g2i4 d6b5 i4g6 b5c3 g6h7 h8h7 b4c3 e5c3 e3c3 c10d9 a6a3 d7e6 d5e6 c9b8 c5a7 b10c10 c3e3 e8d6 a7d4 i9g9 f3e5 i10f10 i2i6 d6e5 d4e5 b8e5 e3e5 d10b8 e5b8 b9b8 f1f4 h7h8 i6i7 e9b6 i7e7 g9e9 d1i6 e10d10 e7e9 b6e9 i1i2 e9b6 a1d1 b8d8 i6i3 f10e10 d1d8 h8d8 i2d2 e10e6 a3e3 e6e3 i3e3 b6e3 f4e3 d8b8 d2i2 c10c7 e3d4 c7e7 e1d2 b8c7 d2c1 f5f4 i2i10 e7e10 i10e10 d10e10 d4e4 e10f10 h6h7 c7f7 h7h8 f4f3 e4f3 f7f3 h8h9h f10e10 c2h7 e10d10 h9f9 f3f9 h7f9 d10e9 f9i6 e9f8 c1d2 f8g7 d2e3 d9i4 i6g4 i4e8 h4h5 g7f7 g4f5 f7e7 h5h6 e8h5 e3f4 e7f7 f5e4 h5i4 e4h7 i4h5 f4f5 f7e7 h7e10 e7f8 f5f6 f8g9 g5g6 h5d1 h6h7 g9f10 e10g8 d1i6 f6g7 f10e9 h7h8 i6e2 h8h9h e9d8 h9f8 d8e9 f8e6 e9d9 e6e2 d9c8 g7f6 c8b7 g6g7 b7b6 g8f7 b6c7 g7g8 c7b6 e2b2 b6c7 g8g9q c7c6 g9c9 c6d7 b2d1
d3d5 d8d6 i3i5 i8i6 c3c4 h8h7 f3f5 c8c6 h3h4 b10c8 e3e4 g9h8 g3g5 f8f6 f2h3 c6d5 c4d5 g8g6 h2g4 h9f8 h1g3 b9d8 b1c3 d8f7 g1e3 f10g9 d2b1 a8a6 a3a5 h10g8 b3b4 f8d7 b2c4 b8b7 c2b3 e9c7 a2c2 f9f8 c1b2 c7b8 b1a3 b7b6 a5b6 c8b6 c4a5 d7e5 g4e5 d6e5 a5c6 b8b10 e2d2 f7d6 a1c1 e8e7 e3b6 b10b6 c3a4 b6b9 a4c5 g6f5 g3f5 g10c6 d5c6 d9c7 g2f3 c10f7 f5d6 e7d6 c5d7 f8e7 b3f7 e7f7 f3g4 b9b10 d7c9 a9c9 i2f2 i10f10 f1d3 a10a8 i1f1 c9d9 g4d7 f7e7 a3c4 f6g5 f2f10 g8f10 c4d5 c7d5 e4d5 g5h4 d3h7 e7g8 h7e4 f10e8 d7e8 a8e8 d2d3 d10b8 d3a6 b8b9 d1d3 e8a8 a6c4 d9f9 c2f2 f9f2 f1f2 h8i7 c1c2 g9h10 c6c7 g8e7 f2f3 e10d10 c2f2 i9e9 f3f7 e7g8 c4c6 b10a10 f7i7 g8i7 h3h4 i7g8 d3g3 b9d7 c6d7 a10d7 g3g5 h10e7 h4i6 e9h9 e4g2 d7b5 f2f10 d10e9 g5e7 g8e7 i6g7 b5b4 e1f1 h9h4 f10f7 h4f4 f7f4 b4f4 f1g1 a8a2 g7h5 f4i1 g2h1 i1h1 g1h1 a2b2 h5g5 b2b10 g5e4 b10i10 h1g2 e9e8 c7c8 e8d8 g2f2 i10i5 e4c3 e7f5 c3c4 f5e4 f2e1 i5i1 e1e2 i1i2 e2d1 e4f2 d1c2 f2e3 c2b3 e3c2 b3a4 i2i4 c8c9c d8c9 a4b5 i4c4 b5c4 c9c8 c4b5 c2b3 b5a6 b3c4 a6a7 c4c5 a7a8 c5b7
d3d5 i8i6 i3i5 d8d6 f3f5 c8c6 e3e4 b10c8 c3c4 g8g6 h3h4 h10g8 b1c3 h8h7 g3g5 f8f6 f2h3 c6d5 c4d5 f6g5 h4g5 g6f5 e4f5 c9g5 h3g5 g9i7 g5h7 e9c7 h7i7 h9i7 h2g4 i7h5 g1d4 i9h9 a3a5 a8a7 d2e4 b9d8 b3b5 b8b6 h1g3 b6a5 b2c4 d8b7 c4a5 b7a5 a2a5 e8e7 g3i4 d9e8 d1d3 g8f6 g4f6 h5f6 e4g5 f9d8 g5e6 c7b8 a5a6 d8e6 f5e6 d10i5 i4g3 i5f8 g2i4 e8g7 d4f6 e7f6 g3f5 c10i4 i2i4 g7e8 i4i6 i10i6 e2i6 g10f9 i6i4 h9h10 a1a4 c8e7 f5d4 f10h8 d4c6 b8b7 d3g3 e10e9 i4i7 a10g10 g3e3 g10g7 i7h8 f8h8 a6a7 a9a7 a4a7 b7b9 i1i8 h8h4 e3f2 e7g8 f2h4 h10h4 a7g7 e8g7 f1g1 g7h9 c1e3 f9c6 i8g8 c6f9 g8g7 h9f8 g7i7 h4h10 i7i8 h10g10 g1h2 f8e7 e1d2 e9d9 c2h7 d9e10 h7f9 e7f9 h2h7 b9c10 i8f8 g10g2 c3e2 g2g9 f8f9 g9f9 h7h10 e10d9 h10d6 d9e10 e3h6 f9b9 d6e7 e10d9 e7f7 d9c9 f7f6 c9c8 f6f8 c8b7 h6f4 c10c4 e2c3 c4d4 d2c2 d4b6 c2b3 b6e9 f8f7 b7c8 f7d7 c8c9 f4g5 c9b8 g5d8 e9f9 d7c7 b8a8 b5b6 b9b8 c7a7 a8b9 d8c7 b8f8 e6e7 f8f3 a7b8 b9c10 b8c8 f9c9 e7e8 f3e3 c8a10 c9b10 a10a8 c10d10 a8c6 b10e7 c6h6 d10c10 e8e9h e7e9 c7e9 e3e1 h6h5 c10c9 h5h4 c9d9 h4e1 d9e10 b6b7 e10f9 b7b8 f9g8 e1g1 g8h7 b8b9q h7h8 b9h3 h8i9 g1i1
6 white wins
2 draws
2 black wins
d3d5 d8d6 i3i5 i8i6 f3f5 c8c6 d5c6 e8e6 g3g4 h8h7 h1g3 b10c8 c3c4 b8b7 b1c3 g9h8 b2d3 h9g7 b3b5 e6f5 g4f5 g7h5 c6b7 a8b7 g3h5 i6h5 h2f3 d9b8 h3h4 g8g6 d3f4 c9f6 c1b2 f9g7 f4d5 g7i6 d5f6 h8f6 f2h3 h10g8 d1b1 g10d7 e3e4 c8e7 g1d4 f6d4 f3d4 f8f6 c3d5 g6g5 e2e3 d10d8 a3a5 e7g6 f5g6 h7g6 h4g5 f6g5 h3h2 f10f1 g2f1 i10f10 e1d1 i9f9 f1g2 d7i2 i1i2 a9a5 a2a5 a10a5 a1a5 d8a5 e4e5 d6e5 d4b3 a5d8 b2e5 b8d7 b1a1 d8e8 e5h8 g5g4 i2i3 e8b8 b3c5 d7c9 e3g1 f9f2 i3e3 f2d2 d1d2 c10e8 c2g6 b9d10 h8f10 e10f10 h2g3 b8g3 e3g3 e8g6 d5f6 e9d8 g1d4 g8f6 d4d8 c9d8 a1f6 d8f7 f6b10 f7e8 g3e3 f10g9 e3e8 d10e8 b10e7 g9f9 g2b7 i6g7 b5b6 f9g8 b7c6 g7f6 e7h10 g4g3 d2c1 g6f5 b6b7 e8g9 b7b8 f6e5 h10h5 g9f7 h5f5 e5f5 b8b9q f5d6 c6d5 g8f8 c5e6 f8e8 b9b8 e8e7 b8f8 e7f6 f8g7 f6e7 e6d4 e7d8 g7g3 d6e8 g3a9 d8e7 i5i6 e8g9 i6i7 e7f8 i7i8 g9i8 a9b8 f8g7 b8i8 f7g5 c4c5 g5f7 i8i7 g7f6 d5f7 f6e7 d4e6 e7d7 i7i3 d7c6 i3b3 c6d7 b3b7
d3d5 i8i6 i3i5 d8d6 f3f5 c8c6 d5c6 e8e6 g3g4 h8h7 c3c4 b10c8 h1g3 g9h8 h2f3 b8b7 f3d4 b9d8 c6b7 a8b7 b1c3 d9b8 h3h4 g8g6 f5e6 d8e6 d4e6 e9e6 g2d5 e6e9 f2h3 h10g8 b2d3 h8c3 d2c3 c9f6 c3d2 f6a1 a2a1 f8f6 c1b2 h9f8 b2f6 g8f6 f1f6 f9e7 f6b2 f8e6 d3f4 c10f7 f4e6 f7e6 e3e4 g10d7 g1e3 e9e8 e3h6 d10c10 h6g5 e7g8 b3b4 i9f9 d2e3 b8c7 c2b3 f10g9 i2f2 f9f2 h3f2 i10f10 f2d3 c8e7 i1f1 f10f1 g3f1 a9f9 d5e6 d7e6 b4b5 c7d7 e1d2 e10f10 b2c3 b7b6 e3d4 e7c8 f1e3 c8e9 d2c2 f10g10 g5f4 c10c8 e3d5 e9f7 c2b2 a10f10 d1g1 g10h10 e2g2 f7e5 f4e5 d6e5 d3e5 d7e5 d4e5 g8f7 e5c6 f7d6 c6d6 g9d6 a1d1 e8f8 d5b4 d6c5 g1c5 b6c5 b4c6 f8h8 g2g3 f9f2 b3c2 f10f3 c3h8 c8h8 g3e5 h10i9 a3a5 f3h3 e5h8 i9h8 c6e5 h3h2 d1c1 h2h4 a5a6 h4i4 e5d3 f2f9 d3c5 e6g4 a6a7 g4b9 b5b6 i4i5 c5b3 b9a8 c1d1 f9f8 c4c5 i5i2 b2c3 i6i5 b3d4 f8c8 c3c4 i5i4 c2a4 c8d8 c5c6 i2a2 c6c7 a2a4 c4b5 a4d4 d1d4 d8d4 c7c8 a8c6 b5c5 i4i3 c8c9q i3i2q c9b8 h8i7 b8f4 i7i6 f4f3 i6h6 c5d4 i2d2 d4c5 c6b7 f3h3 h6g7 h3e6 d2e3 c5b5 e3d3 b5a5 g7h6 e4e5 h6h5 a5b4 d3d4 b4a3 d4c3 a3a2 c3d3 a2b2 b7d5 e6c8 d3d2 b2b1 d5e4 b1a1 d2a5 a1b2 a5b6 b2c3 e4f5 c8b8 b6b8 a7b8 g6g5 c3d4 g5g4 d4e3 h5h4 e3d4 g4g3 b8b9c f5b9 d4c5 g3g2h c5d6 g2g6 d6c7 h4g5 c7b8 b9g4 b8b7 h7h6 b7c7 h6h5 c7b8 h5h4 b8b7 h4h3 e5e6 h3h2q b7b6 h2b8 b6a6 g6e6 a6a5 e6c5
d3d5 d8d6 i3i5 i8i6 h2g4 c8c6 d5c6 e8e6 c3c4 b10c8 b1c3 h8h7 f3f5 g9h8 f5e6 h9g7 b2d3 g7e6 c1b2 f9d8 g1i3 c8e7 b3b5 b8b7 c6b7 a8b7 a3a5 d9c8 d2b3 d8d7 e3e5 d6e5 g4e5 d7e8 e5f3 e8d7 f3e5 d7e8 c3d5 e7d5 c4d5 e6c7 b5b6 f8f6 e5c4 c7d5 i3h2 d5e7 d3c5 b9d8 h3h4 f6f5 b2h8 f10h8 g3g4 c9b8 g4f5 a9d9 h2b8 c8b8 d1b1 d8c6 c5e6 c10b9 e6c7 c6d4 c7e8 g10e8 b1b2 e8h5 g2f3 d4e2 b2h8 e2c1 f3h5 i6h5 f2e2 c1b3 c2b3 h10f9 h8b2 e7f5 i2f2 f5d4 i1i3 b9g4 b2a3 e10f10 i3e3 g4e2 a2e2 e9d8 f2f4 d4e2 f1e2 b8c6 a1d1 d8b8 e2f1 g8g6 h1g3 d9d1 b3d1 c6d5 f4e4 h7h6 d1a4 h6i5 e3f3 b8c9 a3b2 a10a8 b2f2 d10d9 h4i5 d5b4 e4d4 b4a4 d4d9 c9d9 c4d6 a4b4 f2d2 b4c6 d6f7 d9e10 f3e3 a8e8 f1e2 i9i8 i5i6 i8f8 f7g5 i10i8 g5e6 f8f7 e6c7 e8e3 e2e3 c6e5 d2e2 e5f3 e2f3 f7f3 c7d9 e10d9 e3f3 i8i6 f3f4 d9d5 e1f2 d5a5 f4c7 f10g9 c7d6 g9g10 d6e6 a5d2 f2f3 d2d3 f3g2 i6i3 g3h1 d3c2 h1f2 h5h4 e6g4 h4h3 g4h3 i3h3 g2h3 c2f2 h3g4 f9g7 g4g5 f2f5 g5h6 g7i8 h6h7 g10h9 h7i6 f5h3 i6i7 h3h6
d3d5 i8i6 i3i5 d8d6 c3c4 h8h7 f3f5 c8c6 e3e4 g9h8 h3h4 b10c8 g3g5 f8f6 f2h3 g8g6 h2g4 h9f8 b1c3 f10g9 d2b1 c6d5 c4d5 b9d8 g1e3 h10g8 h1g3 d8f7 b2c4 a8a7 a3a5 f8d7 b3b5 d9f8 b1b2 e8e7 b2b3 g6f5 e4f5 b8b6 e1f2 f7e5 c2e4 d7c5 e3c5 e5c4 c5d4 c4a5 b3b4 a5b7 e4f3 b7c5 e2b2 c10e8 f1c4 g10h9 g5f6 g8f6 g4f6 e7f6 d4e3 h8g7 e3h6 c8e7 h6g7 f9g7 c1h6 g7h6 i5h6 i10g10 i1e1 c5d7 e1e6 c9b8 i2i3 d7e5 c4e2 h9e6 d5e6 e5f3 g2f3 d6d5 c3d5 a9d9 d1b3 b8e5 b2c1 e7d5 f3d5 e10f10 f2f1 f8e7 d5e4 a10c10 a2c2 c10c2 e2c2 d9d4 b4c3 e5g3 c3d4 d10d4 h3g3 e9a9 b3d3 g9d9 d3d4 d9d4 g3e2 d4e5 e2f3 i9g9 a1a3 e7d6 a3c3 d6e4 c3c10 f10f9 c2c9 f9f8 e6e7 f8g8 c10g10 a9c9 g10g9 c9g9 c1c4 g8h8 c4e4 e8b5 f1f2 e5b2 f2e1 b2c1 e1f2 c1f1 f2e3 g9c9 e3f4 b5c6 e4e6 c9b8 f4e3 f1c1 e3f2 c6f3 e6f6 h8i8 f6f8 b8f8 e7f8 f3c6 i3e3 c1c2 f2e1 c2f5 f8f9c c6f9 e3e7 a7a6 e7a7 f5e4 e1d2 a6a5 a7g7 e4h4 g7g2 h4d4 d2e1 d4e3 g2e2 e3e2 e1e2 a5a4 e2f3 a4a3 f3g4 b6b5 g4g5 b5b4 g5f6 b4b3 f6g5 a3a2h g5f6 b3b2q f6e6 a2a6 e6d5 b2c3 d5e4 a6f6
d3d5 i8i6 i3i5 d8d6 c3c4 h8h7 f3f5 c8c6 h3h4 c6d5 c4d5 b10c8 e3e4 g8g6 f2h3 g9h8 g3g5 f8f6 h2g4 h9f8 h1g3 b9d8 g1e3 d8f7 b1c3 f10g9 d2b1 h10g8 a3a5 a8a7 b2c4 f8d7 b3b5 d9f8 g4h6 f7e5 c4e5 d7e5 e2f2 c10b9 c3e2 g10h9 e2d4 f8d7 c1b2 e10d9 d4e6 b8b6 a5a6 a9a8 b1a3 c8e7 h6g4 g6f5 e4f5 d9c10 g3e4 f6g5 g4e5 d6e5 h3g5 e7d5 d1d5 c9g5 e3g5 g8e7 d5d2 e7f5 f2f5 h9e6 f5f2 i10f10 g2f3 g9h9 i2g2 h8g7 d2e3 e8e7 c2b3 c10b10 a1d1 a8f8 g2g3 a10a8 b3e6 h9e6 d1d7 d10d7 b2c3 a8d8 a2d2 d7c7 d2d8 f9d8 i1i3 e6f5 a3b4 b9a8 f2c2 d8e6 e3e2 f8d8 f1g2 d8d4 b4b3 a8d5 c3d4 d5b3 c2c7 e9c7 d4b2 b3c4 f3g4 c4e2 g4f5 e6f5 g2e2 g7f6 g3c3 c7b8 c3f3 f5e6 e2c4 b8b9 f3f2 f10c10 c4e2 f6h8 i3f3 i9c9 f3f8 c9c2 e2d3 c2f2 f8f2 b9c8 e4g3 h8f6 g5f6 e7f6 d3h7 c8d7 h7d7 e6d7 g3e4 d7e6 e4f6 e6c5 f2f3 c5c4 b2a1 e5e4 f6e4 c10e10 e1f2 e10e4 f2g3 c4b5 h4h5 i6h5 f3f5 b5c4 f5h5 c4e3 a1f6 b10b9 h5h9 b9c8 h9h4 e3f5 g3f3 e4h4 f6h4 f5h4 f3e4 h4i5 e4e5 i5g6 e5e4 g6e7 e4d3 e7d5 d3e2 d5e4 e2f1 b6b5 f1g2 b5b4 g2h2 b4b3 h2i3 b3b2q i3h3 b2a3 h3g4 a3g3 g4h5 e4g5
d3d5 i8i6 i3i5 d8d6 f3f5 c8c6 c3c4 c6d5 c4d5 b10c8 b1c3 h8h7 h3h4 g9h8 g3g5 f8f6 f2h3 g8g6 e3e4 f10g9 h2f3 b9d8 b3b4 b8b6 a3a5 b6a5 a2a5 d8f7 d2b3 a8a6 h1g3 e9c7 a5a6 a9a6 a1a6 a10a6 e2a6 d9b8 a6a3 h10g8 f3d4 f7e5 d4e6 c7e9 b2c4 h9f8 g1d4 f8e6 f5e6 g10i8 f1e2 i10f10 i1f1 c9e7 g2h1 f9d8 i2f2 g9h10 c4e5 d6e5 d4c5 i9f9 c3b5 d8b7 d1d3 f6g5 c1g5 e7g9 f2f9 f10f9 f1f3 e8e7 b5c3 c10e8 e1f2 e10f10 f2g1 f10g10 g1h2 g10h9 e2e1 c8d6 c2d1 f9f3 h1f3 h8g7 c5e3 h10e10 c3a4 d6b5 a3a1 d10a10 a4c5 a10a1 b3a1 b7c7 a1b3 h9h10 d1e2 g9h8 d3d1 i8g10 f3g2 b5d6 g2f1 e8b5 e2b5 d6b5 g3i4 g8f6 i4h6 b5d6 h3f2 h10h9 f2f3 g10e8 h6g4 e9g9 g5h6 g7h6 e3h6 f6g4 f3g4 d6b5 b3a5 c7d6 h6e3 h8g7 e3h6 g7f6 e1d2 g9f9 a5b3 b5d4 b3c3 b8c7 h2h1 e10f10 d2f2 f6h8 f2f9 f10f9 g4e3 c7d9 f1h3 e8b5 h3g4 d9e8 c5d7 h8f6 e3g2 b5d7 e6d7 e8f7 d1b1 e7e6 b1a2 h9i9 d5e6 d4e6 c3d5 d6d5 a2d5 e6f4 h6f4 e5f4 g2f3 f6d8 e4e5 g6g5 e5e6 f7g6 h4g5 f9a9 g4f5 a9a1 h1g2 a1b2 g2f1 b2c1 f1e2 c1b2 e2d1 g6g5 f3g5 d8g5 d7d8 b2a1 d1e2 f4f3 d5f3 a1b2 e2f1 b2a1 f1g2 g5d8 f5e4 a1a2 g2f1 a2a1 f1g2 a1a2 g2f1 a2a1 f1e2 a1a2 e2d1 a2a4 e4c2 a4a1 d1e2 a1a6 e2f2 a6a7 f2e2 a7a6 e2d1 a6a1 d1d2 d8g5 d2e2 a1a6 e2f2 a6b6 f2g2 b6e6 f3f9 i9h8 f9h7 h8g9 h7g7 e6g8 g7g8 g9g8 g2h3 g5d2 b4b5 d2e1 h3i4 e1f2 c2g6 g8h8 g6d9 f2a7 d9e10 h8i7 i4h4 a7f2 h4g5 f2i5 b5b6 i5g3 e10d9 i7h7 d9e10 h7g7 e10i6 g7f7 i6f3 f7e6 f3g4 e6d6 g4f3 g3f2 b6b7 f2a7 g5f6 a7c9 f6f7 d6d7 f3h1 d7c7 f7e6 c9g5 e6e5 g5e3 e5f6 e3c5 f6f7 c5e3 f7e8 e3f4 e8e7 f4g5 e7e6 g5c9 e6f7 c7d7 h1f3 c9g5 f3c6 d7c7 f7e8 g5c9 c6e4 c9h4 e8f7 h4g5 f7e6 g5c9 e4d5 c9a7 e6f7 a7d4 f7e8 d4f6 e8f7 f6c9 f7e8 c9g5 d5e4 g5f6 e8f7 f6c9 f7e8 c9b10 e8f7 b10c9 f7e6 c9i3 e4f3 i3h2 e6e7 h2i3 e7e8 i3g5 e8f7 g5d8 f7e8 d8c9 e8f7 c7d7 f3d5 c9d10 f7f6 d10b8 d5e4 d7d6 e4f5 b8c9 f6g6 d6c7 f5e4 c7d7 e4g2 d7e6 g6g7 e6e7 g7g6 e7d7 g6f5 d7c7 f5e5 c9a7 e5e6 a7c9 g2f3 c9g5 e6f7 g5f4 f7e6 f4g5 f3c6 g5c9 c6h1 c9b10 e6f7 c7d8 f7e6 d8c7 e6f7 c7d8 h1g2 b10c9 f7e6 d8c7 g2d5 c9b10 e6e5 b10c9 d5h1 c9a7 e5f6 a7c9 f6f7 c7d7 h1g2 c9d10 f7f6 d7d6 g2h3 d10c9 f6f5 d6c7 h3g2 c7d6 f5e4 d6c7 e4e5 c9a7 g2d5 a7c9 d5e4 c9a7 e5f6 a7c9 f6f7 c9d8 f7e6 d8c9 e4g2 c9b10 e6f7 c7d8 g2f3 d8c7 f7g6 b10c9 g6g7 c7d8 g7f6 d8c7 f6e5 c9a7 e5e6 a7c9 f3g2 c9b10 e6f7 c7d8 g2h3 d8c7 h3c8 b10g5 f7e6 g5f4 e6d5 c7b6 d5e6 b6c6 e6f5 f4b8 f5f6 c6c7 f6e6 c7c6 e6e7 c6c7 e7e6 c7c6 c8d9 b8c9 d9e10 c9d10 e6e7 c6c7 e7e6 c7c6 e6f6 d10c9 f6f7 c6c7 f7e6 c7c6 e6e5 c9b8 e5f6 b8a7 f6e7 a7c9 e7e8 c6c7 e10d9 c9a7 e8e7 a7b8 e7e6 c7c6 e6f5 c6c7 f5e6 c7c6 d9c8 b8c9 e6f7 c6c7 f7e6 c7c6 e6e5 c9d8 e5f5 d8c9 f5g6 c6c7 g6f5 c9a7 f5e6 c7c6 e6e7 a7c9 e7e8 c6c7 c8e10 c9h4 e8f7 h4c9 f7e6 c7c6 e6f5 c6c7 f5e5 c7c6 e10d9 c9b8 e5f6 b8c9 f6f7 c6d7 d9c8 d7d8 f7e6 d8c7 e6d5 c9a7 c8d9 c7d8 d9c8 d8c7 c8d9 c7d8 d9e10 d8c7 e10c8 a7b8 d5c5 b8a7 c5b5 a7e3 b5a6 e3c5 c8d9 c5e3 d9c8 e3g1 c8i2 g1e3 i2h1 e3c5 h1e4 c5g1 e4f3 g1c5 f3h1 c5d4 h1f3 d4e3 a6b5 e3a7 b5a6 a7c5 a6b5 c5f2 f3c6 f2e3 b5a6 e3g1 c6h1 g1c5 h1i2 c5e3 i2g4 e3f2 g4h3 f2e3 h3f1 e3d4 f1g2 d4g1 g2c6 g1f2 c6e8 f2c5 e8g6 c5g1 g6d9 g1e3 d9g6 e3c5 g6e4 c5f2 e4g2 f2c5 g2f3 c5f2 f3d5 f2c5 d5h1 c5e3 a6b5 e3f2 h1f3 f2e3 f3g2 e3g1 b5a6 g1c5 g2f3 c5g1 f3e2 g1c5 e2d3 c5e3 d3h7 e3c5 h7c2 c5g1 c2f5 g1c5 f5c2 c5e3 c2d3 e3c5 d3b5 c5f2 b5d3 f2c5 d3e2 c5g1 e2c4 g1e3 c4d5 e3c5 d5g2 c5f2 g2c6 f2e3 a6b5 e3a7 b5a6 a7c5 c6g2 c5g1 a6b5 g1e3 g2c6 e3f2 b5a6 f2c5 c6a4 c5f2 a4b3 f2g1 b3g8 g1e3 g8a2 e3f2 a2c4 f2c5 c4b5 c5e3 b5e2 e3c5 e2d1 c5e3 d1c2 e3c5 c2g6 c5f2 g6e8 f2e3 e8d9 e3f2 d9f7 f2c5 f7d5 c5e3 d5a2 e3g1 a2b3 g1c5 b3d5 c5g1 d5e4 g1d4 e4c2 d4e3 c2b3 e3f2 b3c4 f2g1 c4g8 g1c5 g8h7 c5f2 h7e10 f2g1 e10f9 g1f2 f9b5 f2e3 b5e8 e3g1 e8g6 g1d4 g6i8 d4e3 i8e4 e3g1 e4f5 g1d4 f5h7 d4f2 h7e10 f2c5 a6b5 c5d4 b5a6 d4c5 e10g8 c5g1 g8f9 g1e3 f9g8 e3d4 g8f9 d4e3 f9b5 e3d4 b5a4 d4e3 a4d1 e3g1 b7b8 c7b8 d1c2 g1f2 c2b1 f2e1 b1a2 e1d2 a2b1 d2c1 b1a2 c1b2 a2b1 b2a1 b1a2 a1b2 a2b1 b2a1 b1c2 a1c3 c2d1 c3a1 d1c2 a1c3 c2d1 c3e1 d1e2 e1d2 e2d1 d2c1 d1c2 c1d2 c2b1 d2c1 b1a2 c1b2
d3d5 i8i6 e3e5 d8d6 e5d6 c8c7 d6c7 d9c7 d2e4 f8f7 c3c5 h9g7 g3g4 b8b6 c5b6 c7b6 b2c4 b6d7 b3b4 b10c8 c2a4 d7f6 f3f5 f9f8 a2d2 f6e4 f2e4 e8e7 a4g10 f10g10 i3i5 g7e8 g1c5 c9b8 h1g3 c8d6 e4f3 g8g6 b1c3 h8h7 c4d6 e8d6 c3e4 g9h8 e4d6 b8d6 c1b2 h8b2 d2b2 h10g8 g3e4 d6c5 b4c5 b9c7 d5d6 a9d9 e1f2 a8a6 d1b3 g6f5 g4f5 c7e8 a1d1 e7d6 c5d6 e10f10 h2g4 e8d6 e4d6 d9d6 f3e5 d6d1 f1d1 g10b5 b3e3 b5e2 d1e2 f7f6 e5e4 e9e7 b2b6 i9e9 i1d1 d10a7 b6e6 e7c9 e6e9 c9e9 g4f6 g8f6 e4f6 c10h5 g2f3 e9c9 e3a7 a10a7 e2e5 i10g10 f3h5 i6h5 e5d4 a7f7 d4d10 c9d10 d1d10 f10f9 d10d6 f7c7 f2f3 c7c3 f3f4 c3a3 d6d8 a3a4 f4f3 a4a3 f3e4 g10e10 e4f4 e10e8 d8e8 f8e8 f6h7 e8f7 i2c2 a3h3 c2c7 h3h4 f4e3 h4h3 e3f2 f7d6 c7c9 f9e8 h7f6 e8d8 c9c10 a6a5 c10a10 h3h4 a10a5 d6e4 f6e4 h4e4 f5f6 e4i4 a5h5 d8d7 f6f7 d7e6 f7f8 i4f4 f2g3 f4f8 g3g4 f8g8 h5g5 g8h8 g5g6 e6f7 g4g5 h8h1 g6h6 h1g1 g5h5 f7g7 h5i6 g1a1 h6h10 a1a3 h10g10 g7h8 g10h10 h8i8 h10h4 a3a7 h4h7 a7a6 h7h6 a6a7 h6h10 a7i7 i6h6 i7c7 h10i10 i8h9 i10f10 c7c6 h6i7 c6c7 i7h6 c7c6 h6g5 h9h8 f10f6 c6c7 g5h6 c7h7 h6i6 h7i7 i6h5 i7d7 h5h6 d7h7 h6i6 h7i7 i6h5 i7d7 f6a6 h8i7 a6i6 i7h7 i6h6 h7i7 h6i6 i7h7 i6h6 h7i7 h6h10 d7d5 h5g6 d5d6 g6h5 d6d5 h5g6 d5d6 g6g5 d6d5 g5h4 d5d4 h4g5 d4d5 g5h4 d5d4 h4h3 i7i6 h10i10 i6h7 h3i3 d4b4 i10i9 h7g6 i5i6 b4b1 i3h2 g6h6 i6i7 h6h7 i9i10 b1b8 h2h3 b8i8 i10i8 h7i8 h3g4 i8i7
d3d5 i8i6 i3i5 d8d6 f3f5 c8c6 e3e4 b10c8 h3h4 c6d5 e4d5 g8g6 f5g6 e8e6 d5e6 h9g7 c3c4 g7e6 b1c3 g10i8 f2g4 d9d8 g2e4 c8e7 h2i4 i8g6 e4g6 e7g6 i4h6 h10g8 d2e4 g6e5 g4h3 d8c8 b2d3 c10g6 e4d5 g6d3 c2d3 b9c7 d5b4 e5d3 d1d3 c8d7 c3d5 c7d5 c4d5 e6c5 d3g6 g8h6 e2e9 f10e9 i2e2 c9e7 c1h6 d10d9 g6f5 e10d10 g1d4 d10c9 g3g5 a10c10 h1f2 c9b10 f2g4 d7d8 e1f2 f9g7 f5f3 g7g6 f2g2 e9f9 g2h2 i10e10 a3a4 a9c9 b4b5 f8f7 g4f6 c5d7 f6d7 d8d7 a1e1 g9f10 e2e3 f10d8 f1d3 e7f8 h6f8 e10e3 e1e3 d7f8 i1f1 f9h7 f3e2 g6h5 e3e6 i9e9 e6e9 d8e9 f1f6 d9d7 f6h6 h7d3 e2d3 d7h3 d3h3 c9c2 a2c2 c10c2 h2i1 c2c1 i1h2 c1c2 h2i1 h5f4 h3h1 c2c1 h1c1 f4g2 i1i2 g2g3 i2i3 g3g2 i3i2 g2g3 i2i3 g3g2 i3i2
f3f5 d8d7 g3g4 e8e6 i3i5 i8i6 h1g3 g8g6 f5g6 d9e7 h3h5 f8f7 h5h6 f7f6 c3c5 h9f8 b1c3 f8g6 d3d5 c8c7 a3a5 c10f7 c2g6 e7g6 g2i4 g6f8 e3e4 h10g8 b2c4 b9d8 b3b5 b10c8 f2h3 f7i4 h2i4 d8f7 d1b3 d7d6 c1a3 d6c5 g1c5 f8d7 c5g9 i9g9 d5e6 d7e6 d2e3 a8a6 b5b6 c9e7 b6c7 e7a3 c7b8 a9b9 b3a3 f9f8 a2b2 b9b8 a1d1 d10c9 b2b8 c9b8 g3f5 g10b5 e2b2 f7e5 i2d2 e5c4 e3c4 g8e7 c3b5 a6b5 f5d4 e6f7 d4b5 a10a6 g4g5 e9a9 i1i2 e7g6 i2f2 g6e5 c4b4 f8e8 d2d5 b8a8 a3c3 c8e7 d5c5 g9c9 c5c9 a9c9 c3c9 e8c9 i4g3 c9e8 b5c3 a6e6 b4c5 f10c7 f1b5 a8c8 c5e6 c8e6 h3g2 e6c8 c3d5 e7d5 d1d5 i10g10 f2f6 f7g5 f6f5 g5f5 e4f5 e5f7 e1f2 e10f9 b2d4 c7b7 g2f3 g10b10 b5e2 f9g10 f2g2 g10h9 g2h3 b10g10 f3h4 g10g9 d5b5 b7d7 d4d7 e8d7 b5b4 c8c3 b4g4 g9g4 e2g4 d7f6 g4a4 f6g5 h3i3 c3e3 h4g2 g5h5 i3h2 e3e5 a4b3 h5g4 h2i2 h9g8 a5a6 e5a5 h6h7 g8g7 b3c4 g4g5 g2h3 g5h7 h3g4 a5d2 g3e2 d2a5 c4e6 h7g8 e6a10 a5a2 g4f4 g8f6 a6a7 f6g5 a10d10 g7h7 d10e10 h7g7 f4g5 f7g5 e10e7 g5f7 i2h3 a2a6 f5f6 g7g6 e2f4 g6g5 h3g3 a6a4 f4g2 a4a2 g2h4 a2a1 h4f3 g5g6 e7e4 g6f6 a7a8 f7d6 e4h4 f6e6 h4d8 a1i1 g3g2 i1i4 g2f2 i4i5 f2e3 i5c5 f3d4 e6f7 d8f10 f7g6 f10g9 g6f7 a8a9q d6f5 e3e4 c5d4 e4f5 d4d5 a9e5 d5e5 f5e5 h8h6 g9f9 f7e7 f9i6 h6h5 i6h5 e7d7 h5d9 d7e7 d9e9 e7f7 e5f5 f7g8 f5g6 g8h8 e9f9 h8i8 g6g7 i8i7 f9h7
d3d5 i8i6 i3i5 d8d6 c3c4 h8h7 f3f5 c8c6 h3h4 g9h8 e3e4 g8g6 d5c6 e8e6 f2h3 d9e7 g3g5 f8f6 b3b5 g6f5 e4f5 c10h5 h2g4 h9g7 g5f6 e7f6 f5e6 h5g4 h3g4 g7e6 g2d5 f6g4 e2g4 e6f4 g1e3 f4d5 c4d5 i9g9 g4h3 d10d8 i2e2 d8h4 e3f2 h4h3 f1h3 c9e7 h1g3 h10g8 d2c4 i10h10 a3a5 f9e8 f2b6 b9c7 c2f5 e8c9 b6d4 h8d4 c4d4 h7h6 i5h6 g8h6 f5a10 a9a10 b5b6 h6g8 h3f5 c7e8 f5f10 e9f10 e2e7 g8e7 c1i7 b10c8 b1c3 e10d9 b2c4 f10e9 i7g9 e9g9 g3e4 a10f10 d1i6 e7f5 d4b3 h10h6 i6i5 g10h9 i1f1 c8e7 a1d1 h6h3 a2f2 g9h8 b3b4 f10i10 i5g5 i10g10 g5f4 h3h4 f4i1 h9f7 f2f4 h8h6 f4h4 f5h4 d1d2 f7h5 b4d3 h4f3 f1f3 h5f3 c4d6 e8d6 i1d6 h6d6 e4d6 c9d8 d3e3 f3i6 d2i2 i6f9 e3c4 e7c6 d5c6 d8c6 i2i9 d9e10 i9i5 a8a7 b6b7 g10g1 e1f2 g1c1 d6c8 c1c2 f2g3 c2c1 i5i10 e10d9 i10i9 d9e10 c4d5 f9g10 i9e9 e10f10 d5f6 g10f9 c3e2 c1c5 f6f7 c6d7 e9b9 c5e5 e2f4 e5e8 f4g6 d7d8 b9b10 f9e10 b10e10 f10e10 g6f8 e8f8 f7f8 e10f10 c8b10 d8e7 f8e7 f10g9 b10d9 g9h8 e7f7 h8i7 d9f8 i7i8 f7g7 i8i9 g7h9
3 white wins
3 draws
4 black wins
d3d5 d8d6 i3i5 i8i6 c3c4 h8h7 f3f5 c8c6 h3h4 g9h8 e3e4 g8g6 d5c6 b8b7 c6b7 a8b7 f2h3 e8e6 g3g5 f8f6 h1g3 h10g8 b1c3 d9b8 h2g4 b10c8 b3b5 f9f8 d2b3 h9g7 a3a5 f6g5 c1g5 c9g5 h4g5 g6f5 e4f5 g7f5 g3f5 e6f5 c2f5 g10d7 g2e4 a9a5 f5d7 d10d7 e4f5 d7d8 a2a5 a10a5 a1a5 d8a5 g1d4 a5d8 i2f2 i9f9 e1d2 h8d4 b3d4 f8g7 f5h7 g7h7 f2f9 f10f9 f1f9 e10f9 e2e9 d8e9 i1e1 e9d10 b2d3 f9g9 c3e4 b9c7 d3f4 h7f8 d2c1 b8d7 g4f6 d7e7 h3h4 d10a7 d4c2 i10h10 h4i6 c10f7 d1d4 a7d4 c2d4 c7e6 f4e6 f7e6 c4c5 h10h3 e4f2 h3h10 f2e4 h10h2 d4f3 h2h3 f3d4 e7f5 d4f5 e6f5 c5d6 c8e9 d6d7 e9d7 e4d6 g8f6 g5f6 f5g6 i6g7 f8g7 f6g7 d7c5 e1e7 h3c3 c1b2 c3b3 b2a2 g9g8 d6b7 b3b5 b7d6 b5b8 e7c7 g6b1 a2a1 c5e6 c7e7 e6g7 e7b7 b8b7 d6b7 b1e4 b7c5 e4d5 c5d7 g8h8 a1b2 h8i7 b2c3 g7e6 d7f6 d5b7 f6d7 i7i6 c3c4 i6i5 d7c5 e6c5 c4c5 i5h4 c5d6 h4g5 d6e5 b7c8 e5e4 g5f6 e4d5 c8f5 d5d4 f6e6 d4c5 e6e5 c5c4 f5e4 c4c5 e4d5 c5b5 e5d6 b5b4 d5g8 b4c3 d6d5 c3d3 g8h7 d3e3 d5e5 e3f3 h7i6 f3e3 i6g8 e3f3 g8i6 f3e3 i6h5 e3d3 h5f7 d3e3 f7d5 e3d3 d5g8 d3e3 g8h7 e3f3 h7f5 f3e3 f5e4 e3e2 e5f4 e2d2 e4h7 d2c3 f4e5 c3c4 h7e4 c4c5 e4d5 c5b5 e5d6 b5b4 d5e6 b4c3 d6e5 c3d3 e6f7 d3e3 f7g6 e3f3 g6h5 f3e3 h5e8 e3f3 e8h5 f3e3 h5d9 e3f3 d9c8 f3e3 c8f5 e3f3 f5b9 f3e3 b9h3 e3f3 h3c8 f3e3 c8f5 e3f3 f5b9 f3e3 b9a8 e3d3 a8d5 d3e3 d5e4 e3e2 e5d4 e2f2 e4b7 f2g3 d4e5 g3g4 b7c6 g4g5 c6f3 g5g6 f3d5 g6g5 d5e4 g5g4 e4c6 g4g5 c6f3 g5g6 f3d5 g6g5 d5e6 g5g6 e6c4 g6g5 c4e2 g5g6 e2c4 g6g5 c4e6 g5g6 e6h9 g6g5 h9i8 g5g4 e5e4 g4g5 e4e5 g5g4 i8e4 g4g5 e4f5 g5h5 e5f4 h5h6 f4e5 h6h5 e5f4 h5h6 f5i8 h6g7 f4e5 g7f7 i8c2 f7e7 c2f5 e7f7 f5d3 f7e7 d3c4 e7d7 c4b5 d7e7 b5c4 e7d7 c4b5 d7e7 b5c6 e7f7 c6e4 f7e7 e4d5 e7d7 d5f3 d7e7 f3g4 e7f7 g4h5 f7e7 h5i4 e7d7 i4g2 d7e7 g2h3 e7f7 h3i4 f7e7 i4h5 e7d7 h5d1 d7e7 d1b3 e7d7 b3a4 d7e7 a4c6 e7f7 c6e4 f7e7 e4f5 e7f7 f5d3 f7e7 d3g6 e7d7 g6h5 d7c6 h5e8 c6c5 e8f9 c5c4 f9h7 c4c5 h7e4 c5c4 e4g6 c4c5 g6e4 c5c4 e4c6 c4d3 c6d5 d3e3 d5c4 e3f3 c4e6 f3e3 e6c4 e3f3 c4e6 f3e3 e6h3 e3f3 h3d7 f3e3 d7g4 e3d3 e5d5 d3e3 d5e5 e3d3 e5d5 d3e3 g4h3 e3f3 d5e5 f3e3 h3g2 e3f2 g2b7 f2e3 b7c6 e3d3 c6b5 d3e3 b5a6 e3f3 e5f5 f3e3 f5e5 e3f3 a6c4 f3g4 e5f6 g4f4 c4d5 f4e3 f6e5 e3d3 d5h9 d3e3 h9i8 e3f3 i8f5 f3e3 f5g6 e3f3 e5f5 f3e3 f5g4 e3d4 g4f4 d4d5 g6f7 d5d4 f7g8 d4d3 f4e5 d3e3 g8i6 e3d3 e5d5 d3e3 d5e5 e3d3 e5d5 d3e3 i6g4 e3f4 g4d7 f4e3 d5e5 e3f3 d7i2 f3e3 i2h1 e3d3 e5f4 d3d4 h1g2 d4d3 f4e5 d3e3 g2b7 e3d3 e5d5 d3e3 d5e5 e3d3 b7a6 d3e3 a6b5 e3f3 e5f5 f3e3 f5e5 e3f3 b5d7 f3e3 d7e6 e3d3 e5f4 d3d4 e6h9 d4d3 h9d5 d3d4 d5h9 d4d3 f4e5 d3e3 h9i8 e3f3 e5f5 f3e3 f5g4 e3d4 g4f4 d4d5 i8h9 d5d4 h9e6 d4d3 e6g8 d3d4 g8f7 d4d3 f7g8 d3d4 g8e6 d4d3 e6h9 d3d4 h9g8 d4d3 g8e6 d3d4 e6a2 d4d3 a2d5 d3d4 d5a2 d4d3 f4e5 d3e3 a2h9 e3d3 h9a2 d3e3 a2b1 e3f3 e5f5 f3e3 f5e5 e3f3 e5d4 f3g4 d4e4 g4g5 e4e5 g5g4 b1d3 g4f3 e5f5 f3e3 d3e4 e3d4 f5f4 d4c5 e4f3 c5d4 f3g2 d4d3 f4e5 d3e3 g2h1 e3d3 e5d5 d3e3 h1i2 e3f3 d5d4 f3f4 i2d7 f4f3 d7b9 f3f4 b9i2 f4f3 i2f5 f3f4 f5c8 f4f3 c8e6 f3f4 e6c8 f4g5 d4e5 g5g6 c8g4 g6g5 g4b9 g5g6 b9c8 g6g5 c8i2 g5g6 i2e6 g6g5 e6b9 g5g6 b9h3 g6g5 h3d7 g5g6 d7e8 g6g5 e8d7 g5g6 d7e8 g6g5 e8b5 g5g4 b5e2 g4g5 e2d3 g5g4 d3e2 g4g5 e2d1 g5g6 e5f4 g6f6 d1g4 f6g6 g4c8 g6f6 c8i2 f6g6 f4e5 g6g5 i2a10 g5g6 a10b9 g6g5 b9c8 g5g6 c8g4 g6g5 g4i2 g5g6 i2d7 g6g5 e5d4 g5f6 d7b5 f6e6 d4c5 e6e5 b5c4 e5e4 c4b3 e4e3 b3c4 e3f3 c5d4 f3g4 d4c3 g4f4 c4b3 f4e3 b3d1 e3f4 d1c2 f4e3
d3d5 i8i6 i3i5 d8d6 c3c4 h8h7 f3f5 c8c6 h3h4 b10c8 b1c3 g9h8 g3g5 f8f6 h2f3 g8g6 e3e4 h10g8 h1g3 c6d5 c4d5 b9d8 f2h3 h9g7 a3a5 d8f7 b3b4 g7h5 d2b3 f9f8 b2c4 e9h9 g1e3 f7e5 c1b2 a8a7 e1d2 f8f7 f1f2 b8b7 f3d4 d9b8 d4e6 c9e7 g3i4 a9c9 i4h6 g8h6 i5h6 c10b9 c2d3 c8e9 c4e5 d6e5 g2f3 e9c8 d2c2 c8d6 c2b1 a7a6 a2a3 h5f4 e3f4 e5f4 i2i5 a10c10 h3f4 g6f5 e4f5 c9c3 b2c3 c10c3 b3c3 f6g5 h4g5 h8c3 a3c3 d6b5 d3b5 a6b5 f4d3 b8a6 d1b3 h9h10 f2h4 i9d9 i1c1 f10g9 h4i4 b9e6 f5e6 f7d8 e2e4 d10f8 c3c8 d8b9 g5g6 f8h6 c8c10 e10e9 i5f5 h6g6 a1a2 g6i4 e4i4 d9d10 c10d10 b9d10 d5d6 e7d6 a2c2 g9e7 c2c10 d10d9 b3c3 d6c7 c10a10 a6b8 i4d4 c7d6 c3d2 b8a10 d3c5 h7h6 c5d6 e7d6 d4d6 h10d6 d2d6 g10i8 d6g9 e9d10 g9g7 d9e9 c1d1 d10c10 g7e9 i8f5 b1b2 c10b10 d1d9 i10c10 e9d8 a10c9 d9c9 c10c9 d8f10 b10a9 f10f5 h6h5 f5b5 h5h4 b5b7 i6i5 b7a6 a9b10 a6b5 b10c10 b5i5 h4h3 i5h4 c10d9 f3b7 d9c10 h4h3 c10b9 h3h8 e8e7 h8a8 b9b10 a8d8 b10c10 b7a8 c10b10 d8d10 b10a9 d10c9 a9a8 c9b10 a8a7 b10b9 a7a6 b9b6
d3d5 d8d6 i3i5 i8i6 f3f5 c8c6 d5c6 e8e6 g3g4 h8h7 c3c4 b10c8 h1g3 b8b7 c6b7 a8b7 g2b7 d9b8 b7c8 b8c8 b3b4 b9c7 h2f3 g8g6 f5e6 h9g7 b1c3 g7e6 a3a5 a10b10 b2d3 c10a8 b4b5 g9h8 c1b2 d6d5 c2b3 f9g8 b5b6 g10c6 b6c7 d5c4 b3c4 c6f3 f2f3 a8f3 d2f3 f8f7 e3e5 e6c7 g1b6 c9e7 f3e4 i9f9 c3b5 e7d8 b5d6 c8e7 h3h4 h10i8 d3c5 d10d9 f1h3 i8g7 i1f1 g7e6 i2f2 e6c5 b6c5 c7e6 c5e3 h8i7 g4g5 f10g10 a5a6 e10f10 a6a7 d8c7 c4b5 b10b5 d6b5 d9d1 a1d1 c7d8 b2a3 e7d9 d1d7 d9e8 e4d6 g10h9 d6e8 e9e8 d7f7 g8f7 b5d6 d8a5 e3d2 f7d6 d2a5 f10g10 f2f9 a9f9 a3d6 h9g8 a2b2 e6d4 f1f9 e8f9 e2e4 f9a4 a5c3 a4a7 b2b9 i7f10 e4d4 a7f7 b9b8 g8f9 h3c8 h7h6 e5e6 f7h7 b8b7 h7g8 b7g7 i10i8 d4a4 g10h9 g7g8 f9g8 c8b9 f10g9 a4b4 h9i10 d6g9 g8e10 b4f4 i8g8 g9e7 e10h10 e7h10 g8g9 b9g9 h6h5 f4f7
f3f5 d8d6 i3i5 i8i6 c3c4 h8h7 b1c3 e8e6 f5e6 e9e6 d3d5 e6e9 h2f3 b8b7 f3d4 g9h8 g3g4 d9b8 h1g3 c9f6 f2e4 f9e7 g1i3 f6i3 i2i3 c8c6 h3h4 h9g7 b2d3 b9c7 b3b5 c10g6 e4f4 c6d5 c3d5 c7d5 c4d5 a8a6 b5a6 a9a6 c1b2 b10c8 e1f2 g10d7 h4h5 i6h5 g4h5 g6e8 f1h1 h10f9 d2e4 f9d8 d3b4 a6a9 d4f3 g7f9 g3f5 d7f5 b2h8 f10h8 e4f5 e8d7 f5d4 d8f7 h1h4 e10f10 d4e4 a9a5 i3g3 c8b6 a3a4 d10d8 i1i4 f10g9 d1d4 f9g7 h5h6 g7i6 h4i3 i10c10 c2b3 g9h10 e2d1 g8g6 f2g1 h8d4 d1d4 e9h9 e4f6 g6g5 f6e7 f8e7 f4e2 b6a4 b4d3 a4c5 d3c5 a5a2 a1a2 a10a2 b3a2 c10c5 a2b3 b8c7 d4d1 b7b6 f3d4 b6b5 g2h3 c7e8 h3d7 d8d7 d4e6 h9g8 i4f4 g8i10 e6c5 d6c5 d1c2 i6h8 f4i4 c5c4 i4c4 b5c4 b3a4 d7d9 a4e8 d9e8 i3h3 i9i5 h3a10 h10h9 a10i10 h9i10 c2c4 f7e5 c4a6 g5g4 e2f4 e8c10 a6e6 i10i9 g3g4 c10c1 g1f2 c1d2 f4e2 e5g4 e6g4 d2d5 e2g3 i9i8 g3f4 d5d2 f2f3 d2d1 f3f2 d1d2 f2f3 d2d1 f3g2 d1c2 g2g3 i5i3 f4h3 i3h3 g4h3 c2c7 g3f3 h8g6 h3i2 i8h8 i2i10 c7b7 f3f2 b7b2 f2e1 b2a1 e1d2 a1a5 d2d3 a5f5 d3c3 f5f6 c3d3 h8g9 i10d5 g6f8 d5i5 e7e6 d3e2 g9g8 i5i10 g8f9 i10i5 f9e8 i5i4 e8d8 i4i5 e6e5 i5i10 f6f5 i10i3 d8d7 i3c9 d7e8 c9c7 f8d7 c7c10 e8e7 e2e1 f5d3 e1f2 e7f6 c10c6 f6g5 c6g2 g5h6 g2h3 h6g7 h3e6 d3d2 f2f3 d2d1 f3f2 d1d3 e6e7 g7g6 e7e8 g6f5 e8h5 f5f6 h5h6 f6f7 h6h5 d3g6 h5i5 d7c5 f2e1 h7h6 i5i10 f7f6 i10i3 f6e6 i3d8 g6g1 e1e2 g1g4 e2e1 c5d7 d8e8 e6d6 e8a8 h6h5 a8a6 d6e7 a6e10 e7f6 e1d2 h5h4 e10f9 f6e7 f9e10 e7d6 e10a6 d6e7 a6e10 e7d8 e10d10 d8c8 d10a10 c8d9 a10b9 d9d8 b9b10 d7c9 b10f10 d8c8 f10h8 c8b7 h8e5 h4h3 e5b5 b7c8 b5a6 c8d8 a6f6 d8e8 f6e5 e8d9 d2c3 g4g2 e5h5 c9e8 h5h9 d9d8 h9h4 d8c8 h4h5 c8d7 h5f5 d7d8 f5d3 d8e7 d3h7 g2g7 h7g7 e8g7 c3d4 h3h2q d4d3 e7d6 e3e5 d6d5 e5e6 g7f5 e6e7 f5d4 e7e8 h2e2 d3c3 d5c5 e8e9c e2c2
d3d5 d8d6 i3i5 i8i6 f3f5 c8c6 e3e4 b10c8 c3c4 g8g6 d5c6 e8e6 b1c3 h9g7 f5g6 d9e7 e4e5 c10g6 c2g6 e7g6 h2g4 h10g8 e5d6 d10d6 f2e4 d6d10 g4e5 g6e7 g1c5 e7e8 h3h4 g10i8 e4d4 f8f6 e5d7 e9d8 g2i4 g9c5 d4c5 e8e7 g3g5 b8b6 c5d4 c8e9 g5f6 g8f6 d7c9 d10c9 d2f3 a10d10 h1g3 d8f8 i2f2 e9f7 i4f7 e7f7 c1g5 f9e7 g3e4 g7h5 b2d3 b9a7 e4f6 i8d3 f6d7 d10d7 d4d3 d7d3 d1d3 i9d9 g5e7 f8e7 d3e3 h5g7 f3g5 f7g5 h4g5 f10e9 b3b5 c9c7 i1i4 a7c8 i4e4 e7g9 f2f7 i10f10 f7c7 f10f1 e2f1 e9c7 a2e2 d9e9 a1d1 c8d6 e4e5 a9d9 f1f6 c7b8 c6c7 b8c7 f6b10 e10f9 e3b6 c7b6 b10b6 f9g8 b6c5 g9f8 c3e4 g7f5 e4d6 f8i5 e2f2 i5g3 d1d2 g3g1 e1e2 g1g4 e2f1 g4i4 f1e1 i4i1 e1e2 d9c9 d6c8 e9e8 e5e3 e8c8 c5h10 c9c10 d2d10 c10d10 h10d10 i1c7 d10g10 g8f8 e3e4 c8d8 g10f10 f8g8 f10g10 g8f8 a3a4 c7d6 g10h10 f8f7 h10d6 d8d6 c4c5 d6d5 e4c4 i6i5 c5c6 f7e8 c4c3 a8a7 f2i2 f5d4 e2f1 d5f5 i2f2 f5g5 f2h2 e8d9 h2h8 d4f5 c3d3 d9c10 h8c8 c10b9 c8i8 g5g9 d3d7 a7a6 b5b6 i5i4 d7b7 b9c10 i8i10 c10c9 b7a7 c9b9 c6c7 g9h9 a7a6 b9c8 a4a5 c8b7 a6a7 b7c6 c7c8 f5e3 f1e2 e3f5 a7c7 c6b5 c8c9h h9c9 c7c9 f5d6 i10i5 e6e5 i5e5 b5a6 c9a9 a6b7 a9a7 b7b8 e5i5 d6c8 a7c7 b8c9 b6b7 c9b8 b7c8 b8c7 c8c9q c7d6 c9f6 d6c7 i5i7 c7c8 i7i8 c8d7 i8d8 d7c7 f6b6
f3f5 i8i6 i3i5 d8d6 c3c4 h8h7 b1c3 e8e6 f5e6 e9e6 d3d5 e6e9 h2f3 b8b7 f3d4 g9h8 g3g4 f9g9 h1g3 d9b8 a3a5 g10d7 b2d3 c8c6 b3b5 c6d5 c3d5 b10c8 d3f4 a8a6 b5b6 g8g6 c2a4 d7a4 d1a4 h10g8 c1b2 h9g7 g1i3 b9d8 g3e4 d8f7 i3c9 e9c9 h3h4 f7e5 g4g5 g7h5 d4f3 c10e8 a4a3 e8d7 g2h3 d10e9 e4d6 c8d6 b2e5 h8e5 f3e5 e9e5 f2f3 h5f4 f3f4 e5e8 a3d6 f8f6 e3e5 d7h3 f1h3 f6f5 d6a3 g9f8 a1d1 i9e9 d5c7 e8c8 d2c3 a10d10 a2d2 a9a10 i1f1 f10h8 e5e6 e10f10 d2d10 a10d10 d1d10 c9d10 c3d5 f10g10 d5d6 c8e10 d6f5 g6f5 a3f8 e9f9 e2b2 f9f8 b2h8 g8e7 h8g7 g10h9 i2d2 d10e9 h3c3 i10i8 h4h5 i8h8 e1f2 b8c6 d2d7 f8g8 g7h6 c6c5 f1e1 e9g9 c3f6 c5c6 d7d10 e10e9 e1d1 e9h6 f6h6 e7f9 d1d9 c6e7 d10e10 e7f8 e10e9 f8e9 d9e9 g9c5 f2g3 g8g9 c7e8 c5g1 f4g2 f5f4 g3f3 g1d1 f3f4 i6h5 f4g3 h8e8 e9e8 f9h8 g3h2 d1d6 h2i3 g9g8 e8e9 g8g9 g2h3 h9i8 i5i6 h8i6 e9e8 i6h8 h6f6 g9h9 e8d8 d6c5 e6e7 i8i9 e7e8 c5e3 f6g7 e3e1 g7g8 h5h4 i3i4 e1e7 g8h9 i9h9 d8d9 h9g8 e8e9a e7e9 d9e9 h8f7 e9e8 g8f9 e8e7 f7d8 e7h7 d8c6 h7b7 c6a5 b7c7 f9e8 i4h4 a5b3 b6b7 e8d8 b7b8 d8c7 b8b9h c7c8 b9b3 a6a5 h3g4 a5a4 b3b4 c8d9 g4f6 a4a3 b4b8 d9e10 f6e8 a3a2c b8d8
d3d5 d8d6 i3i5 i8i6 f3f5 c8c6 d5c6 e8e6 g3g4 h8h7 c3c4 g9h8 h1g3 b8b7 c6b7 a8b7 g2b7 b10c8 b1c3 d9b8 b7c8 b8c8 h2f3 b9c7 a3a5 c9f6 g3e4 f6g7 f5e6 c10a8 f2d3 h9i7 b3b4 a8e4 c3e4 i7g6 f3d4 c7e6 d2c3 f9e7 b2a4 g6e5 d3d2 e5c4 d2c4 d6d5 c4b3 d5e4 c2e4 a9d9 h3h4 a10c10 a4c5 c8d6 c1a3 g10c6 e4c6 c10c6 a2d2 g7d4 e3d4 d6d5 g1e3 e6c5 b4c5 c6e6 i2i3 e9d8 b3c4 d5c3 c4c3 i9e9 d1a4 e7c6 a3b2 h10f9 e1d1 f9e7 c3c4 e7d5 e2g2 d8h4 a1a3 f10f9 i3f3 h4d8 e3h6 h8f6 g4g5 g8g7 g5f6 g7h6 i5h6 d10a10 i1i5 a10d7 g2f2 e10d10 i5e5 c6e5 d4e5 d7a4 a3a4 f9a4 d1c1 i10e10 f3a3 a4c6 c4b6 d5b6 d2d8 d9d8 a5b6 e6e5 b2e5 e9e5 f1c4 c6h1 c1b2 h1d1 f2c2 e5e2 a3a10 d10c9 a10e10 e2c2 c4c2 d8d2 c2d2 d1d2 b2b3 d2d4 b6b7 d4d5 b3c3 i6i5 e10e9 c9b8 e9i9 d5c5 c3b3 c5e3 b3c4 e3e6 c4b5 e6f5 b5c4 f5f6 i9i7 f6h6 i7i8 h6f4 c4b3 h7h6 i8h8 f4e3 b3c2 e3e4 c2c1 e4c4 c1b1 c4b3 b1c1 b3c3 c1d1 c3h8 d1e2 i5i4 e2d3 i4i3 d3c4 i3i2q c4d5 i2d7 d5e4 h8d4 e4f3 d7g4
d3d5 d8d6 f3f5 c8c6 d5c6 i8i6 i3i4 e8e6 c3c4 h8h7 f5e6 h9g7 a3a5 a8a6 b3b5 a6b5 c4b5 a9a5 a2a5 a10a5 a1a5 e9a5 b1c3 a5a10 b2c4 b10c8 d2b3 g7e6 h2g4 f8f6 h3h4 g8g6 g2d5 f9e7 e3e4 h10g8 i4i5 b9d8 f2h3 d8f7 g1e3 g10e8 h1i3 c9d8 i3g2 c10b9 c1a3 e6c7 a3b4 g9h8 e3d4 i9f9 g2e3 c7e6 d5e6 e7e6 h3f4 c8b6 d4b6 d8b6 c4b6 f10b6 c3d5 b6d8 i2f2 e10f10 f4e6 b9e6 b3a4 f10g10 d5f4 e6g4 e3g4 g10h9 f4d5 f7e5 g4e5 d6e5 f2f3 f6f5 f1g2 d10g7 i1f1 e8f7 f3d3 d8e8 d5e3 d9c8 e4f5 f9a9 f5g6 f7g6 d3d7 a9a4 c2a4 c8d7 c6d7 g7d7 d1d7 e8d7 a4b3 a10a1 e2d1 a1d1 e3d1 i10d10 f1f8 h8g9 g2f3 d7d4 b3g8 h9g10 f3c6 g10h10 c6c3 d4d1 e1f2 d1g4 g8c4 g4i2 f2e3 i2i1 c3e5 i1c1 e3f2 c1c4 f8f4 c4a2 e5e2 a2a7 e2e3 a7e3 f2e3 d10d3 e3f2 d3b3 b4g9 h10g9 g3g4 b3b5 f4d4 b8b6 f2e3 b5b1 e3d2 g9g8 d4d8 g8g7 d8d7 g7h8 d7d5 g6f7 d5f5 f7e6 f5f8 h8g7 f8f10 b1h1 f10e10 e6c4 e10g10 g7h8 g4g5 h1h4 g5g6 h7h6 i5h6 h4h6 d2c3 c4g8 g10b10 h6g6 b10h10 h8i7 h10h1 g6g3 c3b4 i6i5 h1i1 g3b3 b4a4 b6b5 a4a5 i7h6 i1h1 h6i6 h1h8 g8c4 h8i8 i6h5 i8h8 h5g4 h8i8 g4h4 i8h8 h4i3 a5b6 i5i4 b6c5 i3i2 h8d8 i4i3 d8d4 i2h3 d4d2 c4f1 d2d1 i3i2q d1d5 b3c3 c5d6 i2i1 d6e7 i1c7 e7f8 c3f3 f8e8 c7f7 e8d8 f7d5 d8c7 f3c3 c7b8 b5b4 b8a7 d5b5 a7a8 c3a3
d3d5 i8i7 i3i5 d8d6 f3f5 c8c6 d5c6 e8e6 c3c4 f9e7 b3b5 h9g7 f5e6 b8b7 c6b7 a8b7 g2b7 b10c8 b1c3 h8h7 h2f3 g7e6 i5i6 h7h6 g3g4 g9h8 b7e4 e6c5 h1g3 e9a5 f3d4 b9c7 b2d3 c7e6 d3c5 d6c5 d4b3 a5c3 d2c3 h8c3 c1d2 c3e5 g1i3 e7d6 a3a5 h10f9 a5a6 c9i3 i2i3 f9e7 b3a5 a9a7 a5b7 d6d7 h3h4 c10a8 e4g2 a8b7 g2b7 f10h8 f1h1 d9e8 d2a5 i9d9 d1c1 a10b10 b7f3 c8b6 e1f1 d7d6 c2b3 e10f9 f1g2 d6f7 a2d2 e7g6 d2d9 d10d9 f2h3 e5a1 c1a1 g6e5 f3e4 b6d7 h1b1 f9g9 i1f1 f7e7 g3f5 e7c8 f5g3 g10i8 e4i8 i10i8 g3h5 g8g6 h5f4 e8g7 g2h1 g9h10 h3g3 h8g9 e2g2 i8g8 f4d5 f8f6 a5c3 g8f8 d5f4 c8d6 g2e2 f8e8 f4g2 a7a6 a1a6 d9a6 b5a6 e8b8 e2c2 b8b3 b1b3 b10b3 c3e5 d7e5 c2b3 g9a9 f1b1 d6c8 b3a4 e6c7 h4h5 a9a6 a4a6 c7a6 h5g6 e5c4 g3h5 g7g8 g2f4 a6c7 i3i2 c4d6 g6g7 c7e8 f4g6 e8g7 h5i7 g8i7 g6i7 h10g9 i7h5 d6e8 h5g7 e8g7 i6i7 g9h9 i2a2 c5c4 a2a8 c8c7 a8h8 h9i9 b1b4 g7h9 b4c4 h9i7 h8h7 c7d5 h7i7 i9h8 c4c7 d5e4 i7h7 h8i9 h7i7 i9h8 c7h7 h8g8 h7g7 g8f8 g7f7 f8g9 f7g7 g9f9 g7f7 f9g8 f7g7 g8f8 g7f7 f8g8 i7g7 g8h8 f7e7 e4f3 g7h7 h8i8 h7i7 i8h9 e7h7 h9g8 h7g7 g8f8 g7f7 f8e8 f7e7 e8d9 i7g7 d9d8 e7e10 f3g3 h1g1 d8d9 e10e6 f6f5 g7g9 d9c8 g4f5 g3f5 e6e8 c8c7 g1f2 h6h5 f2f3 c7d6 e8e10 d6d7 e3e4 f5h4 f3e3 d7d8 g9g8 d8d7 g8g7 d7d8 e10h10 d8e9 h10h8 e9f9 e3f4 f9e9 g7g9 e9f10 h8h9 h4h3 f4e5 h3f2 g9f9 f10g10 f9f2 g10h9 e5f6 h9h10 f6g5 h5h4 g5h4 h10i9 e4e5 i9h8 e5e6 h8g8 e6e7 g8h8 e7e8 h8g7 e8e9q g7g8 f2g2 g8f7 h4h5 f7f6 g2f2
d3d5 i8i6 i3i5 d8d6 c3c4 h8h7 f3f5 c8c6 h3h4 c6d5 c4d5 g9h8 e3e4 g8g6 g3g5 f8f6 h2f3 b10c8 b1c3 b9d8 f2h3 d8f7 h1g3 h9g7 b3b4 b8b6 a3a5 b6a5 a2a5 g7h5 d2b3 h10g8 b2c4 a8a6 g1e3 c9d8 a5a3 d10c9 e1f2 h5g3 h3g3 g8i7 g3g4 i9g9 d1d2 d9c7 c1b2 i7h5 f1h1 g10h9 a3a5 i10g10 f5g6 g9g6 e4e5 f6e5 b4b5 a10b10 b3b4 a6b5 a5b5 a9b9 c4a3 f9g7 g2h3 c8a7 a1c1 c9d10 e3a7 d10a7 f2e1 a7a9 c2g6 g7g6 e2c4 b9b6 i2f2 c10b9 g4e3 h5f4 h3i2 e8e6 c1a1 a9b8 d5e6 b9e6 i2e6 c7e6 c3d5 e6d5 e3d5 f4d5 b4d5 b6b5 a3b5 b8b5 c4b5 b10b5 a1a10 b5b10 a10b10 d8b10 f3h2 g6h4 d5d6 f7d6 f2f10 g10f10 d2d6 e9a5 d6d2 a5d2 e1d2 f10f2 d2c1 h4g2 h1i2 f2c2 c1b1 g2e3 i2b9 e3d2 b1a1 d2b3 b9b3 h9b3 i1e1 e10d9 h2g4 b10g5 g4e5 c2i2 a1b1 g5f6 b2d4 b3a2 b1a1 a2e6 a1b1 e6f5 b1a1 i2i4 d4c3 f5e4 a1b2 f6e5 c3e5 h8e5 b2c1 e5c3 e1e4 i4e4 c1c2 c3g7 c2b3 d9e8 b3c2 e4e1 c2b3 g7i5 b3b4 i5g3 b4a3 i6i5 a3b2 i5i4 b2c3 i4i3 c3b4 i3i2q b4c3 i2e2 c3b4 e1b1 b4c5 b1b5 c5c6 e2c4
5 white wins
1 draw
4 black wins
d3d5 d8d6 i3i5 i8i6 f3f5 c8c6 e3e4 b10c8 c3c4 h8h7 h3h4 g9h8 g3g5 f8f6 f2h3 g8g6 h2g4 h9f8 b1c3 c6d5 c4d5 b9d8 b3b4 d8f7 d2b3 b8b6 h1g3 a8a6 a3a5 b6b5 b2d3 h10g8 g1d4 f6g5 d4h8 f10h8 h4g5 a9a7 g3i4 a7c7 c1b2 h8g9 e2d2 c10a8 c3e2 g6f5 e4f5 d10b10 e2d4 g8i7 d1c1 c8e7 d3f4 i7h5 d4e6 h5f4 f1f4 c7c4 f4f2 b10b7 c1b1 c9a7 f2g3 a10c10 c2e4 e10d10 i4h6 f8d7 h3f4 d10c9 b2i9 g9i9 g4e3 a7e3 d2e3 c9b10 a2c2 c4c2 e4c2 g10h9 c2e4 i10g10 h6g4 b7b8 i1h1 f7e5 h1h7 e5g4 f4g4 c10c4 h7h6 d7e5 g4h4 h9e6 h6e6 a8d5 e4d5 c4h4 g3h4 f9g7 h4h3 g7h5 d5f3 h5g5 h3i3 g5e6 f5e6 d6d5 a1a2 e9g7 a2e2 d5d4 e3e4 d4d3 e2d2 d9c8 d2d3 e5d3 b1d3 g7g3 e1f1 g10f10 d3c3 i9g7 e4h4 g3e5 b3d4 e5d6 i3h2 b10b9 h4h8 g7h8 h2h8 f10f4 d4c5 d6d1 f1f2 f4f9 h8d4 d1d4 c3d4 e7f5 d4g4 b8e5 c5d3 e5e6 g4i6 e6f7 i2i4 e8e6 d3c5 e6e5 c5b6 c8b8 b6a6 f7f6 i6f6 f9f6 a6c5 f5d4 f2e3 d4f5 e3d3 f5g3 f3g4 b9b10 i4i3 e5e4 d3d4 g3h5 g4h5 f6f5 g2e4 f5h5 c5b6 h5h9 i5i6 h9h6 b6b5 b8d7 i6i7 h6e6 b5c4 e6e9 i7i8 d7f6 c4d5 f6g8 d5c7 e9c9 i8i9h g8i9 c7a8 b10c10 a8c9 c10c9 i3i9 c9d8 a5a6 d8e7 a6a7 e7f6 a7a8 f6e7 a8a9q e7f7 a9d6 f7g7 i9f9 g7h8 d6g9
d3d5 d8d6 f3f5 i8i6 i3i5 c8c6 c3c4 c6d5 c4d5 b10c8 b1c3 h8h7 h3h4 g9h8 b2c4 h9i7 e3e4 g8g6 f2h3 h10g8 a3a5 b9c7 g3g5 e8e7 h1g3 f9d8 h2f3 b8b7 c1b2 e9h9 f3d4 c9a7 d2d3 a7d4 g1d4 f8f6 g2f3 a8a7 b3b4 d9f8 e1d2 i7h5 e2h2 a9c9 a1c1 g10d7 c2b3 c8e9 f1f2 h5g3 h3g3 e9f7 d4e3 c10e8 i1h1 c9c8 h2h3 h9a9 d1g1 f7e5 c4e5 f6e5 f3g4 i9f9 b3c4 f8g7 a2a1 f10g9 f2e2 i10f10 i2f2 a10c10 f2f3 g8i7 e2f2 c7b9 c4b3 i7h5 g3e2 g6f5 e4f5 f9f5 f3f5 f10f5 g4f5 d7f5 f2f5 g7f5 h3f5 e8g6 f5f3 g6d3 e2d3 e10d9 g1g4 d9c9 b4b5 c9b10 c3e4 c8c9 h1f1 d10g10 b5b6 g10b5 c1c9 c10c9 a1a3 a7a6 f1c1 c9c1 b2c1 g9g6 d3c4 b5d7 g4d7 d8d7 c1b2 a9b8 b3c2 b8g8 d2c1 g6f7 f3h3 g8f9 c4d2 d7b8 c1b1 f9f8 c2b3 h5f4 h3h1 b9d8 a3a4 f8e8 e4c3 e7e6 h1e4 f7g6 e4g6 e8g6 b1a1 e6d5 c3d5 f4e6 d5c3 d8c6 b2a3 e6d4 b3d5 b8d7 a1b2 d4b5 c3e4 d7e7 d2c4 g6h5 g5g6 b10b9 g6h7 h5d1 e4c3 b5c3 c4c3 d1d5 a4e4 d5f7 c3d2 f7h7 e4g4 e7d5 b2c1 c6a5 e3h6 h7d7 g4g3 d7c6 c1d1 a5c4 d2c3 d5b6 h6e3 c6h1 d1e2 h1h2 e3f2 c4a3 e2f1 b6a5 c3d2 a3c4 d2e2 d6d5 e2g1 h2i1 f1g2 e5e4 g2h3 d5d4 g1g2 i1d1 f2d4 d1d4 g2g1 b7b6 g1e2 d4d6 g3g1 d6d3 e2d3 e4d3 g1d1 c4b2 d1a1 d3d2h h4h5 d2d3 h3g2 h8e5 g2g1 d3h3 g1g2 h3h2 g2g1 h2i2 g1f1 b2d3 h5h6 i2g3
d3d5 d8d6 f3f5 i8i6 i3i5 c8c6 e3e4 b10c8 c3c4 g8g6 d5c6 e8e6 h2g4 f8f6 b1c3 f9e7 b3b5 b8b7 c6b7 a8b7 f5e6 h10g8 d2b3 c9d8 h3h4 d8a5 c1d2 e7e6 c3d5 b9c7 f2h3 c7d5 c4d5 e6e7 d2a5 a9a5 a3a4 g10d7 b2c4 a5a9 g1d4 h8h7 b3b4 h9g7 a4a5 e9e8 d1b1 f6f5 g4h6 g9h8 h3g5 g8h6 i5h6 g7i8 f1g1 e7g8 e4f5 e8e2 e1e2 g6f5 c2f5 d7f5 g5f5 i8h6 f5g5 i9e9 e2d1 d9f8 g2e4 d10d7 a2e2 i10g10 h1i3 g8i7 g5f3 c10g6 g3g5 h6f7 i3g4 e10f9 a1a2 a10e10 e4d3 a9c9 g4f6 d7d9 f3g4 e10c10 a2c2 e9e2 i2e2 c8e7 g1g3 f10g9 i1e1 g10e10 b1b3 f9g10 d1c1 h7h6 g3f2 h6h5 g4h3 g6d3 b4d3 i7g6 c1b1 g10h9 h3g3 f8g7 g3h3 e7f5 d4b2 e10e2 e1e2 g9g10 d3b4 g7f8 e2e6 f5g7 e6e1 g7f5 e1c1 h8g7 c4e3 c9c2 c1c2 c10c2 b3c2 f5e3 f2e3 g10e10 e3e10 d9e10 b1a2 i6i5 f6d7 f8h7 d7f6 h7h8 c2c9 h9i10 h4i5 e10a10 h3g1 g7f6 b2f6 a10g4 f6h8 g6h8 g5g6 g4b4 g6f7 b4a5 a2b2 a5b4 b2c2 b4a4 c2b2 a4b4 b2c2 b4a4 c2b2 a4b5 b2c1 b5d5 f7f8 d5c5 c9c5 d6c5 g1h3 h8g10 h3g3 g10f8 g3h5 f8f7 c1c2 b7b6 i5i6 i10i9 c2b3 b6b5 i6i7 i9i8 b3c3 i8h7 c3b2 f7e7 b2a3 b5b4 a3a4 c5c4 a4b4 e7d5 b4a5 d5c6 a5a4 c6e5 h5i6 h7g6 i6h4 g6f7 h4g4 e5e4 g4g5 e4g5 a4b4 g5h6 b4c4 h6i7 c4d5 i7h5 d5e4 f7e6 e4d4 h5f4 d4c4 e6d6 c4d4 d6c6 d4c3 f4e3 c3b3 e3d3 b3a2 c6c5 a2b3 c5b5 b3a3 b5c4 a3a2 c4c3 a2a1 d3b2
d3d5 i8i6 i3i5 d8d6 c3c4 h8h7 f3f5 c8c6 h3h4 g9h8 e3e4 b10c8 g3g5 f8f6 f2h3 g8g6 b1c3 h9f8 h1g3 f10g9 h2f3 c6d5 c4d5 b9c7 b3b5 a8a7 d2b3 g10h9 f3d4 a7a6 a3a4 f8d7 b2c4 h10g8 d4e6 a6b5 a4b5 a9a2 a1a2 a10a2 b3a2 c7e6 d5e6 d7e5 a2b3 c10a8 g1d4 d10a10 c1a3 e5c4 b3c4 f6g5 h4g5 h8d4 d1d4 c9d8 e1d1 d8b6 d4d2 b6c5 a3b2 c8b6 c4b3 i9i7 c3a4 b6a4 b3a4 g8e7 c2b3 e7c8 d1c2 e10d10 f1a1 d10c9 c2b1 a10b9 b2d4 g6f5 g3f5 i10a10 a1c3 b8b6 i1f1 c9b8 f5d6 c5d6 f1f9 g9f9 g5g6 i7i10 h3g5 a8b7 a4b2 h7g6 d4e5 e9c7 e5d6 c8d6 c3b4 d9c8 i2i3 i10d10 i3c3 d6c4 d2c1 c4d2 e2d2 d10d2 c1d2 c7e9 d2d6 b8c9 d6e7 c9d10 e7h10 d10d9 h10i9 d9c10 b4h10 c10c9 h10e7 c9c10 e7h10 c10d9 i9d4 e9d8 h10i9 d8d4 i9d4 d9c10 e6e7 h9b3 b2b3 b9d9 g5e6 d9d4 b3d4 f9a9 c3c8 c10b10 c8c7 a9a1 b1c2 a10a2 c2d3 a1d1 d3c4 a2a4 c4c3 a4a3 c3b2 d1a1 b2c2 a3a2 c2d3 a1d1 d3c4 b7e10 g2f3 a2a4 c4c3 a4a3 c3c4 d1d2 c4d5 a3a4 c7c4 a4c4 d5c4 e10g8 e6d5 d2a2 c4d3 g8d5 d4d5 a2b3 d5c3 b3a3 f3i6 a3e7 c3d5 e7i3 d3c4 i3i5 d5b6 i5i2 i6h7 b10c9 b6b7 c9d9 b7d6 i2e2 c4c3 e2e3 c3c4 e3e2 c4b4 e2d1 d6e7 d9e9 e7f9 e9d9 f9e7 d9c9 e7e8 c9b8 b4c5 d1h5 c5c6 h5h7 e8d9 b8b9 d9d10 b9b8 d10d9 b8b9 d9d8 b9a10 d8c9 a10a9 c9c8 a9a10 c8c9 a10a9 c9c8 a9a10 c8c9
d3d5 i8i6 i3i4 f8f6 e3e4 e8e6 f3f5 d8d7 b3b4 c8c6 d5c6 d7c6 c3c5 b10c8 a3a5 g8g6 g3g4 h8h7 h1g3 d9e7 b2c4 h10g8 b1c3 b9c7 h2f3 b8b7 f5g6 c10g6 h3h5 i6h5 i4h5 i9i2 i1i2 i10i2 g3i2 g6e8 e4e5 h9f8 i2g3 c7d5 d2d3 d5c3 d3c3 d10d1 c2d1 g9h8 d1b3 a10d10 g1i3 e7d5 c3c2 f6e5 i3c9 a9c9 c4e5 d5c7 f1i1 g8f6 e1f1 f9g8 f1g1 h7h6 c1b2 e9i9 i1h2 g10i8 c2a3 c9f9 a1e1 f6d5 g3e4 f8d7 e5d3 h8b2 e2b2 d7f6 e4f6 f9f6 h2g3 e10d9 a3c4 d9c10 g1h2 i8h7 f2h3 i9f9 f3d4 g8g7 h3h4 c10b9 b2a1 c7a6 a2d2 f10c7 c4e5 h7d3 e5d3 d5f4 d3e5 f9c9 a1c3 g7f7 e5f7 f6f7 h2g1 c7d8 d4f3 f4d5 c3b2 e8d7 h4h3 f7i7 f3h4 a6b4 b3d5 b4a4 b2a1 c6d5 e1e6 a4c5 e6h6 d7b5 g4g5 c5c4 d2c2 c4d3 a1d1 d10e10 d1d3 b5d3 g3d3 i7i1 h3i1 d8g5 i1h3 g5h6 d3d5 h6e3 g1h2 e10e5 d5d1 e5a5 g2f3 c9b8 h3g3 b8d6 h4f5 d6d1 f5e3 d1d4 e3f5 d4d3 f3e4 d3d1 g3e2 d1d10 c2d2 d10f8 e2f4 c8e7 f4e6 f8h8 f5g3 a5h5 g3h5 h8h5 h2g3 h5i5 g3f4 i5i7 e6g5 a8a6 d2d7 b7b6 d7b7 b9c8 f4g4 i7i2 g4h5 i2e2 h5h6 e2h2 h6i6 e7f5 g5f5 h2i2 i6h5 i2f5 e4f5 c8b7 h5g5 b6b5 g5f4 b7b6 f4e4 b6a5 e4d5 a5b4 d5c6 b4b3 c6b6 b5b4 f5e6 b3c3 b6a6 b4b3 e6b3 c3b3
d3d5 d8d6 i3i5 i8i6 f3f5 c8c6 c3c4 c6d5 c4d5 b10c8 e3e4 g8g6 h3h4 h8h7 f2h3 g9h8 g3g5 f8f6 h2g4 h9f8 h1g3 b9d8 b1c3 d8f7 g1e3 f10g9 d2b1 h10g8 a3a5 f8d7 b2c4 a8a7 b3b5 d9f8 c1b2 d7e5 e2f2 c9e7 b5b6 e9c9 f2d2 d10d8 b6b7 e5g4 d1g4 c8e9 c3b5 d8d7 b5d4 d7b7 d4e6 f8h9 c2a4 c10b9 b1a3 b7d9 a1c1 c9d10 a3b3 a10c10 f5g6 h7g6 h3f4 h9i7 g2i4 e9d7 i2f2 f6g5 h4g5 h8b2 d2b2 d7c5 e3c5 c10c5 i4g6 b9e6 d5e6 c5g5 e6f7 g5g4 f7e8 f9e8 g6e8 d9b9 f4g4 b9g4 c4e3 g4g3 e3f5 e7f6 f5g3 f6b2 c1c10 d10c10 e8c10 b2e5 i1g1 g10a4 a2a4 i10f10 g3f5 g9f8 f1b5 i9c9 a4c4 c9c4 b5c4 e10d10 c10i4 a9c9 c4e6 f8c8 e6c8 c9c8 f5e7 c8c3 e7g8 f10f2 b3c3 e5c3 e1f2 i7h7 f2f3 h7i5 g1g4 d10c9 a5a6 c9d8 g8f10 i5h7 f10e8 d8d7 g4g6 h7i5 g6g4 i5h7 i4g6 h7f8 e8f10 d7d8 f3g2 f8e7 f10d9 e7f6 g2h3 d6d5 e4d5 c3e5 d9f8 f6d5 g6h7 i6i5 f8g6 e5g7 g6h8 g7f8 g4g8 d5f4 h3h2 f4f3 h2h1 f3f2 h1h2 f2f3 h2h1 f3f2 h1i2 d8c7 g8f8 f2g1 i2i3 g1g2 i3i2 g2g3 i2i3 g3g4 i3i2 g4g3 i2i3 g3g2 i3i2 g2g3
d3d5 i8i6 i3i5 d8d6 f3f5 c8c6 e3e4 b10c8 c3c4 h8h7 h3h4 g9h8 g3g5 f8f6 h2f3 g8g6 b1c3 c6d5 c4d5 f10g9 f2g4 h9f8 a3a5 b9d8 b3b5 d8f7 d2b3 f7e5 f3e5 g6f5 e4f5 d6e5 h1g3 h10g8 b2c4 f8d7 g5g6 h7g6 f5g6 c10b9 g2i4 a8a6 b5b6 d7f8 g4i3 c8e7 d5d6 e7c6 g3f5 b8b7 c1h6 b9f5 c2f5 h8g7 i4h3 f8d7 h6e3 a10c10 f1f3 c9b8 a1c1 f9h8 c3e4 d9f8 a2d2 a9d9 e1f1 e8e6 d6e7 g8e7 c4d6 e7f5 h3f5 g10h9 d6f7 h9f7 g6f7 g9f9 f3h3 h8f7 c1c3 e9e8 e4c5 d7c5 e3c5 d9d2 b3d2 c6e7 c3d3 d10c9 e2e4 e10f10 d2b3 e7f5 c5f8 f9f8 e4f5 f7e7 i2c2 c9c2 b3c2 e7f5 h3f5 e5e4 d3d7 b8i1 g1e3 f8g8 c2d4 i9d9 d7d9 e8d9 d4e2 d9d1 e2d1 i10g10 f5e4 c10e10 e4g4 g8i8 g4f3 g7h8 i3h3 i8b1 f1f2 e10e5 d1d2 b1g6 f3b7 i1g3 f2e2 e5a5 b7d7 g10g8 d7d10 f10g9 d10c9 g9h10 c9c4 a5b5 c4e4 g6h5 e4f3 g3h4 f3h5 b5h5 d2d3 h4i5 h3i4 a6a5 b6b7 g8e8 i4h5 i6h5 e2f3 h8g9 e3f4 a5a4 b7b8 e8e9 d3c3 a4a3 f4c1 i5e1 c3b3 e1b4 f3g3 e9b9 g3h4 b9b8 h4h5 b4d6 b3a2 b8g8 c1a3 d6a3 a2c3 g8g5 h5i6 h10g10 c3d4 g10f9 d4e6 a3e7 i6h7 f9e8 h7i6 g9f8 i6h7 f8d10 h7i6 f6f5 i6i7 d10b8 e6d4 e8f7 i7h7 e7f8 d4e3 f8g7 e3f3 g5h5 h7i6 h5h6 i6i7 f7g6 i7i8 h6h8 i8i9 h8h3 i9i8 h3f3 i8h9 g6f7 h9g9 f3e3 g9h9 f7f8 h9i10 f8g8 i10h10 e3e10
d3d5 d8d6 i3i4 i8i6 f3f5 h8h7 h2g4 c8c6 d5c6 b10c8 a3a5 a8a6 c3c4 g9h8 b1c3 e8e6 f5e6 h9g7 b2d3 g7e6 c1b2 f9e7 g1i3 e7f7 d3f4 c9i3 h1i3 c8e7 b3b5 a6b5 c4b5 a9a5 a2a5 a10a5 a1a5 e9a5 d2c4 a5a10 f4e6 f7e6 c4b4 d9c7 c2b3 e6c5 f2d3 c7b6 c3a4 c5d3 e2d3 b6a5 b2h8 a5b4 h8f10 b4d3 f1d3 e10f10 i1f1 d6d5 a4c3 i9d9 g2d5 b9c7 e3e4 h10f9 i2a2 a10c8 d1a1 f10g9 e1f2 b8b7 f2g2 b7c6 b5c6 c10b9 a2f2 e7c6 d3e3 c7d5 c3d5 f8f7 f1c1 d9d6 f2f6 d10f8 e3f4 c8b8 c1c6 d6c6 f4b8 f8b8 f6c6 b8b3 c6c9 b3b8 a1c3 b9a10 g4f6 g8g7 c3a3 g9h9 c9e9 a10h3 g2h3 g7f6 i3g4 i10i8 d5f6 i8h8 a3a10 h7h6 a10f10 b8b5 g4e3 h6h5 i4i5 b5b1 e9f9 g10f9 f10f9 h9h10 f9e10 h10h9 e10d9 h9i8 e3d1 h5h4 g3h4 b1b3 h3g2 b3e6 d9d4 e6i2 g2f3 h8h4 d1f2 i2i5 f6g4 i5g5 d4d9 i6i5 d9e8 i8i9 e8f9 i9h10 f9f10 h10i9 f10f9 i9h10 f9f8 h10i9 f8i5 g5i5 g4i5 i9h8 i5g4 h8g7 f3f4 g7g6 f2d3 f7f6 d3f2 g6f7 f4g3 h4h5 f2h3 h5a5 h3f4 f7g7 g4e3 g7f7 e3g4 a5a3 g3g2 a3a2 g2f3 a2a3 g4e3 a3b3 f4g2 f7e6 g2i3 b3a3 i3g4 a3a5 e3f5 e6f7 f5e3 f7e6 e3f5 e6f7 f3f4 a5a1 f5e3 f7e6 g4h6 a1h1 h6f5 e6f7 f5g3 h1i1 g3f5 i1h1 f4g3 h1g1 e3g2 f7e6 f5e3 g1a1 g3f4 a1a2 g2h4 a2f2 f4g3 f2a2 h4f5 e6f7 g3f4 a2f2 f4g3 f2a2 e3d5 f7e6 g3f3 a2a1 d5e3 e6f7 e3g2 f7e6 g2e3 e6f7 f5g3 f7g6 f3f4 a1i1 g3f5 i1a1 e3d5 a1f1 f4g4 f1g1 g4f3 g1f1 f3g4 f1g1 f5g3 g1i1 d5f4 g6f7 g3f5 i1e1 f5d6 f7e7 d6f5 e7f7 g4g3 f7f8 g3f3 e1f1 f3g3 f1e1 g3f3 e1f1 f3e3 f1e1 e3d3 e1h1 f5e3 f8f7 d3e2 h1a1 e3g4 a1g1 g4h6 f7g7 h6f5 g7f7 f5e3 g1a1 e3d5 a1g1 e2f2 g1a1 f2f3 a1f1 f3g4 f1g1 g4f3 g1f1 f3e2 f1g1 e2f2 g1a1 d5e3 a1a4 f2f3 a4a3 f3f2 a3a4 f2f3 a4a3 f4g2 f7e6 f3f4 a3a1 g2i3 a1a2 e3g4 a2a5 g4e3 a5a2 f4f3 a2a5 i3h1 a5a3 f3f4 a3a2 f4f3 a2a1 h1g3 e6f7 g3f1 f7e6 f1g3 e6f7 g3f5 f7g6 f3f4 g6f7 e3d5 a1f1 f4g3 f1g1 g3f3 g1f1 f3g2 f1e1 g2f2 e1h1 f2g2 h1e1 g2f2 e1h1 f5g3 h1h4 f2f3 f7g6 f3e3 g6g5 e3d4 h4h10 g3f5 h10d10 f5g7 d10e10 g7f5 e10d10 f5g7 d10e10 d4e3 e10e5 e3d3 g5g6 g7f9 e5e10 f9d8 e10a10 d5e7 g6g7 e7f5 g7f8 d3c4 f8e8 d8e6 e8f7 e6d8 f7e8 d8e6 e8f7 e6f4 a10a5 c4d4 a5a1 f5h6 f7g7 h6f5 g7f7 d4c5 a1e1 f5d6 f7e7 d6f5 e7f7 f4d5 f7e6 f5d4 e6f7 d4f5 f7e6 f5d4 e6f7 d5c3 e1c1 c5c4 c1a1 d4f5 f7e6 c4d4 a1a7 f5e3 a7a3 c3d5 a3a4 e3c4 a4a1 d5f4 e6f7 c4e3 a1a4 e3c4 a4a1 c4e3 a1a4 d4d5 a4a5 d5c6 a5a4 e3f5 f7f8 f4e6 f8e8 e6c7 e8d8 c7e6 d8e8 e6f4 e8f7 c6d7 a4a7 d7c6 a7a5 f5d6 f7e7 f4g6 e7e6 g6f8 e6e7 f8d9 e7e6 d9f8 e6e7 f8d9 e7e6 d9c7 e6e7 d6f5 e7f7 c6d7 a5a7 f5d6 f7g6 d7d8 a7a10 d8e8 a10e10 e8d7 e10d10 d7e7 d10e10 c7e8 e10e9 d6c8 e9e10 e7d7 g6g5 c8d6 e10a10 d7e7 a10e10 e7f7 e10g10 f7e7 g10e10 e7f7 e10g10 f7f8 g5g6 f8e7 g10e10 d6f5 g6g5 e7f7 e10b10 f5e7 b10e10 e7f5 e10b10 f5e7 b10e10 e8d6 e10f10 f7g7 f10g10 g7f7 g10f10 f7e6 f10e10 e6d7 e10d10 d7c6 d10c10 c6d7 c10d10 d7c6 d10c10 c6d5 c10d10 e7f9 d10e10 f9d8 e10e7 d8f9 e7e5 d5c6 g5f4 f9g7 e5i5 c6d7 i5i7 d6e8 f4e5 d7e7 i7h7 e7f7 h7h6 g7e6 e5e4 e8f6 e4f5 e6g7 f5g5 g7e6 g5f5 e6g7 f5f4 g7e8 h6h2 f7e6 h2e2 e6f7 f4e5 f6g4 e5f5 g4f6 f5e5 f6g4 e5f4 g4i5 f4f5 i5h7 e2f2 e8d6 f5e5 f7e7 f2e2 h7g5 e5d5 e7d7 e2g2 g5e6 g2d2 d6f7 d5e4 d7e7 d2e2 e7f6 e2f2 f6g6 e4d5 e6c7 d5d4 c7e6 d4d5 e6c7 d5c6 c7e8 c6d7 e8g7 d7e7 f7g5 f2f6 g6h5 f6f8 h5g6 f8f6 g6h7 f6f1 g5e4 e7f7 e4g3 f1g1 g7h5 g1g2 h7h6 g2g1 g3e4 g1g6 h6h7 g6g9 h7h6 g9e9 e4g5 f7e7 h5g7 e9e10 h6g6 e10g10 g5e6 g10f10 e6d4 f10g10 d4f5 e7d7 g6f7 g10f10 f7g6 f10g10 g6f6 g10e10 g7h9 e10e1 h9f8 d7c6 f5e7 c6d6 e7f5 d6d5 f6g6 e1e8 f8d7 e8e6 g6g5 d5c6 d7b8 c6d5 b8d7 e6e1 d7f6 d5e6 f6g4 e1e4 f5e3 e4d4 g4f6 d4d3 f6g4 d3b3 g5g6 b3b4 g4f2 b4a4 f2d3 a4d4 d3f2 d4f4 f2h3 f4f6 g6h5 f6f10 h5g4 f10e10 e3d1 e10e7 d1e3 e7g7 g4f3 g7e7 h3f2 e7f7 f3g3 f7e7 f2e4 e6e5 e4d2 e7d7 d2f1 d7e7 f1h2 e5e4 h2g4 e7f7 g3h4 f7h7 h4g5 h7g7 g5f6 g7g8 f6f7 g8g5 f7f6 g5g8 f6f7 g8g5 f7e6 e4f4 e6f6 g5g8 f6f7 g8g5 f7f6 g5g10 f6e6 g10g7 e6d5 g7a7 d5e6 a7a5 e6f6 a5a9 f6e6 a9d9 e6f7 d9e9 f7f6 e9h9 f6g6 h9h3 g6f6 h3h7 f6e6 h7b7 e6d6 b7b5 d6e6 b5b9 e6d6 b9h9 d6e6 h9h3 e6d6 h3h9 d6e6 h9h3 e6f6 h3f3 f6g6 f3g3 g6f6 g3g1 f6e6 g1a1 e6d6 a1a7 d6e6 a7g7 e6d5 g7d7 d5c4 d7d2 c4c3 d2d8 c3c4 f4f3 c4c3 d8d9 c3c4 f3f4 c4c3 d9d10 c3c4 d10d9 c4c3 d9d8 c3c2 d8d10 c2b3 d10c10 b3b2 c10c5 b2b3 c5c1 b3b4 c1c10 b4b3 c10c5 b3b2 c5c6 b2b3 c6c1 b3b4 c1c9 b4b5 c9c10 b5b4 c10c1 b4b5 c1c9 b5b4 c9c1 b4b5 c1c8 b5b6 c8c9 b6b5 c9c8 b5b6 c8c10 b6b7 c10c1 b7b6 c1c8 b6b5 f4f3 b5b6 c8c3 b6b5 c3c9 b5b6 c9c3 b6b5 c3c1 b5b6 c1c8 b6b7 c8c3 b7b6 c3c1 b6b5 c1c8 b5b4 f3f4 b4b3 c8c9 b3b2 c9c6 b2a3 c6e6 a3b4 e6e4 b4c5 e4a4 c5d5 a4a6 d5d4 a6d6 d4c5 d6e6 c5d5 e6e9 d5d4 e9e4 d4c5 e4a4 c5d5 a4a6 d5c4 a6d6 c4c5 d6d8 c5c6 d8a8 c6d6 a8a3 d6e6 a3b3 e6e7 b3b1 e7d6 b1b5 d6e6 b5a5 e6f6 a5a3 f6g6 a3a1 g6f6 a1a9 f6f7 a9e9 f7g6 f4f3 g6f6 f3f4 f6g6 e9h9 g6g7 h9f9 g7g6 f9f8 g6g7 f8f9 g7g6 f9f8 g6h7 f8f10 h7h6 f10g10 h6h7 f4f3 h7h6 f3f4 h6h5 g10h10 h5i4 h10h8 i4i3 f4f3 i3i2 h8h4 g4i3 h4h7 e3f1 f3f2 f1h2 h7h4 i3h1 f2g2 h1i3 g2f2 i3h1 f2g2 h2g4 h4g4 h1i3 g2f3 i3g4 f3g4
d3d5 i8i7 i3i5 d8d6 f3f5 c8c6 d5c6 e8e6 c3c4 f9e7 b3b5 e6f5 b1c3 b8b7 c3d5 e7e6 c6b7 a8b7 h2f3 h9g7 f3d4 e6d7 d4f5 h10f9 d2b3 b10c8 a3a5 h8h7 f5d4 b9d8 h3h4 d8e6 g2h3 f9e7 i5i6 h7h6 f2f3 d9b8 d5f4 f8f7 c1d2 d7c5 d2c3 c5b3 d4b3 g9h8 f4d5 b7b6 e3e4 b6a5 a2a5 g7e8 c3h8 f10h8 a5a9 c8a9 b2d3 c10b9 g1e3 a9b7 e1f2 a10a1 d1a1 h8a1 f1a1 e6g5 e3g5 h6g5 h3b9 b8b9 h4g5 e8g7 f2f1 i10h10 d5f6 g10d7 g3g4 i9h9 h1g3 g7e6 e4e5 d7c8 b3d4 g8g7 f6h5 e6d4 a1d4 g7g6 h5f6 b9c7 d3f4 b7c5 e5d6 c5e6 d4c3 d10d6 f4e6 c7e6 e2e3 d6c7 i2e2 e6c5 c2b3 c9a7 e3e5 c8e6 f6h7 c7c8 g3e4 c5d7 e5g3 a7b8 g3i5 b8i1 i5i1 e9c7 i1c7 d7c7 c3b4 h9e9 e4d6 c8a8 f1f2 h10f10 c4c5 a8a1 h7f6 f10h10 f6h7 h10f10 h7f6 f10h10 d6f7 h10h3 e2e6 h3f3 f2f3 a1f1 f3g3 f1g1 g3h3 g1h1 h3g3 h1g1 g3h3 g1f1 h3h2 f1f2 h2h1 f2f1 h1h2 f1f2 h2h1 c7e6 b3e6 e9d9 f6d7 d9h9 f7h6 h9f9 h6f7 f9h9 f7h6 h9f9 h6f7 f9h9
d3d5 d8d6 i3i4 i8i6 f3f5 h8h7 h2g4 f8f7 c3c4 g9h8 b1c3 g8g6 f5g6 h7g6 e3e4 h9f8 b3b4 c8c6 f2d3 b10c8 a3a5 h10g8 c2a4 b9d8 i4i5 f7f6 d5c6 d8f7 c4c5 f6f5 g4h6 g8h6 i5h6 c9f6 c3d5 f6g5 d2b3 g5c1 d1c1 e8e6 d5b6 d6c5 g1c5 f9g8 g3g5 f5g4 h3g4 f7e5 d3c2 a8a7 b6c4 g10c6 a4c6 e5c6 e4e5 d9d8 b4b5 c6e7 g4g5 c10e8 h1f2 e8b5 f2g4 g8f7 c2c3 f10f9 b3b4 a7a6 b2a4 f8d7 a2d2 a9d9 d2d3 b8b7 a1a2 d10b8 f1f4 e7d5 d3d5 e6d5 g2d5 h8e5 g4e5 f7e5 f4f9 i9f9 c4e5 d7e5 b4b5 a6b5 d5i10 e5f3 e1d1 b5a4 d1c2 a10a5 e2e9 c8e9 c5b6 d8c6 b6a5 c6a5 c2b1 d9c9 a2c2 f9f5 i10c4 f3e5 c4e2 c9c3 c2c3 e5d7 e2i6 e10d9 i2b2 f5b5 b2b5 a5b5 c3e3 b8c9 i6h7 c9c1 b1c1 d9d8 h7g6 b5b4 i1i3 b4a2 c1d2 a2b2 d2e1 b2c4 h6h7 e9g10 i3i8 d8c7 e3e10 a4a3 i8a8 d7c5 g6b1 g10h8 e10e2 h8i6 g5g6 c7b6 e1f1 c5b3 b1a2 b3d2 f1g1 c4d3 e2e6 b6b5 a8a3 d2f3 g1f1 d3f4 a3f3 f4f3 e6e2 b7b6 h7h8 i6g7 h8h9a f3g3 f1e1 g7h9 a2h9 g3f5 e2g2 f5g7 h9f7 b5b4 e1d2 b6b5 g2f2 g7h5 d2d3 b4a5 f2f5 h5g7 f5f1 a5b6 d3c3 b5b4 c3b4 b6c7 f1d1 g7f5 d1d5 f5f6 b4c4 f6e7 c4d3 e7f6 d5d10 f6g7 d3e4 g7f9 d10d9 f9g7 e4e5 c7c6 d9h9 c6c5 h9h7 g7f8 e5f6 f8d7 f6g7 c5d6 h7h2 d7e7 h2e2 e7f9 g7f6 f9f8 e2e8 f8g9 e8d8 d6c7 d8g8 g9f9 g6g7 c7d6 g8e8 f9g9 e8d8 d6c5 g7g8 c5b4 d8d9 g9h7 f6e5 b4c5 g8g9h h7g9 d9g9 c5c6 g9d9 c6c5 d9d6 c5b4 e5d4 b4b5 f7e6 b5b4 e6c4 b4a4 d4c3 a4a3 d6a6
2 white win
5 draws
3 black wins
Random move test
using https://fairyground.vercel.app/advanced.html
White wins: 0
Black wins: 1 (1 from getting stalemated)
draws: 11
c3c4 a8a7 e3e4 d8d6 h2g4 e9a5 g4e3 d6d5 d2c3 f10d8 e4d5 d9e9 e1d2 f8f6 f2g4 i8i7 g4f2 a5b6 c3e4 f9f10 g1h2 f6f5 b3b5 d8i3 e4c5 g8g7 h3h5 i3i2 c5b3 i2i5 d2c3 c8c6 f2g1 g9d6 i1i3 d6a3 i3h3 h10g8 h2i1 d10d5 a2a3 b10c8 g1f2 g8h10 b3a5 d5b5 h3i3 c8e7 e2e1 e9d9 a5b5 b6e3 b5b4 e3h6 b4a2 h6e6 d3d4 e7f9 d1d3 f9d10 c4c5 e6d7 a3a7 c9g5 f2e2 d9c7 i3h3 c7e6 c3b3 f5f4 i1h2 d7a7 e1d2 g10f9 d2e3 g5f6 h3h4 i5i4 a2c3 f4g3 a1a7 b8b7 h1g3 i4i3 b2d1 h8h6 c1b2 i3i2 a7b7 f6d8 b2a3 d8b6 c3b4 i2g4 d1c3 e6e5 b4a5 g4f3 e3c1 b9d8 d3f5 e5f4 f5c8 c10d9 a5c4 a9b9 e2d3 a10a4 c4d6 f3h5 g2d5 e8e6 d3c4 b9b10 g3e4 f4e2 d6e7 b6a5 e4f2 h9f8 h2c7 f9e8 c4b5 a4d4 e7d6 e2c1 a3c1 b10a10 c8c9 d9c8 d6c6 f8h9 b5a4 e8d7 h4h5 d4b4 c6b4 c8b7 f2h3 a5b4 f1f7 a10a9 f7f3 b7a6 c9f9 a9f9 c2e4 a6d9 d5c6 i9i8 f3g4 d7c8 c7b6 i8e8 a4b2 d8b7 h5i5 b4a3 b2a1 b7d6 i5f5 g7g6 e4f3 a3b2 h3g5 f10g9 g4g3 f9e9 b6a7 i7i6 c3a2 c8b9 c6b7 g9f9 g3e1 b9d7 a7b8 b2h8 b7a8 d9b7 e1i1 i10i7 i1d6 e8f8 a8c10 h8a1 c10e8 i7i8 f3d1 e9c9 d1f3 d7c6 d6d9 c9d9 g5h3 f8e8 b8a7 e8b8 c1b2 f9g7 b2a3 a1b2 f5f6 h9i7 h3i1 h6h5 b3b2 g7f8 f3d5 c6d7 b1d2 d7e8 i1g2 d9e9 f6f2 e8g10 d5c6 i8i10 d2f3 f8f7 g2e1 f7e8 a7b6 e8d9 b2a1 b7c6 a2c1 c6b5 f3h2 b8i8 c1e2 d9d8 e2c3 g10f9 f2b2 h5h4 c3a4 h4h3 b2b5 d8e7 e1c2 e9d9 h2i4 f9g10 a1b1 i6i5 a3b2 e7f5 i4g3 d9d3 a4c3 i7g8 b2a1 d3c3 g3f5 d10f9 b6a7 g8f6 b5a5 h3h2a a7b6 e6f5 a5a2 h2g4 a2a3 f5f4 b6d8 f4f3 a3b3 i8f8 d8f10 f6d5 b3b5 g4e5 f10e9 f8i8 b5b10 e10d9 b10g10 d9c8 c2d4 f3f2h c5c6 e5f7 d4f3 i8i7 f3g5 f7e5 g10b10 c3b3 a1b2 d5c3 b1c1 f2f3 g5e4 c3a2 c1d1 f3h3 e4d2 i7f7 e9d8 a2b4 b10f10 h3f4 b2a3 f7h7 d8c9 e5c4 f10e10 b3b1 d2b1 f4e4 e10a10 e4f2 d1c1 c4f1 a10a5 h7g7 a5a7 g7a7 b1c3 c8c9 c3a2 f2i2 a2b4 i5i4 c6c7 a7a6 b4a2 c9b10 a3e7 b10b9 e7i3 f9e7 c7c8 b9b10 a2b4 f1g3 b4d3 a6a8 d3e1 i2g1 i3f6 i4i3 c8c9a b10b9 f6b2 g3e5 c9a10 b9c10 a10f5 i10i6 f5g6 e5g6 b2a1 a8a7 a1b2 h10g8 b2g7 i3i2a g7d10 a7a10 d10a7 g1e2 c1d1 i2g4 a7d10 g4h3 d10f8 g6d9 f8i5 d9c8 i5g7 i6i3 g7h6 h3i5 h6f4 e2d4 e1d3 a10a9 f4c1 i5h6 c1d2 d4e4 d1c2 a9a1 d3c5 e4f6 d2h6 i3i4 h6f8 a1a3 c5a4 c8h3 f8e9 a3b3 c2d2 b3b7 e9h6 f6f9 a4b6 f9g9 d2e3 e7d5 e3d2 d5c7 b6c8 i4i3 d2c3 i3i6 c8b10 g8e7 h6d10 i6g6 d10h6 g9f7 b10a8 b7b10 h6i7 f7h8 c3d2 g6g7 i7h8 b10b8 d2c1 c7a8 h8i7 b8b7 c1c2 g7g3 i7h8 a8b6 h8b2 b7a7 c2d1 h3f5 b2f6 g3d3 d1c1 d3d2 f6h4 e7f9 h4e7 f5i8 e7a3 i8g7 a3b2 a7a4 b2d4 a4a10 d4f6 c10d10 f6h4 d2d6 c1b1 f9e7 h4e7 d10d9 e7g5 d6d7 g5f4 a10a5 b1c2 d7d5 f4e5 a5a7 e5f6 a7a5 f6c9 g7h8 c9e7 h8e5 c2b3 e5f3 e7c5 d9e10 c5b4 d5d7 b4h10 b6d5 h10c5 d7g7 c5d6 d5e3 d6b8 e3c2 b8h2 f3d5 b3b2 a5a7 h2f4 g7b7 b2c2 d5b4 c2c1 b7f7 f4i7 f7f1 c1b2 b4a5 i7f4 e10d10 f4c1 d10c10 c1g5 a7h7 g5b10 a5d2 b2a3 c10d10 b10h4 f1f10 h4c9 d10d9 a3a4 h7c7 c9b8 d2f3 a4b5 f3d4 b5a6 c7c6 a6b7 c6d6 b8d6 d4c5 d6c5 d9c9 c5f8 c9c10 f8h6 c10b9 h6e9 f10b10 e9f10 b10a10 f10d8 a10g10 b7c6 g10g6 c6b7 g6g9 d8e9 b9b10 e9i5 b10c10 b7c8 c10b10 c8c7 b10a9 c7d8 a9a10 i5e9 g9g2 e9f10 g2e2 f10e9 e2e8 d8c7 e8i8 e9d10 a10a9 d10b8 a9b10 b8c9 b10c9 c7c6 c9b10 c6d5 b10a10 d5c5 i8i4 c5d6 a10b9 d6e5 b9b8 e5f6 b8b9 f6g6 i4i6 g6h7 b9a10 h7h8 i6i2 h8h9 i2i9 h9h8 a10b9 h8h7 i9i7 h7g8 i7i2 g8g7 i2f2 g7h6 f2h2 h6g5 h2a2 g5f5 a2a3 f5e4 a3e3 e4f4 b9b8 f4f5 e3a3 f5g4 a3d3 g4f4 d3i3 f4f5 b8b9 f5g6 i3i4 g6g7 i4i10 g7g8 b9c8 g8h7 i10i2 h7h6 i2i3 h6g5 i3c3 g5h5 c3i3 h5h6 i3b3 h6i6 b3b1 i6i5 c8d7 i5h5 b1b7 h5h6 b7c7 h6i7 d7d6 i7h6 d6c5 h6h5 c7f7 h5g4 f7d7 g4g5 c5b6 g5h5 d7i7 h5g4 b6b7 g4g5 i7i2 g5g6 i2i1 g6f5 b7b8 f5e5 i1i3 e5e4 b8b7 e4d4 i3i7 d4e4 b7b8 e4d4 i7h7 d4e5 h7g7 e5f4 b8b9 f4e4 g7g5 e4f4 b9b10 f4f3 g5i5 f3f2 b10c9 f2e2 i5i4 e2d1 c9d10 d1c2 i4b4 c2d2 d10d9 d2e3 b4g4 e3f3 g4g10 f3f2 g10g2 f2f1 g2h2 f1g1 h2h8 g1g2 d9c10 g2f3 h8a8 f3e3 a8a10 e3f3 c10b10 f3f2 a10a4 f2g2 a4a9 g2g3 a9b9 g3h4 b10a9 h4g3 b9h9 g3g4 h9c9 g4g5 c9c6 g5h5 a9b8 h5h4 c6c7 h4g3 c7i7 g3g4 i7i3 g4h5 i3i8 h5g5 b8b7 g5f4 i8g8 f4e5 g8e8 e5f6 e8e4 f6g5 e4e7 g5f6 b7a8 f6g5 e7e2 g5h5 e2a2 h5g5 a2a3 g5f5 a3a1 f5e4 a1c1 e4e3 c1c9 e3f3 a8b7 f3f4 b7a6 f4f5 c9c4 f5e5 c4c1 e5e6 c1d1 e6f5 d1d4 f5f6 d4d2 f6f5 d2d6 f5g5 a6a7 g5h4 d6d3 h4i4 d3d1 i4i3 a7a6 i3i2 a6b6 i2h2 d1b1 h2g3 b6a7 g3h4 b1e1 h4h3 e1c1 h3h2 c1b1 h2g2 b1e1 g2f3 e1e7 f3f4 e7e6 f4f3 e6b6 f3e4 b6b3 e4f4 a7a8 f4f5 b3f3 f5g6 f3f2 g6g7 f2a2 g7f7 a2b2 f7f6 b2b10 f6e7 b10b5 e7e6 b5b8 e6d6 b8h8 d6e5 h8h4 e5f5 h4g4 f5f6 g4f4 f6e5 f4a4 e5d6 a8a7 d6c6 a4b4 c6d7 b4a4 d7c8 a4b4 c8d8 a7a6 d8d9 b4b1 d9d10 b1c1 d10e10 c1c7 e10f9 c7a7 f9e10 a7h7 e10e9 h7h3 e9e8 h3g3 e8d8 g3e3 d8d9 a6a5 d9c9 e3c3 c9d9 c3e3 d9c9 a5a4 c9c8 e3d3 c8c9 d3e3 c9d8 e3e4 d8c8 a4a3 c8b9 a3b3 b9c9 e4e10 c9b8 b3a3 b8c9 a3b4 c9b9 b4c4 b9c8 e10e5 c8c9 c4c3 c9c8 e5e10 c8b7 e10e2 b7a7 e2a2 a7b7 c3d3 b7c6 a2a6 c6b5 a6h6 b5a4 h6e6 a4a5 d3e3 a5b4 e6e4 b4c5 e3f3 c5d6 e4i4 d6c7 i4d4 c7b6 d4d2 b6b5 f3f4 b5c4 f4e5 c4b3 d2i2 b3a3 i2c2 a3b4 c2c8 b4a3 e5d5 a3b3 c8c9 b3b2 c9c4 b2b3 c4f4 b3b2 f4f1 b2b3 f1f2 b3c3 d5d6 c3d3 d6c5 d3e4 c5b4 e4d4 f2f10 d4d3 b4b5 d3c2 f10e10 c2d2 e10g10 d2c3 b5c5 c3b2 g10c10 b2a1 c5d6 a1b2 c10i10 b2b1 i10i7 b1a1 i7i5 a1b2 i5h5 b2c1 h5h4 c1d2 d6c7 d2c3 c7b7 c3b3 h4d4 b3c3 b7b8 c3c2 b8b9 c2b2 d4d8 b2a3 d8d7 a3a4 d7d8 a4b4 b9a9 b4a5 d8f8 a5a6 f8f4 a6b6 a9a10 b6a5 f4d4 a5b5 d4c4 b5b6 c4c7 b6c7
i3i5 h9i7 h1i3 f9g7 e3e5 c8c6 a3a4 g7f9 d3d5 g8g7 a4a5 g7g6 h2g4 h10g8 f2h1 i10h10 g4f2 f9g7 e2b5 e9f9 f1d3 h10i10 f2g4 i10h10 g4h6 b10c8 d2e3 c8d6 d3d2 f8f7 e5d6 h8h7 b1a3 g9d6 c2g6 f7f6 g6d3 c6d5 h3h4 g7h8 d3f5 d5d4 g2h3 e8e6 i3g4 d9c8 i2g2 d8d7 g2h2 c9e7 d2g2 h8g7 g2e2 d4d3 b5b8 e6f5 h2g2 d3e2c e1e2 d6b4 g2f2 g7g6 g4i3 g6h5 b2c4 g8e9 i1i2 h5h4 b8a9 c10g6 i3h5 c8b7 f2f1 e7d8 h1i1 h4g5 c1b2 g5f4 e2e1 b7c6 d1d3 f9f7 i2c2 f4e3 i1g2 e3e2 d3e2 i9g9 c4b6 c6b5 a3b5 g10h9 e2e4 f7f9 e4e7 f9f8 b6d5 b4e7 a9c7 i7g8 c2f2 e7d6 a5a6 e9g10 h3i2 f8e8 d5e7 f5f4 i5i6 g8e7 f2c2 g9g8 a1d1 f10h8 c7c10 h8i9 d1d5 d8b10 g2h2 e7f9 c10e8 d10e9 e8e3 d6e7 h2g4 e7f8 b5c7 f4e3 g4f6 b10d8 f6f5 g6c10 f5e4 e3e2h e1d1 e9f10 c7b9 g10e9 b9c7 e2d2 d1e1 d2f1 e1f1 a8a7 a2a4 a10a9 g3g5 f9h8 b2c1 d8g5 g1i3 i8i7 c7a8 e9g10 i2h3 g5d8 h5g7 f8c5 h6i8 d8a5 i6h7 a5c7 d5d7 a9b9 d7d2 g8g9 g7h9 c10i4 d2d6 h10h9 a4a1 g9g3 a1a5 c5a3 f3f4 a3c1 a8b6 f10f7 a5a2 b9b8 c3c5 f7f6 d6d7 c7d8 d7d8 h9h10 c2i2 g10e9 d8d2 e9g8 i8h10 i4h3 f1f2 f6f4 e4f4 i9i10 f2e1 b8b7 d2d1 b7c7 i3c9 g3g4 c9f6 h3i4 h7g8 c7c9 f4d3 i10i9 b6a8 g4a4 b3b4 i9g9 a2c2 e10d9 c2c1 g9g10 i2a2 g10e8 e1d2 e8e10 c5c6 h8i6 d3e2 i4e8 a2a1 a4a2 d2e3 d9c10 d1h1 a2e2 e3f4 c10b9 h1h2 e8f7 h10f9 e10e7 a8c7 c9c7 a1a2 e7d8 f6b2 d8e7 f9h10 f7c10 b2a3 e2h2 a2a1 h2h1 g8g9q b9b8 h10g8 e7g7 c1c4 g7e5 f4e5 c7f7 c4c3 h1h3 g8h10 b8c7 e5d4 f7f8 h10g8 f8f1 a3c1 h3h5 g8f6 h5d5 d4c4 d5d8 g9g7 c7c8 b4b5 f1h1 g7h6 h1h6 f6e8 h6h4 c4c5 h4h2 c3b3 c10d9 c1d2 d8e8 c5c4 e8e4 c4d3 e4e9 d2h6 e9e2 h6f4 e2e5 f4h2 e5e8 a1g1 e8e2 b3c3 d9i4 g1g6 e2b2 g6g1 i6g7 h2g3 i4f1 d3d4 g7f5 d4e5 b2c2 g3f4 f5e7 f4h6 e7c6 e5d6 f1d3 g1a1 d3c4 c3a3 i7i6 a3d3 c6e7 d3h3 e7d5 h3a3 c4d3 d6e5 c2f2 e5e6 f2b2 h6c1 b2b5 c1g5 c8b8 g5e7 d5e7 a1d1 b5b4 e6f7 d3h7 d1d5 h7c2 a3h3 c2d1 h3g3 b4f4 f7g7 d1a4 d5d10 f4f5 d10a10 a4b3 g3g4 e7c8 a10i10 c8b10 g4g6 f5h5 i10e10 b3d1 e10c10 i6i5 g6g2 h5h9 g2g5 h9h7 g7f6 h7h6 f6g7 i5i4 g5f5 h6e6 g7g8 b8a9 c10c7 e6i6 c7c2 i6i8 g8f9 i8f8 f9f8 d1f3 c2d2 f3e4 f5f1 e4d3 f1f4 d3g6 f4c4 a9a8 d2g2 a8b8 c4g4 g6c10 g4i4 c10a8 i4i2 a8e4 g2g8 e4b1 g8g5 b1f5 i2i6 f5a10 g5a5 b8c8 i6h6 c8b9 f8f9 b9c10 h6g6 c10d9 a5c5 d9d8 c5c1 a10e6 c1d1 e6d5 d1d4 d8c9 f9e8 d5a2 d4g4 c9c10 g6f6 a2b3 g4e4 b10c8 f6f1 c8e9 e4d4 b3a2 f1b1 e9f7 d4d7 a2b1 d7d3 f7g5 d3d9 g5i4 d9d5 b1h7 d5a5 c10b10 a5f5 b10c9 f5f2 c9b9 e8f8 i4g5 f8e7 g5f7 e7f6 b9a9 f2i2 a9a10 i2i3 h7b1 i3i8 b1e4 i8i1 e4b1 i1h1 b1f5 h1f1 a10b9 f1f5 b9a10 f5f4 f7e5 f4g4 a10a9 f6g7 e5g4 g7g6 a9b10 g6f5 b10b9 f5f4 b9a10 f4e4 a10b9 e4d3 g4h6 d3e2 h6g8 e2d1 b9b8 d1e1 g8i9 e1f2 b8c9 f2f3 i9g10 f3e2 c9c8 e2d1 c8b9 d1e1 b9a10 e1f2 g10i9 f2f3 i9g8 f3e3 g8i7 e3f2 a10b10 f2g1 i7g6 g1f1 g6f8 f1g1 b10c9 g1f1 f8d7 f1e2 d7f8 e2e1 f8d9 e1d2 d9e7 d2e3 e7g6 e3d3 c9d10 d3c2 g6h4 c2c3 h4g2 c3c4 d10e10 c4d5 g2f4 d5d6 e10f10 d6c5 f4d5 c5b5 d5b4 b5c4 f10e9 c4c5 e9d10 c5d6 b4c2 d6c7 d10d9 c7d7 d9d10 d7d8 c2a1 d8d7 d10e9 d7e7 e9e10 e7e8 a1c2 e8e7 c2e3 e7f7 e3d1 f7f8 d1f2 f8g7 f2d1 g7h7 e10e9 h7g6 d1c3 g6g5 c3a2 g5f6 e9f8 f6e6 a2b4 e6e5 f8g8 e5d4 b4d3 d4e3 g8f8 e3e4 d3e5 e4d5 f8f9 d5d4 e5c6 d4c3 f9g8 c3c2 g8f9 c2b2 c6e5 b2b1 e5g6 b1a1 g6e5 a1a2 f9e10 a2a3 e5g4 a3b2 g4i3 b2b1 i3h5 b1b2 h5i3 b2c3 e10f10 c3d2 i3h1 d2e1 f10e9 e1d1 e9d10 d1c2 h1g3 c2d3 d10e9 d3e3 e9d9 e3d2 d9c9 d2c1 g3h5 c1d2 c9c8 d2e3 h5g7 e3e2 g7f5 e2d3 c8b8 d3c3 b8b9 c3c2 b9a8 c2c1 f5h6 c1b1 a8b8 b1c1 b8c9 c1c2 c9c8 c2d1 c8c9 d1e1 c9c8 e1d2 h6i4 d2d3 c8d7 d3e4 d7d8 e4d5 i4g5 d5c6 g5i6 c6b7 i6g5 b7b8 d8e7 b8a9 e7f8 a9b9 g5e4 b9c10 f8g9 c10b9 e4f6 b9c9 g9h8 c9b8 f6e4 b8a9 e4d2 a9b8 d2f1 b8c8 h8g7 c8b8 f1g3 b8c7 g3f1 c7d7 g7f6 d7c6 f1e3 c6d7 e3d1 d7c6 d1b2 c6d5 b2a4 d5e4 a4c3 e4d4 f6e6 d4c5 e6e7 c5c6 c3e4 c6b7 e4d2 b7c7 e7f7 c7b7 f7g6 b7c6 g6h5 c6d7 d2e4 d7c7 e4g3 c7d7 g3f5 d7d8 h5i4 d8d9 f5d6 d9c10 d6b7 c10d9 i4h5 a6b7 h5g6 d9d8 g6f5 d8e7 a7a6 e7d8 f5g4 d8d7 g4g3 d7d6 g3h3 d6e6 h3i2 e6d6 i2i1 d6e7 i1h2 b7b8 h2g2 b8b9c g2f2 b9d10 f2g3 e7f8 g3h3 f8g8 h3g4 g8f9 g4h5 f9e10 h5g4 d10d9 g4g3 d9c9 g3f3 c9e8 f3g4 e8f9 a6a5 f9e7 g4h3 e7f8 h3h4 f8f7 a5a4 f7g5 h4i3 g5h7 a4a3 e10f10 i3i2 f10f9 i2h3 f9e8 a3a2h h7f6 a2e2 f6e5 h3i2 e8d7 e2f2 d7e6 f2h1 e6f5 h1e1 e5g4 e1h1 g4h3 i2h3 f5e6 h3i3 e6d5 h1b1 d5c6 b1b5 c6b5
a3a5 h9g7 f3f5 g7h5 c3c5 d8d7 h2f3 c9f6 i2h2 h8h7 b2a4 f9e7 b1a3 e7d8 d3d5 b9a7 g3g4 g9i7 a1b1 e10f9 d5d6 a7c6 b3b4 f6e7 h3h4 d8e6 e2d3 e6e5 g4g5 e5g4 d3c4 f9g9 d2e4 e9c7 f2g3 g4f2 h1f2 h7h6 e4d4 g10f9 g3h3 c6a5 h3f4 e7c9 i1h1 h5i3 d1d3 e8e6 f3e5 i3h5 h2h3 c7c5 d3e2 a5c6 c4d3 c6d4 g2f3 c5c3 a4c3 d9e8 e5f7 e8f7 c3e4 c9f6 f4h5 d10c9 b1b2 c9d8 f5e6 d4e6 d3d4 c8c7 c2b1 f7e7 h5f6 f9e8 f6d7 c10b9 d4b6 g8g7 b4b5 e8g6 b6c5 e7f6 c5b4 f10g10 e4c3 f6h5 f3b7 g10f9 c3d5 d8e7 f2e4 e7e9 a3c2 h5g5 e4g5 f9d7 a2a4 a8a7 f1f2 e9f10 b7c8 a9a8 c8b9 g6e4 e2d3 f10g10 g5e6 g10f10 b4b3 h10f9 b9c10 f9d8 b1a2 e4h7 e6g7 c7d6 g1h2 f10c10 h2i1 d7e7 d3f5 g9h10 f5f4 h10g10 a4d4 d8f9 f4e5 e7f7 d5f6 f9d8 e5i5 c10e8 b3d5 i9e9 f6g4 d8f9 f2f6 f8g7 f6f3 a7a6 d5f7 e9b9 f7e7 e8i4 a2c4 b9a9 d4d5 f9e7 i5g5 a6a5 e1e2 h7g6 f3g3 i10h10 c2a3 i7f10 g5e5 a9f9 g3e1 h10i10 e3e4 g6h7 b2d2 g10h10 e5d6 f10g9 d6e5 e7g6 h3b3 b8b7 e1f2 a8c8 f2f8 a5a4 g4h2 i4i2 d2a2 c8c7 c1g5 g6i5 e5e7 h7f5 b3i3 f5e4 f8d10 f9f10 d10d7 i2i1 d5d6 i8i6 g5d2 f10d10 d2c1 d10c10 e7f8 a10a6 d6d4 c10d10 d4d3 e4f3 e2f2 i10i9 d7d6 g9f8 f2e1 i1i3 d6d4 i3h2 d3d2 h2h4 d4h4 g7g6 d2h2 c7g7 c1e3 i9a9 c4h9 g7c7 h9g8 d10d4 b5b6 b10d9 b6c7 f3e4 g8f7 e4b1 f7d9 a9c9 e3f2 b1c2 a3c2 a6c6 d9c10 a4a3 f2g3 d4d9 e1f1 d9d3 h4d8 c6d6 g3f4 c9d9 h2d2 f8g7 d8f6 d6f6 h1i1 f6f8 i1h1 d3d2 c2b4 g7d4 b4d3 f8d8 h1h5 i5h7 h5i5 b7b6 f4i1 d4f2 d3b4 d9h9 c10f7 d2d4 i5i6 d4i4 i1g3 i4i3 c7c8 h10g10 g3h2 d8d2 i6h6 f2c5 f1e1 d2d10 a2g2 i3g3 b4d3 g3g4 c8c9c c5b4 e1e2 d10a10 h2g1 b4c3 c9b10 g4c4 g2g3 c3d4 e2d2 a3a2a f7d5 a2c1 d2d1 h9h8 g3i3 c4c8 i3i5 a10a9 h6h2 a9b9 d3c1 h7f6 h2c2 b6b5 b10c9 h8h10 g1h2 g10g9 c2f2 f6d7 i5i10 h10b10 c1a2 d4h8 c9a8 d7b8 d5h9 b9d9 h2d6 d9d6 d1e2 c8c4 i10i4 b8d9 a8b7 c4f4 b7c5 f4f2 e2e3 d6a6 c5d5 f2a2 i4i8 h8f6 h9g8 b5b4 i8i7 g9f8 i7g7 a6a8 g7f7 f8e8 d5c6 b10e10 c6b8 f6i9 f7h7 a2c2 h7h2 e8f8 e3d3 e10c10 h2f2 f8g9 g8c4 d9b8 f2f5 c10h10 c4i10 c2c7 d3e4 g6g5 i10c4 c7c5 c4a6 a8a7 f5f1 g9g8 e4e3 a7f7 e3e4 h10h3 f1g1 h3h10 g1a1 h10c10 a1c1 c10c9 c1c2 i9f6 c2f2 g8g9 f2i2 c5e5 e4d4 e5e6 d4d3 g9h10 i2b2 f6e7 b2f2 c9f9 a6c4 f9b9 f2a2 b8c6 a2b2 f7f4 b2i2 c6b8 i2e2 e6e5 e2f2 f4h4 f2e2 b9h9 c4e6 e5b5 e2f2 h4h3 d3c2 b5f5 f2f1 f5f4 f1f3 f4f8 f3e3 h3h8 e6b3 b8c10 b3a2 e7d6 a2c4 c10b8 e3e4 d6f4 e4e2 f8d8 e2e10 h10g9 e10e4 g9f8 e4e10 f4d6 c2d2 h9e9 d2d1 e9g9 e10e2 h8h9 e2e7 d6g3 e7d7 g9b9 c4b3 g3e1 b3d5 b9g9 d7d6 f8f9 d6i6 e1d2 d5c6 b8c6 i6d6 g9g10 d6d3 g10b10 d3d7 c6d4 d7g7 d4f3 g7f7 f9e10 f7f4 d8d6 f4e4 f3e5 e4e5 h9e9 e5g5 d6f6 g5g1 f6f4 g1g10 e10f9 d1d2 f4f3 g10e10 f3g3 e10d10 g3e3 d10b10 f9f8 b10d10 e3g3 d10b10 e9a9 b10c10 g3e3 c10c4 a9a6 d2d1 a6a9 c4e4 a9h9 e4b4 h9h6 b4c4 e3e9 c4c3 f8f9 c3c10 h6h3 c10c5 e9e7 d1c2 h3i3 c5b5 e7f7 b5b2 i3i10 b2b9 f9f10 b9h9 f7f9 h9i9 f9i9 c2d1 i9i4 d1c2 i4i8 c2d2 i8i4 d2d1 i10g10 d1c2 f10g9 c2c3 g9h9 c3d3 g10d10 d3e3 i4i3 e3f2 d10e10 f2g2 e10h10 g2f1 h9g9 f1e2 h10h6 e2f2 i3d3 f2g1 h6h3 g1f2 d3d4 f2e2 h3a3 e2f1 d4f4 f1g2 a3a2 g2g1 a2b2 g1h1 b2f2 h1i1 f4g4 i1h1 g4a4 h1g1 a4a6 g1f2 a6a4 f2e2 g9h8 e2d2 h8g9 d2e1 a4h4 e1d1 g9h9 d1d2 h4h3 d2e1 h3b3 e1f2 b3f3 f2g1 h9h10 g1g2 h10i9 g2h2 f3f1 h2g2 f1c1 g2f2 c1d1 f2e2 d1d2 e2f3 d2d5 f3e2 d5i5 e2d2 i5i1 d2c2 i1a1 c2c3 i9h8 c3b2 a1i1 b2a2 h8g9 a2b2 i1i9 b2c2 i9i6 c2b1 g9h8 b1a1 h8h7 a1a2 i6i1 a2b3 i1g1 b3c2 g1e1 c2c3 e1e2 c3b3 e2e8 b3c2 e8g8 c2d1 h7h6 d1e1 g8g5 e1d2 h6h5 d2c1 g5a5 c1b2 a5d5 b2a2 h5h4 a2a3 h4h3 a3b2 d5d10 b2a3 h3i2 a3b3 d10d5 b3b2 d5g5 b2a1 i2i1 a1b1 g5h5 b1c1 h5h10 c1b1 h10h2 b1a1 h2d2 a1b1 d2e2 b1a1 e2e5 a1b1 e5e2 b1c1 e2e10 c1d1 i1h2 d1d2 e10e9 d2d3 e9e1 d3c3 h2g1 c3c2 e1f1 c2b2 g1h2 b2c2 f1d1 c2b2 h2i1 b2c2 d1c1 c2d3 c1d1 d3c2 i1h2 c2c3 h2g2 c3b2 g2f2 b2a3 d1d4 a3b3 d4i4 b3a2 i4i9 a2a3 f2e1 a3b4 i9i6 b4a4 i6h6 a4b4 h6d6 b4a4 d6i6 a4a5 i6i1 a5a6 i1h1 a6b7 h1h9 b7a8 h9h5 a8b8 h5h4 b8b9 h4h1 b9a10 h1i1 a10b10 i1i8 b10c10 e1f1 c10d9 i8e8 d9c9 f1g1 c9c10 e8e10 c10c9 e10a10 c9d9 a10i10 d9e8 g1f2 e8f7 i10i4 f7g6 f2f3 g6g5 i4i2 g5h4 i2i7 h4g5 i7e7 g5h5 e7e3 h5g5 e3e1 g5h5 e1f1 h5i6 f1e1 i6h6 e1g1 h6i5 g1g7 i5h5 g7g6 h5g6
c3c4 c8c7 f2g4 a8a7 b2a4 b10a8 c4c5 g8g7 c5c6 f8f6 d3d5 e8e7 b1c3 b8b6 a2b2 f9e8 c2b1 g7g6 e3e4 d9b8 g4f4 c9b10 h3h4 g6g5 e2e3 b10c9 c3e2 a7a6 e3c3 d8d7 h2g4 e9f8 i3i5 h10g8 g2i4 d7c6 f4g2 g8i7 i2i3 b8a7 f3f5 i7g8 c3f3 f10e9 b1c2 h8h6 g2e3 g8h10 a1b1 f8f7 f1g2 g10f9 g4e5 c9d8 g2h3 e7e6 e3d3 f7g7 a4c3 e10f10 i4g6 c10d9 f3g4 c6c5 d3c5 g9h8 g4i6 d9b7 i6f3 a7c6 c3b5 d8b10 g3g4 e9c9 h3f1 c6a5 f3h3 f9i6 c5a6 e8e9 g6f7 c9c10 h3f3 g7i7 f7d9 e9d7 f1h3 i7h7 i3i4 h7e10 d2c3 d7c8 h3g3 h8g7 f5e6 e10e9 f3e3 e9g9 g3h2 g7e9 d9e10 c8d6 e3c5 b7a6 h1g3 i8i7 e5c6 b10d8 c5b6 c10d9 e6e7 h10f9 c6b8 g9h10 c3b4 d9f7 c2d3 a6b7 b5d6 h6h5 b4a6 h10f8 i1i2 c7d6 a6c5 a5a4 c5c4 d10c9 g3f5 a4a5 c1d2 h9g7 c4c5 i10h10 e7e8 f7e6 b8a10 c9a7 f5d4 f8h8 c5d7 b7c8 d1c2 h8h7 b6d6 f10e10 d6e6 a7b6 d7e7 b6d6 e7c8 h10f10 d3a6 d6b4 a10b8 f9d10 a3b4 a5b4 c8b6 b4a6 b6c7 g7f9 c2c6 a6a5 c7a8 h5i4 a8a9 d10e8 e6f5 a5a4 h2f4 f10h10 f5f6 a4b4 f6e5 h7a7 f4f9 e10d10 f9h7 a7e7 g1e3 b4b5 h7e7 i6h5 i2i4 h10g10 e5f4 b5c6 e1d1 g10g9 a9c8 d10e10 c8d6 e10d10 e7g9 c6d4 f4f3 h5i6 e3f4 e8c7 d6f5 i6h5 b1c1 h5e8 c1c3 d4b3 g9g5 e8f7 f5g7 i9i10 f4h2 b3a1 i5i6 f7h9 b8d9 a1b1 g7f5 b1c1 e2c1 d8b10 c3d3 h9d5 g5i7 d5a8 d9b10 b9d8 i7h7 e9i5 e4e5 a8f3 c1e2 f3c6 h7c7 c6f3 c7c2 i10e10 g4g5 e10i10 b2b6 i10i7 b6e6 f3c6 h2f4 i7e7 d3g3 e7d7 g3g4 c6g2 c2b3 g2c6 e2c3 d8e10 e6e8 c6f3 d1e1 f3d1 i4i5 d7d6 i6i7 d1e2 b3g8 d10c10 f5d6 e10c9 g8b3 e2d1 i5i1 d1c2 g4g1 c9b7 b3f7 c2i8 f7c7 c10b9 c3d5 b7d8 d5f6 d8e6 c7b7 b9a10 d6c6 a10a9 b7b2 e6d8 f6g8 i8h9 f4g3 h9i8 c6e7 d8e6 e8e10 i8g6 e7d6 g6c10 d6d7 e6d8 d2b4 d8f9 b4e7 f9d10 e7c5 c10i4 g8h6 i4f1 b2b8 a9a10 d7b6 d10b9 e10d10 f1b5 g3f2 b5f9 h6g4 f9a4 f2g3 a4c2 d10d1 c2b1 c5b4 b1a2 b8c8 a2c4 d1d7 c4a6 d7d10 a6c4 c8c5 a10a9 b6a4 c4f1 b10d9 f1g2 g5g6 g2c6 d9f8 c6h1 d10d9 h1c6 c5b5 a9a10 d9b9 c6d5 a4b6 d5a8 b5d5 a8d5 i1i6 d5c6 i6i3 a10b9 g4h2 c6e8 i3i6 b9c9 g6g7 c9d8 g1g2 e8h5 g2f2 d8e8 i6c6 h5i4 e1d2 e8e9 d2c1 i4g6 c1d2 g6i8 b6a5 i8g10 c6c7 g10f9 c7a7 f9g8 f8h7 g8h9 h7i5 h9c4 a5a6 c4h9 b4f8 e9e8 f8a3 h9g10 a6b5 e8e9 i7i8 e9e10 i5h7 g10c6 h2f1 c6e8 b5c3 e8g10 c3b3 g10c6 h7f8 e10f9 f8h7 f9g8 h7g5 c6f9 g5i4 f9e8 f2f3 e8h5 a7a4 h5i6 a4a5 g8g7 g3f4 i6f3 b3a2 g7f7 f4g5 f3d1 i8i9a f7g6 d2d1 g6f7 a2b3 f7e6 i9g7 e6f7 b3c3 f7g8 f1d2 g8f7 g7f6 f7e6 a3b4 e6f7 i4h6 f7e6 b4f8
f2e4 i8i7 e1f2 f8f6 b3b5 h9g7 c3c4 b8b7 e4f4 c8c6 f4e6 g10i8 a3a5 i7i6 a2a3 g7h9 d3d4 g9f8 d2e1 c9a7 b5c6 i8g6 c2e4 g6f5 e6f5 a7b6 e1d2 i9i7 g3g5 f10g10 f5g3 f8b4 a3d3 i7c7 g5g6 b6a7 f2e1 d8d6 b1c3 h9i7 b2a4 a7d4 d2c2 d6d5 a4b6 i7g6 c1a3 c7i7 g3h5 e8e6 e2f2 d9f8 e1d2 f8e7 h1g3 b4a5 a3e7 a5b4 c2b2 c10f7 h5g4 f9f8 c4c5 g10f10 h2i4 e9e8 h3h4 h8h6 g3h5 e8e9 a1c1 d10d8 b2a2 f7c10 h5g7 b9a7 f2g3 a7b5 e4g6 i10i9 g6i8 a8a6 i4h6 i7g7 g4f6 d4e3 d2e3 b7c6 g1f2 c10g6 d1e1 e9e7 d3d4 b4a3 f6d7 f8h9 c1d1 h10i8 d1d3 b10a8 d4b4 d8e8 d7c9 e10e9 b4b2 a10d10 g3g5 e7f6 g5g3 g6d3 g3b8 d3f1 h6g4 b5d4 e1e2 i8h6 g2f1 f10f7 c9a8 d4f3 b2b3 f3e1 b8e5 f6f2 g4f2 h6f5 e5f5 g7g6 f5h3 d10d9 h3h2 e8e7 b3b4 e9d8 e2e1 e7e10 a2a3 h9g7 b4e4 g7f8 e4b4 d9f9 c3a2 a9e9 e3d2 e10c8 h2b8 f7f6 b6a4 f8e8 f2h1 e8d6 b8b5 c8b9 b4b2 f6d4 d2e2 d4c5 b5b7 c5c3 e1a1 d6d7 b2b5 c3a3 h1g3 b9a10 b7e10 a3g9 e2d1 g9d6 b5b2 i9h9 b2b1 d7e8 h4h5 f9f10 i3i4 d6c7 i2f2 a10d7 a8b8 c7a5 a1e5 d7c7 f2f8 f10f8 a4c5 c7d7 b8c10 d8e7 e10e9 a5a3 a2c1 f8f6 e5e2 f6f8 d1c2 a3f3 e9e10 h9a9 c2d1 f3c3 h5g6 d7c7 b1b4 c3e3 g3h5 a9a8 f1g2 c7a9 g2f1 e3i3 e10f10 a9c9 e2a2 a8a7 d1e2 i3h4 b4b2 e8f9 c5e6 a7b7 c10c9 h4h3 c9c8 e7e6 a2c4 h3i3 f1g2 f9g9 c4b4 i3c9 b4d4 b7b4 e2d2 g9h10 d4e5 e6e5 c8b10 b4b10 h5f6 e5d6 i1e1 i6i5 g2h3 h10g9 f10e10 f8d8 e10e8 c9c10 d2c2 d8d7 e8g10 c10c7 h3g4 g8g7 g4f5 b10c10 g10h10 c7e9 b2b7 e9e10 f6g8 g9h10 e1e9 e10g8 e9e5 c10c7 e5d5 d6e7 f5d3 g8i6 d5d7 e7f6 d7d4 f6e6 c2b1 i6e10 b7b5 e10d9 c1e2 d9d5 b5b2 c7f7 d4g4 f7c7 d3b5 d5b5 b1c1 b5e5 g4a4 h10g9 e2d4 e6d6 b2b8 e5h2 c1b1 c7c8 d4f3 g9h8 b8b10 c8b8 a4b4 h8i8 b4b7 b8b9 b7b6 b9i9 f3h4 i9e9 b10g10 i8g9 b6b4 h2a2 b1c1 g9f10 b4b9 d6c5 b9b2 e9e2 b2b5 a6b5 g10h10 e2e3 h4g2 a2h9 g2e3 h9h1 e3d1 h1h6 d1e3 h6e3 c1c2 f10h9 h10i10 e3e10 c2b2 e10i6 i10h10 i6f3 b2c1 f3d1 c1b2 d1c1 b2b3 c1f1 h10d10 f1f9 d10e10 f9i6 e10e3 i6g4 b3c2 g4g2 c2c1 h9h8 e3e1 g2h3 c1c2 h3a3 e1e3 a3b3 c2c1 h8i10 e3b3 i10h10 b3b4 h10i10 c1c2 c5b6 c2b1 i10g9 b1c2 g9h7 c2c1 b6c5 b4e4 h7g6 c1b1 c5d6 e4f4 g6h7 f4f7 h7h6 f7a7 d6c5 a7a6 h6i8 b1a2 b5b4 a6a10 b4b3 a2a1 c5d5 a10i10 b3b2h i10b10 i8g9 b10i10 b2b3 a1a2 d5c5 i10d10 b3b6 d10d7 b6a4 a2b3 a4a5 b3b2 a5b7 d7b7 g9f7 b2a2 c5d5 b7b2 g7g6 b2i2 d5c4 i2b2 f7h6 b2b1 c4c5 b1d1 h6g8 d1d10 g8g9 d10d1 g9f10 d1c1 c5d4 c1e1 f10d9 e1e10 d4d3 e10f10 d9c8 a2b3 d3d4 b3b4 c8b6 f10h10 b6c4 b4a4 c4b2 a4a5 b2a3 h10h7 a3a2 h7h5 d4d3 h5c5 d3e2 c5f5 a2b1 a5b6 e2d3 f5g5 d3c4 g5h5 c4b4 h5f5 b1c1 f5d5 c1d3 b6a7 b4a3 d5i5 a3b2 i5i6 d3e1 i6i5 e1f3 i5h5 f3e4 h5g5 c6c5 g5h5 e4f5 h5h4 c5c4 h4g4 f5f4 a7b7 c4c3 b7a7 b2a3 g4g3 f4f3 a7b6 f3g2 b6a7 g2g1 g3f3 g1i2 a7a8 i2i3 f3e3 i3g4 i4i5 g4e5 e3i3 e5e4 a8a7 a3a2 a7b7 e4d6 b7a8 d6c8 i3d3 c8b7 a8b7 a2b2 b7a7 c3c2c d3d7 b2b1 d7b7 b1a2 b7h7 c2d1 h7d7 a2b2 d7i7 d1f2 i7i9 b2c1 i9i10 f2f1 i10i7 c1d2 i7i9 f1e3 i9f9 e3d1 f9d9 d2c3 a7a6 d1c2 d9d8 c2e3 a6a7 e3d3 d8b8 d3e2 b8e8 e2g3 e8g8 g3f5 a7b8 f5e3 g8e8 c3b4 e8e5 b4c4 e5c5 c4c5 b8a9 e3f5 a9a10 f5h6 a10a9 c5d6 i5h6 g6g5 h6h7 g5g4 a9b8 d6e5 b8c9 e5d5 c9d9 g4g3 d9d10 g3g2q d10c10 g2i4 c10d10 i4c4 d10d9 d5c6 d9c9 c4f1 h7h8 c6b5 c9d9 f1i1 d9d10 i1i5 d10e10 b5c4 e10d9 c4d4 h8h9a i5h5 d9d8 h5g5 d8e9 g5d8 e9e10 d8c9 h9i8 c9a7 e10e9 a7a2 i8g6 a2d2 g6c10 d2h2 c10b9 d4c5 e9f10 h2h7 b9e6 c5b5 e6c4 b5b4 c4e3 h7h1 f10g9 b4a4 e3g1 h1h9 g9h9 a4a3 g1e2 a3b3 e2c3 b3c3
d3d5 i8i7 f2d3 h10i8 e1f2 h9g7 f3f4 g7e6 e2e1 a8a6 d1g4 d8d6 h2f3 i9h9 d5e6 g9h10 f2e2 c9d8 a3a4 e8e7 c3c4 d9c9 d3d4 c9b7 h3h4 d10c9 e2d1 i7i6 d4c3 i8h6 a2a3 h6i8 g4h5 b7c7 d1e2 c10d9 h5f7 i8g9 b2d3 d9e8 f3d4 b9a7 c1b2 g8f7 d4c6 c7d5 c6e5 d5b6 d3f2 g9i8 e5d3 b6a5 c3b5 f9g9 g2d5 h8h7 e1c1 e9f9 c1e1 a5c4 i3i4 h9i9 h4h5 c8c6 d3c5 b8b6 g1i3 g9g8 h5i6 c9b8 f2g4 c6b5 g4h6 f7f6 e2f2 c4d2 b2c1 g8h6 c2f5 e8h5 c5e4 f9c9 e4c3 d2f3 d5f3 h6g8 e3e4 e10d9 f1g1 i9e9 c1b2 c9d10 e1c1 d8c7 a4a5 f10e10 f2e3 f8f7 e3f2 d9c9 c3e2 h10i9 i6i7 g8g7 i4i5 h5f3 c1f1 f3g4 i3f6 e9h9 b3b4 b8a8 f5g6 d6d5 f1c1 a8b9 g1h2 g7f6 h2h3 e10e9 f4f5 b9a8 b2f6 h9h8 f2g1 c9c8 h3g4 a9d9 i5i6 h8d8 g4i4 d8d6 a3c3 c8c9 c1d1 e9d8 d1d2 d10f8 i4g2 h7g6 f6i3 g6g5 d2b2 f7f6 b2d2 a8c10 c3c6 d9f9 d2e1 c10i4 c6c5 d6e6 e1f1 f8f7 f1c1 i4e4 g3g4 i9g7 a1a3 e4d4 c1e3 f7c10 h1f2 c10f10 e3c1 d8d10 i3h4 d10d8 e2f4 g7e9 g2f3 f10c10 f5e6 i8h10 a3a2 e9i5 f3e4 f9h9 e4g6 c9d10 f4h3 a7c6 a2c2 c10f7 c5c3 g10d7 c1b2 h9h7 i2i3 d8f8 b1a3 c7f4 i3i2 f8a8 i1h1 h7h8 h4g3 i5g7 g6d3 f7g6 g1h2 g6h7 d3e4 d10e10 i2i1 d4e3 c3e3 a8b7 e4d5 g7i5 d5f3 i5d10 c2e2 h8f8 h1g1 h7c2 f3c6 b7b8 h2g2 h10i8 g3f4 f8h8 e6d7 b8d6 f4g5 h8h7 e3c3 d6c5 g5d2 c5c3 f2h1 f6f5 h1i3 h7h4 d2g5 d10f8 b2b3 i8g9 c6e4 c3c9 i3h1 c2a2 g5e7 g9e8 e4f5 c9d10 i1i4 e10f10 e7f6 h4i4 a3c2 d10b8 g1a1 b10d9 a1a2 b6a5 g2f3 f8c5 h3i5 e8c9 b3b2 b8d8 f6i9 d8f6 e2e8 a10d10 e8f8 f10e10 f5f6 c9a10 f6d6 c5a7 d6h2 a7f2 a2a4 f2h4 b2e5 h4e7 h2h4 i4i3 f3e4 i3c3 c2e3 d10b10 h4g5 i10h10 f8f2 h10h7 g5h4 h7h10 e3c2 d9f8 b4a5 c3h3 i5g6 h10i10 e5d4 i10f10 h4f6 b10b9 f2d2 h3h4 f6f3 b9h9 f3f2 h9b9 d4b4 b9g9 d2d1 e10f9 f2i2 b5a4 g6e5 f8h7 e4f4 h7g5 b4b10 g5e4 b10b1 f10e10 d1c1 e4f2 b1b2 g9g5 i9g7 h4g4 e5g4 g5g6 i2h2 g6i6 g4e3 f2e4 h2i1 f9g10 g7i9 e7d8 b2b7 d8b10 d7d8 i6b6 c2e1 e10e5 c1d1 b6b7 i9e5 e4c3 i1i3 g10f10 e5b8 c3a2 i3i2 b10a9 i2g2 b7e7 d1b1 e7d7 g2a8 d7h7 d8d9a f10g9 e3c4 h7i7 c4a3 i7c7 a8c6 a9b8 c6e6 c7d7 e6d6 b8d6 f4e3 d7c7 b1b9 d6e7 b9a9 e7f6 h1g3 f6d4 e3f4 c7c2 d9g6 a10c9 a3b1 d4h8 g6d9 c9b7 b1a3 b7c9 d9g6 g9f10 a9b9 a2c1 e1d3 f10f9 g6i4 f9f8 i4f7 h8i9 f4e4 i9a1 d3c1 c2h2 b9a9 c9b7 a9h9 b7a9 f7d8 h2e2 e4d5 e2e4 d5c5 e4e3 g3i2 a1b2 d8i3 b2e5 i2h4 e5f4 i3g1 f8g7 h9h8 e3e10 h4f5 g7f6 h8i8 e10f10 i8i5 f6g6 g1h2 f4h2 i5g5 g6g5 c5b6 f10a10 f5h6 a10b10 b6a7 b10a10 c1a2 g5h4 a7a6 h4g3 h6g4 g3f4 a2c3 f4g3 g4f2 a10h10 a3b1 g3h4 a6a7 h4i3 f2d3 h10i10 c3d5 a9b7 b1c3 i10i6 d3c1 i6a6 a7b7 i3h3 c1e2 a6a8 e2c1 a8b8 b7a7 b8b6 d5b6 h2g3 b6d5 h3h2 a5a6 g3b8 a7b6 h2g2 c3b5 a4a3 d5c3 a3a2a c1e2 g2h3 c3a4 h3h2 b6c5 a2g8 e2g1 b8g3 g1h3 g3h4 a6a7 g8i9 h3i1 i9g10 b5a3 h4d8 a4c3 d8i3 c3e2 i3g5 a3c4 g5d8 e2f4 d8f6 c4e3 g10b5 e3g2 b5c4 f4e6 f6d8 g2f4 d8h4 e6f8 c4e2 i1g2 h4d8 f4g6 d8g5 f8e6 h2g3 a7a8 e2h5 a8a9q g5f4 a9a10 h5i4 g6e7 g3f3 c5b6 f4g3 a10d10 g3i1 e6d4 f3f2 d4c2 i1h2 b6a7 i4h3 g2e3 h3g2 e3c4 h2b8 d10b8 g2e3 c2d4 e3g4 a7a6 g4a10 e7c8 f2e1 c4d2 a10b8 a6a5 b8d9 c8a7 d9g6 a7c8 g6h5 c8b6 h5f3 a5a6 f3g4 b6a4 g4c8 a6a5 c8e7 a5b5 e7c9 d2b1 c9b7 d4c2 e1d1 a4b6 d1c1 b1c3 b7a5 b6a8 a5b7 b5c4 b7f3 c4d3 f3i6 a8c7 i6g4 c3d5 g4f3 d3e3 f3d2 e3d4 d2e4 c2a1 e4c2 d4c3 c1d1 c3c4 c2g6 c4c5 d1c1 c5d4 g6h4 d4c5 h4b10 d5f4 b10d9 c7a8 d9f8 c5b6 f8g7 f4h5 g7e8 a8c9 e8a4 b6a5 a4b5 h5g3 b5a7 a1b3 c1b2 g3i4 a7c8 c9a10 b2b3 i4h6 c8e7 a5b6 e7d8 b6b5 d8f9 b5a5 f9h7 h6g4 h7f9 g4i5 f9e8 i5g6 e8d6 g6i5 d6b8 a10c9 b8g3 a5b5 g3f2 b5c6 b3c2 c6d6 f2c5 d6d5 c5b4 d5e4 c2b2 c9e8 b4d3 e4d4 d3f5 d4e5 f5d4 e5d4 b2b1 e8f10 b1a2 i5h7 a2b2 d4e3 b2b1 h7i9 b1c1 f10e8 c1c2 e3e4 c2c3 e4f4 c3b4 f4e4 b4a3 i9g10 a3b4 e4f3 b4c5 f3g4 c5c6 g4g5 c6b6 e8c7 b6c6 g5g6 c6b6 g6h6 b6c5 c7b5 c5d5 g10h8 d5e4 h6h7 e4d3 b5c7 d3e4 h8f9 e4e5 h7g8 e5f4 c7a6 f4g5 a6c7 g5h4 c7e8 h4g5 g8g9 g5g4 e8g7 g4f3 f9d8 f3e4 g7f5 e4e5 f5h6 e5e4 d8b9 e4d3 g9f9 d3e4 h6i4 e4f4 f9f8 f4f3 b9c7 f3g2 c7b5 g2f3 b5d4 f3f4 i4g5 f4g4 f8g8 g4g5 d4e6 g5h5 g8g7 h5i4 g7f8 i4h4 f8e9 h4g3 e6c5 g3f3 c5a4 f3g4 e9f10 g4f5 f10g9 f5e5 g9f8 e5e4 f8e9 e4e3 e9f10 e3e4 f10f9 e4d4 f9f8 d4e5 a4c5 e5f6 c5a6 f6e5 f8e7 e5d4 e7f8 d4c4 f8f7 c4b3 f7f8 b3a3 f8f7 a3a2 f7g7 a2a1 g7g6 a1b2 g6f5 b2c1 f5g4 c1c2 a6c7 c2b2 c7d5 b2b1 d5e3 b1c1 e3f5 c1d1 g4g3 d1d2 g3f3 d2c1 f3e3 c1b1 f5e7 b1a2 e7f9 a2a3 e3d4 a3b4 d4d3 b4a3 d3c3 a3a2 c3b4 a2b1 f9h10 b1a2 h10i8 a2b1 b4a5 b1a2 i8h6 a2a3 h6i8 a3b3 i8h10 b3b2 a5b5 b2c1 b5a6 c1c2 a6a5 c2d1 h10f9 d1e1 a5a4 e1f2 a4b5 f2e3 b5a4 e3f2 f9h10 f2e3 a4b5 e3d2 h10g8 d2c2 g8h10 c2d2 b5c6 d2d3 c6d7 d3c3 d7d8 c3b3 h10i8 b3c2 i8h10 c2d1 d8d9 d1e1 d9c10 e1e2 c10d10 e2d2 d10d9 d2c2 d9c8 c2b1 c8c7 b1c1 c7c8 c1c2 c8b7 c2b3 b7c6 b3c4 h10i8 c4c3 i8h10 c3c2 c6c7 c2b3 h10i8 b3c3 c7d7 c3d4 d7e6 d4c4 e6e5 c4c5 i8h10 c5b5 e5d6 b5a6 d6c7 a6a7 c7d7 a7b7 h10i8 b7a6 d7e6 a6b7 e6d5 b7c8 i8g9 c8c9 d5e4 c9d9 g9i10 d9d8 e4e5 d8e8 e5f6 e8d9 f6e5 d9c10 i10g9 c10c9 g9i10 c9d10 e5f6 d10c9 f6g7 c9b10 g7f7 b10c10 i10g9 c10b10 f7e8 b10c10 g9f7 c10b10 f7e9 b10c9 e8d7 c9d10 d7d6 d10e9
h2i4 b9c7 h3h4 f8f6 i4g5 e9g7 f2h3 c10b9 g3g4 d9c10 g5h7 g9f8 d3d4 g8h7 g1f2 f6f5 a3a5 c10d9 b3b5 a8a7 e3e4 a7a6 d2e3 d10e9 i2h2 g7g4 a2a4 f9g7 b1d2 g7h6 d2c4 a9a8 a1a3 h6g8 e3d3 g4i6 a3a1 f5f4 a4b4 i6h5 h1g3 g8f6 g2h1 i8i7 f1g2 f6g4 g3f1 f8g7 c4b6 d8d6 a1a4 g4f3 g2f3 c7d5 b6c8 a8a7 f3g4 d5b6 h3g1 f10f8 h2g2 d9c10 c2b3 b6d7 e2d2 h5b5 d1c2 e8e7 b3e6 c10d10 g1h2 e10f10 d3c5 d10c8 a4a3 a7b7 g4g7 f8f7 c5d5 f10f9 d5e3 f7h5 e6c4 b5a4 h2g1 c8c7 b4a4 d7f6 g2g5 b10c8 c4d5 h5d1 b2d1 a10a7 h4h5 b9c10 i3i4 f6e4 a4c4 f9e8 a3a2 c7a8 g1i2 h9f10 h5h6 h10f9 f2i5 g10h9 g7g8 e8d7 c4a4 c10b9 g8f9 d7d8 g5g10 e7e6 f9c6 h9f7 c2d3 b9c10 g10i10 a8b9 i5h4 d8d9 a4a3 c9e7 h1e4 e9f8 e3f5 i9i8 c6e8 f7e8 f1e3 e6e5 d5c6 b9a10 i10i9 d9e10 a2c2 b7b1 i1h1 e8d9 f5g3 b1b4 h4f6 e7d8 c6a4 c8a9 d3a6 a7b7 a6d6 f8d10 i9h9 d8b6 c2b2 b6a5 d4d5 b4b5 d6d7 f10h9 g3f1 i8i10 f6b10 a5c3 d5d6 c3d4 d7d8 b7c7 d2d3 c10b9 e3d5 d4c3 d1c3 a9c8 d8e7 d10e9 a3a2 c7c5 b2d2 h9g7 e7f6 b5b3 e4h7 g7f9 f6e6 i10i8 f1h2 b3b2 c3b1 c8b10 d5c7 i7h6 h7g6 c5c4 a4c6 c4a4 c6b5 a4d4 h2g2 e9e8 e6g4 e10d10 h1h2 b10a8 g2f1 a8c7 e1d1 e8g8 d3h3 b8b7 h3a3 g8i10 a3b2 i8i9 a2a7 i9i5 g4g2 d10c10 a7a4 i10g8 g2b7 i5h5 i2g1 g8f8 g6d3 f9e7 b5f9 b9i2 b1c3 f8g7 b7b10 a10b10 a4a5 b10a8 d3g6 h5f5 c3e4 g7i7 f9i6 f5f8 g1f3 a8b7 h2e2 b7b6 a5a9 f8d8 b2b5 b6a7 i6h7 a7a6 d6d7 d9f7 b5a5 e7g6 a5d5 a6b5 f1g1 d8c8 e4c5 b5a7 e2e3 c7b5 d5d4 i2d7 c5b7 f7h9 d4c3 b5d6 c3b3 c8c5 f3e5 h9g8 b7d6 g8e10 a9f9 a7a8 d2e2 d7c6 e5f4 c6b7 f9f10 c5c8 e3d3 c8g8 b3f7 c10c9 e2a2 g6i5 f7f5 g8g2 d3b3 g2b2 h7g8 b7f3 f4f3 h6h5 f3h2 b2b3 f10g10 b3b9 h2f1 a8a9 f5a5 a9c10 a5c3 c9d9 a2a6 b9a9 f1g3 h8h7 c1b2 a9a8 g3e2 a8g8 b2a1 c10e9 a6a5 g8h8 a1b2 e9c10 e2f2 i7i6 f2e3 i6h6 c3d4 h8h10 a5b5 c10b9 b5h5 b9a8 g1e2 d9d10 g10g4 d10e9 h5a5 e9d9 e2d3 h6d10 d3c3 a8b6 d6c4 d9e9 g4g6 e10d9 g6g9 e9f10 c3d5 b6c4 g9g3 c4d5 g3h3 d9a6 d4h4 d5c5 e3d4 f10e9 h3a3 d10d8 b2c3 c5d5 a5a4 d5e6 h4i5 e9f10 c3a5 d8a5 i5h5 a5h5 d4f3 h5f7 a4c4 f7f3 a3f3 e6f6 f3h3 a6e10 d1d2 f6h5 c4c7 h5f4 c7a7 f4d3 d2d3 h10h8 a7a5 h8i8 h3e3 i8i7 d3c4 h7h6 e3a3 e10f9 a5d5 i7g7 a3a9 f9g10 d5d9 g10a4 a9a5 a4c2 d9d6 c2b1 a5b5 b1g6 b5b4 g6h5 d6d2 f10g10 b4a4 g10f9 d2d1 g7g5 a4a7 h5e2 c4c3 e2f3 a7e7 f3h1 d1b1 f9f8 b1e1 h1e4 e7e5 g5i5 c3b4 i5e5 e1i1 e5e9 b4c4 e9c9 c4b4 c9f9 i4i5 f8e8 b4a4 f9e9 i1a1 e4b7 a4a5 e8f7 a1a3 e9e4 a3i3 h6h5 a5b5 e4e10 i3d3 h5h4 d3g3 e10a10 b5b4 a10c10 g3c3 c10b10 c3c2 b7e4 b4a5 h4h3 c2c8 b10b7 c8c1 b7b3 c1c2 e4b7 i5i6 b3b2 c2c1 b2a2 a5b6 f7e7 c1f1 b7d5 f1h1 a2a10 h1h2 a10a4 h2d2 a4f4 b6a7 f4c4 a7a6 d5g8 d2d7 e7f6 d7h7 c4h4 h7h9 f6f7 h9h8 f7g6 h8h4 g8e10 a6a7 h3h2a h4h5 e10f9 h5b5 g6g7 i6i7 h2e5 a7b6 f9c6 b5d5 g7h6 d5d1 h6g5 d1d10 c6a4 d10b10 e5d3 b10b7 a4d7 b6c7 d3e1 b7b3 d7b5 b3b2 b5d7 b2b8 g5h6 b8c8 h6i5 c8a8 e1g3 c7b7 d7a4 a8a7 i5h6 b7b6 g3i5 b6a5 i5e1 a5a4 h6h5 a7a5 h5i6 a5h5 e1f2 h5b5 f2b6 a4b4 b6d8 b5a5 d8e6 a5a8 e6c8 b4c4 i6h5 c4c3 c8h3 a8a10 h5i4 a10c10 h3g1 c10f10 g1f2 f10f9 i4h5 c3c4 h5i4 f9f2 i4i5 c4c3 i5i4 f2c2 i4h5 c2c1 h5i5 c1e1 i5h5 e1e6 h5g5 e6e1 g5h5 c3b4 h5h6 b4c5 h6h5 c5b5 h5h4 e1c1 h4i3 c1b1 i3h3 b1g1 h3h4 g1e1 h4g4 e1e10 g4f3 b5b6 f3g3 e10c10 g3f4 c10e10 f4g5 e10e1 g5h4 b6c7 h4i5 c7b6 i5h4 e1e7 h4h3 e7c7 h3h2 c7c4 h2g2 b6c7 g2f1 c7c6 f1g2 c4b4 g2h2 b4b8 h2g2 b8b7 g2g1 b7b6 g1h1 b6b10 h1h2 b10b9 h2h1 b9g9 h1i1 i7i8 i1i2 g9g3 i2h1 g3a3 h1i2 c6d6 i2i1 i8i9a i1h1 i9e5 h1g1 a3a1 g1f2 d6e7 f2e2 e5c6 e2d3 a1a3 d3d2 c6a5 d2d1 a5e1 d1c1 e1d3 c1d1 e7d6 d1d2 a3a5 d2d1 a5f5 d1d2 f5f7 d2d3 d6c5 d3e3 c5b6 e3e4 f7b7 e4e5 b7b8 e5e6 b8b9 e6d6 b6a6 d6c6 b9i9 c6d6 a6a5 d6e7 i9c9 e7d7 c9c6 d7d8 a5b6 d8e8 b6a6 e8f8 c6i6 f8e8 i6d6 e8e7 d6d5 e7f8 d5d9 f8e7 d9d1 e7f7 a6a7 f7f8 a7a6 f8e7 d1e1 e7f6 e1i1 f6g7 i1i6 g7h7 a6b5 h7h8 b5a5 h8h7 i6i2 h7g7 i2h2 g7g6 h2d2 g6h6 d2d8 h6g5 d8h8 g5f6 h8h2 f6e6 h2h4 e6d7 h4e4 d7d6 e4e9 d6d5 e9h9 d5c4 h9h2 c4c5 h2h9 c5c4 h9d9 c4c3 d9d2 c3b3 a5b5 b3c3 d2f2 c3b3 f2f10 b3c2 f10g10 c2b1 b5b4 b1c1 g10g8 c1b2 b4a4 b2a2 g8g3 a2b2 g3g7 b2a1 g7a7 a1a2 a7i7 a2a1 i7i2 a1b1 i2i9 b1c1 i9h9 c1b1 h9b9 b1c1 b9i9 c1c2 a4b5 c2b1 i9i4 b1b2 i4i2 b2c1 i2i6 c1d1 i6i7 d1d2 b5c5 d2e2 i7i10 e2e3 i10h10 e3d2 h10g10 d2c1 g10g6 c1d1 g6f6 d1c2 f6a6 c2d3 c5b5 d3e2 a6h6 e2d2 b5b6 d2d3 h6h5 d3c4 b6a6 c4c3 h5h7 c3b3 h7c7 b3a4 c7c5 a4b3 c5i5 b3a2 i5i2 a2b3 i2i4 b3c3 i4g4 c3b2 g4d4 b2a1 d4d5 a1b1 d5f5 b1b2 a6b5 b2c2 b5a5 c2b3 f5f10 b3a3 f10f7 a3b3 f7f5 b3b2 f5f6 b2b1 f6f1 b1b2 f1f8 b2c1 a5a6 c1d1 f8f1 d1d2 f1f10 d2d1 f10f3 d1d2 f3f6 d2c2 f6h6 c2c3 a6b6 c3c2 h6c6 c2b1 c6c10 b1b2 c10c7 b2b3 c7h7 b3a2 b6c7 a2b1 h7h9 b1c2 h9h4 c2c3 h4h2 c3d4 h2h8 d4c4 c7c8 c4c3 c8d8 c3c4 d8c7 c4d3 h8h1 d3e3 h1f1 e3e4 c7d7 e4d3 f1f7 d3c4 d7d6 c4b4 d6e7 b4a4 f7f9 a4a3 f9i9 a3a4 i9c9 a4a3 c9a9 a3b3 a9a6 b3c3 a6a9 c3c2 a9a2 c2b3 a2a9 b3c4 a9a10 c4d5 e7f7 d5e5 f7g7 e5d6 g7h8 d6e6 a10a1 e6f7 a1g1 f7f6 g1i1 f6f7 i1i7 f7e8 i7i1 e8d7 i1h1 d7c8 h8i9 c8d8 h1b1 d8e7 b1h1 e7f8 h1h8 f8g7 h8g8 g7h7 g8g2 h7h6 g2a2 h6g7 a2a7 g7g6 i9i8 g6g5 i8h7 g5f5 h7h6 f5e5 h6g5 e5e6 a7b7 e6e5 b7c7 e5d6 g5f6 d6c7
b2a4 i8i7 f2g4 d9e7 h1f2 g8g7 a4c5 e7d7 g4f4 b8b6 a2b2 d7b8 g3g4 c10d9 c5e6 b8d7 d3d4 d10c10 f2e4 c9d10 g1f2 d7c7 f4d3 h8h6 e6d8 f9d8 g2h1 d8d7 f2h4 c7d8 c3c5 d7e6 e4f6 b6b5 f1g2 e6f4 b2a2 c8c7 f6e8 f4f5 g4f5 d10c9 g2g1 d8e7 d2e4 d9e8 g1g5 e7e6 e4f6 b9d8 g5g2 e8h5 e1f1 a9b9 e3e4 h10i8 c1d2 e9d10 d2f4 e6g5 g2g5 c9a7 f6g6 a10a9 f1e1 c10c9 f4d6 c9c8 g6f7 i7i6 d6f8 b9b7 b3b4 g9i7 c2b3 c8b8 h2f1 a9f9 f7e8 f9c9 b1d2 h5g6 f8e7 b8b9 e2g2 b10d9 b3g8 d8f9 e8g9 f10g9 a1b1 d10c10 e1e2 b9c8 f5g6 a7b6 d1e1 c10b9 h4i5 g9f8 d3c3 c8e8 e2d3 b9h3 g5f5 h3g2 d3c2 g2g6 c3e2 i7f10 f5c8 f10d8 e7g5 d8f10 e1c1 e8e6 f3f5 h6i5 d2b3 c9c10 e2f2 b7b8 g8e6 g6f6 e4e5 b6a5 c2b2 i8g9 b4a5 b8b9 h1b7 f8c8 f2g1 c8b7 e6d7 f6f5 g5h6 f5f2 g1f2 i5i4 c1c2 b7c6 h6c1 g9f7 c2d2 f9d10 b3a1 f7e9 d4d5 h9f8 b2c2 c6b7 d7f9 i9f9 d2g5 b7c8 g5d2 b9c9 a2b2 f8g6 b2b4 e9g8 f2h3 f9g9 d2e3 g8h6 i1h1 d9b8 a3a4 c9e9 e3f3 c8b9 h3h4 h6g4 i2g2 g6h8 f3d3 b8d9 c1g5 i10i7 b4b5 d10c8 g2e2 d9b8 c2b3 g10e8 h4i6 c8b10 h1h8 g4f6 e5e6 f6d7 h8h7 g9h9 d3d4 e9d9 d4f4 i7i8 f4f2 h9g9 f1e3 b9a9 e2e1 a9b9 i6i7 e10d10 e1g1 e8g10 g5h6 i8i9 h7h10 d9e9 f2c2 g9f9 b3a2 f9f5 c2c4 i9h9 g1g5 b9a9 a2b2 d10d9 c4e4 f5f4 e3g2 d7e5 e4e5 e9g9 h6i5 c10d10 e5e4 h9i9 b5b3 f4f5 g5g4 i9i10 h10h9 f5f1 g4g3 b8a6 i7i8 g9e9 e4i4 d9e10 g2e1 d10d8 e1g2 d8d9 b3c3 e9e7 b2b3 f1f7 h9h7 a9b9 b3c4 b9b2 c5c6 e7e8 b1c1 f7e7 h7h6 d9d7 g2i1 e8b8 h6h10 f10e9 c4d3 e10f9 h10h1 g10h9 g3g2 e7e6 i8h10 i10h10 i4g6 b2b5 d3d4 b5b4 c3c4 f9g10 g6g7 d7g7 d4d3 e6e2 h1h5 e2e8 h5h2 e8e6 i5e1 b4a5 h2h5 e6f6 g2g1 b8b6 i3i4 f6f7 i1h3 a5e1 d3d4 e1f2 d4e5 g10g9 h3i1 h9g10 c4h4 e9f8 i4i5 f7f5 e5e4 f8c5 a1c2 b6b3 c2a1 a8a7 a1c2 f5e5 e4e5 f2e2 e5f5 g7g6 i5i6 g10i8 g1d1 b3h3 i1g2 h3d3 c2d4 g6e6 f5f4 c5e7 h5h6 h10c10 d5e6 e7f8 h4h3 c10h10 e6e7 d3d1 h3i3 f8d10 a4a5 h10h7 d4b5 g9g8 g2h4 d1f1 i3f3 e2d1 i6i7 d1d8 c1c2 d10c9 c2c3 a6c5 c3e3 f1b1 b5d4 d8f10 f4g3 f10f4 g3f4 b10a8 f4g5 c5b7 h4i2 b1e1 g5f4 g8g7 e3c3 a7a6 f3g3 g7f7 g3g6 e1e5 d4f5 c9b8 c3e3 b7a9 h6h4 h7i7 g6g7 f7e8 e3e4 i7i2 e4b4 e8d9 h4h9 d9c8 f5h6 b8a7 g7g1 e5d5 h9a9 d5d1 b4b8 a7b8 g1g5 i2b2 g5c5 d1d8 a9e9 a8b6 e9e10 d8d9 e10h10 d9d2 h10h7 b6a8 c5i5 a8b10 h7h8 c8c9 f4e5 d2e2 e5d4 e2e4 d4d3 b10c8 h6g8 b2b1 g8f10 e4f4 d3e2 b1g1 i5i7 f4f6 i7i3 i8g10 i3i6 f6f10 i6i9 g10h9 h8g8 g1g7 i9i6 f10f2 e2f2 h9g8 i6i2 c8e9 i2i7 g8d5 f2e2 g7i7 e2f2 c9b9 f2g3 b9c9 e7e8 d5c6 g3f2 e9f7 f2e3 c6h1 e8e9c i7i9 e9c10 c9c8 e3e2 h1g2 c10b10 c8d8 b10a8 g2a8 e2e1 a8b7 e1f2 i9a9 f2g1 d8e7 g1f2 b7c6 f2e2 f7h6 e2e1 c6b7 e1f1 c7c6 f1f2 h6i8 f2f3 a9a7 f3g4 a7a10 g4h5 b7a8 h5i4 i8h6 i4i3 a10f10 i3i2 f10a10 i2i3 e7d6 i3i2 d6c7 i2i1 h6f7 i1h2 b8a7 h2i1 a7b6 i1i2 b6d4 i2h1 d4c5 h1i2 c5d6 i2i3 f7h6 i3i2 a10a9 i2h1 a9d9 h1g2 d9f9 g2g1 f9f1 g1g2 f1f10 g2g1 d6g3 g1g2 h6f7 g2h3 f10i10 h3g2 c7b7 g2g3 i10b10 g3h3 b7a7 h3i2 b10g10 i2h2 g10d10 h2h1 d10h10 h1g1 f7d6 g1f2 d6f7 f2g2 f7d6 g2g1 h10h1 g1h1 c6c5 h1i2 a8f3 i2i3 f3g2 i3i2 d6f7 i2i1 g2e4 i1h2 a7b7 h2i3 b7c7 i3h4 c7d8 h4i4 f7h6 i4i5 h6i8 i5h5 d8c7 h5g4 c7b7 g4h3 b7c6 h3g3 e4d5 g3g4 c6b7 g4g5 i8h10 g5h6 d5g8 h6i5 b7a8 i5i4 g8c4 i4h3 a8b8 h3h4 c4g8 h4i5 g8e6 i5i6 e6a2 i6h7 a2e6 h7g7 b8a8 g7h6 a8a7 h6g7 e6g4 g7f8 g4e2 f8e9 e2g4 e9f10 a7b7 f10g10 b7a7 g10g9 h10g8 g9g8 a7a8 g8f9 g4i6 f9e8 c5c4 e8d9 i6g8 d9e9 a8b8 e9f10 b8b9 f10g10 b9c8 g10f10 c8c9 f10g9 c9b10 g9g10 b10a9 g10g9 g8e10 g9h9 e10g8 h9i8 g8f7 i8h7 f7i4 h7i7 i4e8 i7h7 e8c6 h7h6 c6e4 h6i5 e4h1 i5i6 h1b7 i6i7 b7c8 i7h6 c8f5 h6i7 f5c8 i7h8 a9b9 h8h9 c8e6 h9i8 b9a9 i8h7 e6g4 h7g6 g4i2 g6f6 a9b8 f6f7 b8c8 f7g6 c8c7 g6h5 c7c6 h5g6 c6c7 g6h6 i2a10 h6i6 a10f5 i6i5 c4c3 i5h5 c7d6 h5i4 d6c6 i4h5 c3c2c h5h6 c6b5 h6g5 f5e4 g5h4 c2c1 h4i3 b5c6 i3h4 e4c2 h4h3 c2i8 h3g2 c1b1 g2f3 c6d6 f3g3 i8h7 g3h4 b1c2 h4h3 c2e1 h3h2 d6d7 h2h3 h7c2 h3i4 e1f1 i4i5 d7e6 i5i6 c2i8 i6h6 f1g3 h6g7 i8f5 g7g8 g3e4 g8h8 e4g5 h8i9 g5h5 i9h10 e6d6 h10h9 d6d5 h9i10 d5c6 i10i9 f5d3 i9h8 h5g6 h8i8 g6f7 i8i7 f7h8 i7h8 c6c7 h8g8 d3i8 g8f9 c7d8 f9f10 i8e4 f10g9 d8d9 g9h9 e4f3 h9h10 f3g2 h10i9 g2e4 i9h8 d9c9 h8g7 e4b1 g7f6 b1e4 f6e6 c9d8 e6f7 e4d3 f7f8 d3g6 f8g7 g6b1 g7h6 d8d9 h6g7 b1c2 g7g8 d9c9 g8h9 c2h7 h9h10 c9c10 h10i9 h7c2 i9h10 c2d3 h10g10 c10d9 g10h10 d3f5 h10g9 d9d8 g9h10 d8e7 h10g10 f5d7 g10f10 e7d8 f10g9 d8c9 g9f8 d7i2 f8e8 c9b10 e8f9 i2h3 f9g10 b10a9 g10g9 h3f5 g9f8 a9b9 f8f9 f5e4 f9e10 e4a8 e10f9 b9a10 f9g8 a8f3 g8g7 a10b9 g7h7 f3h5 h7g7 b9a10 g7h7 a10b9 h7g7 b9a8 g7f8 h5d1 f8f7 a8b8 f7e7 b8c8 e7f6 c8c7 f6e5 c7b8 e5d5 b8c7 d5e5 d1h5 e5f6 h5d9 f6f5 d9e8 f5g5 e8a4 g5f6 c7c8 f6f5 a4b3 f5g6 c8d7 g6f5 b3c4 f5e5 d7d8 e5f4 d8e8 f4f3 e8f7 f3g4 c4d3 g4f3 f7e6 f3f4 d3c2 f4g4 e6d7 g4h4 c2i8 h4g4 i8h7 g4h3 d7c6 h3g2 c6d6 g2f3 d6e5 f3e3 h7e4 e3e2 e5f5 e2d2 e4g2 d2d3 g2f3 d3d2 f5g5 d2d3 f3d5 d3d4 d5g2 d4c3 g5h4 c3c2 h4i4 c2b2 i4h3 b2a3 h3g4 a3b2 g4h5 b2c3 g2h3 c3d4 h5h6 d4d3 h3f5 d3c4 h6i6 c4d4 f5c8 d4d3 i6h6 d3e2 c8b9 e2d1 b9h3 d1e2 h3f1 e2f2 f1h3 f2f3 h6i6 f3g3 h3e6 g3f2 e6i10 f2g1 i10a2 g1f1 i6h5 f1g1 a2e6 g1g2 e6b9 g2g1 b9e6 g1h2 h5g4 h2i3 g4f5 i3h2 e6f7 h2i3 f7i10 i3i4 i10d5 i4h4 d5a2 h4h3 f5e4 h3g3 a2b1 g3h3 e4d4 h3g2 b1g6 g2f3 g6c2 f3g2 c2b1 g2g1 d4c4 g1h1 c4d4 h1g2 b1d3 g2h2 d3b1 h2h3 d4c5 h3h4 c5b5 h4h5 b1e4 h5i6 e4d3 i6i5 b5c4 i5i6 d3f1 i6h6 f1e2 h6g6 e2d1 g6g5 c4b4 g5f6 d1b3 f6g7 b4c4 g7f7 c4d3 f7g6 b3c2 g6h6 d3c3 h6i5 c3d4 i5i6 c2g6 i6h6 d4d5 h6g6 d5d6 g6g7 d6d7 g7g8 d7d8 g8f9 d8e7 f9e10 e7e6 e10f9 e6e7 f9f10 e7f6 f10e10 f6e5 e10f10 e5d6 f10e9 d6c7 e9e8 c7b8 e8d8 b8a9 d8c7 a9a8 c7c8 a8a7 c8d9 a7b8 d9c10 b8a7 c10b9 a7b7 b9c10 b7c7 c10d9 c7d6 d9d8 d6c5 d8e8 c5c6 e8e9 c6d6 e9f10 d6e6 f10e10 e6f5 e10d9 f5g6 d9e8 g6f5 e8d7 f5g4 d7e7 g4f5 e7d7 f5f6 d7e8 f6g6 e8e9 g6f7 e9f9 f7g6 f9f8 g6g5 f8g9 g5f5 g9h10 f5e6 h10i10 e6f7 i10i9 f7f6 i9i10 f6f7 i10h9 f7e8 h9h8 e8e7 h8g8 e7e8 g8h7 e8e9 h7h8 e9f10 h8g7 f10g9 g7f7 g9h8 f7f8 h8i9 f8g9 i9i8 g9f10 i8h8 f10e10 h8g8 e10e9 g8f7 e9d9 f7g7 d9e10 g7f8 e10d9 f8g8 d9c9 g8f9 c9d8 f9g8 d8d9 g8g7 d9e10 g7f7 e10f10 f7f8 f10g10 f8e8 g10g9 e8d9 g9g10 d9e10 g10h9 e10d10 h9h8 d10e9 h8i9 e9e10 i9h9 e10f10 h9h10 f10e10 h10i10 e10d10 i10h9 d10e9 h9h8 e9f8 h8i9 f8g9 i9i10 g9f8 i10h10 f8g8 h10i9 g8f9 i9i8 f9g8 i8i9 g8g9 i9i8 g9g8 i8i9
b3b5 h9i7 c2b3 c8c6 g3g5 g8g6 f3f5 i9h9 d2e4 c6b5 a3a5 i10i9 a2a4 b8b6 e4d2 d8d7 a4a3 c9e7 b2c4 e7g5 h2g4 d7d6 a5a6 b9c7 c4b6 d9e7 b3a2 e7d5 d3d4 d5f6 d4d5 f6e7 c1b2 e10d9 h1g3 g5h6 g3i4 b5b4 b6a4 d9e10 d2c2 f9g8 h3h5 g8f6 f2h1 e10f9 c2b4 c10d9 a2c4 g6f5 e2f2 d9a6 g4h2 d10d8 f1e2 f9e10 b2c1 e10f9 e1f1 h6g7 e3e4 e9d10 f2i5 b10c8 i5g3 f6e6 b4c5 d10d9 c4b3 i7g8 c5b6 e7f6 g3e1 f6e7 b6b7 g7c3 c1i7 c3e1 d1d3 c8e9 a3a2 a8a7 i7d2 i8i7 e2e1 e7f7 g1a7 h8h6 b3c4 f7g5 e1e2 g5f3 d2h6 a6b7 b1c3 b7a8 e2c2 f3h4 a7e3 i7h6 g2h3 f10c10 d3e2 g9i7 e2e1 a9b9 e3b6 c10e10 c4b5 b9c9 c2c1 i7f10 b6g1 f8f6 f1f2 h4i6 c1g5 e6e5 h3g2 i6g5 e1d2 d9c10 d2d1 e5e6 d1e1 d8d9 g2f1 e10d10 f2g2 g5h3 g2h3 e6f7 e1e2 h10i8 h1g2 a10a9 g1e3 c10a10 e3h6 c7e6 e2e1 g8e7 g2f2 a10b9 f2g4 h9h7 h3h4 f7g8 e1c1 e6d8 i1g1 e9f7 h6g5 a8b7 a2b2 d10a10 b5c4 g10h9 g5d2 d9c10 c4d3 c10d10 c3b5 b9e6 a1a3 a9a6 h4g3 h9g10 c1b1 a6a7 b5a7 c9c10 a7c6 g8i7 d5e6 d10e9 i4g5 f9e10 b2c2 c10c8 g5i4 c8c6 c2c4 i7h5 g3h3 i9h9 d2h6 i8h6 f1e2 e7d9 e6f7 h5i4 h2i4 h6i4 g4h5 h7i7 i2h2 h9h5 e2h5 d9e7 h5d1 c6c5 d3f1 b7e4 a3a1 a10d7 h3h4 d8b7 a1a2 d7a10 g1g5 a10e6 c4c1 c5c8 a4b2 c8c10 a2a3 f5f4 g5e5 c10c8 e5i5 c8d8 c1c6 f10h8 b1c1 e7g6 h4h5 h8i9 a3a8 g6h8 c1c5 e9h9 c5d6 e4d3 b2a4 h8f9 h5i4 h9h4 i3h4 e6b9 d6d5 i7g7 h2c2 b9a9 a8d8 d3b5 d8b8 a9a8 c6c8 f4f3 c8c7 a8b9 d5d3 b7a9 d3a3 e10d9 b8d8 d9e10 i5e5 f9e7 a3c3 b9d9 d8d2 d9d4 i4i3 a9c8 c3c5 d4f4 f1e2 f3e2h c7d7 f4b4 c5d6 g7g4 d7d9 g4d4 c2c4 c8d6 d2e2 d6c8 c4c6 c8a9 c6f6 d4f4 f6e6 f4f3 i3i4 i9h10 d9d2 b5a6 e6g6 e7c6 e2i2 b4f8 e5f5 f8a3 g6i6 h10d6 a4b2 a9b7 f5g5 a3b4 i6d6 c6b8 d6a6 f3a3 d1f3 g10i8 f3i6 e10e9 i6e2 b8c10 e2i6 a3e3 g5g3 b4a3 i2f2 a3g9 b2c4 i8e4 g3h3 g9g3 a6a10 g3g2 i6e2 e4h7 c4e5 e8e6 i4i5 g2e4 i5h5 b7a9 a10b10 e4a8 h5g5 c10b8 b10h10 e3e4 h3e3 a8a7 d2d1 h7e10 e2a6 e10g8 f7f8 e9e8 d1f1 e4b4 h10e10 g8e10 a6b7 e8e7 e3e1 a7f2 b7h1 f2h2 e1a1 h2i1 f1f4 a9c10 h1c6 i1i10 f4d4 e7f8 d4f4 f8g8 c6d5 i10i5 g5g6 c10a9 f4f7 b4b6 f7f6 e10c8 a1a9 i5i2 a9e9 e6d5 e9b9 b6b2 e5g4 b2b1 f6f1 i2i1 b9e9 i1i4 g6f6 b8c10 e9a9 c8d9 a9a8 g8f9 a8c8 f9e9 c8c1 i4g6 f6e5 g6g5 f1f5 g5c9 f5f6 b1b4 f6f3 c9c6 f3f8 b4e4 e5f5 e4e7 c1i1 e7g7 g4f6 d9g6 f5f4 c10b8 f6e8 c6b6 i1i3 b8c10 i3i7 g6h7 i7i6 b6b9 i6i2 g7g5 i2i3 b9i2 i3a3 e9d8 e8f10 d8c7 a3a2 h7f9 a2e2 g5g9 e2b2 i2c8 f10d9 c7d6 d9e7 f9e10 b2f2 d6c7 f4e3 c8h3 e3f4 g9g1 f8g8 h3b3 f2g2 c7b6 f4f5 b3c3 e7g6 c3h8 g8d8 b6b5 d8c8 h8i7 f5e6 i7g5 c8c4 b5a6 g2i2 a6b7 g6h8 g1a1 c4c7 b7a6 e6d7 g5g7 d7e8 g7g3 h8f7 g3c7 i2d2 c7c2 d2c2 e10f9 e8e7 a1a2 h4h5 a6a5 f7h8 a2a4 h8g10 a4c4 e7e6 a5b4 e6f5 f9c6 c2a2 c4e4 g10f8 e4e10 f5f6 c10e9 f8d7 e9c10 f6f7 c10a9 f7f8 c6a4 d7b8 a4c2 f8g7 a9b7 a2a5 b4c4 a5a7 e10b10 b8d7 b7c5 a7a6 c4b4 g7h8 b10h10 h8g8 c2h7 g8f8 c5e4 d7c5 e4d2 a6a2 h10c10 f8e8 d2e4 a2a3 c10e10 e8d8 e10e8 d8e8 b4c4 e8f7 e4g5 f7e7 g5f3 c5b3 h7f9 a3a1 f9e8 a1a4 c4d3 b3c5 d3e3 c5b7 e8b5 b7a9 b5f9 e7f7 f9i6 f7e8 e3d3 a4b4 d3c2 e8e9 i6h5 e9d8 c2c1 a9b7 c1d1 d8c9 d1c2 c9d8 h5g6 b4i4 f3d2 i4i9 g6i4 i9i6 c2b1 i6c6 d2e4 c6d6 i4g6 d6c6 e4f6 c6c8 f6d7 b7c9 g6e8 c9a8 d7b6 c8c3 b6a4 a8c7 b1b2 d8e8 a4b6 c3h3 b2a1 h3c3 a1b1 e8e9 b1b2 c7d5 b2a2 e9f8 b6d5 c3c8 d5c3 c8a8 a2b2 a8a7 c3d1 a7h7 d1c3 h7h4 c3d5 h4g4 b2a2 f8f7 a2a3 f7f8 d5f6 f8g9 f6g4 g9g8 g4h2 g8f9 a3b3 f9f10 b3b2 f10g10 h2g4 g10g9 b2a1 g9h10 a1b1 h10g10 g4f6 g10h10 f6e8 h10g10 e8f10 g10f10
f3f4 f8f7 e3e4 f9f8 g3g5 h10f9 f2g3 h8h6 e2i6 g9i7 f1f3 f8g9 d3d4 d8d6 h2f1 c8c7 c2d3 c9g5 d2e2 g5e7 b3b5 e7f6 f4f5 g9f8 i6g8 e8e7 i3i5 f8d7 g3h5 a8a7 e2e3 f10g9 h5g7 i10h10 b1d2 d7e5 a3a4 e5e4 b5b6 e9e8 e3c2 f6d4 f3h5 e4d5 e1e2 e8c8 g7g6 g9g8 h5g4 d9e9 h3h4 c7c6 g1i3 g8i6 c2d4 a7a6 d4e4 c10d9 g2h3 c8c10 e4g3 i7g9 g6f7 d5e4 f1e3 h9g7 i3g1 e4d4 e2e1 b10a8 i2e2 i6h5 e3d5 d4f5 h1f2 a10b10 d3a6 f5f6 d5f6 h10h7 f6d5 g7e6 b2d3 c10c8 d2b3 c6d5 g3f4 c8c10 g4g8 h5e5 e1d2 e9f7 b3c5 e5e2 d1e2 c10c5 g8g4 c5b6 i1i2 g9i7 f2d1 d9b7 e2h2 i9i10 f4f5 b6d4 g4f3 e10f10 f3f1 d4a7 f1f2 a7f2 d3f2 h7h10 i5i6 e6c7 a2a3 b9a7 f5d6 d10d9 h2g3 a9a10 g3g7 b10e10 h3c8 e10e8 a1a2 f7e5 g7e9 d9e9 c8d7 e5d7 d6e5 d7c8 d2e2 b7a6 e5c4 a6b5 e2e1 e9d10 c4a5 h10h8 a5b7 i10i9 i2i5 c8d8 a2d2 h8h10 b7b8 b5c4 i5i3 i7h8 b8c9 c4f1 a3a1 f1h3 d1e3 d8c9 d2b2 a10b10 e3f1 b10b2 f2g4 e8e10 g1e3 h3f1 i3i4 f1e2 e3g5 e2d3 g4i3 b2g2 c1a3 h8i7 i4i5 d3c4 a1a2 a8b10 i5i4 c4b5 i3g2 c7b9 g5d2 d10d6 a3b2 d6d9 d2e3 i9g9 e3b6 b9d8 i4i1 b5e8 b6a7 e10d10 e1d2 f9g7 a7g1 g7f9 d2d3 e8h5 g1d4 d8b9 g2i3 h10h9 d4e5 c9d7 i1c1 h5i4 c3c5 d7c9 i3g4 b9c7 e5c7 f10e10 c7b6 i4e8 c1i1 e8i4 b6e9 h6h5 i1e1 g9g6 e1e4 g6g9 g4f6 d9d7 f6d5 h9h7 e9h6 d7h3 d3d4 c9e8 h6g5 h3g3 g5f6 g9g6 e4e5 g3f3 d4c4 h7h8 d5b4 f3b7 e5e7 h8h6 b2c3 d10d8 e7e4 d8d6 f6g5 b7g7 a2i2 g6f6 b4a2 h6i6 e4e3 d6c6 e3e2 g7a7 e2f2 i7h6 c3b2 e8g9 a2c3 c6c5 c4d4 f6f2 a4a5 h6i7 g5c1 i6e6 i2i1 f2b2 c3d1 c5a5 d4c4 a5a1 i1i2 b2b1 d1c3 a1a6 c1d2 a6a1 d2e3 e6g6 e3b6 g9f8 i2f2 a7a4 c4d3 a4b3 b6d8 i4g2 d8a5 f8h7 f2c2 g2h1 c2e2 e10d10 e2a2 b1f1 a2f2 i7d2 f2f5 f1e1 f5c5 d10e10 d3d4 b3b5 c5g5 e1e8 a5c7 g6c6 g5c5 e8c8 c3e2 d2c3 d4e3 c6d6 e2g3 b5a6 c5e5 d6e6 g3f1 c8b8 f1g3 a1g1 c7e9 g1e1 g3e2 b8c8 e9h6 a6d3 e3f2 d3c2 e5d5 c2g6 d5d6 e1g1 h6g7 g6c10 g7e5 c10g6 e5f4 g6d3 f4d2 c8a8 d2g5 c3a1 g5e3 h1i2 f2g1 e6e5 g1f2 i2f5 d6e6 e5e6 e3g5 d3h3 e2c3 h3i4 f2f3 f9d10 c3d5 f5g6 d5b6 i4i2 b6d5 a8a5 g5c9 a5a2 f3g3 e6e3 g3f4 d10c8 d5c3 e3e2 c9e7 h7g7 e7d8 g6h7 d8b10 i2h3 f4g5 e2d2 c3a4 h3h1 a4c3 h1b7 c3e2 e10f10 g5f4 b7d7 b10a9 f10g9 f4g3 h7c2 g3f4 a1e5 f4f3 d2d3 f3e4 g9h9 a9e5 d7f9 e5g7 c8d10 e2g1 d3f3 e4d5 c2h7 d5d6 f9a9 d6d5 f3f6 g7i5 f6f5 d5e4 a9g9 i5g7 h7e10 g1h3 e10f9 e4e3 a2f2 g7d10 f5e5 e3d4 i8i6 h3i1 g9f8 d4d3 e5g5 d3e3 f2f6 e3e2 f8g8 e2d1 g8e8 d1d2 g5g1 i1h3 e8f7 d10g7 f7e6 d2d3 f6f8 g7h6 g1g2 d3c3 f8f4 c3d3 f4f8 h6i5 h9i8 h3g5 e6a10 d3c4 i8i7 g5f7 a10f5 f7h6 f8g8 h6i8 i7i8 i5g7 f5h3 g7d10 g2d2 d10e9 d2c2 c4d5 g8c8 e9h6 f9c6 d5d4 h3h2 d4d3 g10f9 d3d4 h2h4 d4d3 c8c9 h6e9 h4f2 e9c7 i8h7 c7e5 h7i8 e5f4 f9d7 f4c7 f2e1 c7g3 c2c5 g3c7 c9d9 c7f10 e1e4 d3d2 e4b1 f10e9 c5b5 d2c3 b1h7 e9b6 d9f9 c3c4 c6b7 b6g1 h7f5 g1f2 f9f6 f2e3 b7a6 e3g5 i8i9 c4d4 f6g6 d4c4 d7a10 g5d8 f5f2 d8a5 f2g1 a5e1 g1h2 e1c3 i9h10 c3b2 h2c2 c4d4 a6d9 b2c3 g6h6 c3d2 b5d5 d4e3 c2c1 e3f3 d9g6 d2b4 h10i9 b4e7 d5a5 e7g9 c1i1 f3g2 i9h9 g9e7 a10c8 e7g5 c8d7 g5h4 a5a3 h4f6 i1d1 f6h8 d7h3 g2f2 h9i10 h8b2 h6h10 b2a1 a3a7 a1h8 g6c10 h8e5 d1d3 e5b2 d3g6 b2c3 h3i2 f2f3 a7i7 c3d4 i2f5 d4b2 g6g4 f3f2 i7b7 b2a3 c10g6 a3c5 i10i9 f2e3 b7b4 c5g9 g4h4 g9f8 b4b9 f8g9 h10f10 g9f10 b9h9 f10b6 h4f2 e3f2 i9i10 f2g3 h9h6 b6e9 h6h9 e9a5 f5i2 g3g2 h9d9 g2g3 i2a10 g3f3 d9d10 f3f4 g6c10 f4e3 a10i2 a5b6 i2f5 e3f4 d10d6 b6a7 f5a10 f4g3 i6i5 a7e3 d6h6 e3c5 h6h8 c5f8 h8h10 g3h2 a10e6 h2i3 e6h9 i3i2 h10f10 f8e9 f10f5 e9i5 f5c5 i5f2 h9c4 f2h4 c5e5 h4b10 c4a6 b10d8 c10a8 i2i3 e5e2 d8a5 e2g2 a5d8 a6d3 d8f10 d3f5 f10i7 a8f3 i7h6 g2g10 h6i7 f5i8 i7c1 i10i9 i3h2 i8c2 h2i3 g10g7 c1i7 f3d5 i7d2 g7g9 d2i7 i9i10 i3h3 c2b3 i7g5 g9h9 g5d2 h9e9 h3i2 d5f7 i2h2 f7d5 d2g5 d5g8 g5e3 b3c4 h2g3 e9b9 e3f2 g8e6 f2g1 b9b8 g3f2 b8c8 f2g3 i10i9 g1c5 c8d8 c5h10 i9h8 g3f2 h8h9 f2f3 d8d1 f3g3 h9h8 g3f2 c4e2 h10g9 h8h9 f2e2 e6f5 g9b4 d1b1 e2f2 f5e6 b4f8 e6a2 f2e3 a2g8 f8d10 b1b9 d10a7 h9i9 e3f3 g8e10 a7d10 b9b4 d10c9 h5h4 c9g5 b4b9 f3f4 i9h9 g5f6 h9g10 f6e5 b9i9 f4e4 i9a9 e5h8 a9i9 h8g7 g10f10 g7f6 e10b7 e4e5 f10e9 e5e6 h4h3 f6i3 b7h1 i3e7 h3h2h e7g9 e9f9 g9c5 i9i8 c5d6 h1a8 d6e7 f9e10 e6d7 h2h10 e7h4 a8c6 d7d6 e10d10 h4d8 i8e8 d6c7 c6d5 d8e7 d5b7 c7b7 h10h8 e7g9 d10c10 b7c6 h8f9 g9a3 f9f6 c6c7 f6d5 c7c6 d5d9 c6b5 d9b10 b5c4 e8a8 a3h10 b10b4 h10b4 c10d9 b4f8 a8a9 c4b4 d9c10 f8h10 a9a4 b4c5 c10b9 h10g9 a4g4 g9f10 g4b4 c5b4 b9c9 f10c7 c9b10 c7f4 b10b9 b4a5 b9b10 a5b4 b10c10 f4i7 c10c9 b4b3 c9b9 i7f4 b9c9 f4i1 c9d8 b3c3 d8d7 i1h2 d7e7 c3c4 e7f8 h2e5 f8f7 c4b4 f7f8 b4a3 f8g8 e5g7 g8f9 g7h8 f9g10 a3a4 g10f9 h8d4 f9g10 d4g1 g10g9 a4b5 g9h10 b5c4 h10h9 c4b3 h9g10 b3a2 g10f9 a2b2 f9f8 b2a3 f8g7 g1e3 g7h7 a3a4 h7g8 e3c1 g8g9 c1h6 g9h10 h6e9 h10h9 e9d8 h9i10 d8a5 i10h9 a5b6 h9g9 b6f2 g9g8 a4a5 g8f7 a5b4 f7e8 b4c5 e8e7 c5d5 e7f8 f2e1 f8f7 e1i5 f7f6 d5e4 f6g6 i5f8 g6f7 f8e9 f7e7 e4e3 e7d7 e3f3 d7c8 e9h6 c8d9 h6g5 d9c10 g5h4 c10d9 f3g2 d9e8 h4i5 e8d9 i5g7 d9c8 g2f3 c8d9 f3e3 d9c8 g7d10 c8b9 e3f3 b9c8 d10a7 c8d9 a7b6 d9c10 b6f2 c10c9 f2b6 c9b8 f3e2 b8b7 b6d4 b7b8 e2f2 b8b9 f2f3 b9a8 f3e4 a8b8 d4b6 b8c9 b6e3 c9b8 e3h6 b8c7 h6e9 c7c8 e9d10 c8d7 e4f4 d7e8 f4g3 e8d8 d10f8 d8e8 f8d10 e8d7 d10b8 d7c6 g3f3 c6b6 f3g4 b6b5 b8c7 b5c6 c7a9 c6b7 g4h3 b7b6 a9d6 b6c6 d6g3 c6b6 g3a9 b6a7 h3i2 a7b6 i2i1 b6b7 a9h2 b7a7 h2c7 a7b7 c7f4 b7a8 f4b8 a8b8
h2g4 h9g7 g4i5 d8d7 b2a4 e9d8 d3d5 f8f7 c1b2 g9d6 b3b5 b9c7 d2c1 a8a7 c2f5 c7b5 e2c4 d9e9 c1d2 d8b6 c4c7 d6c7 i5h7 g10h9 f2d3 f10g10 h7f6 e9f10 d3c1 b5d6 h3h4 b6b2 f1f2 e8e7 g2f1 f9e9 a2b2 c7a5 f6g8 f10g9 g8f10 e10f9 f5d7 d6e8 d2d3 c8c7 d7b5 a5b4 f3f4 g9h7 d3e2 e9e10 b5d7 d10d8 b2b4 g10g8 f10e8 h7i7 c1c2 c10d9 e2d2 f9g10 d7b9 e10d10 d2c1 i7g6 f1e2 g6g5 c1b2 g5h5 b4d4 h5g3 e8f10 d9e8 e2b5 g10f10 b9f5 g3g2 e1e2 d8c8 c2d2 g2h4 a4b6 g7e6 d4a4 d10d9 c3c4 h4i2 f5i2 d9e10 d1c1 a9b9 f2f1 g8g9 d5e6 g9d9 b6c8 e10e9 c8a9 a10a9 b2c2 i8i6 e2e1 e9d10 a1a2 b8b7 c2d1 f10e10 h1f2 c9b8 g1h2 i9i8 d2e2 d10e9 i2h1 e10f10 a4a6 d9d1 e1d1 e8g10 b5d7 i10i9 c1d2 i6i5 d2d3 a9a10 a2a1 b8d10 d7b5 e9e10 b5f9 e10g9 d3d2 g9f9 d2e1 d10h6 i3i4 i8i6 e1c3 h9i8 c3b3 i8b1 e2d3 b10d9 d3e1 f9g7 b3c3 a10b10 h2i3 b10d10 a6c6 g7g8 e1e2 b9c9 e2d4 a7a6 d1c1 i9f9 c3d2 h6f4 i1i2 d10b10 c6c5 i6i9 e3e5 b10a10 h1e4 f4g3 f1d3 f9g9 i2g2 g10e8 d3b1 g8f8 e4c2 g3h4 a1a2 f8g8 d4e2 d9f8 b1b2 f10e10 b2b1 c9c8 f2h1 h4f2 c2g6 a10a8 e2d4 g8h6 i3h2 g9c9 c1c2 a8a10 g6h5 f8h9 d2d1 e8a4 c2b2 h10g8 a2a1 h6i7 c5c6 f2e1 d1e2 g8f6 g2g1 c8a8 b1e4 e1f2 b2c1 f2d4 e2f1 f6e8 h5f7 c9e9 f1e1 a10a9 c6d6 e9d9 e4c6 e8g9 c1d2 d4c5 g1g4 c5d4 c6f3 c7d6 e1c1 d4a1 f3g2 a9c9 g4d4 a4d7 h2g3 h8h7 g2h2 i9i10 c1c2 d7c6 h2e2 g9f7 d4f4 c9b9 g3i5 i7h5 a3a4 d6e5 f4d4 h5g6 i5h6 a8a10 d4d6 h9i7 c2e4 b9b8 e4h4 c6g2 h4h3 i10i8 d2c2 b8c8 c2b1 g2f3 h3h2 f3h1 b1c2 g6h4 h2h3 e10f10 d6b6 c8d8 h3h4 d8b8 h4e1 d9d5 e2e5 a1d4 e5i5 f7d8 b6b4 i8i9 i5f5 d4f6 f5d5 i9c9 d5h5 b7b6 c2b3 f10f9 h5d5 f9g10 e1d1 h1d5 d1d5 c9f9 h6c1 b8b7 c1f4 d8c10 f4h6 f6g5 h6i5 g10f10 d5e4 f10g9 e4e3 i7g8 b3c2 g5i7 e3c5 f9f3 i5h6 c10a9 c2c1 g9f9 b4b1 a10f10 h6e3 f3f5 e3g5 b7b9 c5c10 i7g9 b1b6 g8h10 c1d1 f5f3 d1c1 f3f5 b6c6 g9i7 g5e3 b9b4 c10d10 f10d10 a4a5 f5f1 c1c2 d10f10 e3d4 f1g1 d4g1 i7e3 i4i5 f10b10 c6d6 b10g10 d6c6 g10g3 c6c10 b4a4 c10a10 a4c4 c2b1 e3b6 g1h2 g3g5 a10e10 b6f10 h2i3 f9e10 b1a1 e10f9 i3g5 f9f8 g5i7 c4c1 a1b2 h10g8 b2b3 c1d1 b3a4 a9c10 i7h8 d1h1 h8g9 f8f9 a4b4 h1a1 b4c5 f9g10 g9i7 f10h8 i7e3 g8h6 c5d5 h6f5 d5c5 a1g1 e3f4 g1g9 c5b4 h8f6 b4c4 f6b2 c4b3 g10h9 f4i1 g9a9 b3b2 h9i8 i1h2 i8i9 b2c1 f5h6 i5i6 c10d8 c1b2 d8c6 b2a3 i9i8 i6i7 i8i9 h2g1 i9h9 a3b2 h9g9 g1i3 h6g4 i3g1 c6a7 b2a1 a9c9 g1b6 a7b5 b6f2 g9h10 f2c5 g4e3 c5d4 e3d1 d4b6 c9d9 a1b1 d9e9 b6a7 e9d9 a7f2 h10i10 f2c5 d9d7 e6d7 d1e3 b1a1 e3c4 c5f2 c4b2 d7d8 h7h6 a1a2 i10h9 f2e3 b5a3 e3c1 e7e6 d8d9a h9g9 d9b10 e6e5 a2a1 b2c4 c1a3 g9f9 b10e7 f9e9 e7b4 e9f10 b4c2 e5e4 i7i8 f10f9 a3f8 c4e5 c2a3 e5d3 a3e7 f9f10 a1b1 d3e1 f8g7 e1d3 g7c3 d3c5 e7d6 c5b7 d6a9 f10g9 a9g3 e4e3 g3i2 b7d6 i2a10 d6e8 i8i9q g9g10 i9i6 g10f10 c3f6 f10g10 i6h5 e3e2h h5d5 e8f10 d5d3 e2b2 b1c1 f10h9 d3g6 g10f9 g6g4 b2f2 f6g7 f2h2 g4e2 h2h4 e2b2 h4d4 a10d7 f9f10 d7h3 d4d7 b2d4 d7e5 d4e3 e5f5 c1b1 f5h5 h3a10 h5h2 e3f2 f10e10 f2f8 h2g2 b1c1 g2i2 a10b9 h9i7 b9d7 i7g6 g7a1 i2d2 d7e5 d2a2 c1b1 a2c2 e5f6 g6i7 f6d8 e10d9 a1i9 c2e2 f8f6 e2e7 b1a1 e7f5 f6c3 f5f8 d8e7 d9d10 c3d4 f8d9 d4d6 d10c10 e7d9 c10c9 i9h8 c9d10 h8g7 d10c9 g7c3 i7h9 d6d2 h9f8 c3h8 f8d9 h8f10 d9c7 a1b2 c9b9 f10e9 b9c9 d2d7 c7d5 b2c2 d5f4 d7d2 f4e6 d2g2 e6f8 g2g9 c9b8 g9h10 h6h5 c2b3 b8b7 h10a10 f8g10 a10a9 b7c6 e9g7 c6d5 a9a6 d5c5 g7c3 h5h4 a6e6 g10h8 c3g7 h4h3 e6f6 c5b5 f6f1 b5c5 g7c3 h8g10 c3d4 c5d5 f1h3 d5c6 h3c8 c6d5 b3a2 g10f8 a2b3 d5d6 c8h3 f8h9 d4e5 d6e5 b3b4 h9i7 h3h9 e5f6 h9a9 f6g7 a9d9 i7h9 d9d4 g7h6 d4d1 h6g5 d1i1 g5h5 i1e5 h5i6 e5c5 h9f8 c5e5 i6h6 e5i1 h6g7 i1d1 g7f6 d1e1 f8h9 e1h4 f6f7 h4g5 f7e8 g5g9 h9i7 g9a9 e8e7 a9e5 e7d8 e5i1 i7g8 i1g3 g8h10 g3e3 h10g8 b4c4 d8d9 c4d5 g8i9 e3e10 d9d8 d5c5 i9h7 e10a6 d8c7 c5b5 c7b8 b5c5 b8c9 a6c4 c9c8 c4h4 c8c7 a5a6 h7f8 c5b4 f8d7 h4g5 c7b6 g5g9 b6a6 g9g6 a6a7 g6g9 d7b8 g9d9 b8d9 b4c5 a7a6 c5c4 a6a5 c4c3 d9b10 c3d4 a5a4 d4e4 b10a8 e4d4 a4b3 d4e4 b3b2 e4f3 b2a1 f3f2 a1b2 f2e2 a8b6 e2d3 b2a1 d3c3 b6a4 c3c2 a4c5 c2c3 c5e6 c3b3 e6d4 b3c3 d4b3 c3d3 b3a5 d3e4 a1a2 e4d3 a2b2 d3d2 a5c4 d2d1 b2c3 d1e1 c3c2 e1f2 c4a5 f2f1 c2b3 f1f2 b3c2 f2e2 a5b7 e2f3 b7a5 f3e4 c2b3 e4e3 b3c4 e3d2 a5b7 d2e1 b7c5 e1f1 c5b3 f1f2 c4d5 f2e3 d5e5 e3f2 b3d4 f2g1 d4b3 g1h1 e5d6 h1i2 b3c5 i2i1 d6d7 i1h1 d7c8 h1i2 c5e4 i2i3 c8b8 i3h3 b8c7 h3h4 c7b8 h4i3 e4g5 i3i2 g5e4 i2h1 e4c3 h1g2 c3d1 g2f3 d1b2 f3e4 b8b9 e4f3 b2d1 f3e2 b9a9 e2f3 a9a8 f3e2 a8b9 e2e1 d1c3 e1f1 b9b8 f1g2 b8a7 g2h3 a7b6 h3i3 c3b5 i3h4 b6c5 h4i4 b5c3 i4i3 c3e4 i3i2 e4g3 i2i3 g3e4 i3i4 c5b5 i4i5 e4d6 i5h6 b5c4 h6g7 c4c3 g7f6 c3c2 f6g7 d6c4 g7g6 c2b3 g6f7 c4d2 f7f8 b3a3 f8f7 a3a4 f7f6 d2e4 f6e5 e4d6 e5f6 d6f7 f6f7
e3e4 g8g7 d3d4 f8f6 e2a6 a8a7 d1e2 g9b4 a6c4 h10g8 d2e3 c8c6 c3b4 e8e6 b1c3 f9g9 e3d1 f6f5 f2g4 b10c8 d1d2 d9f8 g4f2 c8d6 e2d1 c10i4 d4d5 g8f6 h2g4 e9e7 e1e2 e10d9 g4e5 f6g8 f2e3 i4h3 e2d3 f8e10 i3i5 g8h6 e5c6 e7g5 b4b5 d8d7 e4e5 g9e8 e3e2 h3i4 c4a4 i4g2 e2e3 e10f9 a4c4 a9a8 i5i6 f10d8 c4d4 g2f1 e3f1 a10a9 d4c5 g5g6 d2e4 f9e10 g1h2 d10a10 e4f6 d9c10 g3g5 d8b6 h2g3 d6b5 c5d6 g10f9 c6b8 b6b8 f6e7 g6h5 d3e2 e8f10 e7g6 b9d8 d6b6 h5h1 d1d4 h1h4 d4e4 i10h10 e4a4 h4e4 c1e3 b8c8 b6b7 e4i4 f1e1 a7a6 e2d2 a10b9 e1d1 i4f1 i2i5 c10d9 g6f8 h9f8 e3b6 f9e8 d2c1 a9a10 c2e4 f5e4 a4a5 h10i10 b2a4 f8h7 i1i2 h7g5 b6e3 b9b10 e3f4 f10g9 a5d8 c9d8 i2d2 e6d5 a2c2 b5d4 b7b5 c8c9 i5i1 e10d10 i1g1 d4b5 c2b2 g9h7 d2g2 c9c10 g2c2 i9e9 c2f2 e8f9 f2g2 c10c3 c1b1 d10c8 d1e1 e9e10 a4c3 d8e9 b1c2 g5i4 c2d2 i4g3 d2e3 d5d4 e3d2 e10c10 f4g5 h6f5 c3e2 d9d10 e1f2 g3i4 e2f4 h7g8 g5d8 g8f10 d8g5 b10b8 g5i3 f1c4 i3e7 c4d3 f2d3 c10b10 e7b10 f9e10 g2g6 f5h6 d3b4 f10g10 b4d3 e10f9 e5e6 c8a9 g6g4 b8b7 d3e3 i10i9 i6i7 b5d6 d2c1 h6g8 g1f1 i9g9 f4d3 a6a5 g4f4 g8h6 d3e1 f9g8 e3e2 e4e3 f4f8 g10f10 e2e3 h8h7 f3f5 d7e6 e3g4 a8c8 c1d1 f10d9 b2g2 b7d5 b10f6 e9f8 g2g3 h6f7 f6d8 c8b8 g4f2 d5e5 d8i3 d9c7 g3h3 g7g6 h3h6 a9b9 i3g5 b8c8 f1g1 f7g5 f2f3 c7d8 f3d4 d8d9 d4b5 g5e4 h6g6 d9e7 g6h6 b9c7 b5c4 f8e9 c4e3 e5g7 h6h5 g7e5 g1g2 e5b5 f5f6 e7d5 e1c2 c8b8 g2g7 d6f7 h5h4 c7a6 g7g3 f7g5 e3f5 b8d8 a3a4 g9i9 f5g5 e4g3 g5f7 d5e7 f7d8 g8h9 d8d9 e7d9 h4i4 d9d8 b3b4 a10a7 i4i2 d8c7 i2i4 b5g10 i4h4 g10h10 c2e1 h10e10 d1c2 h7h6 h4h5 c7c8 h5h4 d10c9 c2d1 e9f8 h4h3 e10e9 h3i3 c8d10 i3g3 a7e7 a1b1 f8h10 e1g2 e9f10 b1a1 f10g10 g3g4 g10f9 b4a5 e7i7 g2e1 h10b4 g4h4 f9f8 a1b1 d10e10 h4h3 b4c5 f6f7 c9d8 b1b4 i7i4 h3g3 e10f9 g3i3 d8c9 b4c4 f8e8 c4e4 i4f4 i3d3 f4i4 d3b3 c5g1 e1c2 c9c8 e4e1 e8e7 b3i3 a6b6 e1e4 i4i7 i3h3 i7f7 e4e6 e7h4 h3h1 h4d8 c2d4 f7e7 d1c2 d8d5 a5b6 f9f10 h1g1 h9g8 g1g8 c8b7 d4b3 d5e6 g8g2 b7c6 g2g1 f10e9 b3c1 e6c4 c2b2 i8i7 g1g2 i9h9 g2g8 e7b7 g8g7 h9f9 g7d7 c4h9 c1d3 f9f6 d7c7 c6d6 b2b1 h9b3 b1c1 d6e6 c7c6 e6f5 c1d2 f5e4 d3c5 e4f5 c5d7 b3c2 d2e3 c2b3 e3e2 e9c10 d7f8 f5g4 e2d2 c10a9 c6c3 f6g6 c3c9 b3c4 c9c5 c4a6 c5c3 a9b10 d2c1 g6c6 f8e6 b7g7 c1d1 a6b6 c3f3 g7g6 e6c7 b6b8 d1e2 b8b1 e2d2 g6g10 f3e3 b10d9 c7d5 c6c2 d2d3 b1d1 d3e4 c2a2 e3d3 a2e2 d3e3 d1i1 e4d4 g10i10 d4c5 i1h1 e3c3 e2e6 c3b3 d9f8 c5b4 e6e2 b4a3 e2f2 b3b5 h1f3 d5c3 f2a2 a3b4 a2a1 b4a5 i10i8 c3d1 f3a8 a5b4 g4f3 b5f5 f3g3 f5c5 f8d7 b4c4 a8d5 c4b5 d5g2 c5c4 g2f2 c4i4 i8f8 b5c4 f2f3 d1e3 a1b1 e3d5 b1h1 d5b6 g3f2 i4i5 f3c3 c4d5 c3d4 d5d4 f8f10 b6c4 h1c1 i5i3 d7c7 i3i5 h6h5 c4a5 c1e1 i5i6 e1e3 d4c4 e3e8 i6i4 f2e1 i4h4 e8e7 h4g4 f10h10 g4g1 e1f2 g1d1 e7e9 d1d4 h10b10 d4d9 e9e1 d9e9 e1b1 e9e3 i7i6 e3e4 c7b9 e4e9 b9c7 e9e3 c7d7 e3c3 f2g1 c4d3 b1f1 c3c2 d7c5 d3e3 b10b8 a5c6 b8b7 c2e2 f1f2 e2e1 g1h2 c6e7 b7b1 e1g1 f2f3 e3f3 b1b2 g1b1 b2b6 b1b4 b6b8 b4e4 c5b4 e4g4 h2h1 g4g10 h1i2 g10g8 b4d5 f3f2 b8b7 g8b8 b7b6 f2e2 b6b4 b8b6 d5c6 b6c6 b4b9 e7f5 i2h3 c6g6 b9e9 e2f3 e9e2 a4a5 e2b2 g6g2 h5h4 g2g5 b2b4 g5g6 b4b9 f5e7 b9g9 a5a6 g9f9 e7f9 h3h2 g6g8 h2h3 g8g4 h3i4 g4b4 i4h3 b4e4 h3i2 f3g4 i6i5 e4e5 i2i1 g4g5 i1h2 f9d10 h2i1 d10b9 i1h2 g5g4 h2h1 e5i5 h1h2 i5i7 h2g1 a6a7 h4h3 i7i8 h3h2a g4h4 g1f1 b9d8 h2i1 i8i10 i1e5 d8e10 e5f4 i10h10 f4i1 h4g4 f1e2 h10h8 i1g3 e10c9 g3b8 h8h9 e2e3 g4h3 e3e2 a7a8 e2e3 h3h4 b8a10 h9f9 a10i2 h4g5 e3d3 f9f6 i2b9 c9e8 d3c3 a8b9q c3c2 b9i2 c2c3 f6f3 c3b4 g5h5 b4a4 i2d2 a4b5 f3f8 b5c6 d2g5 c6b6 g5c5 b6b7 f8f2 b7a8 c5a3 a8b8 f2h2 b8b9 h5i4 b9b10 a3a10 b10a10 h2h9 a10b10 h9h10 b10a9 h10i10 a9b8 e8g7 b8a8 i4h5 a8b7 h5i4 b7b6 i4h3 b6a7 i10e10 a7b6 e10b10 b6a7 b10b9 a7a8 h3g2 a8a7 b9b3 a7a6 b3b6 a6b6 g7i6 b6c6 g2h2 c6c7 h2h3 c7d6 h3i3 d6d7 i3h3 d7d6 h3i3 d6c7 i3h3 c7c8 i6g5 c8d7 g5f3 d7d8 h3g2 d8e9 f3d2 e9f9 d2e4 f9f10 g2h1 f10e10 e4c5 e10d10 h1i2 d10c9 c5e4 c9c8 i2h3 c8d9 e4g3 d9e9 g3f1 e9e10 h3h2 e10d10 h2i2 d10d9 i2i1 d9c8 f1g3 c8c9 g3i2 c9c8 i2g3 c8d8 g3i4 d8d7 i4h2 d7e6 h2f3 e6d6 f3h2 d6d7 h2i4 d7e6 i1h2 e6e5 h2i3 e5d5 i4h6 d5c5 i3i2 c5d4 i2i1 d4c4 i1h1 c4d5 h6i4 d5c5 h1g2 c5c6 g2h1 c6b6 h1g1 b6a5 i4g5 a5a6 g1g2 a6b5 g2h2 b5c4 h2i1 c4b5 g5f3 b5a5 f3e5 a5b6 e5g4 b6b5 g4i5 b5c5 i5h3 c5b5 h3f4 b5a5 f4h5 a5b5 i1h2 b5c4 h5g7 c4c5 g7f5 c5b4 f5d4 b4c5 h2h1 c5d6 d4f3 d6e6 f3h2 e6d7 h2f1 d7e8 h1h2 e8f9 h2i1 f9f10 i1h1 f10g9 h1i1 g9f10 f1h2 f10g10 h2f1 g10f9 i1h1 f9g10 f1g3 g10g9 g3e4 g9g8 e4d2 g8f9 d2f3 f9e8 f3e1 e8f8 h1h2 f8g9 h2i3 g9h9 i3i2 h9h10 i2h2 h10i9 e1f3 i9i10 h2g3 i10h9 g3h3 h9i8 h3g4 i8i9 f3g5 i9i10 g5e6 i10h9 g4h5 h9g10 e6d4 g10f9 h5h6 f9f10 d4b5 f10e10 b5a7 e10d9 h6g5 d9e8 a7b5 e8e9 g5g6 e9d8 b5a7 d8c9 g6f6 c9d8 a7c6 d8c7 f6f7 c7b7 f7e8 b7c8 e8f9 c8c9 c6e7 c9b8 e7c6 b8c8 f9e8 c8c7 c6b4 c7c8 b4a2 c8b7 e8f7 b7c7 f7g6 c7b8 g6f7 b8b9 a2c3 b9c10 f7g7 c10d9 g7h7 d9c10 h7g7 c10b10 c3b5 b10c10 b5c3
Chess comparison: https://www.reddit.com/r/chess/comments/frkr4f/white_wins_52_of_randommove_games_50_of_the_time/
I submitted it to chess.com
Their interface for setting up a custom variant is a bit confusing but here are my settings.
Promotion rank: 11th
Pawns promote to: EHMQ
Stalemated player wins
R-0,1,0,1-0,0,0,0-0,0,0,0-0,0,0,0-0-{'pawnBaseRank':5,'wb':true,'dim':'10x10','noCorners':true}-
x,x,x,x,x,x,x,x,x,x,x,x,x,x/
x,x,yR,yN,yB,yQ,yK,yQ,yB,yN,yR,x,x,x/
x,x,yR,yN,yB,yM,yQ,yM,yB,yN,yR,x,x,x/
x,x,yP,yP,yP,yP,yP,yP,yP,yP,yP,x,x,x/
x,x,9,x,x,x/
x,x,9,x,x,x/
x,x,9,x,x,x/
x,x,9,x,x,x/
x,x,rP,rP,rP,rP,rP,rP,rP,rP,rP,x,x,x/
x,x,rR,rN,rB,rM,rQ,rM,rB,rN,rR,x,x,x/
x,x,rR,rN,rB,rQ,rK,rQ,rB,rN,rR,x,x,x/
After playing a lot of games (way more than the 10 required) i did submit it to chess.com
https://variants.world/posts/794
I don't have too much faith in their review system so they might reject this variant due to some bullshit reasons (i have seen that with other suggested variants).
This is very similar to already existing variants and previously declined variants.
No such "very similar" variant was mentioned.
Someone mentioned Blackletter Chess but that is a very different game in terms of actual gameplay.
But the bigger issue was their incorrect automatic draw rules i couldn't change and incorrect numbering of ranks.
Description
Pawn promotion at rank 9 (not 11) to one of the following pieces
Centaur (king+knight moves), called "general" on this website.
Archbishop (Bishop + knight)
Chancellor (Rook + knight)
Queen (Rook + Bishop)
No castling.
You win if you get stalemated.
https://vintologi.com/threads/9x10-chess-with-centaurs.1080/page-2
The game was tested with Fairy Stockfish to confirm that it wouldn't be too unbalanced, win rate for white seems to be less than 50% when having the same strong engine play both sides.
Potential issue: chess.com may incorrectly conclude a game as drawn from insufficient material even though one of the players can win by getting stalemated (typically cannot be forced though).
There are positions where you can win by forcing your opponent to stalemate you but i have so far not encountered that in a real game. 50-move rule for draw might not be ideal for this game (at least not regardless of material) since there are endgame that may last longer than that (such as queen & knight or queen & bishop vs centaur).
What does this add to normal chess and/or other similar variants (like Gothic Chess, Blackletter Chess, Courier Chess, etc.)?
This game has 2 centaurs which is an interesting piece most variants do not have.
This game is less prone to draw than standard-chess (so far not a single drawn game out of maybe 50 played so far) even though it's likely draw with perfect play.
This variant is highly tactical and often features very complex positions due to all the pieces you start with (even relative to the board size).
You have a decent shot of winning even if you have less material since you might still be able to checkmate your opponents king anyway (rather than it reaching the endgame where material has a bigger impact).
Updated description (new text only)
Note that this variant currently has incorrect automatic draw rules due to chess.com being a bad site you should avoid.
There shouldn't be "draw from insufficient material" unless only 2 kings remain.
If only a single bishop or a single knight remains only the player without a piece should be able to claim automatic draw (since that is the only player who can still win by getting stalemated).
That is not a problem in terms of prolonging games much since you can force a draw pretty quickly (3-fold repetition) if you are the player with the piece left.
50-move rule for draw might not be ideal for this game (at least not regardless of material) since there are endgame that may last longer than that (such as queen & knight or queen & bishop vs centaur). I recommend using a 250-move rule (exceptions are allowed if they don't result in more draws with perfect play regardless of starting position).
#44
Lessons from human vs human matches
The game was intended to be less prone to draws than standard chess and this ended up working out a lot better than expected. Not a single draw in over 40 games i have played so far.
You might think that it's over if you are say a queen down in material but very often you will be able to recover from that, you will often still have a lot of pieces left which may allow you to checkmate your opponents king anyway. Even a single centaur can be pretty dangerous close to the king.
Most games will end in checkmate while the checkmated player has a lot of material left, that's because humans are prone to miscalulation resulting in them pursuing material only to completely lose the game.
Here i am behind 10 points in material but i have mate in one:
White did the mistake of taking my undefended rook instead of taking my queen.
https://www.chess.com/variants/custom/game/71742774
Here instead i was the one with more material but i ended up making some bad moves resulting in my opponent winning anyway:
https://www.chess.com/variants/custom/game/71785896
I probably could have survived by sacrificing the centaur for the opponent knight but i didn't see that i was going to get checkmated after king to f7.
#45
The closest to a draw i have gotten is me playing this endgame where i have the ability to force a win.
Here it's black to move and thanks to the pawn i have left winning shouldn't be too hard even against stockfish. It would have been a lot harder if it wasn't for that pawn (if you can force a win to begin with).
https://www.chess.com/variants/custom/game/71750004
#46
100 million nodes / move test
nmoverule = 250 (regardless of material)
1 million nodes/move if niether player has any more material than a single knight or a single bishop or two bishops confined to the same color (does not have to be set to that right away).
f3f5 d8d6 c3c4 i8i6 i3i5 e8e6 f5e6 e9e6 d3d5 e6e9 g3g4 b8b7 h1g3 h8h7 b1c3 d9b8 a3a5 g9h8 h2f3 h9i7 g1h2 c8c7 b2d3 b10c8 c1b2 i7g6 b3b4 c7c6 g3f5 b9c7 e3e4 g6e7 f5e3 e7g6 e3f5 g6e7 f5e3 e7g6 c4c5 g6h4 f3h4 c9h4 h2g3 h4g3 f2g3 a8a7 c2b3 f9e8 h3h4 d6c5 b4c5 b7b6 d5d6 c7a6 e3f5 a6c5 d3c5 b6c5 e4e5 f8f6 g2i4 e8f8 c3e4 f6e5 i2f2 c10i4 f1i4 g10e8 i4g2 a9d9 b2c1 i9f9 b3c4 a10b10 d2d3 h8i7 i1f1 i10i9 c1i7 f10i7 a2d2 e8g6 d3c5 f8d7 c4a6 e10f10 a1b1 b8c9 b1c1 e9a5 c5c6 d7c6 c1c6 c9b8 c6c8 b8a6 f5e7 f10g10 f2f9 i9f9 f1f9 h10f9 c8g8 g10h9 e7c8 d10c9 c8b10 c9b10 g8g6 h7g6 e1f1 a6b4 d2b2 d9b9 f1g1 f9h8 g2f2 h9i8 b2b4 b9b4 g1h2 a5b5 d6d7 b4d4 d1c2 d4d7 g4g5 d7f7 e4f6 b5b8 g3g4 e5e4 h2i3 f7c7 c2d2 b8c8 f2i2 b10b3 i3i4 c7c1 d2d5 b3d3 d5e4 d3e2 e4e2 h8f7 g4f4 c8b8 e2e3 c1e1 e3g3 e1g1 g3h2 i7g9 f4h3 b8h2 i2h2 g1e1 h2b8 i8h9 h3f2 e1e6 b8a7 g9f8 a7c9 e6e9 c9c2 f8b8 c2g6 f7h8 g6d3 e9e1 d3d9 h9g10 i4h3 e1c1 f6h7 c1c9 d9d10 g10h9 d10d5 h9h10 d5d3 c9c6 f2g3 b8c9 d3d4 c9c8 d4g4 c8b8 g4f4 b8c8 f4f5 c8g8 f5b1 g8c8 b1f5 c8g8 f5f3 g8c8 f3g4 c8g8 g4b4 h10h9 b4b9 h8f9 h7f6 g8f7 g3e4 h9g10 b9d7 f7b3 d7d3 b3b9 f6d7 b9a8 d3d5 a8a3 h3g4 c6a6 d7c5 a6b6 d5g8 g10f10 g8i10 f10g9 i10i9 g9g10 i9i8 g10g9 i8i9 g9g10 i9i8 g10g9 i8i7 g9h9 i7f10 b6b9 f10e10 a3b2 g4h3 b2b1 e10e6 h9g9 e6d6 g9h9 d6d5 h9h10 e4g3 f9h8 d5f5 b1b4 f5e5 b9h9 c5e4 b4b3 e5e7 h10i9 e7i7 i9h10 e4f6 b3e6 h3i3 e6d6 g3h3 d6d8 i7a7 h9e9 a7c5 h10i9 c5a3 d8b8 f6d7 e9a9 a3e7 b8g8 d7f6 g8a2 f6h7 i9i8 h7g9 i8i9 g9h7 i9i8 h7f8 a9a7 e7e4 i8i9 f8h7 i9i8 h7f8 i8i9 f8h7 i9i8 h7f6 i8i9 e4e9 i9i8 f6g4 h8f7 e9f9 i8h8 g5g6 f7g9 f9i6 a7a3 g4e3 h8h9 i6h5 h9g10 h5c5 a3b3 c5c6 g10h10 c6e6 a2b2 g6g7 b3b6 e6g4 b2b5 g4d4 b6g6 d4d10 h10h9 d10f8 b5e5 e3f5 e5c3 i3i4 c3e5 f8h8 h9g10 h8c8 g6b6 c8c10 g10f9 h3g4 e5e8 c10e8 f9e8 g4e5 e8d8 f5d6 b6b9 d6f7 g9f7 e5f7 d8d7 g7g8 d7c8 i5i6 c8c7 i6i7 c7b6 g8g9h b9g9 f7g9 b6c5 i7i8 c5b4 g9f7 b4c4 f7e5 c4b5 e5d5 b5a5 i8i9q a5a6 i9b9 a6a5 d5b4
f3f5 d8d6 i3i5 i8i6 c3c4 e8e6 f5e6 e9e6 d3d5 e6e9 h2f3 b8b7 b1c3 h8h7 h3h4 g9h8 a3a5 c8c6 b3b5 b10c8 g3g5 f9d8 g2h3 b9c7 h1g3 a8a7 f2g2 c10b9 e3e4 h9i7 g1d4 c8e7 h3b9 a9b9 d2b3 i7g6 g3f5 c6d5 e4d5 e7f5 c2f5 e9e2 c3e2 g10d7 f5g6 h7g6 i2i3 i9e9 b2d3 h10i8 e1f2 h8d4 f3d4 i8g7 f2g1 f8f7 e2g3 e10f9 a2e2 c9b8 d1d2 e9e2 g3e2 d9f8 i3e3 b9e9 i1i3 f9g10 e3e9 d10e9 i3e3 e9d9 c1a3 c7e8 e2g3 g10h9 d3f4 g7h5 a1e1 f8h7 g3e4 f10f9 a3b4 a10e10 f1d3 i10f10 e1f1 d8c8 f4h5 i6h5 e3f3 b8d10 b4c3 d10g7 f3f2 g7e5 d2b2 e8g7 e4f6 h7i6 f6d7 c8d7 g1h1 d9c8 f1e1 f9b9 e1e4 a7a6 b5b6 f7f6 g5f6 f10f6 d4f3 e10f10 c3d4 f10f9 d3e2 d7e7 h1g1 e5d4 b3d4 e7f5 f3g5 f5g5 h4g5 f6f2 g2f2 i6g5 b2c1 f9f2 e4e9 h9g10 e9e10 g10g9 e10e9 g9g10 c1g5 f2e2 e9b9 e2e1 g1f2 e1e10 b9i9 c8i2 f2g3 i2i1 g3g2 i1i2 g2g3 i2i1 g3g2 i1i4 g2h2 g10h10 g5h6 h10i9 h6g7 i9h9 d4f3 i4f1 g7b7 f1f3 b7d9 h9h8 d9e10 f3f4 h2g2 f4g4 g2h2 g4h4 h2g1 h4g3 g1h1 g3h4 h1g2 h4g4 g2h2 g4h4 h2g1 h4g3 g1h1 g3f3 h1h2 f3f4 h2h3 f4f1 h3g3 f1d3 g3h2 d3c2 h2g1 c2c1 g1g2 c1g5 g2h3 g5f5 h3g3 f5g5 g3h3 g5f5 h3g3 f5d3 g3g2 d3c2 g2h1 c2c1 h1g2 c1c2 g2f3 c2d3 f3f2 d3d4 e10e3 d4h4 f2f3 h4g4 f3f2 g4i2 f2g1 i2i1 g1g2 i1i5 b6b7 i5i4 g2h2 i4h4 h2g2 h4c4 b7b8 c4g4 g2h2 g6g5 e3f2 h8h7 f2a7 h7h8 a7f2 h8h7 f2a7 g8g7 a7f2 h7g8 f2e3 g8f8 e3b6 g4h4 h2g2 h4e4 g2f1 e4d3 f1e1 d3e4 e1d2 e4f4 d2c2 f4h2 c2d3 h2h3 d3e2 h3g4 e2e1 g4e4 e1f2 e4f5 f2g1 f5g4 g1f2 g4f4 f2e2 f4g4 e2f2 g4h4 f2g2 h4i4 g2h2 i4f4 h2g2 f4i4 g2g1 i4i1 g1f2 i1f4 f2g1 f4i1 g1f2 i1f4
f3f5 i8i6 i3i5 d8d6 d3d5 c8c6 c3c4 g8g6 f5g6 c6d5 c4d5 e8e6 b1c3 b10c8 e3e5 b9c7 d2c4 d9e7 h2g4 h9g7 c1g5 e6d5 c3d5 e7d7 d5f6 d7e6 h3h4 d6d5 c4c3 c9f6 e5f6 g7f5 g4h6 c10g6 g3g4 f5h6 c2g6 d5d4 c3d3 h6f7 g6f5 e6d8 d3d4 c8d6 f5a10 d10a10 i2i3 a9d9 i3e3 c7e6 d4d5 f7g5 h4g5 d6b7 f2h3 f8f7 e3d3 b7c5 d3d2 c5d7 b2c4 f9f8 h1g3 h10g8 b3b4 g10e8 d1b3 e10f9 a1d1 g8i7 g3f5 i7g6 d5e4 f9g10 g1h2 g10h9 h2g3 d9c9 a3a5 f10f9 e1f2 i10c10 c4d6 i9i10 f2g1 e8d9 i1h1 i10e10 h3i4 e9f10 e2f2 f8g8 g1h2 d7f8 f5h6 g8i7 e4f5 d8e9 a2c2 b8b7 c2c9 c10c9 g2d5 f10g10 d1c1 c9c1 f1c1 g10i10 h1e1 h9i9 c1b2 e9d8 b4b5 a8a6 b3f3 e10b10 b5b6 a10b9 f2g2 g9f10 b2a2 i7h7 d5b3 d8e9 d2e2 f9d7 e2c2 b10c10 c2d2 d7g10 d6b7 g6i7 b7d6 c10c5 b3d5 f10g9 d2c2 c5c2 a2c2 g10e10 b6b7 e10c10 b7b8 c10c2 g2c2 e9d8 e1b1 i10c10 c2g2 d8c7 d6f7 d9f7 h6f7 c10f7 i4h6 f7d9 g3c7 e6c7 d5f7 d9d8 f3h3 h7h6 i5h6 i7h9 f5e7 f8e6 f7e6 d8e7 e6b9 e7e5 h2i2 c7b9 h3i4 h8h7 b1b7 e5e10 g5g6 h7g6 i4g6 g9f10 b7h7 f10h8 g2c2 h9f8 h7i7 h8i7 g6i8 i9h10 h6i7 e10f9 i8h8 f9h9 h8f8 h10i10 c2c10 b9d10 c10d10 i10i9 b8b9h i6i5 f8h8
f3f5 d8d6 c3c4 h8h7 i3i5 i8i6 d3d5 c8c6 h3h4 g9h8 f2h3 c6d5 c4d5 b10c8 e3e4 g8g6 g3g5 f8f6 b1c3 b9d8 b2c4 d8f7 h2f3 h9g7 a3a5 h10g8 b3b5 a8a7 g1e3 f7e5 h1g3 f9f8 c1b2 f8d7 f3e5 d6e5 f5g6 h7g6 g2f3 e8e7 f3g4 d7d8 i2f2 i9f9 g3i4 b8b7 i4h6 g10h9 c3a4 d9b10 a4c5 c9b8 b2c3 c10e8 d1b1 a9d9 f1g2 a10a9 i1f1 c8d6 c2a4 a9c9 c4d6 b8d6 c5d3 c9c10 a2c2 d10b8 c3b4 d6b4 d3b4 c10c2 b1c2 d9c9 c2b1 f10g10 g5f6 e7f6 a5a6 b8d6 a6b7 d8b7 a4c2 f6f5 e4f5 g8h6 e3h6 e9b6 d2e4 d6g9 f5g6 e8g6 e4e5 f9f2 f1f2 g6c2 b4c2 c9e9 g4d7 g10h10 h6e3 e9e5 e3b6 g7f5 c2e3 b7b6 d7f5 e10d10 e1f1 g9c5 g2g5 b10d9 a1a6 h10f8 a6b6 a7b6 b1a2 d9c9 e2c2 e5e3 g5c9 d10c9 a2a9 c9d8 a9b8 d8e9 b8b9 e9d8 b9b8 d8e9 b8c9 e9f10 c2c5 b6c5 h3g5 h8d4 g5g6 e3e8 c9c10 f10e9 g6f8 e9f8 f5d7 d4f2 c10e8 f8g9 e8e7 g9h8 f1f2 c5c4 e7f8 h8i9 f8g7 i9h10 g7e7 h10i9 e7g7 i9h10 g7e7 h10i9 e7e5 i9h10 e5d6 h10i9 d6i6 i9h8 i6f6 h8g9 f6d6 g9h8 d6f8 h8i9 f8f6 i9h10 f2e3 i10i8 e3d4 i8g8 d4c4 g8g1 f6f10 h10i9 f10i7 i9h10 b5b6 g1f1 i7h6 h10g9 b6b7 f1f8 h6f8 g9f8 b7b8 h9i8 b8b9h i8c2 b9f9 f8g8 d5d6 c2b1 d7e8 b1a2 c4c5 a2b1 d6d7 b1e4 f9f6 g8h8 f6e4 h8g8 e4e6 g8h8 d7d8 h8g8 d8d9h g8h8 e6g6 h8i8 d9g9
f3f5 d8d6 i3i5 i8i6 c3c4 e8e6 f5e6 e9e6 d3d5 e6e9 h2f3 b8b7 b1c3 h8h7 a3a5 c8c6 b3b5 g9h8 f3d4 c6c5 d4f3 c9f6 c3e4 f6e7 g3g5 b10c8 h3h4 a8a7 g2h3 d9b8 h1g3 f9d8 d2b3 g10d7 b2d3 h8a1 a2a1 b7b6 a5a6 c10e8 d3f4 d7h3 f4h3 b9c7 e4f6 h9g7 g1h2 e9h9 e3e5 a9e9 c1b2 h10f9 f2e3 e8g6 e1d2 e10d9 h3f4 f8f7 f1h3 d9c9 d2c1 f10g9 f4g6 h7g6 b2c3 i10e10 e3g4 a10c10 c1b2 c9b10 e2f2 e7f8 i1e1 g7h5 i2i1 f9g7 i1f1 h5g3 g4g3 h9g10 g3g2 i9h9 f6e4 g7h5 e5d6 c8d6 f3e5 b8c8 e4d6 f8d6 d1d3 c7e8 c2d1 e8g7 d1g4 g7f5 f2c2 d8c7 f1f5 g6f5 d3f5 g9f8 f5f3 c8e7 a1d1 f8a8 f3f1 e7f8 e5c6 c10c9 g2f3 g10h10 b3d2 d6h2 h3h2 c7d6 f1i1 f8g6 e1e6 e9e6 d5e6 c9c6 b5c6 d6c6 g4f5 g6f5 c2f5 e10e6 d2e3 h9d9 d1d9 d10d9 e3d5 c6d7 d5c7 d7c7 h2c7 h10c10 c7b8 c10b9 b8a8 b9a8 i1c7 a8c8 c7c8 d9c8 f5d3 c8a6 c3e5 a6b7 f3e4 h5g7 e4f6 g7e8 d3d8 b10b9 f6e8 b7g2 b2b3 g2f3 e5c3 e6e8 d8e8 f3d3 e8f9 b9c10 f9e10 c10c9 e10f9 c9d10 f9a4 d10d9 a4f9 d9d10 f9g8 d3b1 b3a3 b1c1 c3b2 c1c4 b2g7 d10d9 g8i6 c4b4 a3a2 b4d2 a2b3 d2b4 b3c2 b4h4 i6f9 d9d8 g7f6 d8c7 f9f7 c7c6 f7e6 c6b7 e6d7 b7a6 d7c8 a6b5 c8e8 b5a6 e8e2 a6b7 i5i6 h4a4 c2d3 a4b3 d3e4 b7c6 e2f3 b3f7 e4f5 c6b5 g5g6 f7d7 f5g5 d7d2 g5h5 d2h2 h5i5 h2d6 i6i7 c5c4 g6g7 b5a4 i7i8 d6i1 f6i3 i1e1 i5i6 c4c3 f3f4 a4b3 f4f7 b3b2 i8i9q e1d1 f7h5 c3c2q g7g8 b2b3 g8g9q d1h5 i6h5 c2e2 h5h4 e2f2 h4h3 f2f5 h3h2 f5h7 h2i1 h7c7 i3h2 c7c1 i1i2 c1c8 i2i3 c8d8 i3i4 d8e8 i4i5 e8e1 h2g3 e1a5 g3e5 a5e1 e5g3 e1a5 i5i6 a5b5 i9h9 b5c4 g9a3 b3a3 h9c4 a7a6 c4c3 a3a4 c3b2 b6b5 g3e1 b5b4 b2b4
f3f5 i8i6 i3i5 d8d6 c3c4 e8e6 f5e6 e9e6 d3d5 e6e9 b1c3 b8b7 a3a5 h8h7 g3g4 g9h8 h1g3 c9f6 c3e4 f6e7 h2f3 c8c6 b3b5 b9c7 e4c3 b10c8 f3d4 c6b5 c4b5 a8a7 d2c4 d9b8 e3e4 h9i7 c1i7 h8i7 f2f3 e9c9 i2h2 c8e9 h3h4 e9f7 b2d3 a7a6 c2b3 c7b5 d4b5 a6b5 c3b5 e7d8 g3f5 f7e5 d3e5 d6e5 g1b6 i7f4 i1h1 f9h8 e2b2 g8g6 f5e3 d8b6 a5b6 g10b5 c4b5 c10e8 a2a9 a10a9 b5c4 a9a1 b2a1 f8f6 g2h3 c9c10 h2c2 i9a9 a1b2 a9c9 c4d3 i10i9 c2c9 i9c9 b3a4 h10g8 a4e8 c10e8 f1f2 h8g7 e1f1 b8a6 d1e2 f10g9 f1g2 a6b8 e2e1 h7h6 i5h6 g8h6 g4g5 f6g5 h4g5 h6f7 f2i5 g7h5 i5d10 e10d10 h3g4 f7g5 f3h4 h5h6 e3c4 h6f7 g4e2 c9e9 b2b4 e8e7 b4e7 g9e7 h4g4 e9e10 d5d6 e7f8 d3c5 i6i5 c5d5 i5i4 e1h4 e10i10 h4i3 f7e6 d5e6 g5e6 g4f6 f4e3 c4e3 e6f4 g2h2 i10h10 h2i2 h10h1 f6e7 f8h6 e7e8 d10c10 e8d8 c10d10 d8e8 d10c10 e8d8 c10d10 e3g4 h6h5 d8e8 d10c10 e8d8 c10d10 d8e8 d10c10 e8d8 c10d10
f3f5 d8d6 c3c4 i8i6 g3g4 e8e6 f5e6 e9e6 d3d5 e6e9 h2f3 h8h7 b1c3 g9h8 i3i5 b8b7 g1h2 d9b8 h1g3 c8c7 b2d3 b10c8 a3a5 h9i7 c1b2 i7g6 b3b4 c7c6 g3f5 b9c7 e3e4 g6e7 f5e3 e7g6 e3f5 g6e7 f2e3 e7f5 e4f5 f9e7 h2i3 e7f7 c3e4 h8b2 a2b2 b7b6 c2b3 a8a7 f3d4 c6c5 d4f3 c9i3 i2i3 f10h8 f3g5 f7e7 h3h4 f8f6 g5e6 g8g6 e4g3 h10i8 d2c2 i8g7 e1f2 e10f10 f2g1 h7h6 i5h6 h8h6 i3h3 h6h8 d3f4 c7e6 f5e6 i6i5 h4i5 h8g8 b4c5 i9i5 i1i5 i10i5 c5c6 e9i9 g2h1 a9f9 a5b6 c8b6 f4d3 a10a9 e3g2 g7i6 h3i3 i5i3 g2i3 f9h9 e2e3 a9f9 c2d4 f6f5 b2i2 f5f4 d3f4 g6g5 d4f5 e7f5 g4f5 g5f4 f1f4 f9g9 i3g2 i9f6 i2h2 i6g5 h2h9 g8h9 h1i2 d10g7 a1a2 g10e8 d1d4 e8i4 d4f6 g7f6 g2h2 c10h5 g1h1 h5f3 h1i1 i4h3 h2f3 g5f3 e3f3 h3i2 i1i2 h9i9 g3i4 b8d9 b3d1 g9g1 a2a7 f6b2 d1e2 g1e1 f4g4 b2e2 f3e2 e1e2 g4e2 i9i4 i2h1 d9e8 f5f6 i4h4 h1i2 h4i5 i2h1 i5h4 h1i2 e8f6 e2b2 h4i4 i2h1 i4f1 h1i2 f1i4 i2h1 i4e4 h1g1 e4e3 g1h1 f6g8 b2g2 e3e1 h1i2 e1i5 i2h1 i5f8 g2i4 f8h6 h1i2 h6d2 i2h3 d2e3 h3i2 e3f2 i2h1 f2e1 h1g2 b6c8 a7a2 e1b1 i4c10 f10g9 a2f2 c8e7 c10c9 g9h8 c6c7 b1e4 g2g1 e4d3 c9d8 h8g9 d8d6 d3c4 f2g2 c4c1 g1h2 c1h6 h2i2 h6i5 i2h1 i5h4 h1g1 h4e1 g1h2 e1h4 h2g1 h4i3 g1f2 i3f6 f2g1 f6d4 g1h2 d4f6 c7c8 f6h6 h2g1 h6c1 g1f2 c1d2 f2g3 d2c3 g3h2 c3h8 h2g1 h8d4 g1h2 d4h4 h2g1 h4d4 g2f2 d4g4 g1h2 g4h4 h2g1 h4g5 f2g2 g5c1 g1h2 c1h6 h2i2 h6i5 i2h1 i5h4 h1i2 h4i4 i2h1 i4h3 h1g1 h3e3 g1h1 e3h6 h1i2 h6i5 i2h3 i5h5 h3i3 h5i5 i3h3 i5f5 g2g4 f5f1 g4g2 f1f5 g2g4 f5h7 h3g3 h7d3 g3h4 d3h7 h4g3 h7d3 g3h4 d3h7 h4g3
f3f5 d8d6 i3i5 i8i6 c3c4 e8e6 f5e6 e9e6 d3d5 e6e9 b1c3 b8b7 a3a5 h8h7 h2f3 g9h8 g3g5 f8f6 c3e4 c8c6 e4f6 c9f6 g5f6 c6d5 c4d5 h8f6 g1i3 f6h8 h1g3 d9b8 b3b5 f9g9 a2a4 b10c8 a4e4 c10e8 f3d4 b9d8 b2c4 d8f7 c1b2 h9f8 f2d3 h10f9 d3b4 f8d7 f1f2 d7e5 i1f1 f9e7 i3f6 e7g6 f6h8 g9h8 h3h4 i9f9 e4f4 c8e7 d4f5 e7f5 g3f5 a9c9 f4e4 a10c10 f2g3 g8g7 c4e5 f7e5 g2h3 f10g9 c2a4 g10h9 i2f2 i10f10 b5b6 e8a4 d1a4 b8d7 a1c1 d7f6 c1c9 c10c9 a4b3 d10d8 g3h2 c9c5 e4d4 f6h5 b2a3 h7h6 a5a6 g6i5 h4i5 h5i3 h2g3 h8g6 f5d6 f9f2 f1f2 g6h5 f2f10 g9f10 g3f4 c5c9 h3c8 c9c8 d6c8 d8c8 f4f10 e10f10 b3c3 c8c3 b4c3 h5g3 e2i6 e5f3 d2f3 i3h5 f3g3 h5i6 g3f5 i6g5 f5e7 h6i5 c3e4 g5f7 e4d6 f7e7 d6e7 b7a6 d4f4 f10e10 f4e4 e9e7 e4e7 e10d9 e7g7 d9e8 e3e4 h9f7 e1d2 i5i4 d2c3 f7h5 e4e5 e8d8 g7i7 a6a5 e5e6 d8c8 c3d4 i4i3 i7i3 c8b7 d4c5 h5g4 i3i7 b7c8 c5d4 a5a4 d4e5 c8c9 d5d6 c9b8 d6d7 b8c9 e5d6 a8a7 e6e7 c9b8 e7e8 a7b6 e8e9c g4d7 e9d7 b8b9 i7i9 b9a8 d7c7 a8a7 i9a9
f3f5 d8d6 i3i5 i8i6 c3c4 e8e6 f5e6 e9e6 d3d5 e6e9 b2d3 h8h7 c1b2 g9h8 a3a5 b8b7 b3b5 c8c7 d3b4 b10c8 h3h4 a8a6 b5a6 b7a6 f2d3 b9d8 c2a4 f9g9 b2h8 g10a4 d1a4 g9h8 b1c3 d9e7 g3g5 c10e8 a4a3 c7c6 h1g3 h9g7 g2h3 c6c5 b4c2 g7h5 g3h5 e8h5 h2f3 d8f7 g1h2 a10b10 e2g2 d10d9 e1f2 a9b9 a1e1 i9f9 f2g1 c9b8 g1h1 g8g7 e3e5 h5f3 d2f3 f7e5 h2e5 d6e5 f3e5 b8e5 e1e5 h8g6 a3c5 b9c9 c5g1 f8f6 e5e7 c8e7 h3i4 f6g5 f1d1 h7h6 i4g6 e7g6 c2d4 g6h4 g2h3 h4i2 i1i2 e10d10 a2e2 e9f8 i2h2 h10g8 d3e5 h6i5 d4e6 f8e9 h3i2 i10h10 h2h10 f10h10 h1i1 h10b4 d1d3 e9f10 e2e1 b4b2 d3i3 g8i7 e6g7 f9e9 e1f1 f10f1 g1f1 b2b8 i3h2 e9e5 f1f10 e5e10 h2b8 b10b8 g7f9 d9f9 i2a10 c9c10 f10f9 e10e1 i1i2 c10a10 f9f10 e1e10 f10i7 a10a8 i7g5 b8b2 i2i3 a8f8 g5g3 e10e8 c3d1 b2e2 g3g7 e2e7 g7h6 e7e1 d1f2 e1i1 i3h2 i1f1 f2h1 d10c9 h6c6 e8c8 c6a6 f8h8 h2i2 f1h1 a6f6 c9d9 f6f9 d9d8 c4c5 h1h5 f9g9 h8e8 g9d6 d8c9 d6a9 c9d10 a9a10 d10e9 a10b9 e9f8 b9b6 e8e2 i2i3 c8e8 b6i6 e8e3 i3i4 h5h4 i4i5 e3i3 i5h4 i3i6 h4g5 e2f2 a5a6 i6i10 a6a7 i10g10 g5h4 f2h2 h4i3 h2h7 c5c6 g10i10
f3f5 d8d6 i3i5 i8i6 c3c4 e8e6 f5e6 e9e6 d3d5 e6e9 b2d3 h8h7 c1b2 g9h8 a3a5 b8b7 h3h4 d9b8 b3b5 f9e7 f2f3 c8c7 e3e5 d6e5 g1c5 e7e8 b2e5 h8e5 f3e5 b10c8 a5a6 g8g6 b1c3 h9g7 h2i4 h10g8 e5f3 f8f6 g2h3 c9e7 c5d4 c7c6 i4h6 e8f8 g3g5 c6d5 a6b7 a8b7 a2a9 a10a9 c3d5 f6f5 a1a9 b8a9 d5e7 g8e7 e2e3 b9c7 d4e5 b7b6 h1g3 c10a8 f3d4 c7e6 d4c3 c8d6 d1a1 e9b9 i2e2 a9c8 h3g2 a8g2 f1g2 i9d9 e1f2 e10f9 i1d1 g10h9 c3b4 d6f7 h6f7 h9f7 d2c3 f9g10 f2g1 i10i9 c2b3 i9e9 e3f3 e7g8 e2a2 e9e8 a2a8 c8b10 a8e8 f8e8 g1h1 b10c8 f3a8 g10h9 a8b9 c8b9 g3e2 g8e9 e5h2 e9d7 e2f4 e8f8 f4e6 g7e6 d1d2 e6c5 d3c5 d7c5 b3d1 c5e4 d2d9 f7d9 c3d4 d9b7 d1f3 f10e10 b4d3 d10a10 a1b2 b9d8 d3e5 a10a8 h1i1 d8e7 g2h1 e7g8 h2f4 g8g7 d4e3 e10a10 f4h2 a8a3 h1c1 a3a7 e3f4 g7g8 c1g1 g8e7 g1d4 e7g8 b2g2 h9i8 h2g1 a10f10 g2b2 a7b8 b2a3 e4c5 f3b7 b8b7 d4a1 b7b8 f4d5 f10e9 g1h2 b8d10 a3a8 i8h9 a8a7 c5d7 a7d10 e9d10 e5c6 g8f7 a1a9 h9i8 a9a8 i8h9 a8a9 h9i8 a9a8 i8h9 i1i2 d10e9 a8a9 e9a9 h2a9 f7g7 a9h2 h9i10 d5d6 d7c5 c6b6 c5e4 d6e5 g7h5 e5f3 h5g4 f3g4 f5g4 b6d5 g4g3 i2h3 g3h2c h3h2 e4d2 d5d4 f8d7 c4c5 i10h9 c5c6 d7b6 d4e6 d2e4 e6g7 h9g10 g7h7 b6b5 h7g6 b5c6 g6h8 g10f10 h8g8 f10g10 h4h5 i6h5 g8f8 g10h10 f8g8 h10i10 g8g9 i10i9 g9g8 i9i10 g8g9 i10i9 g9h7 i9i10 h7h8 i10h10 h8f9 h10i10 f9h8 i10h10 h8f9 h10i10 f9h8
White wins: 5
Draws: 4
Blak wins: 1
f3f5 d8d6 c3c4 i8i6 d3d5 g8g6 e3e4 i6i5 i3i4 h8h6 h2g4 h10g8 f5g6 h9i7 e4e5 d6e5 g4e5 g9h8 h1i3 h8e5 e2e5 f9h8 e5e2 i7g6 i3h5 e8e6 c2g6 h8g6 h5f4 g6h8 f4e6 c8c6 e6f4 c6d5 f4d5 b9c7 b1c3 b10c8 b2d3 e9e8 e2e8 d9e8 f2f3 h8f7 g1d4 i9d9 f3e5 i10i7 g2f3 c9f6 d5f6 g8f6 d2e3 f10g9 i2f2 f7e5 d3e5 d9d6 f3c6 e8g7 a2d2 a9d9 c1b2 g10c6 e5c6 d6c6 d4f6 g7f9 f2e2 i7d7 c3d5 c8e7 d5e7 d7d2 e2d2 g9g3 e1e2 d9d2 d1d2 g3h2 e3g2 d10d2 e2d2 h2d6 e7d5 c7d5 b2e5 d6e6 c4d5 e6d5 d2e1 c10e8 f1f3 a10d10 f3d5 d10d5 g2f4 d5b5 b3b4 f9g8 f6i3 e8d7 e1d2 g8f7 a1e1 e10f9 i3g1 c6a6 e1e3 d7h3 g1h2 h3d7 i1c1 a6e6 c1c9 e6e9 c9e9 f7e9 f4g6 e9g8 e3f3 d7e8 g6g7 g8g7 e5g7 b5g5 f3f8 f9g10 f8g8 g10f9 g8f8 f9g10 d2e3 g5g7 f8e8 g7g2 h2b8 g2i2 e8g8 g10h9 g8g6 i2i3 e3f2 i3a3 g6h6 h9g8 h6h5 a3b3 b8d6 a8a6 f2g2 b3d3 d6c5 d3c3 h5g5 g8h7 g5i5 c3b3 i5h5 h7g6 g2h2 b3a3 c5e7 a3c3 e7h10 c3e3 h10g9 e3f3 h5a5 f3f6 h2h3 f6c6 h3h4 c6e6 a5h5 e6e1 g9c5 e1e8 h5g5 g6h7 g5d5 h7g6 d5d6 g6h7 d6a6 e8e4 h4i3 e4c4 a6c6 c4c3 i3h4 c3b3 i4i5 h7i7 c6b6 b3b2 c5e3 i7i8 h4h5 b2h2 h5i6 h2c2 b6b8 i8h9 e3h6 c2c7 b4b5 h9g9 b8b9 g9g8 b5b6 c7c10 b6b7 c10i10 i6h5 i10f10 b7b8 f10f3 b9i9 f3h3 h5g6 h3g3 h6g5 g3b3 b8b9q b3b9 i9b9 g8f8 b9b8 f8g9 g5h6 g9f9 g6h7 f9g9 b8b9 g9h10 h7g8 h10i10 h6g7 i10h10 b9b10
f3f5 i8i6 i3i5 d8d6 d3d5 c8c6 c3c4 g8g6 f5g6 c6d5 c4d5 b10c8 h2g4 h10g8 b1c3 f9g7 h3h4 h9i7 g4h6 g10i8 h6i8 i9i8 b2c4 i7g6 c2g6 g7g6 g2e4 g6g7 e4i8 i10i8 a3a5 a8a6 f2h3 e8e6 e3e4 h8h7 a2c2 b9c7 c1b2 f8f6 g3g4 g8e7 d5e6 g7e6 h1g3 c10a8 c4b6 i8e8 g1e3 d6d5 d2b1 c8b6 a5b6 c7b5 i2f2 b5c3 b2c3 e7g8 a1a6 a8b7 a6a9 a10a9 g4g5 e6f7 g5f6 c9d8 h3g5 d8b6 f1i4 d9f8 e3b6 e9b6 c3d4 b6a5 b3b4 a5a4 c2a2 a4d1 e1d1 a9c9 g5f7 f8f7 e4e5 c9c4 e2d3 b7d9 b1c2 g9i7 i1e1 f10c7 d3h7 e8c8 i4i2 c7c6 h7i6 d10c10 i6g4 c6b7 e1f1 b7b5 a2a5 b5b7 c2d3 c4b4 f2a2 b4b3 d3c5 b3g3 g4g3 c8c5 d4c5 c10c5 i2a10 c5c10 a10c10 d9c10 g3d3 d5d4 a5a10 b7c8 d3c2 c8g4 c2e2 g4c8 e2c2 c8c2 a2c2 g8e9 f1f2 e10f9 a10c10 e9c10 c2c10 f7e5 f6f7 e5e4 c10c9 f9f8 c9c8 f8g7 c8g8 g7h7 i5i6 h7i6 g8g2 e4e3 d1e1 i7f10 g2g5 d4d3 f2i2 i6h7 f7f8 f10a5 g5a5 e3f3 e1d1 f3e3 d1e1 e3f3 e1d1 f3e3 d1e1
f3f5 i8i6 i3i5 d8d6 d3d5 c8c6 c3c4 g8g6 f5g6 c6d5 c4d5 b10c8 h2g4 e8e6 e3e5 d6e5 d2c4 e6d5 c4d5 h9g7 b2c4 b8b7 c2e4 f8f6 g6f7 d9f8 g4e5 b9c7 d5c3 c9a7 c1e3 a9d9 a2d2 f9e7 e3a7 c8a7 a3a4 a7c6 a1a2 c6e5 c4e5 h8h7 f2g4 g7e6 g1i3 e7c8 i3g5 h10i8 h1f2 a10a9 g5e3 g9h8 c3c4 i8g9 e3h6 h8g7 h6g7 e6g7 g4h6 c8e7 f2g4 a9c9 b1c3 c10b9 d2d9 c9d9 a2d2 b9e6 c4c5 g9f7 e5f7 e6f7 f1f2 g7e6 c5c4 f10h8 i1f1 i9f9 f2e3 g10h9 c4e5 f8g7 d2d9 d10d9 g2h1 e6f8 d1d9 e10d9 c3b5 g7h6 i5h6 f8d7 b5c7 e9c7 e2d1 h8d8 i2c2 c7a5 b3b4 a5b4 e3d2 b4a5 e4h7 f9e9 h1e4 d9d10 d2a5 d8a5 d1d2 a5d2 c2d2 f7d5 e5d4 d5e4 h7e4 i6i5 e1f2 i5i4 f2g2 h9f7 f1f4 d10c9 h3i4 f7i4 g2h2 i10h10 d4d5 i4c10 h2g2 e7d5 d2d5 e9e7 d5i5 c10f7 a4a5 f7g8 e4d3 g8h7 d3h7 e7h7 i5i8 h10h8 g4f6 h8i8 f6h7 i8h8 f4f7 d7e9 f7g7 e9g8 g3g5 c9b8 g2h3 b8a7 h3h4 a7a6 h4h5 a6a5 g5g6 a5b4 g7g8 h8g8 h7f6 g8g9 g6g7 b7b6 h5g6 b6b5 h6h7 b4a4 h7h8 g9h9 g7g8 h9h8 g8g9q h8h4 g9a9 h4c4 a9a8 a4b4 a8b7 c4i4 f6d5 b4c4 d5c7 c4c3 c7b5 c3b4 g6h5 i4i10 b5d6 b4c3 b7c6 c3b2 c6b5 b2a1 b5a5 a1b1 a5b4 b1a1 b4a3 a1b1 a3b3 b1c1 b3i10 c1c2 i10c4 c2d2 c4b3 d2e2 d6e4 e2f1 b3b2 f1e1 b2i2 e1d1 i2d2
f3f5 d8d6 c3c4 i8i6 i3i5 e8e6 f5e6 e9e6 d3d5 e6e9 a3a5 b8b7 f2d3 h8h7 b1c3 d9b8 b3b5 g9h8 h2g4 c10h5 h1i3 h5g6 d3b4 h9i7 c4c5 d6c5 b4c5 c9e7 c5b3 c8c6 d5c6 f9g7 c6b7 a8b7 d2c4 d10d1 b2d1 b9c7 g4h6 g6c2 a2c2 g10d7 c1b2 i9f9 b5b6 c7e6 e3e4 a9c9 c4d3 b10c8 h3h4 i7g6 g1e3 a10d10 c2d2 c8d6 g2i4 g7h9 i3g4 e6g7 i4g6 h7g6 g4e5 d7e8 e5f3 f8f6 d3f2 f6f5 e4e5 d6e4 c3e4 f5e4 f3g5 e8d7 g5e4 d7e6 b3a4 e6d7 a4b3 d7e6 b3a4 d10d2 e3d2 h10i8 h6i4 h8i7 d1e3 g7f5 i4g5 e6d7 a4b3 f5h4 g3h4 e7g5 h4g5 d7i2 i1i2 e9e6 e2b5 b8a6 i2g2 a6b5 f1b5 f9f2 g2f2 f10g10 b3d4 g10b5 d4e6 b5b2 e6d8 e10d10 a1d1 i7g5 e4g5 i10f10 d8b9 c9b9 d2b4 b9d9 f2b2 h9g7 a5a6 g7h5 b2d2 d9d2 d1d2 d10c10 g5e6 b7a6 b6b7 h5g3 b4c5 g3f3 e1d1 f3d2 d1d2 f10d10 c5d6 i8g9 e6c7 d10d8 b7b8 d8b8 d6g9 c10d10 c7a6 b8b2 d2c3 b2b1 g9f8 d10e10 a6c5 e10f9 f8h6 g6g5 c5e4 g5g4 e3g4 b1b7 h6e3 b7c7 c3d4 c7d7 d4c5 f9f8 e5e6 d7a7 c5d5 a7a10 e3c5 f8f9 e6e7 a10a9 d5e6 g8g6 g4f6 f9g10 e7e8 a9e9 e6f7 e9f9 e8f9c g10f9 c5f8 f9e10 f7e8 e10f10 e4g5 f10g10 g5i6 g10h9 i6g7 h9i10 i5i6 i10i9 i6i7 g6g5 f6g8 i9i10 i7i8 g5g4 i8i9c
f3f5 d8d6 i3i5 i8i6 g3g4 h8h7 h1g3 b8b7 b3b4 e8e6 c3c5 d6d5 d3d4 g9h8 d2d3 c8c6 e3e4 b9c7 c2b3 e6f5 g4f5 d5e4 e2e4 e9e4 g2e4 d9b8 b2c4 b10c8 b1c3 g8g6 a2e2 f9e9 h2g4 h9i7 g1h2 h10g8 c1f4 c9d8 f5g6 i7g6 e4g6 c10g6 e2e9 a9e9 g3e4 f8f6 g4e3 g10h9 e1d2 g8e7 c4b6 a8a7 b6c8 e7c8 b3h9 i9h9 d2c2 b8d7 h3h4 b7b6 d1d2 c7e6 a1d1 e6f4 h2f4 d8c7 e3g2 a7a6 f4h6 c7i1 i2i1 h8i7 g2f4 i7h6 i5h6 a6a5 f4g6 h7g6 f2h3 a5b4 a3b4 e9e8 h3i5 f6f5 e4g5 c8e7 f1g2 b6c5 d4c5 h9d9 d2f2 d10b8 d1a1 a10d10 i1e1 d7f6 d3c4 f10e9 g2f1 e9h9 a1a4 f5f4 g5e4 f6f5 c4d6 e8e9 i5h3 i10f10 h3g5 f10f9 f1a6 e10f10 a6a7 b8a7 a4a7 f5g5 e4g5 e7f5 a7h7 f5e3 f2e3 e9e3 h7h9 d9d6 h9h10 f10g9 c5d6 d10h10 e1e3 f4e3 c2d3 h10h6 d3e3 h6h4 g5i6 f9e9 e3d3 h4g4 c3d1 e9e5 d6d7 g9g8 d3c2 g4d4 d1f2 e5d5 f2h3 d4b4 i6g5 b4c4 c2b3 c4g4 d7d8 d5d8 b3c3 g4g3 c3c4 d8d5 g5e4 g3h3 e4f6 g8f7 f6d5 c6d5 c4d5 g6g5 d5e4 f7e6 e4d4 g5g4 d4e4 h3a3 e4d4 g4g3 d4c5 g3g2h c5b5 g2c2 b5b6 a3b3 b6a5 c2a1
f3f5 i8i6 i3i5 d8d6 d3d5 c8c6 c3c4 b10c8 h3h4 g8g6 e3e4 h8h7 f2h3 g9h8 g3g5 f8f6 b3b4 f10g9 d2b3 c6d5 c4d5 b8b6 h2g4 h9f8 g1d4 h10g8 h1g3 a8a6 b1c3 f8d7 c1e3 b9c7 a3a4 d9f8 b2d3 c9d8 d3f4 d7e5 f4e6 f8d7 e1f2 e9b9 f2g1 d8e9 a4a5 b6a5 b4a5 a10b10 b3a3 b9c9 g1h2 a9b9 a1c1 b9b8 c2a4 d7e7 g4e5 d6e5 d4c5 c8d6 f1f2 g9f10 c5a7 c10d9 e3c5 d9c8 a7b8 b10b8 c5a7 c7d9 a3b3 c9a9 i1f1 f9g9 f2c5 d6b7 a7b8 d9b8 c5a3 b7a5 b3d2 a5b7 a2b2 b7d6 i2i1 g9f7 c1b1 b8d9 a4c6 e9c7 d1a4 g8i7 c6b7 c8b7 b2b7 e7c8 e2a6 e8e7 a6a9 c7a9 a4a8 d9c7 e6c7 a9c7 a8a10 f10d8 b7a7 i9a9 a7a9 c8a9 a10d10 e10d10 c3a4 g6f5 g3f5 d6f5 f1f5 g10d7 i1c1 d7f5 e4f5 f6g5 h4g5 c7d6 a4c5 i10i9 a3a7 d8c9 a7d7 c9d9 d7g10 d9e10 g10d7 e10d9 d7c6 e5e4 h2h1 f7d8 c6a4 h8e5 c5e6 d8e9 d2e4 i7h5 a4a7 d6b8 b1b8 e5b8 a7e7 i9f9 e7h7 e9e8 h7i6 h5g7 i6g4 f9h9 f5f6 g7e6 d5e6 d10e9 e4f5 a9c8 f5h6 h9h6 i5h6 c8d6 c1d1 e9f10 h6h7 e8f8 g2e4 d9c9 d1d6 b8d6 h7h8 f8h9 g4h5 d6f8 e6e7 c9c4 e4b7 f8e7 h5e8 h9f8 e8a8 c4e6 h1g2 e7d6 a8a5 f10f9 a5b5 f9e9 b7d5 e6c8 h8h9h f8h9 d5h9 c8c2 g2h1 c2c7 b5b9 e9f10 h9b3 f10e10 b3d5 c7c1 h1i2 c1c2 h3g2 e10f10 b9a10 f10g9 a10e6 d6a3 i2h3 g9f10 g2h4 c2d3 h3g4 d3d1 h4f3 a3f8 e6a10 f10e9 a10b9 e9d8 b9b8 d8d9 d5b7 d9c10 b7c6 c10d9 b8f8 d1i1 f8e8 d9d10 f3e5 i1i2 g4h5 i2h3 h5g6 h3i4 g6h7 i4h3 h7g8 h3b3 c6d5 b3b1 e8g10 d10c9 e5d7 c9b9 g10g9 b9a10 d7c9 a10a9 g9a3
f3f5 i8i6 c3c4 d8d6 i3i5 e8e6 f5e6 e9e6 d3d5 e6e9 b1c3 b8b7 a3a5 h8h7 h2f3 g9h8 g3g4 c8c6 b3b5 b10c8 h1g3 b9c7 b2a4 a8a7 h3h4 h9i7 g1h2 c6b5 c4b5 d9b8 d2c4 i7g6 g3f5 c9f6 f2d3 c7e8 c1b2 a9c9 c3e4 f6b2 a4b2 f8f6 c4b4 g6e5 f3e5 d6e5 g4g5 h8g9 b4a4 g8g7 b2c4 a7a6 b5b6 h10g8 a4b3 c8d6 c4e5 f6e5 d3e5 d6f5 e5f5 b8a8 i2i3 g9f8 i3f3 c10b9 f5e5 f9d8 c2d3 a10c10 g5g6 h7g6 e4g5 e8f6 g5f7 d8f7 e5f7 f8b4 b3b4 f10f7 e3e5 b9g4 e5f6 i10h10 i1i4 g6g5 e1f2 g10e8 f2g1 i9h9 d3f5 g4f3 e2f3 g8f6 d5d6 e10f10 d6d7 h9h4 i4h4 h10h4 d7e8 h4b4 a2d2 d10e10 f3i6 e10i6 d1i6 e9i9 f1e2 i9i6 e2i6 c9c1 d2d1 c1a1 d1a1 f7e8 i6i10 f10e9 i10i9 e8f9 i9g7 f9f8 g7i9 f8f9 a1e1 b4e4 e1e4 f6e4 i9e5 e9f10 e5h8 f10e9 g2e4 c10c1 g1g2 a8c9 i5i6 c9e8 i6i7 f9f6 h8h9 e9d8 i7i8 c1c9 f5g6 c9f9 g6e8 f6f1 g2g3 d8e8 h9e6 e8f8 e4h7 f1f4 g3g2 f4i4 g2g1 i4d4 g1h1 f9d9 h7i6 d4h4 e6f6 f8e8 f6g6 e8d8 i6h5 h4e1 h1i2 e1i5 h5i4 i5i4 g6i4 d9f9 i4g6 f9d9 g6f7 d8c9 f7c7 c9d10 c7b8 d10e10 b8c8 e10d10 h2b8 d10e9 i8i9h e9f10 i9d9 f10e10 c8c10
Fairy stockfish blundered here with rook HD:
draw instead of loss with better continuation (black move):
f3f5 i8i6 c3c4 d8d6 i3i5 e8e6 f5e6 e9e6 d3d5 e6e9 b1c3 b8b7 a3a5 h8h7 h2f3 g9h8 g3g4 c8c6 b3b5 b10c8 h1g3 b9c7 b2a4 a8a7 h3h4 h9i7 g1h2 c6b5 c4b5 d9b8 d2c4 i7g6 g3f5 c9f6 f2d3 c7e8 c1b2 a9c9 c3e4 f6b2 a4b2 f8f6 c4b4 g6e5 f3e5 d6e5 g4g5 h8g9 b4a4 g8g7 b2c4 a7a6 b5b6 h10g8 a4b3 c8d6 c4e5 f6e5 d3e5 d6f5 e5f5 b8a8 i2i3 g9f8 i3f3 c10b9 f5e5 f9d8 c2d3 a10c10 g5g6 h7g6 e4g5 e8f6 g5f7 d8f7 e5f7 f8b4 b3b4 f10f7 e3e5 b9g4 e5f6 i10h10 i1i4 g6g5 e1f2 g10e8 f2g1 i9h9 d3f5 g4f3 e2f3 g8f6 d5d6 e10f10 d6d7 e8d7 f5d7 f7d7 d1d7 d10d7 b4d5 g5h4 g2h3 d7b5 a2e2 e9e2 f1e2 b5e2 f3e2 f6d5 e2e8 c9c1 a1c1 c10c1 g1g2 a8c9 e8f7 h9f9 f7d5 c9e8 d5d4 c1c2 g2h1 f9d9 d4e4 c2c1 h1i2 e8f6 e4b4 h10h5 i4h4 c1c2 h4h5 f6h5 b4f8 f10e10 f8h10 e10e9 h10e7 e9f10 e7f8 d9f9 f8h10 f10e9 i2i1 c2c1 i1i2 f9f2 h10g9 e9e10 g9h10 e10e9 h10g9 e9d10 g9g10 d10c9 g10g9 c9d10 g9d6 d10e10 d6e7 e10f10 h3g2 f2g2 e7d8 f10g10 d8g8 g10h10 g8f8 h10i10 f8g8 i10h10 g8h8 h10i10 h8i8 i10h10 i8f8 h10i10 f8f7 i10i9 f7f9 i9h8 f9e8 h8h7 e8f9 h7g6 f9e8 g6f5 e8e5 f5g6 e5e4 g6f7 e4d5 f7f8 d5d8 f8g9 d8e9 g9h8 e9f10 h8h7 f10e10 h7g6 e10e4 g6f7 e4d5 f7f8 d5d8 f8g9 d8e7 g9g10 e7d7 g10h10 d7d6 h10i10 d6e6 i10h10 e6e7 h10i10 e7f7 i10i9 f7d9 i9i8 d9e8 i8h7 e8f9 h7g6 f9d9 g6f5 d9d3 f5f6 d3d6 f6g5 d6e7 h5f6 e7e3 g5g6 e3c1 f6g4 c1c10 g6g5 c10c5 g5h4 c5e7 h4i5 e7g7 i5h5 g7f7 h5h4 f7h7 h4i4 h7i6 i4h4 i6h7 h4g5 h7g8 g5h6 g8f8 h6h5 f8h8 h5g6 h8g8 g6h6 g8f8 h6g6 f8d6 g6g7 d6c7 g7f8 c7d6 f8f9 d6d7 f9f8 d7d6 f8g7 d6g9 g7f6 g9f8 f6g6 f8i8 g6g7 i8i7 g7g8 i7i8 g8f9 i8h9 f9f10 h9h8 f10g10 h8e8 g10g9 e8d9 g9g10 d9d7 g10g9 d7d6 g9g10 d6d7 g10g9 d7g7 g9h9 g7h7 h9g9 h7i7 g9f8 i7h8 f8f7 h8h7 f7f6 h7i6 f6g7 i6i7 g7g8 i7c7 g4h2 c7h2 g2h2 i2h2 g8f7 h2g3 f7e6 g3f4 e6d5 f4f5 d5c4 f5e6 c4b5 e6d7 b5a5 d7c7 a5b4 c7b7 a6a5 b7c7 a5a4 b6b7 a4a3 b7b8 a3a2q b8b9q b4c3 b9b6 a2c4 b6c6 c3d4 c6c4 d4c4
I ended up still counting this game as a loss for black.
f3f5 i8i6 i3i5 d8d6 d3d5 g8g6 e3e4 f8f7 c3c4 e8e6 g3g4 h10g8 h1g3 h8h7 b1c3 c8c6 d5c6 g9h8 h2f3 g6f5 e4f5 a8a6 g4g5 h9f8 f2g4 b9d8 c2e4 f7f6 h3h4 f6g5 f3g5 g8f6 g4h3 f9g8 f5e6 f6e4 g2e4 g10c6 i2f2 i9f9 c3d5 b10c8 g3f5 h8e5 f5h6 g8g7 i1i2 d8e6 g5f7 e9e8 f7e5 d6e5 h6f5 g7h5 b2d3 f8g6 d2c3 f10h8 c1h6 d9e9 c3b4 c6d7 d5b6 c8b6 f5d6 f9f2 i2f2 e8g8 e4b7 d7c8 d6c8 b6c8 g1h2 h5h6 i5h6 c9h4 d3e5 a9d9 e2e3 c10a8 b7d5 a6a5 e5g6 h4f2 a2f2 g8g6 b4c3 a8d5 c4d5 e6c7 h2c7 b8c7 d1d4 d9d8 d4h8 d8h8 e1d1 c8b6 f2f5 h8e8 e3d4 i10f10 f5f10 e9f10 h3f4 g6h6 d1c2 a5a4 b3b4 a10a9 f4g4 h6d6 f1d3 a9f9 a1d1 f10g8 c3b5 d6d7 b5c6 d7g7 d1g1 g7d4 c6d4 g8h8 c2b2 d10d7 d4c5 d7g7 b2b1 f9e9 d3a6 e10f9 a6f1 g7f7 g4g5 f7f1 g1f1 f9g9 g5g4 e8g8 g4h3 e9e5 d5d6 e5c5 b4c5 b6d5 h3f2 h8f7 f2d3 f7e6 f1e1 e6d7 d6c7 d5c7 d3e4 g8g6 e1d1 d7c6 d1d6 c6b5 d6d3 g9h8 e4d4 g6g5 c5c6 i6i5 d4e4 g5g1 b1c2 b5c4 e4f2 g1i1 f2e3 i1i2 c2d1 c4e3 d3e3 i5i4 e3e4 i4i3 e4i4 i2i1 d1e2 i3i2q i4i2 i1i2 e2d3 i2i3 d3d4 i3a3 d4c5 a3f3 c5d6 f3f7 d6c5 a4a3 c5d4 a3a2h d4c4 f7f3 c4c5 a2c3 c5b4 c3e4 b4a5 e4c4
f3f5 d8d6 i3i5 i8i6 c3c4 e8e6 f5e6 e9e6 d3d5 e6e9 a3a5 h8h7 b1c3 b8b7 h2f3 g9h8 g3g5 f8f6 h3h4 f6g5 h4g5 b9d8 g2h3 d8f7 g5g6 h7g6 c2g6 h9f8 g6f7 g8f7 b2d3 c10b9 e3e5 d6e5 f3e5 d9d8 h1g3 c9b8 f2f3 i9g9 i2g2 h10g8 h3i4 b9c10 c1a3 f7f6 e5g4 f6f5 g4e5 c10i4 g3i4 e9e8 g1b6 a9e9 b6d8 d10d8 d5d6 c8c7 d6d7 f8d7 e5d7 e8d7 d3e5 d7e8 e5g6 h8f6 c3d5 b10c8 d5f6 g8f6 a3g9 f9g9 i4h6 a10d10 d2e3 f6g4 h6g4 f5g4 g2g4 b8a7 d1d8 d10d8 e3f4 e8i8 g6e5 g10c6 e5c6 b7c6 f4e4 c8d6 a1d1 g9f7 i1i4 i10g10 g4f4 d6e4 d1d8 i8d8 f4e4 a7c5 i4f4 c5b4 a2d2 f7f6 f1h3 b4d2 e2d2 e9e4 f3e4 g10g1 e1e2 d8d2 e2d2 f10d8 e4d3 f6e8 f4e4 e10d10 e4e8 d8e8 h3a10 d10d9 a10a9 d9e10 a9c7 g1g2 d2c3 g2g5 c3b2 e10d9 c7a9 d9c10 a9c7 c10d9 d3b4 e8h8 b2a3 h8a1 b4a2 a1e5 c7d7 d9e9 d7b9 e9d10 b9d7 d10e9 d7b9 e9d10 b3b4 g5g2 b9d7 d10e9 a2b1 e5e1 d7b9 e9d10 b9d7 d10e9 d7c7 e9d9 c7d6 d9e9 d6h6 e9d9 h6d6 d9e9 d6h6 e9d9 h6c6 e1b1 c6g2 b1d3 a3a4 d3c4 g2g9 d9e8 g9g6 e8e7 g6g5 e7f7 g5f5 f7g7 f5g5 g7f7 g5f5 f7g7 f5d7 g7f8 d7d8 f8f9 d8d9 f9f10 d9d10 f10f9 d10d9 f9f10 d9d8 f10f9 d8d7 f9f8 d7d6 f8e8 d6b8 e8f7 b8a7 f7g6 a7e3 a8a6 a4a3 c4c2 e3h6 g6f7 h6e3 f7g6 e3h6 g6f7 h6f4 f7e8 f4d4 c2f5 d4e3 e8d9 e3g3 f5c2 g3e1 d9d8 e1g3 d8c8 g3f3 c8c7 f3f10 c7d7 f10f9 d7d8 f9f8 d8d7 f8f9 d7e7 f9e9 e7d7 e9d9 d7e7 d9e9 e7d7 e9d9 d7e7 d9b7 e7e8 b7e10 e8d8 e10e3 d8d7 e3d4 d7e8 d4b2 c2f5 b2e2 e8f8 a3a4 f5d7 a4b3 d7d5 b3a4 d5d7 a4a3 d7f5 e2d2 f8e8 d2e3 e8f9 e3g3 f5d5 g3f2 f9e9 f2g3 e9f9 g3b3 d5i5 b3f7 f9e9 f7c10 i5b5 c10c1 b5d3 a3a4 e9d8 c1g5 d8c8 g5c5 c8d9 c5g9 d9c8 g9f8 c8b7 f8e7 b7c8 e7e8 d3d8 e8c10 c8b8 a4b3 i6i5 c10c4 d8c8 c4d3 i5i4 d3g3 c8c7 g3g8 c7c8 g8g3 c8c7 g3g6 c7i7 g6d6 b8c9 d6a9 c9d8 a9b8 d8e9 b8c9 e9f8 c9c8 f8g7 c8g4 g7h6 g4h4 h6g6 h4g4 g6h6 g4h4 h6g6 h4e4 g6g7 e4e5 g7g6 e5e4 g6g7 e4b7 g7h6 b7c6 h6i5 c6d5 i5h4 d5h1 h4g3 h1g1 g3h4 g1f2 h4h5 f2e2 h5h6 e2h2 h6i5 h2f2 i5i6 f2f3 i6h7 f3d3 h7h8 d3d8 h8g7 d8e7 g7h8 e7h4 h8g8 h4g4 g8f8 g4c8 f8g7 c8c7 g7h8 c7b8 h8g7 b8c7 g7h8 c7e5 h8g8 e5b8 g8h7 b8b7 h7h8 b7a8 h8g7 a8g2 g7h6 g2d2 h6h7 d2d3 h7h8 d3d4 h8g9 d4d9 g9h8 d9d8 h8h9 d8h4 h9i8 h4e4 i8i9 e4e5 i9h9 e5h5 h9g8 h5g6 g8f8 g6d6 f8g8 d6d8 g8f9 d8c9 f9e8 c9c8 e8f9 c8c9 f9g8 c9d8 g8h9 d8h4 h9i9 h4g3 i4i3 g3e5 i9h9 e5d5 h9h8 d5a8 h8g7 a8g2 g7h6 g2h3 h6g6 h3d3 g6g7 d3d7 g7h6 d7h3 h6g6 h3e6 g6h7 e6e7 h7h6 e7e3 h6h7 e3d3 h7h8 d3c3 h8h9 c3c4 h9h8 c4h4 h8g8 h4g4 g8f8 g4c8 f8e9 c8b9 e9d8 b9b8 d8e9 b8c9 e9f10 c9b10 f10e9 b10c9 e9f10 c9d8 f10g10 d8d10 i7f10 d10d7 f10f9 d7g7 f9g9 g7d10 g10h9 d10h6 g9h8 h6e9 h8g9 e9h6 g9h8 h6e9 h9i8 e9i5 h8i7 i5f5 i7h7 f5i5 h7i7 i5f5 i8i9 f5b9 i9h8 b9h3 h8i9 h3c3 i9i8 c3d3 i8h9 d3d5 h9h8 d5a8 h8h7 a8b7 h7i6 b7f3 i6h7 f3b7 h7h6 b7h1 h6i5 h1e1 i5i6 e1e6 i7h6 e6i10 h6i7 i10e6 i6h5 e6e2 h5h6 e2a6 h6g5 a6b5 g5f4 b5f1 f4g4 f1g2 g4h4 g2f2 h4h5 f2e2 h5h4 e2e1 h4h5 e1e2 h5h6 e2e3 h6h7 e3h3 h7g6 h3e6 g6g7 e6d7 g7h6 d7h3 h6g6 h3e6 g6h7 e6d7 h7i6 d7d1 i6h7 d1h1 h7i6 h1d1 i6h7 d1c2 h7h8 c2c8 h8g7 c8d7 g7h6 d7d2 h6h7 d2c2 h7h8 c2c3 h8g8 c3g3 g8f8 g3b8 f8g7 b8g3 g7f6 g3f2 f6g6 f2c2 g6g7 c2g2 g7h6 g2d2 h6h7 d2c2
f3f5 d8d6 i3i5 i8i6 g3g4 e8e6 f5e6 e9e6 d3d5 e6e9 h2f3 h8h7 c3c4 g9h8 b1c3 b8b7 g1h2 f9e7 f3d4 c9b8 h1g3 g8g6 b3b4 c8c6 d2b3 b9d8 e3e4 h10g8 a3a5 f8f6 c4c5 b10c8 h3h4 d8f7 b2c4 g10d7 g3i4 d9d8 g2h3 h9g7 c1f4 i9f9 f1g2 f10g9 f2e3 a8a6 i1f1 c6d5 e4d5 f7e5 i2i1 e10f10 i4h6 f10g10 e1d2 g10h9 d2c1 c10e8 c1b2 a9c9 a1c1 a10c10 b2b1 g7i8 h6i8 h9i8 c2d3 i10e10 d4f3 i8h9 i1g1 e8f7 a2c2 e7f8 e2e1 e9d9 c2e2 f9e9 c1c2 c8a7 f3e5 d6e5 f4h6 g8h6 i5h6 a7b5 c3b5 d7b5 e3e4 d8e7 c4e3 b5d3 d1d3 f8g8 b3b2 d9e8 d3a3 e9d9 e2d2 d9d8 d2d1 e10e9 b2c4 e9d9 h2i3 g8h6 h4h5 g6g5 c2f2 b7b6 c4b6 b8a7 b6a7 c9c5 a7b6 c5d5 e3d5 f7d5 d1d5 d8d5 h5i6 d5d3 a3a2 g9g8 f2f3 h7i6 g1h1 d3d4 e4d4 d9d4 h3i2 e8g6 f3f5 d4g4 i2g4 d10d3 b1a1 h6g4 f5f2 g4i3 g2b7 d3d4 f2b2 g8a2 a1a2 c10c2 b7b9 h9i8 b6a4 e7d6 e1d1 g6g8 a2b1 c2b2 a4b2 d4d1 f1d1 i3h1 d1d6 g5g4 d6d8 g8d8 b9g4 i8i7 g4f3 h1h2 f3e3 i7h7 e3e4 h7g7 e4h4 d8d2 h4c4 h2f3 c4c7 g7h6 c7c8 d2e1 b1a2 h8g7 c8h3 f3h4 h3e6 e1b4 b2c4 b4a4 a2b1 a4d1 b1b2 d1e2 b2a3 e2f3 a3b2 i6i5 e6h9 h6g5 h9h7 f3g2 b2b3 h4g6 h7i6 g2g4 i6i10 i5i4 c4d5 g4f3 b3c4 i4i3 c4c5 g7f8 c5b6 i3i2q i10i2 f3d5 i2i3 g5h6 i3h2 h6g7 h2g1 d5b5 b6c7 g7f7 g1g6 f7g6 c7d8 e5e4 d8c7 e4e3 c7d8 e3e2q d8c7 e2e9 c7c8 b5b9
White wins: 5
Draws: 2
Black wins: 3
#47
Forcing early draw instead of doing 250 moves
Turns out we don't actually need to have a special rule for when checkmate is no longer feasible, you can force your opponent to repeat moves way before that if they only have the king left.
[9x10endgame57:chess]
doubleStepRank = 3
maxRank = 10
maxFile = 9
promotionRank = 9
centaur = c
archbishop = a
chancellor = h
promotionPieceTypes = acqh
nMoveRule = 250
nFoldValueAbsolute = true
stalemateValue = win
nFoldValue = loss
startFen = nk7/9/9/9/9/1K7/9/9/9/9 w - - 0 1
10 million nodes/move:
b5c5 b10c9 c5d4 c9d8 d4e4 a10c9 e4d3 d8e7 d3e3 c9e8 e3d4 e7e6 d4c4 e6e5 c4c3 e8d6 c3d3 d6f5 d3c4 e5e4 c4c5 e4e5 c5c4 e5e4 c4c3 e4e3 c3b2 e3d3 b2b3 f5d6 b3b4 d3d4 b4b3 d4d3 b3b4 d3d4 b4a3 d4c3 a3a4 c3c4 a4a5 c4c5 a5a4 c5c4 a4a5 c4c5 a5a6 c5c6 a6a7 c6c7 a7a6 c7c6 a6a7 c6c7 a7a8 c7c8 a8a9 c8c9 a9a8 c9c8 a8a9 c8c9 a9a10 d6e8 a10a9 e8d6
This is especially relevant when a player is low on time, doing 250 premoves is also an option though.
This however doesn't work if both players has 1 bishop remaining that occupy different colors which is why the following rule was added:
Legal capture with the king is forced if there has been 1 moves or more since the last capture, both players has more than a king left and neither player can checkmate a lone king.
Of course even without that rule and and the 250-move rule the game would eventually end in a draw by repetition, the problem is that it would take a lot of moves if one player was trying to delay it as long as possible.
Two bishops can force repetition against a knight but it can take over 50 moves.
[9x10endgame56:chess]
doubleStepRank = 3
maxRank = 10
maxFile = 9
promotionRank = 9
centaur = c
archbishop = a
chancellor = h
nMoveRule = 250
nFoldValue = loss
startFen = bkb6/9/9/9/9/1KN6/9/9/9/9 w - - 0 1
100 million nodes per move:
b5c6 c10e8 c6c7 b10c9 c5a6 e8g10 c7d6 c9d8 a6c5 d8e8 d6e5 e8f7 c5d3 g10f9 d3c5 f7g6 c5d3 g6g5 d3c5 g5g6 c5e4 f9g8 e5f4 a10d7 e4c5 d7a10 c5e4 a10c8 f4e5 c8b9 e4f6 g8f7 f6e4 f7g8 e4c3 g6g5 c3e2 b9a8 e2d4 a8b9 d4f3 g5g4 f3d2 g4g5 d2f3 g5g4 f3h2 g4g5 h2f1 b9a8 f1g3 a8b9 g3e2 b9g4 e2c3 g4b9 c3b5 b9g4 b5c7 g8f7 e5e4 g5f6 c7b5 f7g6 e4d4 g6h7 b5c3 f6f5 c3e4 g4f3 e4d2 f5f4 d2b3 h7f5 b3c5 f3c6 c5b3 f5e6 b3c5 e6f5 c5b3 f5e6 b3d2 e6a2 d2f1 a2b3 f1e3 c6f3 d4d3 b3a4 d3d4 a4b3 e3f1 f3c6 d4c3 c6b5 f1d2 b3a2 c3d4 b5c6 d4c5 c6e8 d2f1 e8i4 f1d2 f4e3 d2b1 a2b1 c5d5 i4f7 d5d6 b1f5 d6c6 e3d4 c6d6 f5e6 d6c6 d4e5 c6b6 e5d6 b6b5 d6d5 b5b6 e6d7 b6c7 f7e8 c7b6 d5d6 b6b7 d7b9 b7b8 b9d7 b8c9 e8h5 c9d10 h5i4 d10e10 d6e7 e10e9 d7c6 e9f10 e7f8 f10e10 f8e8 e10f10 e8f8 f10e10 f8e8 e10d10 e8d8 d10e10 d8e8
#48
Why a 250-move rule without exceptions is fine for human games
Of course you should still be able to claim draw if you only have a king left and your opponent lacks material to checkmate you but that will very rarely come into play with real matches. That however is not actually an exception to the 250-move rule since in that scenario the player who can claim the draw cannot lose in the first place.
From testing it seems like only around 1% of games will actually end in a draw and even less than 1% of games with at least one human would even be affected by a 50-move rule, games very much tend to not last way into an endgame like that.
And even in rare cases where say both player has a bishop left and they are not bound to the same color most players would probably agree to a draw or repeat moves quickly in order to end it (rather than playing on hoping to get a lucky checkmate or eventually win by getting stalemated).
#49
10 billion nodes / move test
Surely now we will stop seeing black wins, right?
d3d5 f8f7 a3a5 e8e6 c3c4 b8b7 i3i5 c8c6 f3f5 e6f5 d5c6 d9b8 c6b7 g9b4 b1c3 a8b7 c2f5 a9a5 a2a5 b4a5 b3b4 a5b4 g2b7 b10d9 a1a10 b8a10 g3g4 b4f8 h1g3 h9g7 d1b3 f9e8 f5c2 h10f9 b2d3 a10b8 i5i6 b9c7 c1b2 d8d6 h3h5 c10b9 b7g2 i8i7 h2f3 g10i8 g1i3 g7e6 b3a2 c9i3 i2i3 d9e7 f2h3 e7c6 e1f2 b9c8 c3e4 g8g7 f2g1 c8a6 e2f2 f9e7 f3d4 e6d4 b2d4 d6d5 c4d5 c6b4 a2b2 b4c2 b2c2 e7d5 f1b1 c7b5 d4b2 e9a9 g1h2 i9c9 c2b3 i10i9 b1a1 i9d9 i1c1 d5c7 d2e1 a9b10 c1d1 a6b7 d1d2 b8a6 b3d1 c9a9 a1c1 c7e6 e1e2 a6a5 d1h1 b7a6 b2e5 b5c7 e5d4 c7b5 d4e5 b5c7 e5d4 e6d4 e3d4 c7e6 e2e3 a5b3 c1b1 d9d4 e3d4 e6d4 d3c1 d4f3 g2f3 b3d2 b1b10 d2f3 h1f3 d10b10 i3i1 a6b7 c1d3 a9a3 f3e2 e10f9 d3c5 b7c6 i1c1 f10c7 e2d2 e8e7 h2i2 e7d5 e4g5 f8c5 c1c5 d5c5 d2d9 f9g8 g5f7 a3a9 f7e9 g8h9 f2f7 c7f7 d9f7 h9i9 e9g8 i9h9 g8e9 h9i9 e9g8 i9i10 g8i7 i10i9 i7g8 i9i10 g8f10 i8h9 f10h9 a9h9 h3f4 c5d6 f7a2 c6e8 i2h3 d6f7 a2f2 h9a9 f4g6 f7g6 h5g6 b10g5 f2f5 g5h6 f5h5 h6d2 h5e5 a9a2 g3h5 a2a3 h3h4 d2f2 h4g5 a3h3 i6i7 f2d2 h5f4 d2d8 g5f5 e8d7 f5e4 d7c6 f4d5 c6d5 e5d5 d8d5 e4d5 h8i7 g4g5 i7i6 d5e6 i6i5 e6f7 i5i4 f7g7 i4i3 g7f7 i3i2h g6g7 h3f3 f7e6 i2e2 e6d6 f3d3 d6c5 e2c2 c5b6 d3b3 b6a5 c2a1
d3d5 d8d6 c3c4 c8c6 d5c6 b8b7 f3f4 d9b8 c6b7 a8b7 b3b5 b7b6 e3e5 e8e6 a3a5 b6a5 e5d6 d10d6 d2b3 d6d1 f2d1 f8f6 h2f3 c10f7 i3i5 i8i6 b1c3 b10c8 c4c5 h8h7 h1f2 h9g7 b2c4 f9h8 f3d4 c9e7 f2d3 g7f5 g1f2 f5d4 f2d4 h10f9 a2a5 a9a5 a1a5 a10a5 b3a5 e9a5 c4a5 f10a5 c1e3 f9g7 d3b2 b9c7 e1f2 g9f8 c5c6 e10f10 f2g1 i9d9 g1h2 a5a10 b2c4 g7f5 c2f5 e6f5 e2f2 h8g6 d1b2 f10g9 d4c5 g9h9 i2i4 c7b5 c3b5 e7c5 e3c5 g10c6 b5c3 f8c5 f2c5 b8d7 c5g1 c6g2 g1g2 d7c5 c4d2 g6g7 i4h4 c5d4 b2d1 i10b10 c3e2 d4d3 e2c1 d3b2 f1e2 f7h5 h4h5 g7h5 e2e8 d9d6 g2e2 h9h8 d2c4 b2d1 i1d1 d6d1 e2d1 a10a7 d1f3 a7c5 e8e6 b10b1 c1e2 c5f8 e2g1 b1a1 c4e3 c8d6 g1i2 d6e4 f3h5 i6h5 i5i6 f8f7 e6b6 a1a2 e3g2 e4d2 i2h4 d2f1 h2i1 f1g3 b6b4 f7f10 b4c3 g3e4 c3c8 e4d6 i6i7 h8i7 c8g8 a2a9 g2i3 i7h6 g8e6 a9d9 e6e7 d9d10 i1h2 d10d8 e7e2 f10f7 e2e9 f7f8 e9e6 d8d9 h2h1 d9d8 h1h2 d8d10 e6b9 f8e7 b9h9 e7e8 h9c9 e8f8 c9h9 f8g7 i3g2 h6i7 g2i3 i7h6 i3g2 h6i7 g2i3 g7f7 h9g9 i7h6 g9e9 f7g7 e9e2 d10g10 h2i2 g10b10 i2h2 b10g10 h2i2 g10b10 i2h2 b10b3 h2i2 b3b7 i2h2 b7b1 e2h5 h6i7 i3g2 b1b3 h2i3 b3b10 h5d9 b10d10 d9h9 d10e10 h9a9 d6f7 a9f9 e10e9 f9d7 i7h8 d7c8 h8i7 c8d7 e9g9 i3h2 g9g10 d7f5 f7h6 f5e6 g7g3 h2i2 h6g8 e6d5 i7h8 d5i5 g3g7 i5h5 h8i8 h5i4 i8h9 i4d9 h9i8 i2h2 g10d10 d9g9 d10d2 g9b4 g7d10 b4e4 d10b8 e4e3 d2b2 e3f3 i8h8 f3g4 b8b7 h4f5 b2d2 f5e3 b7e4 h2g1 g8e7 g4a10 e7g8 a10g4 e4b7 g4f5 b7a7 f5e4 a7a3 g1h1 d2e2 e4f3 e2a2 h1h2 a2a1 f3c6 a3b2 c6f3 b2c1 f3e2 c1a3 e2c4 a1a2 c4d5 a3b2 e3d1 b2c2 d5f3 g8e7 d1e3 a2a3 f3g3 c2e2 h2g1 e7g8 g1h1 a3c3 h1h2 h7h6 h2i3 c3d3 i3h2 g8e7 f4f5 h8h7 h2i1 e7g8 g3f4 e2b2 i1h1 b2e5 f4f3 e5b2 h1h2 d3b3 h2i1 b2e5 i1h1 h7h8 f3f2 b3c3 f2d2 c3b3 d2f2 b3b9 f2f4 b9b2 g2h4 e5f4 h4g6 h8h7 g6f4 h7i6 e3d5 i6i5 f4g2 i5h5 h1h2 h5g5 d5e3 g8e7 h2i3 b2f2 g2h4 h6h5 e3d1 f2f4 h4i6 g5h6 i6h8 h6g7 h8i6 g7h6 i6h8 h5h4 i3h2 h6g7 h8i6 g7h7 i6h4 f4h4 h2i3 h4d4 d1c3 h7h6 c3b5 e7f5 b5c7 d4e4 c7d5 h6g5 i3h2 e4e2 h2g1 e2d2 d5c7 g5f4 g1f1 f5h4 c7b5 f4f3 b5c3 d2d3 f1g1 d3c3 g1h2 f3f4 h2g1 f4g3 g1f1 c3e3 f1g1 e3e1
f3f5 d8d6 c3c4 i8i6 i3i5 g8g6 f5g6 e8e6 g3g4 d9e7 h3h5 i6h5 g4h5 f8f7 f2h3 f7g6 h5h6 e6e5 h2g4 c8c6 b3b4 b10c8 c4c5 h9f8 c5d6 c8d6 g1i3 e7d7 c2b3 h10g8 b2c4 d6c4 d3c4 c9i3 i2i3 d7e7 d2e4 d10d1 e2d1 b9c7 a2d2 c10b9 c1b2 h8h7 a1a2 g9h8 b2e5 e7f5 e5h8 f10h8 h1f2 f9e7 e4f3 g8f6 g4f6 f5f6 h3h4 b9e6 b1c3 a10d10 d2d10 e9d10 d1a1 f6h5 f1h1 b8b6 c3e2 h8a1 a2a1 c6c5 e2f4 h5h4 h1h4 a9e9 a1d1 d10a7 f3d2 e6f5 d2c3 f8d7 e3e4 e7f6 e1d2 b6b5 d2c1 b5c4 b3c4 g6g5 h4h1 c5b4 c3b4 f5e6 f4e6 c7e6 g2h3 e6f4 h1e1 e9b9 f2g4 f6e7 c4i10 i9i10 h3f1 i10i8 i1i2 d7c5 i5i6 b9b4 e1b4 i8b8 b4c3 b8c8 f1c4 c5a4 c3b4 c8b8 b4d2 b8c8 d2b4 c8b8 b4e1 a4b6 c4f1 h7i6 e1i5 b6d7 i5i6 e7f9 i2b2 a7c7 c1b1 e10f10 i6i7 f9h8 i7e7 h8g6 e7h10 b8b2 b1b2 c7b8 i3b3 b8h8 h10h8 g6h8 f1c4 h8g6 b3b9 g6f8 d1i1 f8h7 c4b5 h7h8 i1d1 d7f8 b5g10 h8g10 d1d8 a8a6 d8a8 g10e9 g4f6 g5g4 f6g4 f4e6 a8a10 f8e10 b9e9 f10e9 h6h7 e10f8 a10a6 e6g7 a6a9 e9e8 a9a8 e8f9 h7h8 f9g8 a3a5 g7h9 a8c8 g8f7 a5a6 f8d7 c8c6 d7b8 c6c9 h9f8 a6a7 b8d7 c9c7 f7g8 a7a8 g8h8 a8a9h h8g8 g4h6 g8h7 a9g9 h7h6 c7c6 d7f6 c6f6 f8g6 g9g6 h6h7 f6b6 h7i8 g6h4 i8i9 b6i6
d3d5 d8d6 i3i5 c8c6 c3c4 c6d5 c4d5 f8f7 b1c3 e8e6 e3e4 g8g6 d2c4 b9c7 b3b5 h9g7 g3g5 i8i7 a3a5 a8a7 h1g3 f9g8 f3f5 e6f5 e4f5 f7f6 h2f3 f6g5 f5g6 g9e7 g3i4 d9f8 i4g5 c10g6 i5i6 g10i8 c2g6 i8g6 b2d3 e9d9 h3h5 g7h5 g5h7 f8g7 h7i9 i10i9 i2i4 i9e9 d3f4 e7f6 f4g6 e9e2 d1e2 c7e8 g6f4 b10c8 f4h5 g7h5 i4e4 e10f9 g2i4 h5i4 i1i4 c8e7 f2h3 f9g10 g1d4 h10i8 i4g4 f6g7 c1g5 f10g9 e4e6 a10c10 e2e4 i8h10 f1d3 c9b10 c4b4 h10f9 h3f4 d9c8 a2h2 g10h10 e1d2 d10g10 f4g6 e7g6 e6e8 g6e5 e8c8 c10c8 d4e5 d6e5 a1f1 g8f7 d2d1 b10g5 f3g5 f7d6 e4g2 a9c9 g5e4 d6e7 h2h3 b8b6 a5a6 g9h9 g4g6 h10i9 h3f3 e7g8 e4f6 g8e9 f6h7 i9h10 h7f8 g7f8 g6g10 e9g10 d5d6 h10i9 g2g6 g10g9 c3e4 c8d8 b4c6 c9c6 b5c6 f9e7 f3f8 e7g6 f8d8 g6f4 f1f4 e5f4 d8d9 h9g8 d6d7 f4f3 d3f3 b6b5 d9g9 g8g9 d7d8 b5b4 f3f8 g9g4 d1d2 g4g2 d2d3 g2h3 d3d4 h3h5 f8f9 i9i8 f9h7 h5h7 i6h7 i8h7 d8d9h h7g7 d9e7 g7f8 e7d7 f8g9 e4f6 h8h7 d7d9 g9h8 d9f9 h8i8 f9h10 i8i9 f6g8
f3f5 d8d6 i3i5 f8f7 g3g4 i8i6 d3d4 h8h7 h1g3 e8e6 f2h1 g9e7 e3e4 f9h8 b3b4 c8c7 c3c5 g8g6 b1c3 h9g7 a3a5 h10g8 g1e3 b10c8 b2c4 b9a7 f1f2 a7b5 c1b2 g6f5 g4f5 a8a6 i2i4 b8b6 a5b6 c7b6 i4g4 d9b8 c2d3 d6c5 d4c5 f7f6 f5e6 b6c5 b4c5 c10g6 c3d5 e9f8 d5e7 c9e7 g3f5 g7e6 f5e7 c8e7 e3f4 e6f4 g4f4 g6h5 h2g4 e7g6 f4f3 i9d9 h1g3 i10i9 i1f1 h8f7 e2e3 i9f9 d2e2 a10c10 e4e5 h5g4 g3g4 f9e9 c4d6 b5d6 c5d6 g10d7 g4g5 f7g5 e3g5 f6g5 f3f8 g6f8 f2f8 f10f8 f1f8 e9e5 f8g8 d10i5 e1d2 e5e2 d1e2 d9e9 e2f1 g5g4 f1f4 e9f9 b2f6 f9f6 f4f6 a9f9 f6e7 f9e9 e7f7 e9f9 g8g10 e10e9 f7e7 d7e8 g10c10 b8c10 a2a6 i5f2 d2c3 g4h3 e7c7 e9f8 c7e7 f8e9 e7c7 e9f8 g2h3 f9c9 a1f1 f2f1 d3f1 c10b8 a6c6 c9c7 c6c7 e8d9 c3d4 h7h6 h3e6 i6i5 d4e5 i5i4 e5f6 h6h5 c7h7 b8c6 h7h8 f8f9 h8h9 f9e10 d6d7 c6d6 f1e2 i4i3 h9i9 h5h4 i9i10 e10e9 e2g4 i3i2c i10i2 e9d8 i2i8 d8c7 g4f5 h4h3 f5h3 d9b7 h3f5 b7e10 i8i10 e10d9 i10i8 d9e10 i8h8 e10a6 h8a8 a6b7 a8g8 b7a6 g8a8 a6b7 a8h8 b7e10 h8e8 e10d9 e8g8 d6b7 f5g6 d9e10 g8e8 b7c9 f6e5 c9d9 e6i2 d9c9 g6h5 c9d9 i2g4 d9c9 h5i4 e10a6 e8f8 c9b7 i4f7 b7c6 e5f6 a6b7 f8e8 b7a6 e8a8 a6e10 a8e8 e10a6 f7i4 a6d9 e8i8 d9e10 i8e8 e10d9 e8i8 d9e10 i4g2 c6d6 g4e6 e10d9 i8i9 d9e10 i9i5 e10a6 i5i9 a6e10 i9i3 c7d8 i3i8 d8c7 g2f3 e10a6 i8i1 c7d8 i1i7 d8c7 i7i2 c7d8 i2i8 d8c7 i8h8 a6d9 f3a8 d9e10 h8h1 c7d8 h1h8 d8c7 e6i2 e10a6 a8g2 a6e10 h8i8 e10d9 g2i4 d9i4 i8i4 d6d5 f6g5 d5e7 i4c4 c7b6 c4c8 b6b5 c8a8 b5c5 a8e8 e7d9 g5f4 c5d6 f4e3 d9c7 i2e6 c7b6 e8g8 d6e7 g8e8 e7d6 e6h3 b6c4 e3f3 c4d5 f3f2 d5c7 e8c8 c7d5 f2e2 d5f6 e2d3 f6d5 d3e2 d5f4 e2d1 f4d5 d1c2 d5b4 c2b2 b4d5 b2c2 d5d4 c2c1 d4d5 c1d2 d5e4 d2c2 e4d5 c2d3 d5b4 d3e2 b4d5 e2d3 d5b4 d3e3 b4d5 e3d2 d5f6 d2c3 f6f7 c3c4 f7e5 c4b5 e5d5 c8c1 d5e7 b5b6 e7d8 c1c2 d6d5 c2c5 d5d6 c5c8 d8d9 c8c5 d9b8 c5c8 b8d9 c8c6 d6d5 h3g4 d9e9 c6c1 e9d8 c1d1 d5c4 d1d2 c4c3 d2i2 c3c4 i2d2 c4c3 d2d5 d8b9 d7d8 b9a8 b6c6 a8b8 c6d6 c3b4 g4h5 b8b7 d6e5 b7c6 e5e4 c6c7 d8d9q c7d9 h5d9 b4c4 d9a6 c4c3 a6f1 c3c2 d5b5 c2d2 b5c5 d2e1 e4e3 e1d1 c5c4 d1e1 c4c1
f3f5 h8h7 c3c5 g8g6 g3g4 i8i6 b1c3 f8f6 b3b4 h9g7 h1g3 g6f5 g4f5 d8d6 d3d4 d6c5 b4c5 b8b6 c5b6 f9h8 b2c4 h10g8 i3i5 a8a7 b6a7 d9d8 a7a8 b10a8 e3e4 e8e6 f5e6 d8e6 f2f3 g7h5 g3f5 c9b8 g1e3 e6f5 e4f5 h5g3 f3g3 b8g3 e3f2 g3f4 f2e3 f4e3 d2e3 c10f7 a2b2 g9f8 h2g4 b9c7 c2e4 a8c9 e3c2 e9d8 c1f4 i9e9 g2f3 g10c6 e2d3 c6b7 g4e3 b7a6 b2b6 c9b7 b6a6 a9a6 e4b7 c8b7 a1b1 b7b6 f3b7 e10f9 i2g2 c7d5 c3d5 f7d5 b7d5 d8d5 e1f2 d5f7 f2g1 i10g10 i1i4 f9g9 g1h1 g9h10 d4d5 f7h5 f1f3 e9g9 d5d6 g8e9 e3g4 f10f9 c2c3 e9f7 i4i2 f7g5 f3g3 d10d7 b1b6 g5h3 g3h3 a6b6 c4b6 d7f5 h3h5 f5h5 i2h2 h5i4 h2i2 i4h4 i2h2 h4i4 d3f3 a10a3 b6d5 f9c6 g4i3 i4i5 g2g9 g10g9 i3g2 f8d6 c3d4 c6a6 f4d6 a6d6 f3f4 d6d7 d5e3 h8g6 f4f1 g6g5 d4f3 g5h3 f3g4 d7g4 e3g4 h3g3 h1g1 g3f1 g1f1 i5f5 f1g1 f5g4 h2h7 h10i9 d1g4 g9g4 g1f2 a3a2 f2f3 g4g2 h7i7 i9h8 i7b7 f6f5 b7b6 a2f2 f3e3 f5f4 e3e4 f2f1 b6b3 g2e2 e4d4 f4f3 b3b8 h8g9 b8b9 g9f10 b9b10 e2e10 b10e10 f10e10 d4e3 f3f2h e3d4 f2f5 d4e4 f1f4 e4d3 f5g3 d3d2 f4f2 d2c1 g3f1
This time i opted to keep it as simple as possible by only using a single configuration file:
[9x10centaur:chess]
doubleStepRank = 3
maxRank = 10
maxFile = 9
promotionRank = 9
centaur = c
archbishop = a
chancellor = h
nMoveRule = 250
startFen = rnbqkqbnr/rnbcqcbnr/ppppppppp/9/9/9/9/PPPPPPPPP/RNBCQCBNR/RNBQKQBNR w - - 0 1
1 billion nodes/move:
f3f5 i8i6 e3e5 d8d7 d2e4 g8g7 c3c5 h10g8 g3g4 f8f6 d3d4 e8e6 h1g3 e6f5 g4f5 b8b6 c5b6 f6e5 d4e5 a8a7 b6a7 d7d6 e5d6 c9a7 c1e3 c8c7 b2c4 b10c8 d6c7 g8f6 e4e5 a7e3 f2e3 f9e7 e3f4 h9f8 i3i4 f8d7 e5d3 b9c7 b1c3 i9i8 h3h5 d9b8 h5i6 g10f9 g2f3 c10a8 c2b1 a9d9 a2d2 a8f3 h2f3 f9i6 d3d4 d7b6 g3h5 h8h7 a1a2 i8e8 g1i3 d9d4 d2d4 d10c9 f1h3 a10d10 d4d10 c9d10 i3f6 g7f6 a2d2 d10a10 e1f1 b6c4 b3c4 g9i7 h5i7 f10i7 f4h5 i7i8 h5f4 i8i7 f4h5 i7i8 h5f4 b8c6 e2e1 c8d6 i2e2 d6c4 d2d4 c4e5 b1e4 c6c5 d4a4 a10b9 e1f2 c5b3 a4b4 b3c3 b4b9 c7b9 d1c1 e9c7 e2c2 c7c4 f4e2 c3c2 c1c2 c4c2 e4c2 e5f3 e2f3 i6f3 f2f3 b9c7 c2a4 e8e9 f1g2 e7d5 g2h2 i8i7 f3g4 e9g9 i1e1 e10d10 g4h4 d5f4 h4h6 d10d9 e1d1 d9c10 d1d10 c10c9 h6f6 c9d10 f6b10 d10d9 b10b7 d9d10 b7b10 d10d9 b10b7 d9d10 b7b10
f3f5 i8i6 g3g4 e8e6 f5e6 e9e6 e3e5 e6e9 h1g3 f8f6 e5f6 d8d6 f2h1 e9e2 d1e2 f9e9 g4g5 g8g7 h2g4 g7f6 g5f6 h10g8 g2e4 h8h6 f6f7 g8e7 g4h6 c8c6 i2f2 h9f8 i3i5 b9d8 g3f5 b10c8 a3a5 i9i7 g1i3 g10h9 i3e7 c8e7 f5d6 d9c7 d6e8 c10e8 f7e8 d8e6 h1i2 e9e8 h3h4 g9h8 f1i4 e7d5 i1f1 c9f6 b2a4 a9e9 e1d1 i10g10 e2e1 a8a7 a5a6 d10d8 i2h3 a10d10 c1a3 h9f7 i4i1 f8g6 d3d4 d5f4 f2f4 g6f4 f1f4 e6f4 i1f4 f7e6 h3h2 e8g7 h2g3 e6d5 a4c5 d5e4 c2e4 g7g6 e4g6 e9e1 d2e1 f6d4 a2e2 d4e5 d1c2 g10g6 c5d3 c7e6 d3e5 h8e5 f4f10 e10f10 g3f3 e6f4 c2b2 d10e10 a3b4 f4e2 e1e2 e5c7 e2f2 i7d7 b1a3 d7d2 a3c2 d2f2 f3f2 c7b6 f2f3 g6f6 f3g3 c6c5 b4a3 d8d3 h6g8 f10f9 g8f6 d3g3 a1f1 g3g2 f1f5 e10e2 f6g4 f9g8 f5g5 g8h9 g4e3 g2e4 g5g3 e2i2 e3g2 b6c7 g3g5 c7f4 g5g4 e4e2 a3c5 e2g4 g2f4 g4f5 f4d5 i2c2 b2a3 f5d5 a3b4 h9i8 c5g1 b8b6 a6b7 a7a6 c3c4 a6a5 b4a3 d5d2 b3b4 d2b4
f3f5 d8d6 i3i5 i8i6 d3d5 c8c6 c3c4 c6d5 c4d5 f8f7 b1c3 g8g6 f5g6 f7g6 c2g6 b9c7 h3h4 h10g8 g3g5 h9f8 g6f5 c10b9 h1g3 h8h7 e3e4 e8e6 d5e6 f8g6 f2g4 g8e7 h2i4 g10h9 i4h6 g9h8 g2i4 f10g9 b2c4 b9e6 c4d6 e7f5 e4f5 g9d6 f5e6 h9e6 g3f5 d6g9 d2e4 c9e7 a2d2 b10c8 c1b2 i10f10 g1d4 h8d4 e4d4 d9d8 d4c2 c8d6 i2f2 d6f5 h6f5 a9d9 c3e4 i9h9 i1i3 a10a9 i3d3 d8c8 g4h6 e7f8 h6i8 g9g8 f5h6 g8g10 i4h3 d9d3 c2d3 a9d9 h3e6 e9e6 d3d4 e6e9 h6f7 e9e8 e4f6 e8e2 d1e2 f8e7 f6h7 d10c10 h7i9 g10i10 a1d1 f9e8 e2i6 e10d10 i6g6 d10c9 i9g8 f10f7 f2f7 d9d4 i8h9 e8f7 g6f7 d4e4 d2e2 e4e2 e1e2 c10f7 f1f7 i10h9 i5i6 e7c5 i6i7 h9g10 f7h7 g10c6 b2f6 c9c10 i7i8 c6e6 e2d2 e6i2 d2c1 c7e8 i8i9h i2i9 f6i9 c5a3 c1b1 c8c7 h7f7 c10b9 f7f9 b9c8 f9e10 c8b9 g8e9 a8a6 e10c10 b9a9 d1d9 c7d9 c10d9 a9a8 d9e8 a6a5 e8c6 b8b7 c6c10 a8a7 e9c8 a7a6 c10g6 b7b6 g6b6
f3f5 i8i6 g3g4 d8d6 i3i5 e8e6 f5e6 e9e6 b3b4 f9d8 c3c5 f8f6 d2c4 c8c6 a3a5 b8b7 b1c3 b10c8 e3e4 e6e8 f2f3 h8h7 d3d4 g8g6 h3h4 c9b8 b2d3 h9g7 c1f4 b9c7 h1g3 d9e7 d4d5 a9e9 g1d4 e8h8 f4e3 h10g8 h2i4 c10f7 d3f4 a8a6 i4h6 c7b5 e1f2 g10d7 g3i4 f6f5 e4f5 d6c5 b4c5 g6f5 c2f5 e7f5 h6f5 d7f5 g4f5 b5d4 e3d4 e9e2 a2e2 g9e7 i4g5 b8f4 f3f4 i9e9 g5f7 e7h4 f2g1 d8f7 g2i4 f7f8 e2e9 c8e9 c3e4 c6d5 c4d5 g8e7 d5d6 e9c8 f5f6 c8d6 e4d6 a10a9 f6g7 f8g7 d1b3 h4f6 b3b7 e10f9 d4f6 g7f6 i2g2 a9a7 b7b3 f9e10 i1i3 h8b8 a1b1 f6d7 b3b8 d7b8 f1c4 b8d7 d6e8 d7e8 i4e8 i10i8 i3d3 d10c9 g2g10 i8e8 g10f10 e10f10 c4i10 f10e9 b1b10 c9b10 i10b10 e7c8 b10b9 e9f8 f4g5 a7f7 b9g9 f8g9 g5f7 g9f9 d3d9 e8e9 d9d8 f9e10 f7f8 e10f10 d8c8 e9e1 g1f2 e1e10 c8c9 e10e9 c9c10 e9e10 c10e10
f3f5 d8d6 i3i5 i8i6 d3d5 g8g6 e3e4 h10g8 h3h4 f8f7 g3g5 g6f5 e4f5 e8e6 i2i3 e6f5 h1g3 h9g7 g3f5 g7f5 c2f5 f7f6 i3e3 g9e7 f5g6 d9d8 g6c10 d10c10 g2i4 b10d9 c3c5 c8c7 h2g4 f9g7 g5f6 g8f6 g4f6 g7f6 e3f3 h8h6 i5h6 i9f9 c5d6 c7d6 b1c3 f6g8 f2h3 e9h6 b2c4 h6h9 c4d6 d8e9 c3e4 a8a6 g1f2 e7d6 e4d6 c9e7 a2c2 b9c7 d6e8 f10h8 c1b2 h8i7 e8c7 b8c7 f3g3 a9a8 i1g1 f9f10 c2c4 g10b5 a1c1 c10b10 g3g8 a8g8 g1g8 h9g8 c1c3 g8h9 f1h1 i6i5 h4i5 a10a8 i4h5 a8h8 h3i4 e7f6 d1c2 f6c3 b2c3 f10f2 e2f2 b5c4 b3c4 i10f10 f2h2 b10e7 e1d1 h8h5 i4h5 f10h10 d2b3 h9h5 h2h5 h10h5 h1h5 e7i3 c2h7 i7h7 h5h7 e10f10 h7f5 d9f8 d1c2 i3h2 c3d2 e9e8 f5a10 f10g9 i5i6 h2i3 a10a6 e8d6 d2b4 d6e8 a3a5 g9g8 b3c3 i3i5 c2b3 e8d7 c3d4 g8f9 d4c6 d7e8 a6b5 f9f10 b5b10 f8e10 b10c10 i5h5 i6i7 h5d1 b3b2 d1e2 b2a3 e2e4 a5a6 f10f9 c6c7 e8e9 c10b9 e4h7 c7c6 h7i7 c6e7 i7e7 b4e7 f9e8 a6a7 e9d7 a7a8 e8e7 a8a9q e10c9 a9b10 d7d8 b10h10 e7e8 b9b8 e8d9 h10g9 d8e9 b8c7 c9d7 c7d7 d9e10 g9h10 e9f10 d7d8 e10f9 h10f10
f3f5 i8i6 i3i5 d8d6 d3d5 f8f7 g3g4 h9f8 b2d3 h8h7 c1b2 e8e6 c3c4 g9h8 h1g3 f9e7 h3h4 a8a6 e3e4 c8c6 f2h3 c6d5 e4d5 g8g6 g1d4 h8d4 b2d4 h10g8 b1c3 b9c7 d4i9 i10i9 a3a5 g6f5 g4f5 c10b9 d3b2 g8f6 c3e4 c7e8 d2c3 e9c7 b3b5 a6b5 c3b5 c7d8 b5d4 a9a5 a2a5 a10a5 e2d2 b8b6 e4g5 c9a7 h2g4 e6e5 d4b3 a5a1 d1a1 b6b5 g2f3 d9c7 g4h6 b9a8 h6f7 d8b8 i2e2 b10c8 f7e5 d6e5 e2e5 e7d6 e5e2 i9d9 c2d3 b5c4 d3c4 g10h9 g5e4 f6e4 f3e4 a8d5 e4d5 h9d5 d2c2 f10h8 f1f4 c8b6 a1c1 d9c9 h3g4 c7d7 c4d5 c9c2 b3c2 b6d5 f4i7 h8h9 i1f1 d7e5 e2e5 d6e5 g4f3 e8f6 c2d2 f8g6 f5g6 e5g6 d2c4 h9e6 g3e4 g6i7 c1i7 d10e9 e1d1 f6e4 i7h7 e10d9 h7h6 e4c3 d1c1 e9h6 i5h6 a7e3 f3e3 c3a2 c1d2 d5e3 f1f9 d9e8 c4d3 e8f9 d3e3 b8h2 d2d3 h2b2 e3e4 b2b1 d3d4 b1e4 d4c5 e4b4
f3f5 d8d6 g3g4 e8e6 f5e6 e9e6 i3i5 i8i6 b3b4 e6e9 c3c5 f8f6 d2c4 d6c5 b4c5 b8b6 c5b6 a8a7 b6a7 b9a7 d3d4 h8h7 h1g3 g8g6 h3h4 c8c6 c2b3 h9g7 c4d3 h10g8 f2h3 g9e7 h2i4 f6f5 g4g5 c9b8 b2c4 g10h9 c4e5 c10b9 b1d2 f9e8 e5c6 a7c6 g2c6 e8d8 c6d5 f10h8 i2f2 f5f4 h3f4 b8f4 f2f4 i10f10 d5f7 d9c7 c1b2 b10c8 e3e5 g8i7 f7h9 f10f4 f1f4 i9h9 d4d5 h9f9 f4e3 h8g9 i4h6 b9a8 d5d6 c8d6 e5d6 e7d6 d2e4 a8e4 d3e4 g7f5 h6f5 g6f5 g3f5 d6i1 b2g7 g9g7 f5g7 e9g7 e4f6 g7e9 a2d2 i7h5 b3g8 h5f6 g5f6 d10b8 g8h7 e10d9 h7f9 e9f9 e2i6 f9i6 d1i6 i1d6 i6g6 d9d10 a1b1 b8c8 d2d6 c7d6 g6g10 c8e10 e3e10 d8e10 b1d1 a9d9 g10g7 e10e9 g1b6 d6e8 b6e9 e8e9 d1b1 d10e10 i5i6 e9f9 g7c7 a10d10 i6i7 d9d7 c7c8 e10f10 i7i8 d7i7 b1b9 f9d8 c8c5 d10e10 e1f2 i7i2 f2f1 i2i1 f1g2 e10e2 g2h3 d8b9 c5h10 f10f9 i8i9a i1h1 h3g3 h1g1 g3f3 g1g2 i9h8 f9e8 f6f7 e8d8 h8f10 d8c9 h10i9 c9c10 f10d9 c10d10 d9f8 d10c10 i9h10 c10c9 f8d7 c9d9 h10i9 d9d8 d7b9 d8e7 b9f5 e7d8 i9h8 d8d9 h8c8 d9d10 f5h6 e2e9 c8d8 d10c10 h6e9 c10b9 e9d7 b9c10 d8c9
f3f5 d8d6 g3g4 i8i6 b3b4 g8g6 d3d4 g6f5 g4f5 e8e6 f5e6 b9d8 c3c5 d6c5 b4c5 b8b6 c5b6 a8a7 b6a7 h8h6 b2c4 a9a7 i3i5 h6h5 h1g3 c8c6 h2f3 h10g8 f3e5 f9h8 e5d7 g10d7 e6d7 c10b9 h3h4 b9d7 g2h3 d7c8 b1c3 h9g7 e3e4 a7f7 g3f5 g8e7 d2f3 a10a7 c4e5 e7f5 e5f7 d8f7 e4f5 f7d6 f2g3 d9e8 a3a5 a7e7 g1e3 c9b8 i1g1 b10d9 a5a6 f8f6 a6a7 b8a7 c2d3 e9d8 e1f2 a7b8 i2g2 e8c9 e2c2 g9f8 d3a6 c8b9 a1b1 i9e9 e3f4 e7e8 a2b2 b9c8 a6c8 c9c8 g3i2 i10g10 g2g3 b8a7 f2g2 c6c5 g2h1 c5d4 c3b5 d6b5 b2b5 e10f9 c1d2 d9e7 d2a5 d8d7 f3e4 e7g8 e4d3 g8e7 c2a4 f9g9 b1c1 e7d5 b5d5 d7d5 h3g2 d5f7 c1c8 e8c8 g2c6 c8c6 a5e9 d10d5 d1f3 f10e9 a4c6 d5c6 f3c6 g10c10 c6b5 c10c5 b5b1 g9h9 g3g6 h8g8 d3d4 c5c1 f1c1 a7d4 g1g2 d4b6 c1c6 b6d8 f4h6 d8c7 h6g7 f8g7 g6i6 g8h8 i6g6 e9e5 i2h3 f7d5 c6d5 e5d5 b1b9 h9i8 g6g7 h8g7 b9c8 g7h8 c8c7 d5f5 h3f4 f5a10 c7c2 i8i9 c2c9 i9h10 g2d2 h8g10 d2d10 a10a1 h1h2 a1b2 h2g1 b2a3 c9c10 a3a7 g1h2 a7a2 f4g2 a2a9 g2g3 a9a2 h2i3 a2g8 d10g10 g8g10 c10g10 h10g10 g3f5 g10f9 f5e7 f9g9 i5i6 f6f5 i6i7 f5f4 e7f7 g9f9 i7i8 f9e10 i8i9h e10d10 f7e8 d10e10 e8e9
f3f5 i8i6 i3i5 h8h7 e3e5 g8g6 f5f6 d8d6 d3d4 h9i7 h3h4 d6e5 d4e5 h10g8 g3g5 i7h5 h2g4 h5f4 e2e3 f4g2 f2g2 e8e7 h1g3 b9c7 c2e4 d9d8 d2f3 f9h8 a3a5 b8b7 b2a4 b10d9 a2d2 g10d7 c1b2 e10f9 c3c4 e7f6 g5f6 c10b9 b1c3 d8e8 e4b1 f8f7 c3e4 a8a7 e4c5 c7e6 c5d7 c8d7 c4c5 c9d8 b3b4 f10h10 g3e4 b7b6 a5b6 a7b6 e4d6 e8c9 b1e4 b6c5 b4c5 d9c7 g2g3 d10d9 e3b3 c7e8 d6b7 a9a4 a1a4 a10a4 b7d8 c9d8 b3a4 e6c5 g1c5 g9c5 b2d4 h10f8 d4c5 f8c5 d2d5 c5c3 i2d2 i10a10 a4d4 c3c10 d4b2 b9c8 d2d4 e9f8 i1i2 f9g10 i2c2 c10d10 g4e3 d9e10 f1f2 i9b9 b2c1 g10h9 e3c4 d10b10 f2d2 e8c7 d5a5 a10a5 d2a5 c7e6 d4d6 b9b5 a5a2 e6c5 c2b2 b5b2 c1b2 c5e4 b2b10 e10b10 f3e4 c8b7 d6b6 b10e10 e4d4 h8g9 e1f2 d8c7 d1b3 f8a8 a2a8 c7a8 g3g4 b7d9 g4g5 a8c9 c4d6 e10c10 b3c4 g9f8 b6b2 g8e9 d4d5 c10a8 b2a2 a8b8 d5c7 b8b1 a2a9 c9b8 c7d9 b1b6 f2e2 b8d9 a9d9 f8d9 d6f7 b6c7 c4c7 d9c7 f7e9 c7d5 g5f3 d7d6 e9f7 d5c3 e2e3 c3c4 e3f4 d6d5 f7g5 d5d4 f3e4 d4d3 g5f3 h9g9 f4g5 c4a5 e4c5 a5a4 c5a4 d3d2h f3d2 h7h6 i5h6 i6i5 h4i5 g9h8 a4c5 h8h9 c5d7 h9g8 d7e9 g8h8 e9f8 h8i8 h6h7 i8i9 f6f7 i9h10 h7h8 h10i10 h8h9c
f3f5 h8h7 c3c5 c8c7 g3g4 i8i6 b1c3 b8b6 b3b4 g8g6 d3d5 f8f7 f2d3 e8e6 e3e4 h10g8 i3i5 b10c8 h2f3 h9g7 h1g3 b6c5 b4c5 g6f5 g4f5 d8d6 c5c6 g7h5 g3h5 i6h5 g1f2 c9f6 f3d4 g9h8 b2c4 i9i5 i2i5 i10i5 f2i5 e9i5 i1i5 d10i5 e2f2 f6h4 d2f3 h8f6 c1e3 b9d8 e1d2 h4f2 e3f2 i5i9 a1b1 a9b9 f2e3 f9g7 h3h4 c8e7 f3g3 b9b1 c2b1 a10b10 g2h3 g10e8 d2c1 c10b9 a2i2 i9h8 i2b2 e10f9 b1c2 b9c8 c1b1 g8h6 f1f3 e6d5 e4d5 b10b2 d3b2 f10b10 d1d2 h6g8 b1a2 f9g10 f3f2 d8f9 b2b3 g10h9 d2e1 a8a6 f2i2 d9d8 e3f4 g7i6 d4f3 h8i9 f3g5 i6g7 i2i9 g8i9 g5f3 e7g8 c4e3 d8d9 b3c4 g7i6 c3e4 f6h8 f3g5 i6i7 e4d6 c7d6 g5e4 i7i6 e4d6 g8f6 c2a4 f9d10 d6e8 d10e8 e1b1 i9g8 b1b10 d9b10 a4d1 h8g9 d5d6 b10d9 d6d7 f6d7 d1h5 i6g7 c6d7 c8d7 h5e2 d9c8 c4b3 c8b6 f4e5 f7f6 e5f4 h9h8 e3c4 b6a7 a2b2 g8h6 e2d3 h6f7 a3a5 a7c6 d3e4 c6e7 c4b6 d7b5 b6d5 e7d8 f4d2 e8c7 d5b6 g9d6 d2f4 d6e5 b2c2 f7d6 b3c5 e5f4 g3f4 d8e7 c2d1 d6e4 f4e4 g7h5 e4f3 e7c6 c5c6 b5c6 f3g4 c6e8 d1d2 h5g7 g4f4 e8f7 h3f1 g7f8 f1c4 h8g7 d2e1 f8e7 e1f2 e7d8 c4f7 d8f7 b6c4 c7e8 f2g3 h7h6 h4h5 f7g5 f4g6 g7g8 g6e7 g8h7 e7e8 g5h5 g3h2 h7i7 c4d6 h5g4 h2g1 g4f3 g1f1 f3e3 f1e1 e3f3 e1d1 f3e3 d1c1 e3d3 c1b1 d3c3 b1a1 c3d4 a1b2 d4d3 b2a1 h6h5 e8f6 h5h4 f6g8 i7i8 g8h6 i8i9 h6g8 i9i8 g8f8 d3c2 a1a2 h4h3 f8g7 i8i9 g7h7 i9h9 h7f8 h9i10 f8g9 i10i9 g9g8 i9i8 g8g7 i8i9 g7g8 i9i10 g8h8 i10h10 h8f9 h10i10 f9h8 i10h10 h8g8 h10i10 g8g9 i10i9 g9h7 i9h9 h7f8 h9i10 f8g9
#50
Settings for newer fairy stockfish versions
So far fairy stockfish has kept support for the "promotionRank" while the following only works for newer versions of fairy stockfish:
[9x10centaur-newFSFonly:chess]
doubleStepRank = 3
maxRank = 10
maxFile = 9
promotionRegionWhite = *9
promotionRegionBlack = *2
centaur = c
archbishop = a
chancellor = h
nMoveRule = 250
#51
Me vs fairy stockfish
Fairy stockfish is actually stronger than most humans even at depth set to 1 (lowest possible difficulty searth depth) and i probably tried over 10 times before finally beating it.
Later i challanged Fairy Stockfish again but at 1000 nodes per move, that's a lot harder but somehow i eventually prevailed.
d3d5 i8i7 b2c4 e8e6 d5e6 e9e6 f3f5 e6f6 h2g4 f6f7 e3e5 d8d7 d2e4 h8h6 e4d6 f7h7 g4f6 c9f6 e5f6 f10e9 f2g4 c8c7 d6d7 e9e2 f1e2 d9e9 d7e9 f9e9 c2e4 b10c8 a2d2 b9d8 h3h5 i7i6 h5i6 i9i6 g4h5 c10h5 e2h5 g8g6 f5g6 h7h8 h5i6 i10i6 d1i6 g10f9 i6h5 h8f6 h5h6 h9g7 g1d4 f6e6 g2h3 e6e4 d2e2 e4b7 e2e9 a9e9 c1e3 h10g8 h6g5 g9i7 g5g4 e10d9 i2e2 f9c6 c4a5 g8f6 d4f6 c6d7 g4d7 b7a6 d7d8 d9c10 d8c8 a6c8 h3c8 i7e3 c8a10 e3b6 a5c4 e9e2 e1e2 b6a7 b1d2 g7h5 f6h4 h5g7 a1f1 g7h5 e2d1 h5g7 h4i5 c10b10 i5g7 f8g7 a10f5 d10d9 i3i5 c7c6 i5i6 b8b7 i6i7 a7b8 i7i8 d9i9 f1e1 b8d10 e1e10 b10c9 e10f10 d10e9 f10f9 i9f9 i8i9h f9f5 i9e9 c9b8 i1i8 b8a7 e9c8 f5c8 i8c8 c6c5 c8c5 a7b8 c5e5 a8a6 e5e7 b7b6 e7g7 b6b5 c4d6 b8b9 g7f7 b9a8 g6g7 a8b8 g7g8 b5b4 g8g9h b4a3 g9g8 b8b9 f7f9 b9c10 g8g10
i3i4 f8f6 f3f5 g8g6 d3d4 g6f5 a3a4 e8e6 e2i6 d9e7 f1b5 f9g8 b5c5 h8h7 i6e2 e7d5 c5a5 b8b6 a5a6 d5c7 a6c4 h9g7 b3b5 d8d6 e3e4 f5e4 d2e4 d6d5 c4c7 b9c7 e4f4 g9d6 f4e3 e9f8 b2d3 i9e9 c3c5 b6c5 d3c5 d6c5 d4c5 f8c5 c1a3 c5b6 d1d4 b6d4 e3d4 e6e5 d4c6 e9e6 a3f8 d10f8 c6a5 d5d4 b1d2 c9a7 c2b3 d4d3 e2d3 a7f2 g1f2 e6d6 b3g8 h10g8 d3e2 a9e9 d2c4 d6e6 f2b6 b10d9 a1d1 f8f7 c4d6 e6d6 d1d6 g7f5 b6c7 f7c7 d6a6 d9b8 a2c2 b8a6 c2c7 a6c7 g2e4 f5d6 b5b6 d6e4 b6c7 e4d6 e2a2 f10f7 a2f7 d6f7 g3g4 e5e4 h1g3 e9e5 a5c4 g10a4 c4e3 f7g5 h3h4 g5f3 e1e2 a4b5 e2f2 f3h4 i2i3 b5c6 i1c1 c10e8 i3h3 h4g6 g3f5 a8a6 f5d4 g8e7 d4c6 e8c6 c1c4 a6a5 c4d4 a5a4 d4d2 a4a3 d2a2 c6d5 e3d5 e7d5 h3a3 a10a3 a2a3 e4e3 a3e3 d5e3 h2f3 e5e7 g4g5 f6g5 f3g5 i10f10 f2e2 e3d5 e2d1 d5c7 g5h7 i8h7 d1c1 f10f2 c1d1 e7e2 i4i5 g6i5 d1c1 e2e1
2000 nodes/move:
i3i4 f8f6 f3f5 g8g6 d3d4 g6f5 c3c5 e8e6 e2i6 d9e7 g3g4 h8h7 i6h5 c10h5 i4h5 f5g4 h3g4 f9g7 b1c3 d8d6 b3b4 d6c5 b4c5 c9d8 h1g3 d8a5 b2c4 a5c3 d2c3 c8c6 c4d6 b10c8 f1a6 b8b7 d6c8 e7c8 a6c4 b9c7 e3e5 f6e5 d4e5 d10d1 f2d1 a9d9 g1d4 c7b5 i1f1 g9f8 c1i7 h9i7 h5h6 g7h6 f1f8 f10f8 h2f3 b5c3 c4c3 h6g4 i2i7 g4g3 d1f2 g3f2 d4f2 i9g9 f2i5 f8i5 i7i5 e9i5 e1f1 i5g3 c2b3 c8e7 a2f2 a10d10 f1e2 i8i6 g2i4 d9d8 a1f1 h7h6 b3c2 g10i8 c2i8 i10i8 c3c2 h6h5 c2h7 h10f9 i4g2 e7g6 h7g6 g3g6 f1c1 i6i5 e2f1 i5i4 f3h4 g6h6 c1e1 i4i3 h4i2 h5h4 g2h3 g9g3 i2g3 h4g3 h3i2 g3f2a f1f2 h6h2 f2f3 h2i2 e1e2 i2e2 f3e2 i3i2q e2e3 i8i4 a3a4 i2h3 e3f2 d8d2 f2e1 i4i1
10000 nodes/move:
d3d5 i8i7 e3e5 c8c6 d5c6 b8b7 c6b7 c9a7 f2e4 a7g1 f1g1 a8b7 f3f5 d10a7 g1a7 a9a7 d2c4 h8h6 c1e3 a7a8 e4d6 f8f6 g2b7 g9d6 b7d9 b10d9 c4d6 e8e7 d6d7 e9d10 e5f6 h9f8 d7c5 d8d6 c5c4 a8c8 c4d5 b9c7 d5f4 f9e8 f6e7 d9e7 e3b6 f8d7 b6c7 f10c7 f4e6 c7a7 e6e7 e8e7 e2e7 i9e9 e7e9 d10e9 d1e2 c10h5 g3g4 e9e2 e1e2 d7f6 g4h5 g10c6 h2f3 f6h5 b2c4 e10f9 c4d6 c8d8 d6e4 c6e4 c2e4 a10e10 b1d2 a7b6 h1f2 h10i8 b3b4 i7i6 e2d1 h5g3 d1c2 g3e4 f2e4 b6e3 i1e1 e3f4 f5f6 f4f5 i2h2 i8g9 a3a5 f5d5 f3d4 d8c8 a2a3 d5d4 a5a6 d4e5 a6a7 e5h2 a7a8 h2a9 e4d6 c8d8 d6b7 d8d2 c2d2 a9h2 d2d1 e10d10 d1c1 h2d2 c1b1 d10d9 a8a9q d2e1 b1b2 e1d2 b2b3 i10c10 a9a4 f9f8 a4a8 f8f9 a8c10 d2d5 c10c4 d5b7 a3a7 b7b8 c4c6 b8e8 c6e8 g9e8 a7a9 d9a9 a1a9 f9f8 a9a8 f8f7 b4b5 e8c7 a8a7 f7f6 a7c7 f6e6 b5b6 e6d6 c3c5 d6d5 b6b7 i6i5 b7b8 i5i4 h3i4 h6h5 i4h5 d5e6 b8b9q e6f6 b9f9 f6g5 f9g8 g5h5 c7h7 h5i6 g8i8
i3i4 f8f6 f3f5 h9g7 d3d4 f9e7 e3e4 d8d6 c3c4 c8c6 b1c3 b8b6 h2g4 b9c7 h3h5 b10c8 h5h6 g7i6 g4e3 i6g5 a3a5 b6a5 i4i5 c6c5 d4d5 c7a6 a2a5 e9a5 a1a5 f10a5 e2h5 a6b4 g1i3 i8i6 h5g4 e7f7 g2i4 f7e5 g4e2 d9c7 i3g5 f6g5 e3g4 e5d4 f2e3 d4e2 d1e2 g9e7 f5f6 e7d8 f1f5 i9f9 c3b5 c7d7 e4e5 d6e5 g4e5 d7f6 f5c8 c10d9 c8c5 f6e5 d2c3 b4c2 e3c2 e5f3 e1d1 f3e2 i2e2 g10i8 b2d3 g8g7 b3b4 a5b6 c5b6 d8b6 c4c5 b6e9 i4e8 d9e8 e2e8 g7h6 c2e3 e10f10 i5h6 i8d3 c3d3 e9h6 b5d6 c9b8 d6c8 d10d9 e8e6 d9c8 e6h6 a9e9 h6e6 e9e6 d5e6 a10d10 d3d4 d10d4 e3d4 f9d9 i1i4 d9d4 i4d4 c8e6 c1g5 h10f9 g5f4 b8f4 g3f4 e6g4 d1c1 g4g1 d4d1 g1e3 c1c2 e3f4 d1b1 i6i5 c2b3 i5i4 h1i3 f4f3 b3a4 f3i3 b1b3 i3b3 a4b3 i4i3 b3a4 i3i2h a4b5 h8h6 b5b6 i2i7 c5c6 h6h5 c6c7 i7d7 b6c6 d7e5 c6b6 e5d5 b6a7 d5c7 a7b8 i10i7 b4b5 c7b5 b8a9 a8a6 a9a8 i7a7
#52
9x10archbishop tests
Decided to give this version some more testing before discarding it.
[9x10archbishop:chess]
doubleStepRank = 3
maxRank = 10
maxFile = 9
promotionRank = 9
centaur = c
archbishop = a
chancellor = h
nMoveRule = 200
startFen = rnbqkqbnr/rnbcacbnr/ppppppppp/9/9/9/9/PPPPPPPPP/RNBCACBNR/RNBQKQBNR w - - 0 1
100 million nodes/move:
f3f5 h8h7 i3i5 g8g6 g3g4 i8i6 h1g3 g6f5 g4f5 h10g8 d3d4 h9g7 h2g4 d8d7 f2h1 f8f6 c3c5 c8c6 a3a5 b10c8 b3b4 e8e6 b1c3 b9c7 d2b3 c8e7 e3e4 e6f5 e4f5 d9c8 c1f4 a8a7 c2e4 c10f7 b2c4 g7h5 g3h5 i6h5 g4e3 i9i5 i2i5 i10i5 i1i5 e9i5 h1g3 g10h9 b3b2 c7e8 d4d5 c6d5 c3d5 e7c6 d5c3 c8d8 h3h4 i5g7 e4c6 d7c6 b2c1 g9i7 f4i7 f10i7 a2d2 b8b6 g3h3 b6c5 d2d8 f9d8 b4c5 c9b8 c4d6 e8d6 c5d6 d8e8 c3e4 a9d9 c1c2 b8d6 e4d6 e8d6 d1c1 d6c5 e1f2 a10b10 g1h2 i7g9 f2g1 g8e7 g1h1 e7d5 c1a3 d5e3 a3e3 e10f9 e2f4 f7d5 f1f2 c5c4 e3e2 d5g2 f2g2 d9d7 h3i5 g9h8 i5h5 h9d5 h5i7 h8i7 f4i7 d10i10 h2f4 b10e10 e2g4 c4e5 g4g7 d7g7 i7h8 f9g8 h8i10 e10i10 f4e5 d5g2 h1h2 f6e5 c2e3 i10b10 e3c4 g2d5 c4e5 b10b3 e5f4 b3b4 f4h3 b4b2 h2i3 b2b3 f5f6 g7g6 i3h2 b3b2 h2i3 g6i6 h3i5 d5e6 f6f7 g8f7 i3i4 e6g4 h4h5 g4h5 i4h5 b2b5 h5g4 i6i5 g4f3 i5i3 f3g2 b5b2 g2h1 i3e3 h1g1 c6c5 a1f1 f7e6 f1f2 b2f2 g1f2 e3d3 f2e2 c5c4 a5a6 e6f7 e2f2 c4c3 f2e1 c3c2h e1f1 d3d1
Verdict: not as good as 9x10centaur.
